  3. Home Assistant
  4. Any plan to implement Ethernet GW?
69 Posts 5 Posters 26.4k Views 6 Watching
  • D
    drock1985
    @Dave-Dan
    out of curiosity, did you try a different name for the persistence file after deleting your first one, or did you use the same name?
    My Projects
    2 Door Chime Sensor
    Washing Machine Monitor
    • Dave DanD
      Dave DanD
      Dave Dan
      hey @drock1985,
      No I didn't test that before, but I just did with the same results :(
      I can see in the log how messages are arriving to HA (see below). It's just I can't see them either in the group I created for them or in the Developer Tools.
      16-03-31 09:42:37 DEBUG (Thread-20) [mysensors.mysensors] Received 101;1;1;0;0;20.0
      16-03-31 09:42:37 DEBUG (Thread-20) [mysensors.mysensors] Received 101;0;1;0;1;36.0
      16-03-31 09:42:37 DEBUG (Thread-20) [mysensors.mysensors] Received 101;3;1;0;16;0
      If I go back and restore the previous file I can see them on both the group and the Developer Tools section.
      @martinhjelmare, hope this helps as well ... is is there any specific test you want me to perform please let me know.
        @Dave-Dan
        Did you do it like this?
        1. Stop hass.
        2. Remove old persistence file.
        3. Create new persistence file with the same name and path, containing an empty JSON object, "{}".
        4. Start hass.
        5. Start node. Result: Messages are coming in to gateway, but node sensors are not added to entities nor shown in GUI.
        martinhjelmareM
        martinhjelmareM
        martinhjelmare
        @Dave-Dan
        I finally had some time to test this again. Sorry for the long delay.
        I followed the steps here:
        @martinhjelmare said:
        @Dave-Dan
        1. Stop hass.
        4. Start hass.
        but I'm not able to reproduce your experienced problem. On my end, the node and sensor are added ok. Do you have any more clues what might be different on your end?
        HA config:
        mysensors:
          gateways:
            - device: '192.168.1.18'
              persistence_file: '/home/martin/.homeassistant/mysensors3.json'
              tcp_port: 5003
          debug: true
          persistence: true
          version: '1.5'
          optimistic: false
        console log:
        configuration.yaml  home-assistant.db  home-assistant.log  known_devices.yaml  lib  mysensors3.json
        martin@martin-nuc:~/.homeassistant$ cat mysensors3.json
        {"1": {"children": {"1": {"values": {"40": "ffffff", "2": "0", "3": "0"}, "id": 1, "type": 26}}, "sketch_version": "1.1", "sketch_name": "DimmableLED", "battery_level": 0, "sensor_id": 1, "type": 17}}
        martin@martin-nuc:~/.homeassistant$ rm mysensors3.json
        martin@martin-nuc:~/.homeassistant$ ls
        martin@martin-nuc:~/.homeassistant$ atom .
        {"1": {"battery_level": 0, "sensor_id": 1, "sketch_name": "DimmableLED", "children": {"1": {"values": {"40": "ffffff", "2": "0", "3": "0"}, "id": 1, "type": 26}}, "sketch_version": "1.1", "type": 17}}
        sensor serial log:
        send: 1-1-0-0 s=255,c=3,t=15,pt=2,l=2,sg=0,st=ok:0
        send: 1-1-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,st=ok:1.5.1
        send: 1-1-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
        read: 0-0-1 s=255,c=3,t=15,pt=2,l=2,sg=0:0
        read: 0-0-1 s=255,c=3,t=6,pt=0,l=1,sg=0:M
        sensor started, id=1, parent=0, distance=1
        send: 1-1-0-0 s=1,c=0,t=26,pt=0,l=0,sg=0,st=ok:
