  3. Can it be done? (Countdown timer that survives wait or sleep)
21 Posts 6 Posters 7.5k Views 4 Watching
  • Mark SwiftM
    Mark SwiftM
    Mark Swift
    wrote on last edited by Mark Swift
    Hi Guys,
    I'm trying to add a simple countdown timer into my sketch. the logic is, if x is true, reset the timer, if it isn't start the timer.
    Basically, if rain is detected, reset the timer. If it isn't countdown from 4 hours.
    I tried a library that I found but it didn't seem to work with the wait or sleep command (which I expected).
    Any ideas?
    TheoLT AWIA 2 Replies Last reply
    • mfalkviddM
      The number you get from millis() is increased all the time. It wraps around after a few days, but as long as you don't sleep longer than that you should be able to just use the value returned.
      Edit: I was wrong. Millis is stoppen when the mcu is sleeping.
      • Mark SwiftM Mark Swift
        Hi Guys,
        Any ideas?
        TheoLT
        TheoLT
        TheoL
        @Mark-Swift When an Arduino sleeps. it sleeps. Meaning that the internal timer sleeps also. Thus millis() continues when woken up. But pauses when sleeping. In my opnion, intelligence like this should be handled by your home automation system.
        But it can be done, but not in combination with sleep-mode.
        • Mark SwiftM
          Mark SwiftM
          Mark Swift
          Hi again @mfalkvidd :)
          I've not used that before, I don't intend to wait or sleep (depending on if the node's a repeater) longer that a few minutes. Could you give me an example of how I could achieve this?
          This is what I'm working on:
          // Enable debug prints
          // Required for MQTT as gateway does not automagically assign ID's
          #define MY_NODE_ID 3
          // Set parent node ID manually
          // #define MY_PARENT_NODE_ID
          // #define MY_RADIO_RFM69
          // Set RF24L01 channel number
          #define MY_RF24_CHANNEL 125
          #include <BH1750.h>
          #include <NewPing.h>
          #include <Adafruit_NeoPixel.h>
          #define NEO_PIN 2
          Adafruit_NeoPixel strip1 = Adafruit_NeoPixel(60, NEO_PIN, NEO_GRB + NEO_KHZ800);
          // Power pin moisture sensor
          #define MOISTURE_POWER_PIN 5
          // Digital input pin moisture sensor
          #define DIGITAL_INPUT_MOISTURE 6
          // Power pin rain sensor
          #define RAIN_POWER_PIN 7
          // Digital input pin rain sensor
          #define DIGITAL_INPUT_RAIN 8
          // Ultrasonic trigger pin
          #define TRIGGER_PIN 4
          // Ultrasonic echo pin
          #define ECHO_PIN 3
          // Maximum distance we want to ping for (in cms), maximum sensor distance is rated at 400-500cm
          #define MAX_DISTANCE 300
          // NewPing setup of pins and maximum distance
          NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE);
          // Set BH1750 name
          BH1750 lightSensor;
          // Define end of loop pause time
          #define LOOP_PAUSE 30000
          // Define radio wait time between sends
          #define RADIO_PAUSE 125  // This allows for radio to come back to power after a transmission, ideally 0..
          // Define time between sensors blocks
          #define SENSORS_DELAY 125  // This allows for radio to come back to power after a transmission, ideally 0..
