  3. Home Assistant
  4. Any plan to implement Ethernet GW?
69 Posts 5 Posters 26.4k Views 6 Watching
  • Dave DanD Dave Dan
    hey @martinhjelmare,
    would it be possible to have an updated compilation with the 0.16 versión? I think the one you have above is 0.15 still (or older, right?)
    I'd like to do more testing and integrate other items (for example the new Vera integration) with MySensors actuations, etc.
    thanks in advance.
    martinhjelmareM
    martinhjelmareM
    martinhjelmare
    @Dave-Dan
    I'd like to investigate the issue you reported before I push any new commits or rebase off dev. Sorry to keep you waiting.
    • Dave DanD
      Dave DanD
      Dave Dan
      ahh, ok, makes sense.
      no problem at all! :)
      • D
        drock1985
        @Dave-Dan
        out of curiosity, did you try a different name for the persistence file after deleting your first one, or did you use the same name?
        My Projects
        2 Door Chime Sensor
        Washing Machine Monitor
        • Dave DanD
          Dave DanD
          Dave Dan
          hey @drock1985,
          No I didn't test that before, but I just did with the same results :(
          I can see in the log how messages are arriving to HA (see below). It's just I can't see them either in the group I created for them or in the Developer Tools.
          16-03-31 09:42:37 DEBUG (Thread-20) [mysensors.mysensors] Received 101;1;1;0;0;20.0
          16-03-31 09:42:37 DEBUG (Thread-20) [mysensors.mysensors] Received 101;0;1;0;1;36.0
          16-03-31 09:42:37 DEBUG (Thread-20) [mysensors.mysensors] Received 101;3;1;0;16;0
          If I go back and restore the previous file I can see them on both the group and the Developer Tools section.
          @martinhjelmare, hope this helps as well ... is is there any specific test you want me to perform please let me know.
            @Dave-Dan
            Did you do it like this?
            1. Stop hass.
            2. Remove old persistence file.
            3. Create new persistence file with the same name and path, containing an empty JSON object, "{}".
            4. Start hass.
            5. Start node. Result: Messages are coming in to gateway, but node sensors are not added to entities nor shown in GUI.
            martinhjelmareM
            martinhjelmareM
            martinhjelmare
            @Dave-Dan
            I finally had some time to test this again. Sorry for the long delay.
            I followed the steps here:
            @martinhjelmare said:
            @Dave-Dan
            1. Stop hass.
            4. Start hass.
            but I'm not able to reproduce your experienced problem. On my end, the node and sensor are added ok. Do you have any more clues what might be different on your end?
            HA config:
            mysensors:
              gateways:
                - device: '192.168.1.18'
                  persistence_file: '/home/martin/.homeassistant/mysensors3.json'
                  tcp_port: 5003
              debug: true
              persistence: true
              version: '1.5'
              optimistic: false
            console log:
            configuration.yaml  home-assistant.db  home-assistant.log  known_devices.yaml  lib  mysensors3.json
            martin@martin-nuc:~/.homeassistant$ cat mysensors3.json
            {"1": {"children": {"1": {"values": {"40": "ffffff", "2": "0", "3": "0"}, "id": 1, "type": 26}}, "sketch_version": "1.1", "sketch_name": "DimmableLED", "battery_level": 0, "sensor_id": 1, "type": 17}}
            martin@martin-nuc:~/.homeassistant$ rm mysensors3.json
            martin@martin-nuc:~/.homeassistant$ ls
            martin@martin-nuc:~/.homeassistant$ atom .
