  3. Cant't get MQTTGateway to work
12 Posts 3 Posters 3.9k Views 3 Watching
  • SoloamS
    SoloamS
    Soloam
    Yes I think so! It's the one one the MySensor Store, the red one!
      Could you just try the W5100 Gateway sketch in the dev-branch it should be ready to run without any reconfiguration.
      The 5100 if pretty power hungry, are you able to test it with a bench power supply while testing?
      • SoloamS
        SoloamS
        Soloam
        Hello @hek !
        I tested the W5100 Gateway sketch but nothing happens, I don't see nothing in the serial monitor and I can't ping the IP! I tested also without defining the IP, but no DHCP request is made to my router!
        I also tested like you suggested, with a external power supply just to the W5100, no success!
        Thank You
        • SoloamS
          SoloamS
          Soloam
          wrote on last edited by Soloam
          This is so annoying! I tried this code:
          #include <Ethernet.h>
          const int W5100_RESET_PIN = 8;
          byte mac[] = {
            0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED
          IPAddress MY_IP(192,168,1,177);
            Serial.begin(9600);
            Serial.println();
            Serial.println(F("node starting..."));
            pinMode(W5100_RESET_PIN, OUTPUT);
            digitalWrite(W5100_RESET_PIN, LOW);
            delay(100);
            digitalWrite(W5100_RESET_PIN, HIGH);
            // give the Ethernet shield a second to initialize:
            delay(3000);
            Serial.print(F("static IP..."));
            Ethernet.begin(mac, IPAddress(MY_IP));
            Serial.print(F("local IP:"));
            Serial.println(Ethernet.localIP());
            Serial.println(F("node started."));
          I found it online! Look at the IP (192.168.1,177)! This is the output from serial:
          node starting...
          static IP...local IP:232.64.0.0
          node started.
          If I run it again the IP changes! =/
          • rollercontainerR
            rollercontainerR
            rollercontainer
            Seems, that your ip adresses dont match your network. What is the ip of your router? The first 3 numbers have to match in a normal home network...
            Are you aware how to do that?
            • SoloamS
              SoloamS
              Soloam
              The IP is in the range! I have several networks at my home, I tested it in all! In the case above the router IP is 192.168.1.1.
              Can it be a defected network module? =/
              • SoloamS
                SoloamS
                Soloam
                I ordered 2 new W1500 modules to test out! Now I need to wait for them to arrive!
                • SoloamS
                  SoloamS
                  Soloam
                  Hello, found a solution that solved my problem! You can use the topic https://forum.arduino.cc/index.php?topic=351477.msg2662072#msg2662072 as reference! I soldered the 100ohm as described and it worked 100%.
                  Thank you all
                  • rollercontainerR
                    rollercontainerR
                    rollercontainer
                    Which total wire length is between the W5100 and the next active port (switch/router) ?
                    • SoloamS
                      SoloamS
                      Soloam
                      Wire Length? Way is this important? The problem was solved soldering te 2 resistors! The cable length is a normal small cable going to the router
                      12.5k
