  3. Has anyone made a 2 or 4 channel relay , and is that worked correct ?
40 Posts 7 Posters 12.0k Views 5 Watching
    What does the serial debug output say?
    R
    R
    Reza
    How do I check this?
    • R Reza
      See question 1 in http://forum.mysensors.org/topic/666/debug-faq-and-how-ask-for-help
      R 1 Reply Last reply
        R
        R
        Reza
        @mfalkvidd
        thank you
          R
          R
          Reza
          hi I build a 2channel relay but this is same problem ( just one relay is working
          it is serial manitor :
          send: 2-2-0-0 s=255,c=0,t=18,pt=0,l=3,sg=0,st=ok:1.5
          send: 2-2-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
          read: 0-0-2 s=255,c=3,t=6,pt=0,l=1,sg=0:M
          repeater started, id=2, parent=0, distance=1
          send: 2-2-0-0 s=255,c=3,t=11,pt=0,l=5,sg=0,st=ok:Relay
          send: 2-2-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:1.0
          send: 2-2-0-0 s=1,c=0,t=3,pt=0,l=0,sg=0,st=ok:
          send: 2-2-0-0 s=2,c=0,t=3,pt=0,l=0,sg=0,st=ok:
          • sundberg84S
            sundberg84S
            Hi @Reza
            The start logs looks ok. Does the relay/node log say anything when you send a command from your controller. Any info from your controller?
            Did you define your pins for the relay? A long shot but someone wrote it worked when they changed from 3,4,5,6 to 4,5,6,7 for some reason.
            In most cases though it seems to be a power problem. Try changin your power source and see what happens.
            What im most curous about at this point is to see the log from your relay when you send a on/off command for the two relays.
            • sundberg84S sundberg84
              Hi @Reza
              R
              R
              Reza
              @sundberg84 said:
              Hi @Reza
              now I have a 2channel relay , i want test for 2channel but this is similar to 4channel .
              in pics 2_1459249017068_photo_2016-03-29_15-23-20.jpg 1_1459249017064_photo_2016-03-29_15-23-10.jpg 0_1459249017027_123223454.jpg
              in1=pin3 , in2=pin4 . the pin 3 is not working , now in2 is working , but if i change pin3 and 4 in1 will working. also i change 2 line of program to and wiring in1=5 and in2=4 but now pin4 dont work ....
              #define RELAY_1 4 // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
              #define NUMBER_OF_RELAYS 2 // Total number of attached relays
              now
              AWIA 1 Reply Last reply
              • sundberg84S
                sundberg84S
                Looks great - but taking steps here i want to know what happens in the serial log on your node when you send a on/off command from your controller?
                • R Reza
                  @sundberg84 said:
                  Hi @Reza
                  now
                  AWIA
                  AWIA
                  AWI
                  @Reza we are kind of guessing in the dark right now. Can you post your sketch (as code, use the </> format button)
                    R
                    R
                    Reza
                    read: 0-0-2 s=2,c=1,t=2,pt=0,l=1,sg=0:1
                    send: 2-2-0-0 s=2,c=1,t=2,pt=0,l=1,sg=0,st=ok:1
                    Incoming change for sensor:2, New status: 1
                    • AWIA AWI
                      R
                      R
                      Reza
                      #include <MySigningNone.h>
                      #include <MyTransportNRF24.h>
                      #include <MyTransportRFM69.h>
                      #include <MyHwATMega328.h>
                      MyTransportNRF24 radio(RF24_CE_PIN, RF24_CS_PIN, RF24_PA_LEVEL_GW);
                      //MyTransportRFM69 radio;
                      // Message signing driver (none default)
                      //MySigningNone signer;
                      // Select AtMega328 hardware profile
                      MyHwATMega328 hw;
                      MySensor gw(radio, hw);
                        gw.sendSketchInfo("Relay", "1.0");
                        // Fetch relay status
                          gw.present(sensor, S_LIGHT);
                          pinMode(pin, OUTPUT);
                          digitalWrite(pin, gw.loadState(sensor)?RELAY_ON:RELAY_OFF);
                        if (message.type==V_LIGHT) {
                           // Change relay state
                           // Store state in eeprom
                      • R
                        R
                        Reza
                        wrote on last edited by Reza
                        I change power supply and use a 5v 1A adaptor , but one relay is off always ( led off). and 2channel relay is not failure because when I change output pin 3 and 4 , that relay is on and work !!
                        • barduinoB
                          barduinoB
                          barduino
                          wrote on last edited by barduino
                          • R
                            R
                            Reza
                            :/ why delete your post ? :(
                            barduinoB 1 Reply Last reply
                            • sundberg84S
                              sundberg84S
                              @Reza - ok communication looks good. My vote will be on power.
                              I would try to power the relay separately and see what happens (not from Arduino).
                                R
                                R
                                Reza
                                i test this . with a adaptor 5v 1A but dont any happen !?
                                • sundberg84S
                                  sundberg84S
                                  @Reza From your images you are not - do you have another adaptor for the relay?
                                    R
                                    R
                                    Reza
                                    I disconnect relay from arduino and connect to a adaptor 5v 1A
                                    • sundberg84S
                                      sundberg84S
                                      Strange... im out of ideas at this point. Hardware failure?
                                      Im not that good looking at the code, but I maybe someone else is.
                                        R
                                        R
                                        Reza
                                        :( thank you
                                        this is strange for me too . pin 3 dont working . but pin4 worked . also if i change cable of pin 3 and 4 other relay working and pin 3 dont work
                                        I change 2 line :
                                        #define RELAY_1 4
                                        but so pin 4 dont work and pin 5 working....
                                        • R Reza
                                          barduinoB
                                          barduinoB
                                          barduino
                                          @Reza,
                                          I'm a noob at electronics and arduinos and have a wild imagination :smiley:
                                          I had a theory but was unsure, so I decided to test it first rather than cause more confusion.
                                          I know this is a place of sharing, but more than once I caused more problems when trying to help.
                                          I don't want to bring some stupid idea into the fold.
                                          I'll report back.
