  3. 2 channel in wall dimmer
54 Posts 15 Posters 29.4k Views 26 Watching
  • D Denke
    Finally new boards have arrived..
    Assembly will start soon:)
    ahmedadelhosniA
    ahmedadelhosniA
    ahmedadelhosni
    @Denke Nice :) I am really excited to see your results.
    Regarding the resistor which is in parallel to act as a bleeder. What value do you think the most suitable ? 100K ? 1M ? and howa much watt ?
    D 1 Reply Last reply
      Denke
      @ahmedadelhosni
      Hi I have used 1M as bleeder in 0603 size. This resistor should be able to handle around 0.1W.
      If i have calculated right the power in the bleeder resistor should be around 0.05W
      RaspberryPi-Openhab
      • ahmedadelhosniA
        ahmedadelhosniA
        ahmedadelhosni
        Any pictures of the assembled board ?
          Denke
          wrote on last edited by Denke
          #45
          @ahmedadelhosni Have not started the assembly of these boards yet. Im currently doing assembly of my other project Wirsbo/Uponor thermostat replacement. And those boards seems to be fully functional.
          I will post a picture as soon as I get it assembled
          RaspberryPi-Openhab
          • D Denke
            ahmedadelhosniA
            ahmedadelhosniA
            ahmedadelhosni
            Thanks @Denke
            • ahmedadelhosniA
              ahmedadelhosniA
              ahmedadelhosni
              0_1459108094968_upload-1fb891ae-8d4b-4987-99e9-f797e2264042
              If I am not mistaken, isn't this the bleeding resistor in parallel with the cap ?
              Why is there a reverse diode ? Won't this block the current from passing from the + terminal of the capacitor to the resistor then to gnd ?
                GertSandersG
                GertSandersG
                GertSanders
                @ahmedadelhosni
                It's a zener diode which will pass current once voltage is above 24v and then the resistor protects it from complete shorting to ground.
                • D
                  Denke
                  First components added after a visit to the lab at work and some soldering under the microscope
                  RaspberryPi-Openhab
                  • D
                    Denke
                    #50
                    Hi just wanted to get an update on this project.
                    I have assembled 2 pcb (not all components) to start debug the processor platform and surroundings. Unfortunatly i got a bit stuck as i have problems loading the boot loader. I have tried to use the process suggested on arduino.cc using an nano as ISP. I get alot of strange behaviours and are not able to upload.
                    Any tips and tricks is well received if you have any.
                    Othervise i will rest this project for a couple of weeks to be able to finnish my other thermostat project as well start a new, as the pool season is around the corner. And i really would love to be able to corntol pupm, lghts read temperatures and other stuff.
                    But if i find some good tricks i will pursue the goal to finnish this in wall dimmer before summer.
                    RaspberryPi-Openhab
                    • OitzuO
                      OitzuO
                      Oitzu
                      You not yet have added the nrf24, or? With the nrf24 module added the upload via isp will not work.
                      Can you describe any more behaviour? Log output, led flashing...
                      • sundberg84S
                        sundberg84S
                        @Oitzu - why should not burning a bootloader to the atmega work without the nrf24 attached?
                        • OitzuO
                          OitzuO
                          Oitzu
                          @sundberg84 in most of my cases it failed due to spi interferences.
                          • sundberg84S
                            sundberg84S
                            @Oitzu Ahh, sorry I missunderstood you - the other way around. I read it like you had to have the nrf attached to make it work :)
                            12.5k
