  3. Has anyone made a 2 or 4 channel relay , and is that worked correct ?
40 Posts 7 Posters 12.0k Views 5 Watching
  • mfalkviddM
    What does the serial debug output say?
    R 2 Replies Last reply
      R
      R
      Reza
      How do I check this?
      • R Reza
        See question 1 in http://forum.mysensors.org/topic/666/debug-faq-and-how-ask-for-help
        R 1 Reply Last reply
          R
          R
          Reza
          @mfalkvidd
          thank you
            R
            R
            Reza
            hi I build a 2channel relay but this is same problem ( just one relay is working
            it is serial manitor :
            send: 2-2-0-0 s=255,c=0,t=18,pt=0,l=3,sg=0,st=ok:1.5
            send: 2-2-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
            read: 0-0-2 s=255,c=3,t=6,pt=0,l=1,sg=0:M
            repeater started, id=2, parent=0, distance=1
            send: 2-2-0-0 s=255,c=3,t=11,pt=0,l=5,sg=0,st=ok:Relay
            send: 2-2-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:1.0
            send: 2-2-0-0 s=1,c=0,t=3,pt=0,l=0,sg=0,st=ok:
            send: 2-2-0-0 s=2,c=0,t=3,pt=0,l=0,sg=0,st=ok:
            • sundberg84S
              sundberg84S
              Hi @Reza
              The start logs looks ok. Does the relay/node log say anything when you send a command from your controller. Any info from your controller?
              Did you define your pins for the relay? A long shot but someone wrote it worked when they changed from 3,4,5,6 to 4,5,6,7 for some reason.
              In most cases though it seems to be a power problem. Try changin your power source and see what happens.
              What im most curous about at this point is to see the log from your relay when you send a on/off command for the two relays.
              • sundberg84S sundberg84
                Hi @Reza
                R
                R
                Reza
                @sundberg84 said:
                Hi @Reza
                now I have a 2channel relay , i want test for 2channel but this is similar to 4channel .
                in pics 2_1459249017068_photo_2016-03-29_15-23-20.jpg 1_1459249017064_photo_2016-03-29_15-23-10.jpg 0_1459249017027_123223454.jpg
                in1=pin3 , in2=pin4 . the pin 3 is not working , now in2 is working , but if i change pin3 and 4 in1 will working. also i change 2 line of program to and wiring in1=5 and in2=4 but now pin4 dont work ....
                #define RELAY_1 4 // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
                #define NUMBER_OF_RELAYS 2 // Total number of attached relays
                now
                AWIA 1 Reply Last reply
                • sundberg84S
                  sundberg84S
                  Looks great - but taking steps here i want to know what happens in the serial log on your node when you send a on/off command from your controller?
                  • R Reza
                    @sundberg84 said:
                    Hi @Reza
                    now
                    AWIA
                    AWIA
                    AWI
                    @Reza we are kind of guessing in the dark right now. Can you post your sketch (as code, use the </> format button)
                      R
                      R
                      Reza
                      read: 0-0-2 s=2,c=1,t=2,pt=0,l=1,sg=0:1
                      send: 2-2-0-0 s=2,c=1,t=2,pt=0,l=1,sg=0,st=ok:1
                      Incoming change for sensor:2, New status: 1
                      • AWIA AWI
                        R
                        R
                        Reza
                        #include <MySigningNone.h>
                        #include <MyTransportNRF24.h>
                        #include <MyTransportRFM69.h>
                        #include <MyHwATMega328.h>
                        MyTransportNRF24 radio(RF24_CE_PIN, RF24_CS_PIN, RF24_PA_LEVEL_GW);
                        //MyTransportRFM69 radio;
                        // Message signing driver (none default)
                        //MySigningNone signer;
                        // Select AtMega328 hardware profile
                        MyHwATMega328 hw;
                        MySensor gw(radio, hw);
                          gw.sendSketchInfo("Relay", "1.0");
                          // Fetch relay status
                            gw.present(sensor, S_LIGHT);
                            pinMode(pin, OUTPUT);
                            digitalWrite(pin, gw.loadState(sensor)?RELAY_ON:RELAY_OFF);
                          if (message.type==V_LIGHT) {
                             // Change relay state
                             // Store state in eeprom
                        • R
                          R
                          Reza
                          wrote on last edited by Reza
                          I change power supply and use a 5v 1A adaptor , but one relay is off always ( led off). and 2channel relay is not failure because when I change output pin 3 and 4 , that relay is on and work !!
                          • barduinoB
                            barduinoB
                            barduino
                            wrote on last edited by barduino
                            • R
                              R
                              Reza
                              :/ why delete your post ? :(
                              barduinoB 1 Reply Last reply
                              • sundberg84S
                                sundberg84S
                                @Reza - ok communication looks good. My vote will be on power.
                                I would try to power the relay separately and see what happens (not from Arduino).
                                  R
                                  R
                                  Reza
                                  i test this . with a adaptor 5v 1A but dont any happen !?
                                  • sundberg84S
                                    sundberg84S
                                    @Reza From your images you are not - do you have another adaptor for the relay?
                                      R
                                      R
                                      Reza
                                      I disconnect relay from arduino and connect to a adaptor 5v 1A
                                      • sundberg84S
                                        sundberg84S
                                        Strange... im out of ideas at this point. Hardware failure?
                                        Im not that good looking at the code, but I maybe someone else is.
                                          R
                                          R
                                          Reza
                                          :( thank you
                                          this is strange for me too . pin 3 dont working . but pin4 worked . also if i change cable of pin 3 and 4 other relay working and pin 3 dont work
                                          I change 2 line :
                                          #define RELAY_1 4
                                          but so pin 4 dont work and pin 5 working....
