  3. Cant't get MQTTGateway to work
12 Posts 3 Posters 3.9k Views 3 Watching
  • S Offline
    Soloam
    wrote on last edited by Soloam
    Hell, I've been testing a MQTTGateway in my Arduino UNO and I can't get it to work, I checked and double checked, and the again, all the connections, and all is ok!
    I have a HanRun HR911105A and I'm running with SOFTSPI on! This module is powerd by 5v and I also tested it with a separated power supply!
    When I plug my Arduino I get in the serial monitor:
    Ok!
    The lights in the Ethernet Module start to blink but if I do a ping to the IP, it returns "unreachable"!
    This is my config:
    #include <DigitalIO.h>
    #include <MySigningNone.h>
    #include <MyTransportRFM69.h>
    #include <MyTransportNRF24.h>
    #include <MyHwATMega328.h>
    #include <MsTimer2.h>
    #include <Ethernet.h>
    #include "MyMQTT.h"
    #define INCLUSION_MODE_PIN 3 // Digital pin used for inclusion mode button
    // * Use this for IBOARD modded to use standard MISO/MOSI/SCK, see note 1 above!
    #define RADIO_CE_PIN 3 // radio chip enable
    #define RADIO_SPI_SS_PIN 8 // radio SPI serial select
    #define RADIO_ERROR_LED_PIN A2 // Error led pin
    #define RADIO_RX_LED_PIN A1 // Receive led pin
    #define RADIO_TX_LED_PIN A0 // the PCB, on board LED
    // * Use this for default configured pro mini / nano etc :
    #define RADIO_CE_PIN 5 // radio chip enable
    #define RADIO_SPI_SS_PIN 6 // radio SPI serial select
    #define RADIO_ERROR_LED_PIN 7 // Error led pin
    #define RADIO_RX_LED_PIN 8 // Receive led pin
    #define RADIO_TX_LED_PIN 9 // the PCB, on board LED*/
    #define TCP_PORT 1883 // Set your MQTT Broker Listening port.
    IPAddress TCP_IP ( 192, 168, 2, 30 ); // Configure your static ip-address here
    byte TCP_MAC[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
    Can any one help me? This is driving me crazy!
    Thank you
    • hekH Offline
      hekH Offline
      @Soloam said:
      HanRun HR911105A
      W5100?
      • S Offline
        Soloam
        Yes I think so! It's the one one the MySensor Store, the red one!
        • hekH Offline
          hekH Offline
          Could you just try the W5100 Gateway sketch in the dev-branch it should be ready to run without any reconfiguration.
          The 5100 if pretty power hungry, are you able to test it with a bench power supply while testing?
          • S Offline
            Soloam
            Hello @hek !
            I tested the W5100 Gateway sketch but nothing happens, I don't see nothing in the serial monitor and I can't ping the IP! I tested also without defining the IP, but no DHCP request is made to my router!
            I also tested like you suggested, with a external power supply just to the W5100, no success!
            Thank You
            • S Offline
              Soloam
              This is so annoying! I tried this code:
              const int W5100_RESET_PIN = 8;
              byte mac[] = {
              IPAddress MY_IP(192,168,1,177);
                Serial.begin(9600);
                Serial.println();
                Serial.println(F("node starting..."));
                pinMode(W5100_RESET_PIN, OUTPUT);
                digitalWrite(W5100_RESET_PIN, LOW);
                delay(100);
                digitalWrite(W5100_RESET_PIN, HIGH);
                // give the Ethernet shield a second to initialize:
                delay(3000);
                Serial.print(F("static IP..."));
                Ethernet.begin(mac, IPAddress(MY_IP));
                Serial.print(F("local IP:"));
                Serial.println(Ethernet.localIP());
                Serial.println(F("node started."));
              I found it online! Look at the IP (192.168.1,177)! This is the output from serial:
              node starting...
              static IP...local IP:232.64.0.0
              node started.
              If I run it again the IP changes! =/
              • R Offline
                R Offline
                rollercontainer
                Seems, that your ip adresses dont match your network. What is the ip of your router? The first 3 numbers have to match in a normal home network...
                Are you aware how to do that?
                • S Offline
                  Soloam
                  The IP is in the range! I have several networks at my home, I tested it in all! In the case above the router IP is 192.168.1.1.
                  Can it be a defected network module? =/
                  • S Offline
                    Soloam
                    I ordered 2 new W1500 modules to test out! Now I need to wait for them to arrive!
                    • S Offline
                      Soloam
                      Hello, found a solution that solved my problem! You can use the topic https://forum.arduino.cc/index.php?topic=351477.msg2662072#msg2662072 as reference! I soldered the 100ohm as described and it worked 100%.
                      Thank you all
                      • R Offline
                        R Offline
                        rollercontainer
                        Which total wire length is between the W5100 and the next active port (switch/router) ?
                        • S Offline
                          Soloam
                          Wire Length? Way is this important? The problem was solved soldering te 2 resistors! The cable length is a normal small cable going to the router