          // Define delay set on Landroid
          #define MOWER_DELAY (4UL*60UL*60UL*1000UL)  // Hours (4)
          boolean MowerWaiting = false; // If false, send relay command
          boolean MowerHome = true; // If false, send relay command
          // unsigned long LOOP_PAUSE = 10000; // Sleep or wait time between reads (in milliseconds) 30000
          int lastMoistureValue = -1;
          int lastRainValue = -1;
          uint16_t lastlux;
          int lastDist;
          boolean metric = true;
          #define CHILD_ID1 1 // ID of the sensor child
          #define CHILD_ID2 2 // ID of the sensor child
          #define CHILD_ID3 3 // ID of the sensor child
          #define CHILD_ID4 4 // ID of the sensor child
          MyMessage msg1(CHILD_ID1, V_TRIPPED); // Setup message
          MyMessage msg2(CHILD_ID2, V_TRIPPED); // Setup message
          MyMessage msg3(CHILD_ID3, V_LEVEL); // Setup message
          MyMessage msg4(CHILD_ID4, V_DISTANCE); // Setup message
            sendSketchInfo("R+M+T+H+L+D+U", "1.0");
            wait(RADIO_PAUSE);
            present(CHILD_ID1, S_MOTION);
            wait(RADIO_PAUSE);
            present(CHILD_ID2, S_MOTION);
            wait(RADIO_PAUSE);
            present(CHILD_ID3, S_LIGHT_LEVEL);
            wait(RADIO_PAUSE);
            present(CHILD_ID4, S_DISTANCE);
            wait(RADIO_PAUSE);
            // Set the moisture sensor digital pin as input
            pinMode(DIGITAL_INPUT_MOISTURE, INPUT);
            // Set the rain sensor digital pin as input
            pinMode(DIGITAL_INPUT_RAIN, INPUT);
            // Set the moisture sensor power pin as output
            pinMode(MOISTURE_POWER_PIN, OUTPUT);
            // Set the rain sensor power pin as output
            pinMode(RAIN_POWER_PIN, OUTPUT);
            // Set to LOW so no power is flowing through the moisture sensor
            digitalWrite(MOISTURE_POWER_PIN, LOW);
            // Set to LOW so no power is flowing through the rain sensor
            digitalWrite(RAIN_POWER_PIN, LOW);
            // Check gateway for metric setting
            boolean metric = getConfig().isMetric;
            // Start BH1750 light sensor
            lightSensor.begin();
            // Start NeoPixel
            strip1.begin();
            // Initialize all pixels to 'off'
            strip1.show();
              //--- Moisture sensor ---//
              digitalWrite(MOISTURE_POWER_PIN, HIGH); // Turn moisture power pin on
              wait(200); // Set a delay to ensure the moisture sensor has powered up
              int moistureValue = digitalRead(DIGITAL_INPUT_MOISTURE); // Read digital moisture value
              digitalWrite(MOISTURE_POWER_PIN, LOW); // Turn moisture power pin off
              if (moistureValue != lastMoistureValue)
          #ifdef MY_DEBUG
                Serial.print("Moisture Sensor: ");
                Serial.println(moistureValue == 0 ? 1 : 0);
                send(msg1.set(moistureValue == 0 ? 1 : 0)); // Send the inverse
                wait(RADIO_PAUSE);
                lastMoistureValue = moistureValue; // For testing can be 0 or 1 or back to moistureValue
            wait(SENSORS_DELAY); // Wait between sensor readings, seems to help reliability of second reading
              //--- Rain sensor ---//
              digitalWrite(RAIN_POWER_PIN, HIGH); // Turn rain power pin on
              int rainValue = digitalRead(DIGITAL_INPUT_RAIN); // Read digital rain value
              digitalWrite(RAIN_POWER_PIN, LOW); // Turn rain power pin off
              if (rainValue != lastRainValue) // Check value against saved value
          #ifdef MY_DEBUG
                Serial.print("Rain Sensor: ");
                Serial.println(rainValue == 0 ? 1 : 0);
                send(msg2.set(rainValue == 0 ? 1 : 0)); // Send the inverse
                wait(RADIO_PAUSE);
                lastRainValue = rainValue; // For testing can be 0 or 1 or back to rainValue
              //--- Light sensor ---//
              uint16_t lux = lightSensor.readLightLevel(); // Get Lux value
              if (lux != lastlux)
          #ifdef MY_DEBUG
                Serial.print("LUX: ");
                Serial.println(lux);
                send(msg3.set(lux));
                wait(RADIO_PAUSE);
                lastlux = lux;
              //--- Distance sensor ---//
              int dist = metric ? sonar.ping_cm() : sonar.ping_in();
              if (dist != lastDist)
          #ifdef MY_DEBUG
                Serial.print("Distance: ");
                Serial.print(dist); // Convert ping time to distance in cm and print result (0 = outside set distance range)
                Serial.println(metric ? " cm" : " in");
                send(msg4.set(dist));
                wait(RADIO_PAUSE);
                lastDist = dist;