            {"1": {"battery_level": 0, "sensor_id": 1, "sketch_name": "DimmableLED", "children": {"1": {"values": {"40": "ffffff", "2": "0", "3": "0"}, "id": 1, "type": 26}}, "sketch_version": "1.1", "type": 17}}
            sensor serial log:
            send: 1-1-0-0 s=255,c=3,t=15,pt=2,l=2,sg=0,st=ok:0
            send: 1-1-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,st=ok:1.5.1
            send: 1-1-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
            read: 0-0-1 s=255,c=3,t=15,pt=2,l=2,sg=0:0
            read: 0-0-1 s=255,c=3,t=6,pt=0,l=1,sg=0:M
            sensor started, id=1, parent=0, distance=1
            send: 1-1-0-0 s=1,c=0,t=26,pt=0,l=0,sg=0,st=ok:
            send: 1-1-0-0 s=255,c=3,t=11,pt=0,l=11,sg=0,st=ok:DimmableLED
            send: 1-1-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:1.1
            send: 1-1-0-0 s=1,c=2,t=3,pt=0,l=0,sg=0,st=ok:
            send: 1-1-0-0 s=1,c=1,t=2,pt=2,l=2,sg=0,st=ok:0
            send: 1-1-0-0 s=1,c=1,t=3,pt=2,l=2,sg=0,st=ok:0
            send: 1-1-0-0 s=1,c=1,t=40,pt=0,l=6,sg=0,st=ok:ffffff
            read: 0-0-1 s=1,c=1,t=2,pt=0,l=1,sg=0:1
            Changing level to 100, from 0
            send: 1-1-0-0 s=1,c=1,t=2,pt=2,l=2,sg=0,st=ok:1
            send: 1-1-0-0 s=1,c=1,t=3,pt=2,l=2,sg=0,st=ok:100
            read: 0-0-1 s=1,c=1,t=2,pt=0,l=1,sg=0:0
            Changing level to 0, from 100
            hass log:
            16-04-10 14:23:01 INFO (Thread-8) [mysensors.mysensors] Trying to connect to ('192.168.1.18', 5003)
            16-04-10 14:23:01 INFO (Thread-21) [homeassistant.core] Timer:starting
            16-04-10 14:23:01 INFO (Thread-8) [mysensors.mysensors] Connected to ('192.168.1.18', 5003)
            16-04-10 14:23:03 INFO (Thread-23) [homeassistant.components.http] "GET /api/stream?api_password=no_password_set&restrict=state_changed,component_loaded,service_registered HTTP/1.1" 200 -
            16-04-10 14:23:03 INFO (Thread-24) [homeassistant.components.http] "GET /api/bootstrap HTTP/1.1" 200 -
            16-04-10 14:23:30 INFO (Thread-3) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sun.sun, old_state=<state sun.sun=above_horizon; next_rising=03:40:47 11-04-2016, icon=mdi:air-conditioner, elevation=35.69, next_setting=17:52:06 10-04-2016, friendly_name=Customized Sun @ 14:23:01 10-04-2016>, new_state=<state sun.sun=above_horizon; next_rising=03:40:47 11-04-2016, icon=mdi:air-conditioner, elevation=35.66, next_setting=17:52:06 10-04-2016, friendly_name=Customized Sun @ 14:23:01 10-04-2016>>
            16-04-10 14:24:30 INFO (Thread-2) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sun.sun, old_state=<state sun.sun=above_horizon; next_rising=03:40:47 11-04-2016, icon=mdi:air-conditioner, elevation=35.66, next_setting=17:52:06 10-04-2016, friendly_name=Customized Sun @ 14:23:01 10-04-2016>, new_state=<state sun.sun=above_horizon; next_rising=03:40:47 11-04-2016, icon=mdi:air-conditioner, elevation=35.6, next_setting=17:52:06 10-04-2016, friendly_name=Customized Sun @ 14:23:01 10-04-2016>>
            16-04-10 14:25:30 INFO (Thread-16) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sun.sun, old_state=<state sun.sun=above_horizon; next_rising=03:40:47 11-04-2016, icon=mdi:air-conditioner, elevation=35.6, next_setting=17:52:06 10-04-2016, friendly_name=Customized Sun @ 14:23:01 10-04-2016>, new_state=<state sun.sun=above_horizon; next_rising=03:40:47 11-04-2016, icon=mdi:air-conditioner, elevation=35.54, next_setting=17:52:06 10-04-2016, friendly_name=Customized Sun @ 14:23:01 10-04-2016>>
            16-04-10 14:25:41 INFO (Thread-25) [homeassistant.components.http] "GET /static/frontend-833d09737fec24f9219efae87c5bfd2a.html HTTP/1.1" 200 -
            16-04-10 14:25:42 INFO (Thread-26) [homeassistant.components.http] "GET /static/favicon.ico HTTP/1.1" 200 -
