  3. Init fail
Init fail
5 Posts 4 Posters 1.8k Views 2 Watching
  • P Offline
    P Offline
    pettib
    Hi
    I have been playing with mysensors for a while but now when trying to start it up again after a couple of month of paus.
    I´m getting this error: 0;0;3;0;9;radio init fail when I´m using the following.
    Arduino Nano
    NRF24L01+
    Arduino 1.6.8
    Mysensors 1.5
    SerialGateway sketch
    I have tried to using another NRF chip but same result.
    I have been using the same hardware before to build a gateway
    TheoLT 1 Reply Last reply
    • P pettib
      Hi
      Arduino Nano
      NRF24L01+
      Arduino 1.6.8
      Mysensors 1.5
      TheoLT Offline
      TheoLT Offline
      TheoL
      @pettib Did you check the wires and added a 4.7uF capacitor? Init fail is saying as much as, I can't communicate with the radio. Which is either in the wiring or in the power.
      Good luck!
      • P Offline
        P Offline
        pettib
        Yes, The wires is correct and i have the 4.7uF capacitor connected.
        I have homemade card with everything on it.
        It the same i used before.
        The only thing that have been changed is the version of Arduino IDE and Mysensors 1.5.
        • sundberg84S Offline
          sundberg84S Offline
          Pretty much as @TheoL said:
          Radio init fail means:
          1. Not wired correctly
          2. Not powered correctly
          3. Not a nrf24 with +
          Some reading regarding + and not + Nrf modules.
          http://forum.mysensors.org/topic/1153/we-are-mostly-using-fake-nrf24l01-s-but-worse-fakes-are-emerging/4
          http://forum.mysensors.org/topic/1664/which-are-the-best-nrf24l01-modules/2
          I would trippelcheck my wiring, redo the wiring and try another power source.
          • OitzuO Offline
            OitzuO Offline
            Oitzu
            Also check ce and csn pin configuration correspondence to your wiring.
            11.8k
            113.2k