            //--- Analyse readings and set neopixel & booleans ---//
            if (lastMoistureValue == 0 ? 1 : 0 == 1 || lastRainValue == 0 ? 1 : 0 == 1)
              MowerWaiting = true;
          #ifdef MY_DEBUG
              Serial.print("Mower Waiting: ");
              Serial.println(MowerWaiting);
              strip1.setPixelColor(0, 255, 0, 0);
              strip1.setPixelColor(1, 255, 0, 0);
              strip1.setPixelColor(2, 255, 0, 0);
              strip1.setPixelColor(3, 255, 0, 0);
              strip1.show();
          #ifdef MY_DEBUG
              strip1.setPixelColor(0, 0, 255, 0);
              strip1.setPixelColor(1, 0, 255, 0);
              strip1.setPixelColor(2, 0, 255, 0);
              strip1.setPixelColor(3, 0, 255, 0);
              strip1.show();
            if (lastDist < 60)
              MowerHome = true;
          #ifdef MY_DEBUG
              Serial.print("Mower Home: ");
              Serial.println(MowerHome);
              strip1.setPixelColor(4, 0, 255, 0);
              strip1.setPixelColor(5, 0, 255, 0);
              strip1.setPixelColor(6, 0, 255, 0);
              strip1.setPixelColor(7, 0, 255, 0);
              strip1.show();
              MowerHome = false;
          #ifdef MY_DEBUG
              strip1.setPixelColor(4, 255, 0, 0);
              strip1.setPixelColor(5, 255, 0, 0);
              strip1.setPixelColor(6, 255, 0, 0);
              strip1.setPixelColor(7, 255, 0, 0);
              strip1.show();
            wait(LOOP_PAUSE); // Sleep or wait (repeater)
          Basically
          then reset the timer, else countdown from 4 hours and display the countdown....?
          • Mark SwiftM
            Mark SwiftM
            Mark Swift
            @TheoL I thought as much, I've posted an example of what I'm trying to achieve above, this particular node with only wait (using the MySensors wait) will this make it easier?
            TheoLT 1 Reply Last reply
            • T
              tomkxy
              You can use in addition a real time clock like the DS1307.
                TheoLT
                TheoLT
                TheoL
                @Mark-Swift I'll look at your code later on. I'm just having a short lunch break. Since you'e using MQTT, things are much easier. You can implement the timing stuff completely in NoeRed. I love MQTT and node red.
                • Mark SwiftM
                  Mark SwiftM
                  Mark Swift
                  @TheoL Thank you!
                    Hi Guys,
                    Any ideas?
                    AWIA
                    AWIA
                    AWI
                    wrote on last edited by AWI
                    @Mark-Swift The easiest way to implement a time during sleep (independent from a controller) is count the number of sleep and multiply by the sleep time.
                    or a more straightforward example:
                    unsigned long loopTimer ;
                    loopTimer  = 0 ;
                    void loop(){
                    unsigned long now = millis() ;
                    // whatever
                    // end whatever
                    loopTimer += now ;
                    gw.sleep(sleepTime);
                    loopTimer += sleepTime ;
                    • Mark SwiftM
                      Mark SwiftM
                      Mark Swift
                      @AWI That's very interesting. I had considered something like that but couldn't figure out how I'd do it.
                      Basically, what I'd like to do is have the Arduino light up the neopixel with the remaining hours, i.e. 4 hours, show 4 red LEDS. Not having to reply on a controller for such a simple task seems a bonus. If possible I'll also send the remaining time back to the controller also.
                      Now I just need to figure out how to apply your timer example to my code, oh dear.
                      @AWI If you're feeling generous ;-)
                      AWIA 1 Reply Last reply
                        AWIA
                        AWIA
                        AWI
                        @Mark-Swift I'm feeling generous... but the challenge is yours...:laughing: .
                        If a precision of a few milliseconds is not essential then my idea would be to implement a counter which increments every loop.
                        If the counter reaches 1 hour (3600 s equals ? times the loopDelay) light up the first, etc.
                        • Mark SwiftM
                          Mark SwiftM
                          Mark Swift
                          • Mark SwiftM
                            Mark SwiftM
                            Mark Swift
                            Well, I've been trying and haven't come up with anything that works so far... Crap.
