  3. Has anyone made a 2 or 4 channel relay , and is that worked correct ?
40 Posts 7 Posters 11.7k Views 5 Watching
  • R
    R
    Reza
    wrote on last edited by Reza
    hi
    I built a 4 channel relay . wiring similar to wiring in mysensors Directions . The difference : IN1=3 , IN2=4 , IN3=5 , IN4=6 . and I change just this line in code :
    to
    but after the programming just one relay is working !
    please help me , please give me correct code
    • mfalkviddM
      What does the serial debug output say?
      R 2 Replies Last reply
        R
        R
        Reza
        How do I check this?
        • R Reza
          See question 1 in http://forum.mysensors.org/topic/666/debug-faq-and-how-ask-for-help
          R 1 Reply Last reply
            R
            R
            Reza
            @mfalkvidd
            thank you
              R
              R
              Reza
              hi I build a 2channel relay but this is same problem ( just one relay is working
              it is serial manitor :
              send: 2-2-0-0 s=255,c=0,t=18,pt=0,l=3,sg=0,st=ok:1.5
              send: 2-2-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
              read: 0-0-2 s=255,c=3,t=6,pt=0,l=1,sg=0:M
              repeater started, id=2, parent=0, distance=1
              send: 2-2-0-0 s=255,c=3,t=11,pt=0,l=5,sg=0,st=ok:Relay
              send: 2-2-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:1.0
              send: 2-2-0-0 s=1,c=0,t=3,pt=0,l=0,sg=0,st=ok:
              send: 2-2-0-0 s=2,c=0,t=3,pt=0,l=0,sg=0,st=ok:
              • sundberg84S
                sundberg84S
                Hi @Reza
                The start logs looks ok. Does the relay/node log say anything when you send a command from your controller. Any info from your controller?
                Did you define your pins for the relay? A long shot but someone wrote it worked when they changed from 3,4,5,6 to 4,5,6,7 for some reason.
                In most cases though it seems to be a power problem. Try changin your power source and see what happens.
                What im most curous about at this point is to see the log from your relay when you send a on/off command for the two relays.
                • sundberg84S sundberg84
                  Hi @Reza
                  R
                  R
                  Reza
                  @sundberg84 said:
                  Hi @Reza
                  now I have a 2channel relay , i want test for 2channel but this is similar to 4channel .
                  in pics 2_1459249017068_photo_2016-03-29_15-23-20.jpg 1_1459249017064_photo_2016-03-29_15-23-10.jpg 0_1459249017027_123223454.jpg
                  in1=pin3 , in2=pin4 . the pin 3 is not working , now in2 is working , but if i change pin3 and 4 in1 will working. also i change 2 line of program to and wiring in1=5 and in2=4 but now pin4 dont work ....
                  #define RELAY_1 4 // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
                  #define NUMBER_OF_RELAYS 2 // Total number of attached relays
                  now
                  AWIA 1 Reply Last reply
                  • sundberg84S
                    sundberg84S
                    Looks great - but taking steps here i want to know what happens in the serial log on your node when you send a on/off command from your controller?
                    • R Reza
                      @sundberg84 said:
                      Hi @Reza
                      now
                      AWIA
                      AWIA
                      AWI
                      @Reza we are kind of guessing in the dark right now. Can you post your sketch (as code, use the </> format button)
                        R
                        R
                        Reza
                        read: 0-0-2 s=2,c=1,t=2,pt=0,l=1,sg=0:1
                        send: 2-2-0-0 s=2,c=1,t=2,pt=0,l=1,sg=0,st=ok:1
                        Incoming change for sensor:2, New status: 1
                        • AWIA AWI
                          R
                          R
                          Reza
                          #include <MySigningNone.h>
                          #include <MyTransportNRF24.h>
                          #include <MyTransportRFM69.h>
                          #include <MyHwATMega328.h>
                          MyTransportNRF24 radio(RF24_CE_PIN, RF24_CS_PIN, RF24_PA_LEVEL_GW);
                          //MyTransportRFM69 radio;
                          // Message signing driver (none default)
                          //MySigningNone signer;
                          // Select AtMega328 hardware profile
                          MyHwATMega328 hw;
                          MySensor gw(radio, hw);
                            gw.sendSketchInfo("Relay", "1.0");
                            // Fetch relay status
                              gw.present(sensor, S_LIGHT);
                              pinMode(pin, OUTPUT);
                              digitalWrite(pin, gw.loadState(sensor)?RELAY_ON:RELAY_OFF);
                            if (message.type==V_LIGHT) {
                               // Change relay state
                               // Store state in eeprom
                          • R
                            R
                            Reza
                            I change power supply and use a 5v 1A adaptor , but one relay is off always ( led off). and 2channel relay is not failure because when I change output pin 3 and 4 , that relay is on and work !!
                            • barduinoB
                              barduinoB
                              barduino
                              wrote on last edited by barduino
                              • R
                                R
                                Reza
                                :/ why delete your post ? :(
                                barduinoB 1 Reply Last reply
                                • sundberg84S
                                  sundberg84S
                                  @Reza - ok communication looks good. My vote will be on power.
                                  I would try to power the relay separately and see what happens (not from Arduino).
                                    R
                                    R
                                    Reza
                                    i test this . with a adaptor 5v 1A but dont any happen !?
                                    • sundberg84S
                                      sundberg84S
                                      @Reza From your images you are not - do you have another adaptor for the relay?
                                        R
                                        R
                                        Reza
                                        I disconnect relay from arduino and connect to a adaptor 5v 1A
                                        • sundberg84S
                                          sundberg84S
                                          Strange... im out of ideas at this point. Hardware failure?
                                          Im not that good looking at the code, but I maybe someone else is.