        send: 1-1-0-0 s=255,c=3,t=11,pt=0,l=11,sg=0,st=ok:DimmableLED
        send: 1-1-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:1.1
        send: 1-1-0-0 s=1,c=2,t=3,pt=0,l=0,sg=0,st=ok:
        send: 1-1-0-0 s=1,c=1,t=2,pt=2,l=2,sg=0,st=ok:0
        send: 1-1-0-0 s=1,c=1,t=3,pt=2,l=2,sg=0,st=ok:0
        send: 1-1-0-0 s=1,c=1,t=40,pt=0,l=6,sg=0,st=ok:ffffff
        read: 0-0-1 s=1,c=1,t=2,pt=0,l=1,sg=0:1
        Changing level to 100, from 0
        send: 1-1-0-0 s=1,c=1,t=2,pt=2,l=2,sg=0,st=ok:1
        send: 1-1-0-0 s=1,c=1,t=3,pt=2,l=2,sg=0,st=ok:100
        read: 0-0-1 s=1,c=1,t=2,pt=0,l=1,sg=0:0
        Changing level to 0, from 100
        hass log:
        16-04-10 14:23:01 INFO (Thread-8) [mysensors.mysensors] Trying to connect to ('192.168.1.18', 5003)
        16-04-10 14:23:01 INFO (Thread-21) [homeassistant.core] Timer:starting
        16-04-10 14:23:01 INFO (Thread-8) [mysensors.mysensors] Connected to ('192.168.1.18', 5003)
        16-04-10 14:23:03 INFO (Thread-23) [homeassistant.components.http] "GET /api/stream?api_password=no_password_set&restrict=state_changed,component_loaded,service_registered HTTP/1.1" 200 -
        16-04-10 14:23:03 INFO (Thread-24) [homeassistant.components.http] "GET /api/bootstrap HTTP/1.1" 200 -
        16-04-10 14:23:30 INFO (Thread-3) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sun.sun, old_state=<state sun.sun=above_horizon; next_rising=03:40:47 11-04-2016, icon=mdi:air-conditioner, elevation=35.69, next_setting=17:52:06 10-04-2016, friendly_name=Customized Sun @ 14:23:01 10-04-2016>, new_state=<state sun.sun=above_horizon; next_rising=03:40:47 11-04-2016, icon=mdi:air-conditioner, elevation=35.66, next_setting=17:52:06 10-04-2016, friendly_name=Customized Sun @ 14:23:01 10-04-2016>>
        16-04-10 14:24:30 INFO (Thread-2) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sun.sun, old_state=<state sun.sun=above_horizon; next_rising=03:40:47 11-04-2016, icon=mdi:air-conditioner, elevation=35.66, next_setting=17:52:06 10-04-2016, friendly_name=Customized Sun @ 14:23:01 10-04-2016>, new_state=<state sun.sun=above_horizon; next_rising=03:40:47 11-04-2016, icon=mdi:air-conditioner, elevation=35.6, next_setting=17:52:06 10-04-2016, friendly_name=Customized Sun @ 14:23:01 10-04-2016>>
        16-04-10 14:25:30 INFO (Thread-16) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sun.sun, old_state=<state sun.sun=above_horizon; next_rising=03:40:47 11-04-2016, icon=mdi:air-conditioner, elevation=35.6, next_setting=17:52:06 10-04-2016, friendly_name=Customized Sun @ 14:23:01 10-04-2016>, new_state=<state sun.sun=above_horizon; next_rising=03:40:47 11-04-2016, icon=mdi:air-conditioner, elevation=35.54, next_setting=17:52:06 10-04-2016, friendly_name=Customized Sun @ 14:23:01 10-04-2016>>
        16-04-10 14:25:41 INFO (Thread-25) [homeassistant.components.http] "GET /static/frontend-833d09737fec24f9219efae87c5bfd2a.html HTTP/1.1" 200 -
        16-04-10 14:25:42 INFO (Thread-26) [homeassistant.components.http] "GET /static/favicon.ico HTTP/1.1" 200 -
        16-04-10 14:25:42 INFO (Thread-27) [homeassistant.components.http] "GET /api/bootstrap HTTP/1.1" 200 -
        16-04-10 14:25:42 INFO (Thread-28) [homeassistant.components.http] "GET /api/stream?api_password=no_password_set&restrict=state_changed,component_loaded,service_registered HTTP/1.1" 200 -
        16-04-10 14:25:53 INFO (Thread-8) [homeassistant.components.mysensors] No sketch_name: node 1
        16-04-10 14:25:55 INFO (Thread-8) [homeassistant.components.mysensors] No sketch_name: node 1