                            • m26872M
                              m26872M
                              m26872
                              It looks like you don't need to sleep, i.e. the node isn't battery powered. Then it should be very easy by using the basic millis() counter method. http://forum.mysensors.org/topic/630/gateway-sensor-range-advice/12
                              • Mark SwiftM
                                Mark SwiftM
                                Mark Swift
                                @m26872 Would you perhaps be able to point me in the right direction with regards my sketch?
                                Basically, if
                                reset timer and set MowerWaiting to true (I guess?)
                                after 1 hour light led 1, after 2 hours light led 2, after 3 hours light led 3, after 4 hours light led 4 (and ideally switch MowerWaiting to false)
                                Cheers, Mark
                                  Basically, if
                                  Cheers, Mark
                                  TheoLT
                                  TheoLT
                                  TheoL
                                  wrote on last edited by TheoL
                                  @Mark-Swift Why not make things simple (I love simple things).
                                  if (lastMoistureValue == 0 ? 1 : 0 == 1 || lastMoistureValue == 0 ? 1 : 0 == 1)
                                  Is something that I would code differently. What you are saying is:
                                  if ( inverted value of lastMoistureValue == 1 <-- meaning moisturevalue = 0
                                  or
                                  if ( inverted value of lastMoisterValue == 1 <-- meaning moistureValue = 0
                                  Which basically is a double check for the same. If you'd want to do something when the lastMoistureValue = 0 it would be more logic and simple to say
                                  if ( lastMoistureValue == 0 ) {
                                  But I don't have the time to read this complete thread. To me it always help to write things in pseudo code first. Especially when I have to code a complex algorithm. Like
                                  1. if the lastMoistureValue is off (I presume 0 is off) then do
                                  2. ....
                                  And then I translate the pseudo code to C code.
                                  An algorithm for handling timers could be:
                                  1. If something/sensor value starts a timer.
                                  2. store current time in timerStartVariable
                                  3. if firstTimerElapsed
                                  4. light up led1
                                  5. if secondTimerElapsed
                                  6. light up led2
                                  7. ...... and so on
                                  8. if timer needs reset
                                  9. disable timer mechanism
                                  This gives me lots of insights in what I'd need to code. And there are a lot of different ways you can accomplish this. But for the sake of simplicity I'm not going to use arrays and stuff like that. That is something you can do later on - I'd do immediately, but I wrote my first program 36 years ago on a commodore 64. So I have some experience with software development.
                                  #define firstTimer 36000000 // 60 minutes * 60 seconds * 1000 millis
                                  #define secondTimer 7200000 // 2 times first timer is 2 hours
                                  .... // and so on
                                  bool timerActive =  false; // state for timer active
                                  unsigned long timerStart = 0; // variable for remembering when the timer was triggered
                                  bool timer1Handled = false;
                                  bool timer2Handled = false;
                                      if ( timerActive == false && timerNeedsToBeActivated ) { // don't know how you want to trigger it
                                          timerActive = true;
                                          timerStart = millis();
                                      if ( timerActive == true ) { // check whether a timer has ellapsed
                                          unsigned long cm = millis();
                                          if ( timerStart + firstTimer > cm && timer1Handled == false ) {
                                              timer1Handled = true;
                                              // light up led1
                                          if ( timerStart + secondTimer > cm && timer2Handled == false ) {
                                              timer2Handled = true;
                                              // light up led1
                                          if ( timerNeedsToBeStopped ) {
                                  Now this might not be the best way to code this algorithm. And I haven't checked if it compiles. But I hope this is what you're looking for. And if so I hope it helped the way I translate an algorithm to a piece of software.
                                  Also there might be some small errors in the code. But I just did some development in Python for a course I'm following. And Python has a different syntax.
                                  • Mark SwiftM
                                    Mark SwiftM
                                    Mark Swift
                                    @Mark-Swift said:
                                    @TheoL I'll take a look at that and digest it, thank you so much for taking the time to reply.
                                    BTW, spot the typo! It was meant to read:
                                      TheoLT
                                      TheoLT
                                      TheoL
                                      @Mark-Swift My mistake sorry. But it would also make the code more readable by not doing the invert and just compare for the value.
                                      • Mark SwiftM
                                        Mark SwiftM
                                        Mark Swift
                                        @TheoL I've just tried implementing the code you gave into my sketch, strangely it seems to light all 3 LEDS on the first loop, even though checking the value of 'cm' it's obviously less than timerStarted + TIMERX, any ideas?
