  2. KiCad
  3. NRF24L01+ smd schematics
Scheduled Pinned Locked Moved KiCad
18 Posts 5 Posters 14.0k Views 4 Watching
  • L Offline
    L Offline
    LastSamurai
    Hi, does anyone have the smd kind of the nrf as a part for eagle/target3001/kicad? I saw some of you guys use it in some of your designs but couldn't find it myself.
    Perhaps we could also add it to the mysensors repo.
    G 1 Reply Last reply
    • L LastSamurai
      G Offline
      G Offline
      GertSanders
      @LastSamurai
      If you look on the forum you should find my eagle library with footprints for the smd version. Otherwise just export it from my very narrow node designs.
      L 1 Reply Last reply
      • G GertSanders
        @LastSamurai
        L Offline
        L Offline
        LastSamurai
        @GertSanders I tried to find the library here but I actually coudln't. Could you perhaps give me a hint where to find it? Thanks!
        • E Offline
          E Offline
          emc2
          @LastSamurai for KiCad it's already in the mysensors repo: https://github.com/mysensors-kicad/mysensors_radios.pretty/blob/master/NRF24L01-SMD.kicad_mod
          • L LastSamurai
            G Offline
            G Offline
            GertSanders
            @LastSamurai
            I have added my EAGLE library below:
            0_1459411902291_NRF24L01plus.lbr
            You can rename it because the forum adds the extra "0_1459411902291_" during upload.
            • L Offline
              L Offline
              LastSamurai
              Thank you for the help!
              • alexsh1A Offline
                alexsh1A Offline
                alexsh1
                @GertSanders you can change the status of your node as "tested". It works just fine - one important thing to remember is to solder the 3.3v solderpad. A couple of observations:
                1. I can no longer fit a single AAA battery holders, but a double one only (AA or AAA)
                2. the holes for J1 are two small and I had to drill them out.
                I have not tested ATSHA204A as I do not have all components yet.
                • alexsh1A alexsh1
                  G Offline
                  G Offline
                  GertSanders
                  @alexsh1
                  So you received the boards before I did :-)
                  I'm still waiting on them. They are "in the mail" or at least in the hands of my local mail service (any day now...).
                  Which type of header/connector did you use to mount in the J1 location ? If the holes are too narrow for the breakable two row male headers, I will adapt this (that is why it is still UNTESTED for me).
                  Indeed, one or two single AAA holders are not possible on this board. I found that the double battery holders actually are cheaper, and it allows avoiding two extra holes where the radio now sits.
                  Update: I checked the drill size of the part used in v3 to place the header, indeed this is 0,8mm (31 mil) instead of 1,016mm (40 mil).
                  In my v4 version I already switched to a wider header, and this one does have 40 mil drill diameter. It's good I did not do a panel with the v3 version.
                  alexsh1A 1 Reply Last reply
                  • G GertSanders
                    @alexsh1
                    alexsh1A Offline
                    alexsh1A Offline
                    alexsh1
                    @GertSanders
                    Yes, I have got the boards in 3-4 days. Very quick
                    I have used a single row header like this
                    http://www.protostack.com/connectors/headers/40-pin-2.54mm-snappable-single-row-header
                    • alexsh1A alexsh1
                      @GertSanders
                      G Offline
                      G Offline
                      GertSanders
                      @alexsh1
                      Ordered from OSHPark ?
                      • G GertSanders
                        @alexsh1
                        alexsh1A Offline
                        alexsh1A Offline
                        alexsh1
                        @GertSanders said:
                        @alexsh1
                        Yes - these guys are good
                        • E Offline
                          E Offline
                          emc2
                          Did anyone successfully used kicad footprint for these guys?
                          I received today my first PCB designed for the SMD version, did not work and overheated quite badly. After trying to troubleshoot it, frying a few things on the way, it seems to me that VCC / GND pad are switched between schematics and footprint:
                          "Datasheet" from one of many aliexpress / ebay seller (all seems to be the same)
                          KiCad PCB view
                          I changed it on a local lib to reorder a new PCB and try, but if others can have a look at it, especially @tbowmo to update the official github repo if needed.
                          • E emc2
                            KiCad PCB view
                            alexsh1A Offline
                            alexsh1A Offline
                            alexsh1
                            @emc2 You have to be careful with these. As I discovered myself recently there are ones with PIN1 and PIN2 as VCC and GND and others with PIN1 and PIN8 as VCC and GND.
                            This is not well documented!
                            E 1 Reply Last reply
                            • alexsh1A alexsh1
                              E Offline
                              E Offline
                              emc2
                              @alexsh1 Damnit...
                              Never encountered a PIN1/PIN8 module yet. Are those with blob? I saw a few modules with black blob, often a big cristal and very cheap but I never ordered them.
                              I have a few of this exact module, it has a datasheet on the website and wiring it as described work on a breadboard.
                              Did you encounter any PIN1 - GND, PIN2 - VCC so far?
                              Problem may be somewhere else, probability that I screwed up my PCB design is high. I will see with the next PCB, with pin switched, if it's working.
                              • E emc2
                                @alexsh1 Damnit...
                                alexsh1A Offline
                                alexsh1A Offline
                                alexsh1
                                @emc2 Yes, all of my nrf24l01+ smd modules have PIN1 - VCC and PIN2 - GND
                                No idea why chinese are switching pins
                                • T Offline
                                  T Offline
                                  tbowmo
                                  @emc2
                                  Sorry about that, it was made in a jiffy one dark night, and I never got around to verify the footprint myself :(
                                  I'll update the footprint later today (or you can make a PR on github and change it your self).
                                  • T tbowmo
                                    @emc2
                                    E Offline
                                    E Offline
                                    emc2
                                    @tbowmo
                                    Hey no worries, it's still a great ressource and so far I used it without any problem.
                                    I'm always confused by github when it came to PR etc but it should work. I just switched the coordinates of pad 1 and 2 it should do the trick.
                                    • T Offline
                                      T Offline
                                      tbowmo
                                      @emc2
                                      I updated the footprint on github (and yes, I also chose the easy route, and swapped pins 1 and 2 on the footprint) :)