        16-04-10 14:25:59 INFO (Thread-8) [homeassistant.components.mysensors] Adding new devices: <Entity DimmableLED 1.1: off>
        16-04-10 14:25:59 INFO (Thread-8) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=light.dimmableled_11, old_state=None, new_state=<state light.dimmableled_11=unavailable; friendly_name=DimmableLED 1.1 @ 14:25:59 10-04-2016>>
        16-04-10 14:25:59 INFO (Thread-8) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=group.all_lights, old_state=None, new_state=<state group.all_lights=unknown; hidden=True, entity_id=[], auto=True, order=1, friendly_name=all lights @ 14:25:59 10-04-2016>>
        16-04-10 14:25:59 INFO (Thread-8) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=group.all_lights, old_state=<state group.all_lights=unknown; hidden=True, entity_id=[], auto=True, order=1, friendly_name=all lights @ 14:25:59 10-04-2016>, new_state=None>
        16-04-10 14:25:59 INFO (Thread-8) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=group.all_lights, old_state=None, new_state=<state group.all_lights=unknown; hidden=True, entity_id=('light.dimmableled_11',), auto=True, order=1, friendly_name=all lights @ 14:25:59 10-04-2016>>
        16-04-10 14:25:59 INFO (Thread-8) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=light.dimmableled_11, old_state=<state light.dimmableled_11=unavailable; friendly_name=DimmableLED 1.1 @ 14:25:59 10-04-2016>, new_state=<state light.dimmableled_11=off; V_STATUS=off, node_id=1, V_RGB=ffffff, V_PERCENTAGE=0, battery_level=0, device=192.168.1.18:5003, friendly_name=DimmableLED 1.1, child_id=1 @ 14:25:59 10-04-2016>>
        16-04-10 14:25:59 INFO (Thread-17) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=group.all_lights, old_state=<state group.all_lights=unknown; hidden=True, entity_id=('light.dimmableled_11',), auto=True, order=1, friendly_name=all lights @ 14:25:59 10-04-2016>, new_state=<state group.all_lights=off; hidden=True, entity_id=('light.dimmableled_11',), auto=True, order=1, friendly_name=all lights @ 14:25:59 10-04-2016>>
        16-04-10 14:25:59 INFO (Thread-23) [homeassistant.components.api] Found broken event stream to 127.0.0.1, cleaning up
        16-04-10 14:26:19 INFO (Thread-29) [homeassistant.core] Bus:Handling <Event call_service[L]: service=turn_on, domain=homeassistant, service_data=entity_id=light.dimmableled_11, service_call_id=140012061724232-1>
        16-04-10 14:26:19 INFO (Thread-15) [homeassistant.core] Bus:Handling <Event call_service[L]: service=turn_on, domain=light, service_data=entity_id=['light.dimmableled_11'], service_call_id=140012061724232-2>
        16-04-10 14:26:19 INFO (Thread-9) [homeassistant.core] Bus:Handling <Event service_executed[L]: service_call_id=140012061724232-2>
        16-04-10 14:26:19 INFO (Thread-15) [homeassistant.core] Bus:Handling <Event service_executed[L]: service_call_id=140012061724232-1>
        16-04-10 14:26:19 INFO (Thread-29) [homeassistant.components.http] "POST /api/services/homeassistant/turn_on HTTP/1.1" 200 -
        16-04-10 14:26:21 INFO (Thread-8) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=light.dimmableled_11, old_state=<state light.dimmableled_11=off; V_STATUS=off, node_id=1, V_RGB=ffffff, V_PERCENTAGE=0, battery_level=0, device=192.168.1.18:5003, friendly_name=DimmableLED 1.1, child_id=1 @ 14:25:59 10-04-2016>, new_state=<state light.dimmableled_11=off; V_STATUS=on, node_id=1, V_RGB=ffffff, V_PERCENTAGE=0, battery_level=0, device=192.168.1.18:5003, friendly_name=DimmableLED 1.1, child_id=1 @ 14:25:59 10-04-2016>>