            16-04-10 14:25:42 INFO (Thread-27) [homeassistant.components.http] "GET /api/bootstrap HTTP/1.1" 200 -
            16-04-10 14:25:42 INFO (Thread-28) [homeassistant.components.http] "GET /api/stream?api_password=no_password_set&restrict=state_changed,component_loaded,service_registered HTTP/1.1" 200 -
            16-04-10 14:25:53 INFO (Thread-8) [homeassistant.components.mysensors] No sketch_name: node 1
            16-04-10 14:25:55 INFO (Thread-8) [homeassistant.components.mysensors] No sketch_name: node 1
            16-04-10 14:25:59 INFO (Thread-8) [homeassistant.components.mysensors] Adding new devices: <Entity DimmableLED 1.1: off>
            16-04-10 14:25:59 INFO (Thread-8) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=light.dimmableled_11, old_state=None, new_state=<state light.dimmableled_11=unavailable; friendly_name=DimmableLED 1.1 @ 14:25:59 10-04-2016>>
            16-04-10 14:25:59 INFO (Thread-8) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=group.all_lights, old_state=None, new_state=<state group.all_lights=unknown; hidden=True, entity_id=[], auto=True, order=1, friendly_name=all lights @ 14:25:59 10-04-2016>>
            16-04-10 14:25:59 INFO (Thread-8) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=group.all_lights, old_state=<state group.all_lights=unknown; hidden=True, entity_id=[], auto=True, order=1, friendly_name=all lights @ 14:25:59 10-04-2016>, new_state=None>
            16-04-10 14:25:59 INFO (Thread-8) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=group.all_lights, old_state=None, new_state=<state group.all_lights=unknown; hidden=True, entity_id=('light.dimmableled_11',), auto=True, order=1, friendly_name=all lights @ 14:25:59 10-04-2016>>
            16-04-10 14:25:59 INFO (Thread-8) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=light.dimmableled_11, old_state=<state light.dimmableled_11=unavailable; friendly_name=DimmableLED 1.1 @ 14:25:59 10-04-2016>, new_state=<state light.dimmableled_11=off; V_STATUS=off, node_id=1, V_RGB=ffffff, V_PERCENTAGE=0, battery_level=0, device=192.168.1.18:5003, friendly_name=DimmableLED 1.1, child_id=1 @ 14:25:59 10-04-2016>>
            16-04-10 14:25:59 INFO (Thread-17) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=group.all_lights, old_state=<state group.all_lights=unknown; hidden=True, entity_id=('light.dimmableled_11',), auto=True, order=1, friendly_name=all lights @ 14:25:59 10-04-2016>, new_state=<state group.all_lights=off; hidden=True, entity_id=('light.dimmableled_11',), auto=True, order=1, friendly_name=all lights @ 14:25:59 10-04-2016>>
            16-04-10 14:25:59 INFO (Thread-23) [homeassistant.components.api] Found broken event stream to 127.0.0.1, cleaning up
            16-04-10 14:26:19 INFO (Thread-29) [homeassistant.core] Bus:Handling <Event call_service[L]: service=turn_on, domain=homeassistant, service_data=entity_id=light.dimmableled_11, service_call_id=140012061724232-1>
            16-04-10 14:26:19 INFO (Thread-15) [homeassistant.core] Bus:Handling <Event call_service[L]: service=turn_on, domain=light, service_data=entity_id=['light.dimmableled_11'], service_call_id=140012061724232-2>
            16-04-10 14:26:19 INFO (Thread-9) [homeassistant.core] Bus:Handling <Event service_executed[L]: service_call_id=140012061724232-2>
            16-04-10 14:26:19 INFO (Thread-15) [homeassistant.core] Bus:Handling <Event service_executed[L]: service_call_id=140012061724232-1>
            16-04-10 14:26:19 INFO (Thread-29) [homeassistant.components.http] "POST /api/services/homeassistant/turn_on HTTP/1.1" 200 -
