  3. 💬 Bed Occupancy Sensor
mpr121capacitiveoccupancybedtouch
21 Posts 12 Posters 11.0k Views 7 Watching
  • O Offline
    O Offline
    openhardware.io
    wrote on last edited by hek
    https://www.mysensors.org/view/65/Bed-Occupancy-Sensor
    D 1 Reply Last reply
    • O Offline
      O Offline
      Oitzu
      Can i "mate" that with my fitness tracker? (pun intended) :stuck_out_tongue_closed_eyes:
      • O openhardware.io
        Dwalt
        @petewill
        I may have missed this in the video, but exactly where are the sensor tapes placed? Under the mattress or under the sheets?
        Great project! I have been experimenting with velostat to build binary sensors to accomplish something similar but it is still buggy.
        • A Offline
          A Offline
          aproxx
          Have you ever considered adding a weight/pressure sensor underneath the legs of your bed?
          Lets say if the weight of your bed would be 100kg, that the arduino is configured set to toggle at 110kg? :)
          • P Offline
            P Offline
            petewill
            @Oitzu As long as it's consensual ;)
            @Dwalt
            We have them placed under the sheets and mattress pad. When it is under the mattress pad nothing is disturbed when changing the sheets. I don't think it would work under the mattress unless it was really thin. I didn't do any testing on the max depth that it can sense but I would guess it's no more than 1".
            @aproxx
            Yes, I actually have all the components to build a weight sensor sitting on my desk. I had originally planned to use them instead of the mpr121. The reason I didn't pursue it very far is I have a really heavy bed, I would have had to develop some custom platform for it to sit on and it costs more. So, to sum it up the capacitive sensor is easier and cheaper so I went with that method instead.
            • R Offline
              R Offline
              RJ_Make
              I get away with a lot of stuff, but there is no way my wife would let me do this.. :-) Why did you turn off the YT comments?
              RJ_Make
              • R RJ_Make
                M Offline
                M Offline
                m26872
                After a second thought it's obvious that I'm in the same situation. Need to go for the more expensive weight sensor then I suppose.
                • P Offline
                  P Offline
                  petewill
                  I have my sensors under a mattress pad (which is below the sheets) so she never even sees the sensors even when the sheets are changed. You just need to do it when she is away. ;)
                  Strange, it says they are allowed. Are you not able to comment?
                  0_1459516299216_upload-842ffb97-5e2d-4628-85f1-1bc574e6bb17
                  R 1 Reply Last reply
                  • P petewill
                    R Offline
                    R Offline
                    RJ_Make
                    @petewill Seems to be working this morning.. :scream:
                    RJ_Make
                    • TmasterT Offline
                      TmasterT Offline
                      Tmaster
                      wrote on last edited by Tmaster
                      Realy cool project. Its very usefull ,but in my opinion,all this wires in a bed will cause problems in home:P how far it detect capacitance? if it was mounted on bed plataform would be acceptable (for wifes). OR use a load cell(20 to 100kgs maybe) on one of the foots of bed plataform
                      i'm a arduino fan .Even sometimes don't undestanding how to use it :P
                      P 1 Reply Last reply
                      • O Offline
                        O Offline
                        Oitzu
                        Oh i see its now on hackaday also. http://hackaday.com/2016/04/17/are-you-in-bed/ :clap:
                        • TmasterT Tmaster
                          P Offline
                          P Offline
                          petewill
                          @Tmaster Sorry, I must have missed your comment. I think it probably detects around .5 inches. Maybe a little more. We have it under a mattress pad so wires are hidden and undisturbed when changing the sheets. I'd be interested in hearing how the load cells go. I vaguely remember reading that they start to lose their ability to detect if they are under constant weight. I'm not sure if that was just for detecting minor changes though. It may still work to pick up a body. :)
                          @Oitzu Cool! Thanks for sharing.
                          • franzelareF Offline
                            franzelareF Offline
                            franzelare
                            if you run domoticz or an other home automation system, adding a time in bed script could be a next level
                            https://www.domoticz.com/forum/viewtopic.php?f=23&t=15502
                            • D Offline
                              diamantmatch
                              i have tried making the MPR talk to arduino, but i could not find the right library for your code.. what lib are you using? the adafruit one just spews out errors..
                              • D diamantmatch
                                P Offline
                                P Offline
                                petewill
                                @diamantmatch It's the BareConductive library https://github.com/BareConductive/mpr121 (see the comments in the code for more info)
                                • N Offline
                                  N Offline
                                  Nicolas M.
                                  @petewill
                                  Did you try to use the "virtual 13th pin" of the MPR121? It can be used to have the MPR121 automatically combine the values of (for example) the first four pins and was specifically designed to handle proximity detection instead of touch.
                                  I wonder if this could theoretically cut down on the necessary calculations.
                                  • N Nicolas M.
                                    @petewill
                                    P Offline
                                    P Offline
                                    petewill
                                    @Nicolas-M. I never tried it. I looked into it but didn't use it because I wanted to use the same device to monitor both sides of the bed. I have wondered this on occasion as well. It would be worth looking into if you decide to build one.
                                    • N Offline
                                      N Offline
                                      Nicolas M.
                                      @petewill Ah okay, understandable. I thought about the pros and cons of using two MPR121, since they are extremely cheap (1-2$?), but it would mean more cables, so it would only be worth it if it improves accuracy. I finished rebuilding your setup a few hours ago but didn't have time yet to test it much, maybe I'll build the "virtual 13th pin"-variant aswell if I find the time.
                                      • N Nicolas M.
                                        P Offline
                                        P Offline
                                        petewill
                                        @Nicolas-M. Yeah, they are definitely cheap. I can't remember why I wanted to do one. I guess because it was working and there was less to do.
                                        One thing I would change is I wouldn't use the copper tape any more. I have found that it gets damaged (cracked/separated) rather easily. I have actually switched to a stranded copper wire (18ga I think) that I have removed from the housing and spread out flat. I make sure it's overlapping itself in somewhat of crisscross pattern. That way if one of the wires breaks it still will make connection with other wires. Hopefully that makes sense.
                                        • I Offline
                                          I Offline
                                          Inso
                                          May I ask why you did not "just" install an PIR to detect presence in bed?
                                          12.1k
