  3. Vera
  4. Ethernet Gateway without NRF24L01+
22 Posts 5 Posters 8.7k Views 5 Watching
  • M mlg
    @hek
    Tks , I changed the code
      // Read digital motion value
        if (lastTripped != tripped ) {
          send(msg.set(tripped?"1":"0")); // Send new state and request ack back
          Serial.println(tripped);
          lastTripped=tripped;
      //sleep(INTERRUPT,CHANGE, SLEEP_TIME);
    but vera continues with the same status :(
    some additional info
    mlg
    @hek
    Ok , the message "cant decect device" has disappeared, however not appear the motion sensor, how can I make inclusion?
    • M mlg
      @hek
      mlg
      Connected but motion sensor not appear, someone help?
      <a class=@mlg " class="img-markdown img-fluid" />
        Did you turn on inclusion mode on Vera and restart sensor a few times?
          mlg
          wrote on last edited by mlg
          @hek
          Yes but Start the button does not work :(
          I press but the state does not change, the start it is always green.
          • M mlg
            @hek
            mlg
            Any idea?
            Already I realized the factory reset Vera , erase the eeprom arduino and inclusion using the Pin 4, but no effect :(
            the code that currently have the Arduino
            #define MY_GATEWAY_W5100
            //#define MY_W5100_SPI_EN 4
            // radio on the same spi bus.
            //#if !defined(MY_W5100_SPI_EN) && !defined(ARDUINO_ARCH_SAMD)
              //#define MY_SOFTSPI
              //#define MY_SOFT_SPI_SCK_PIN 14
              //#define MY_SOFT_SPI_MISO_PIN 16
              //#define MY_SOFT_SPI_MOSI_PIN 15
            //#endif
            //#define MY_RF24_CE_PIN 5
            //#define MY_RF24_CS_PIN 6
            #define MY_IP_ADDRESS 192,168,1,169   // If this is disabled, DHCP is used to retrieve address
            #define MY_PORT 5003
            // Flash leds on rx/tx/err
            // Set blinking period
            // Enable inclusion mode
             #define MY_INCLUSION_MODE_BUTTON_PIN  4
            #include <Ethernet.h>
            boolean lastTripped = 0;
            // Initialize motion message
              present(CHILD_ID, S_MOTION);
              Strange...you are using the UI7 branch of the Vera plugin right?
              You could try commenting these two lines away:
              //  #define MY_INCLUSION_BUTTON_FEATURE
              //  #define MY_INCLUSION_MODE_BUTTON_PIN  4
              In case a floating pin causing troubles.
                mlg
                @hek
                Yes UI7 branch, I already commented these two lines and check the cables, when I press start button the rx and tx lights flashing
                • M mlg
                  @hek
                  mlg
                  for restart sensor a few times, simply disconnect the gnd cable or all cables?
                  • einarthE
                    einarthE
                    einarth
                    Isn't digital pin 4 used by the Ethernet shield?
                    Probably not the cause of your problems but just noticed when looking over your code..
                    • einarthE einarth
                      mlg
                      @einarth
                      I already commented this line in the code , my final code
                      //#endif
                      @hek
                      After other factory reset , start button now work !! but the inclusion no ! I press start and after 1 minute change automatically to stop.
                      • M mlg
                        @einarth
                        //#endif
                        @hek
                        mlg
                        Any Ideia?
                          Inclusion mode is supposed to stop after 1 minute. So it sounds like communication between controller and gateway is fine.
                          Did you reset the sensor node during inclusion mode was activated?
                          Have you looked in the gateway debug log (while gateway is connected to your computer)?
                          M 2 Replies Last reply
                            mlg
                            @hek
                            How I make sensor node reset ? Disconnected all cables ? digital pin 3 + gnd + 5v ?
                            If I disconect all cables I log that
                            0;255;3;0;9;Starting gateway (R-NGA-, 2.0.0-beta)
                            IP: 192.168.1.169
                            0;255;3;0;9;Eth: connect
                            0;255;3;0;9;Eth: 0;0;3;0;5;1
                            0;255;3;0;9;Eth:
                            • M mlg
                              @hek
                              IP: 192.168.1.169
                              0;255;3;0;9;Eth:
                              mlg
                              @hek
                              It's normal? If I disconnect the cables get 1/0/1/0 and not stopped
                                mlg
                                #21
                                @hek
                                I found one solution,I turn on sensor in ethernet gateway and press start inclusion and reload engine in Vera .In this way automatically add the sensor
                                However compiled another code by adding a relay but is not added is something wrong?
                                it is necessary void before, presentation ? and assign a child ID to RELAY ?
                                 * Version 1.0 - Henrik EKblad
                                 * LED purposes:
                                // #define MY_LEDS_BLINKING_FEATURE
                                // #define MY_DEFAULT_LED_BLINK_PERIOD 300
                                #define RELAY_1  2  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
                                    sendSketchInfo("Motion Relay", "1.0");
                                    present(sensor, S_LIGHT);
                                    pinMode(pin, OUTPUT);
                                  if (message.type==V_LIGHT) {
                                     // Change relay state
                                     // Store state in eeprom
                                • stofakillerS
                                  stofakillerS
                                  stofakiller
                                  I did'nt have much succes with the radiodevice, and i have made the gateway :-)
                                  But have i missed the code eg for the sensors???
                                  Regards,
                                  Jan
                                  12.5k