            16-04-10 14:26:21 INFO (Thread-8) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=light.dimmableled_11, old_state=<state light.dimmableled_11=off; V_STATUS=off, node_id=1, V_RGB=ffffff, V_PERCENTAGE=0, battery_level=0, device=192.168.1.18:5003, friendly_name=DimmableLED 1.1, child_id=1 @ 14:25:59 10-04-2016>, new_state=<state light.dimmableled_11=off; V_STATUS=on, node_id=1, V_RGB=ffffff, V_PERCENTAGE=0, battery_level=0, device=192.168.1.18:5003, friendly_name=DimmableLED 1.1, child_id=1 @ 14:25:59 10-04-2016>>
            16-04-10 14:26:22 INFO (Thread-8) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=light.dimmableled_11, old_state=<state light.dimmableled_11=off; V_STATUS=on, node_id=1, V_RGB=ffffff, V_PERCENTAGE=0, battery_level=0, device=192.168.1.18:5003, friendly_name=DimmableLED 1.1, child_id=1 @ 14:25:59 10-04-2016>, new_state=<state light.dimmableled_11=on; V_RGB=ffffff, V_PERCENTAGE=100, battery_level=0, rgb_color=[255, 255, 255], child_id=1, V_STATUS=on, brightness=255, device=192.168.1.18:5003, friendly_name=DimmableLED 1.1, node_id=1 @ 14:26:22 10-04-2016>>
            16-04-10 14:26:22 INFO (Thread-7) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=group.all_lights, old_state=<state group.all_lights=off; hidden=True, entity_id=('light.dimmableled_11',), auto=True, order=1, friendly_name=all lights @ 14:25:59 10-04-2016>, new_state=<state group.all_lights=on; hidden=True, entity_id=('light.dimmableled_11',), auto=True, order=1, friendly_name=all lights @ 14:26:22 10-04-2016>>
            16-04-10 14:26:26 INFO (Thread-30) [homeassistant.core] Bus:Handling <Event call_service[L]: service=turn_off, domain=homeassistant, service_data=entity_id=light.dimmableled_11, service_call_id=140012061724232-3>
            16-04-10 14:26:26 INFO (Thread-6) [homeassistant.core] Bus:Handling <Event call_service[L]: service=turn_off, domain=light, service_data=entity_id=['light.dimmableled_11'], service_call_id=140012061724232-4>
            16-04-10 14:26:26 INFO (Thread-13) [homeassistant.core] Bus:Handling <Event service_executed[L]: service_call_id=140012061724232-4>
            16-04-10 14:26:26 INFO (Thread-6) [homeassistant.core] Bus:Handling <Event service_executed[L]: service_call_id=140012061724232-3>
            16-04-10 14:26:26 INFO (Thread-30) [homeassistant.components.http] "POST /api/services/homeassistant/turn_off HTTP/1.1" 200 -
            16-04-10 14:26:27 INFO (Thread-8) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=light.dimmableled_11, old_state=<state light.dimmableled_11=on; V_RGB=ffffff, V_PERCENTAGE=100, battery_level=0, rgb_color=[255, 255, 255], child_id=1, V_STATUS=on, brightness=255, device=192.168.1.18:5003, friendly_name=DimmableLED 1.1, node_id=1 @ 14:26:22 10-04-2016>, new_state=<state light.dimmableled_11=off; V_STATUS=off, node_id=1, V_RGB=ffffff, V_PERCENTAGE=100, battery_level=0, device=192.168.1.18:5003, friendly_name=DimmableLED 1.1, child_id=1 @ 14:26:27 10-04-2016>>
            16-04-10 14:26:27 INFO (Thread-18) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=group.all_lights, old_state=<state group.all_lights=on; hidden=True, entity_id=('light.dimmableled_11',), auto=True, order=1, friendly_name=all lights @ 14:26:22 10-04-2016>, new_state=<state group.all_lights=off; hidden=True, entity_id=('light.dimmableled_11',), auto=True, order=1, friendly_name=all lights @ 14:26:27 10-04-2016>>
            16-04-10 14:26:28 INFO (Thread-8) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=light.dimmableled_11, old_state=<state light.dimmableled_11=off; V_STATUS=off, node_id=1, V_RGB=ffffff, V_PERCENTAGE=100, battery_level=0, device=192.168.1.18:5003, friendly_name=DimmableLED 1.1, child_id=1 @ 14:26:27 10-04-2016>, new_state=<state light.dimmableled_11=off; V_STATUS=off, node_id=1, V_RGB=ffffff, V_PERCENTAGE=0, battery_level=0, device=192.168.1.18:5003, friendly_name=DimmableLED 1.1, child_id=1 @ 14:26:27 10-04-2016>>
            • Dave DanD
              Dave DanD
              Dave Dan
              hey Martin.