        16-04-10 14:26:22 INFO (Thread-8) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=light.dimmableled_11, old_state=<state light.dimmableled_11=off; V_STATUS=on, node_id=1, V_RGB=ffffff, V_PERCENTAGE=0, battery_level=0, device=192.168.1.18:5003, friendly_name=DimmableLED 1.1, child_id=1 @ 14:25:59 10-04-2016>, new_state=<state light.dimmableled_11=on; V_RGB=ffffff, V_PERCENTAGE=100, battery_level=0, rgb_color=[255, 255, 255], child_id=1, V_STATUS=on, brightness=255, device=192.168.1.18:5003, friendly_name=DimmableLED 1.1, node_id=1 @ 14:26:22 10-04-2016>>
        16-04-10 14:26:22 INFO (Thread-7) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=group.all_lights, old_state=<state group.all_lights=off; hidden=True, entity_id=('light.dimmableled_11',), auto=True, order=1, friendly_name=all lights @ 14:25:59 10-04-2016>, new_state=<state group.all_lights=on; hidden=True, entity_id=('light.dimmableled_11',), auto=True, order=1, friendly_name=all lights @ 14:26:22 10-04-2016>>
        16-04-10 14:26:26 INFO (Thread-30) [homeassistant.core] Bus:Handling <Event call_service[L]: service=turn_off, domain=homeassistant, service_data=entity_id=light.dimmableled_11, service_call_id=140012061724232-3>
        16-04-10 14:26:26 INFO (Thread-6) [homeassistant.core] Bus:Handling <Event call_service[L]: service=turn_off, domain=light, service_data=entity_id=['light.dimmableled_11'], service_call_id=140012061724232-4>
        16-04-10 14:26:26 INFO (Thread-13) [homeassistant.core] Bus:Handling <Event service_executed[L]: service_call_id=140012061724232-4>
        16-04-10 14:26:26 INFO (Thread-6) [homeassistant.core] Bus:Handling <Event service_executed[L]: service_call_id=140012061724232-3>
        16-04-10 14:26:26 INFO (Thread-30) [homeassistant.components.http] "POST /api/services/homeassistant/turn_off HTTP/1.1" 200 -
        16-04-10 14:26:27 INFO (Thread-8) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=light.dimmableled_11, old_state=<state light.dimmableled_11=on; V_RGB=ffffff, V_PERCENTAGE=100, battery_level=0, rgb_color=[255, 255, 255], child_id=1, V_STATUS=on, brightness=255, device=192.168.1.18:5003, friendly_name=DimmableLED 1.1, node_id=1 @ 14:26:22 10-04-2016>, new_state=<state light.dimmableled_11=off; V_STATUS=off, node_id=1, V_RGB=ffffff, V_PERCENTAGE=100, battery_level=0, device=192.168.1.18:5003, friendly_name=DimmableLED 1.1, child_id=1 @ 14:26:27 10-04-2016>>
        16-04-10 14:26:27 INFO (Thread-18) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=group.all_lights, old_state=<state group.all_lights=on; hidden=True, entity_id=('light.dimmableled_11',), auto=True, order=1, friendly_name=all lights @ 14:26:22 10-04-2016>, new_state=<state group.all_lights=off; hidden=True, entity_id=('light.dimmableled_11',), auto=True, order=1, friendly_name=all lights @ 14:26:27 10-04-2016>>
        16-04-10 14:26:28 INFO (Thread-8) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=light.dimmableled_11, old_state=<state light.dimmableled_11=off; V_STATUS=off, node_id=1, V_RGB=ffffff, V_PERCENTAGE=100, battery_level=0, device=192.168.1.18:5003, friendly_name=DimmableLED 1.1, child_id=1 @ 14:26:27 10-04-2016>, new_state=<state light.dimmableled_11=off; V_STATUS=off, node_id=1, V_RGB=ffffff, V_PERCENTAGE=0, battery_level=0, device=192.168.1.18:5003, friendly_name=DimmableLED 1.1, child_id=1 @ 14:26:27 10-04-2016>>
        • Dave DanD
          Dave DanD
          Dave Dan
          hey Martin.
          Sorry, I've been traveling for a while.
