  3. Vera
  4. Decimals not appear at Vera UI
5 Posts 3 Posters 2.2k Views 2 Watching
  • rabeliyoR
    rabeliyoR
    rabeliyo
    Hello , I am modifying files multimeter to work well in UI7 , so far work well , but can not get me decimals appear in the interface vera ( in arduino if displayed) , only the first number , for example appears .
    Sketch
    gw.send ( msgVoltBat.set ( ( int ) VoltLevelBat , 2) , 1) ;
    sends 3.95 volts and appears vera UI 3.00
    I tried to change the type of variavle in S_Multimeter1 to i4 , UI4 , string , float without results.
    Use this skit to control the voltage of the battery and solar module and need to be accurate.
    Thank you very much
      @rabeliyo said:
      VoltLevelBat must be a float (or casted to a float) when calling set.
      • rabeliyoR
        rabeliyoR
        rabeliyo
        ok!! Like this?
        float VoltBatScale = analogRead(A2);
        float VoltLevelBat = VoltBatScale*4.12/376; //376 is the analog read at 4.12v (full charged battery)
        if (VoltLevelBat != lastVoltLevelBat) {
        gw.send(msgVoltBat.set((float)VoltLevelBat,2),1);
        lastVoltLevelBat = VoltLevelBat;
        • rabeliyoR rabeliyo
          ok!! Like this?
          BulldogLowellB
          BulldogLowellB
          BulldogLowell
          @rabeliyo
          yes, but you shouldn't need to cast a float to a float like you are doing here:
          also, because of the way floating point numbers work:
          may be a LOT more frequently than you may actually wish. Consider just updating the controller with a simple timer instead.
          • rabeliyoR
            rabeliyoR
            rabeliyo
            wrote on last edited by rabeliyo
            Works!!! Thanks a lot, i upload my remake of multimeter for UI7, all works but i only use the current and the voltage for my solar module, i will change the impedance to Kw/h
            Vera Files:
            http://www51.zippyshare.com/v/fk2Ay5ww/file.html
            Now i have a problem with the 3.3 PIR mod, i open a new post XD