              Sorry, I've been traveling for a while.
              So I just rebuilt my environment and I can't repro the issue anymore.
              If you can't either and no one else is experiencing this I think we can close this down. My environment might be the only thing that is creating the issue.
              If the issue happen again I can update with the new information.
                hey Martin.
                martinhjelmareM
                martinhjelmareM
                martinhjelmare
                @Dave-Dan
                Great! Then I'll move forward and push my latest changes to my github branch. I'll post here when that is done. You're welcome to test these by the update instructions above.
                If nothing comes up, my plan is to have this merged in the next release of home assistant.
                  subutux
                  I've also tested your pymysensors version with tcp gateway. I've had an excessive cpu usage on my pi Zero (actually, a constant 100%). After some debugging I've found that I've had to add a sleep of 0.2 to the while loop of the top socket readout. My cpu usage returned normal.
                  What I've also encountered is that when the tcp gateway looses connection, pymysensors still thinks it's connected. I've buildin an active check by requesting the gateway version every 10 seconds.
                  Would you like me to make a pull request ?
                  martinhjelmareM 3 Replies Last reply
                  • S subutux
                    martinhjelmareM
                    martinhjelmareM
                    martinhjelmare
                    @subutux
                    Thanks for the feedback!
                    I've got some commits that are not pushed yet with some changes, but a pull request should be good anyhow. Great!
                      I've updated the branch at my fork of pymysensors. If you have installed the ethernet branch of my fork of home-assistant, you should uninstall/reinstall that, or just make a new virtual environment and install again. You should remove the lib directory in your home assistant config directory as well.
                      Eg:
                      rm -r ~/.homeassistant/lib
                      mkvirtualenv -p /usr/bin/python3 hasstest2
                      cd ~/dev/home-assistant
                      git branch -D mysensors-tcp-gateway
                      git fetch origin mysensors-tcp-gateway
                      git checkout mysensors-tcp-gateway
                      pip3 install -e .
                      pip3 install colorlog
                      pip3 install python-Levenshtein
                      martinhjelmareM
                      martinhjelmareM
                      martinhjelmare
                      #64
                      I've now pushed some updates to my ethernet gateway branch of pymysensors and rebased my home-assistant mysensors-tcp-gateway branch off latest upstream dev branch and pushed that to my github.
                      To upgrade follow the instructions below.
                      Eg:
                      pip3 install -e .
                      • S subutux
                        martinhjelmareM
                        martinhjelmareM
                        martinhjelmare
                        #65
                        @subutux
                        Please rebase your pymysensors branch off my latest updates, before you make the PR. Thanks.
                        • S subutux
                          martinhjelmareM
                          martinhjelmareM
                          martinhjelmare
                          #66
                          @subutux
                          I went ahead and added your fix for the 100% cpu usage. Although I settled for a very short 0.02 seconds. It was enough for my intel based processor. If you still experience problems and think we should increase it, let me know.
                          Please make a PR for the check of the connection here https://github.com/theolind/pymysensors if you have time.
                          My plan is to try and have this make the release of home assistant that is planned during this week. I think it should be good enough for a first version now. We can add polish for the next release.
                          • D
                            drock1985
                            Hi @martinhjelmare
                            I see HA got released early, and that the ethernetgateway was added. I'll check it out later on tonight but, thanks again for all the work you do on the MySensors project.
                            My Projects
                            2 Door Chime Sensor
                            • D drock1985
                              Hi @martinhjelmare
                              martinhjelmareM
                              martinhjelmareM
                              martinhjelmare
                              @drock1985
                              Yeah, finally! I've been a bit disappointed with myself, that it took a long time and for not finishing this earlier, but now it feels good to have it merged. We still have to polish some things, like checking that the connection is still ok, so all feedback is very welcome and valuable.
                              I need to update the docs at home-assistant.io, and then I might make a new post about the release.
                              BIG THANKS to everyone that tested this:
                              @drock1985
                              @Dave-Dan
                              @Andrew-Sanjanwala
                              @subutux
                                subutux
                                @martinhjelmare As soon as i have the time (and clean up my code because it was a hack) i'll create a pull request. i've mine also at 0.02 and my (pi zero) CPU is now at around 8-10%.