          So I just rebuilt my environment and I can't repro the issue anymore.
          If you can't either and no one else is experiencing this I think we can close this down. My environment might be the only thing that is creating the issue.
          If the issue happen again I can update with the new information.
          • Dave DanD Dave Dan
            hey Martin.
            martinhjelmareM
            martinhjelmareM
            martinhjelmare
            @Dave-Dan
            Great! Then I'll move forward and push my latest changes to my github branch. I'll post here when that is done. You're welcome to test these by the update instructions above.
            If nothing comes up, my plan is to have this merged in the next release of home assistant.
              subutux
              I've also tested your pymysensors version with tcp gateway. I've had an excessive cpu usage on my pi Zero (actually, a constant 100%). After some debugging I've found that I've had to add a sleep of 0.2 to the while loop of the top socket readout. My cpu usage returned normal.
              What I've also encountered is that when the tcp gateway looses connection, pymysensors still thinks it's connected. I've buildin an active check by requesting the gateway version every 10 seconds.
              Would you like me to make a pull request ?
              martinhjelmareM 3 Replies Last reply
              • S subutux
                martinhjelmareM
                martinhjelmareM
                martinhjelmare
                @subutux
                Thanks for the feedback!
                I've got some commits that are not pushed yet with some changes, but a pull request should be good anyhow. Great!
                  I've updated the branch at my fork of pymysensors. If you have installed the ethernet branch of my fork of home-assistant, you should uninstall/reinstall that, or just make a new virtual environment and install again. You should remove the lib directory in your home assistant config directory as well.
                  Eg:
                  rm -r ~/.homeassistant/lib
                  mkvirtualenv -p /usr/bin/python3 hasstest2
                  cd ~/dev/home-assistant
                  git branch -D mysensors-tcp-gateway
                  git fetch origin mysensors-tcp-gateway
                  git checkout mysensors-tcp-gateway
                  pip3 install -e .
                  pip3 install colorlog
                  pip3 install python-Levenshtein
                  martinhjelmareM
                  martinhjelmareM
                  martinhjelmare
                  #64
                  I've now pushed some updates to my ethernet gateway branch of pymysensors and rebased my home-assistant mysensors-tcp-gateway branch off latest upstream dev branch and pushed that to my github.
                  To upgrade follow the instructions below.
                  Eg:
                  pip3 install -e .
                  • S subutux
                    martinhjelmareM
                    martinhjelmareM
                    martinhjelmare
                    #65
                    @subutux
                    Please rebase your pymysensors branch off my latest updates, before you make the PR. Thanks.
                    • S subutux
                      martinhjelmareM
                      martinhjelmareM
                      martinhjelmare
                      #66
                      @subutux
                      I went ahead and added your fix for the 100% cpu usage. Although I settled for a very short 0.02 seconds. It was enough for my intel based processor. If you still experience problems and think we should increase it, let me know.
                      Please make a PR for the check of the connection here https://github.com/theolind/pymysensors if you have time.
                      My plan is to try and have this make the release of home assistant that is planned during this week. I think it should be good enough for a first version now. We can add polish for the next release.
                      • D
                        drock1985
                        Hi @martinhjelmare
                        I see HA got released early, and that the ethernetgateway was added. I'll check it out later on tonight but, thanks again for all the work you do on the MySensors project.
                        My Projects
                        2 Door Chime Sensor
                        • D drock1985
                          Hi @martinhjelmare
                          martinhjelmareM
                          martinhjelmareM
                          martinhjelmare
                          @drock1985
                          Yeah, finally! I've been a bit disappointed with myself, that it took a long time and for not finishing this earlier, but now it feels good to have it merged. We still have to polish some things, like checking that the connection is still ok, so all feedback is very welcome and valuable.
                          I need to update the docs at home-assistant.io, and then I might make a new post about the release.
                          BIG THANKS to everyone that tested this:
                          @drock1985
                          @Dave-Dan
                          @Andrew-Sanjanwala
                          @subutux
                            subutux
                            @martinhjelmare As soon as i have the time (and clean up my code because it was a hack) i'll create a pull request. i've mine also at 0.02 and my (pi zero) CPU is now at around 8-10%.