                                        Code:
                                        #include <BH1750.h>
                                        #define NEO_PIN 2
                                        #define NUM_LEDS 8
                                        Adafruit_NeoPixel strip1 = Adafruit_NeoPixel(NUM_LEDS, NEO_PIN, NEO_GRB + NEO_KHZ800);
                                        #define ECHO_PIN 3
                                        #define MAX_DISTANCE 400
                                        // Set BH1750 name
                                        BH1750 lightSensor;
                                        #define LOOP_PAUSE 10000
                                        #define RADIO_PAUSE 100  // This allows for radio to come back to power after a transmission, ideally 0..
                                        #define SENSORS_DELAY 100  // This allows for radio to come back to power after a transmission, ideally 0..
                                        boolean MowerHome = false; // If false, send relay command
                                        uint16_t lastlux;
                                        int lastDist;
                                        // Trial timer variables
                                        #define TIMER1 3200000 // 60 minutes * 60 seconds * 1000 millis
                                        #define TIMER2 7200000 // 120 minutes * 60 seconds * 1000 millis
                                        #define TIMER3 10800000 // 180 minutes * 60 seconds * 1000 millis
                                        bool timerActive =  false; // State for timer active
                                        unsigned long timerStarted = 0; // Variable for remembering when the timer was last triggered
                                        bool timer1Activated = false;
                                        bool timer2Activated = false;
                                        bool timer3Activated = false;
                                        // Define sensor children for MySensors
                                        // Define MySensors message formats
                                          wait(RADIO_PAUSE);
                                          wait(RADIO_PAUSE);
                                          wait(RADIO_PAUSE);
                                          wait(RADIO_PAUSE);
                                          wait(RADIO_PAUSE);
                                          // Start NeoPixel
                                          strip1.begin();
                                          strip1.show();
                                        #ifdef MY_DEBUG
                                              wait(RADIO_PAUSE);
                                        #ifdef MY_DEBUG
                                              wait(RADIO_PAUSE);
                                            if (lux != lastlux)
                                        #ifdef MY_DEBUG
                                              wait(RADIO_PAUSE);
                                              lastlux = lux;
                                        #ifdef MY_DEBUG
                                              wait(RADIO_PAUSE);
                                              lastDist = dist;
                                          if (lastMoistureValue == 0 || lastRainValue == 0)
                                        #ifdef MY_DEBUG
                                          if ( timerActive == false && MowerWaiting == true ) // Logic for timer trigger
                                            timerActive = true;
                                            timerStarted = millis();
                                            strip1.show();
                                        #ifdef MY_DEBUG
                                            Serial.print("Mower Is Waiting: ");
                                            Serial.println("Activating Countdown");
                                        #ifdef MY_DEBUG
                                            Serial.print("Countdown: ");
                                            Serial.println("Active");
                                            if ( timerStarted + TIMER1 < cm && timer1Activated == false )
                                              timer1Activated = true;
                                              strip1.setPixelColor(3, 0, 0, 0);
                                              strip1.show();
                                        #ifdef MY_DEBUG
                                              Serial.print("3 Hours Left: ");
                                              Serial.println("");
                                            if ( timerStarted + TIMER2 < cm && timer2Activated == false )
                                              timer2Activated = true;
                                              strip1.setPixelColor(2, 0, 0, 0);
                                              strip1.show();
                                        #ifdef MY_DEBUG
                                              Serial.print("2 Hours Left: ");
                                              Serial.println("");
                                            if ( timerStarted + TIMER3 < cm && timer3Activated == false )
                                              timer3Activated = true;
                                              strip1.setPixelColor(1, 0, 0, 0);
                                              strip1.show();
                                        #ifdef MY_DEBUG
                                              Serial.print("1 Hours Left");
                                              Serial.println("");
                                            if ( cm > 14400000 )
                                              strip1.show();
                                        #ifdef MY_DEBUG
                                              Serial.print("Mower Is No Longer Waiting: ");
                                              Serial.println("Stopping Timer");
                                          if (lastDist < 60)
                                            MowerHome = true;
                                        #ifdef MY_DEBUG
                                            strip1.setPixelColor(4, 0, 127, 0);
                                            strip1.setPixelColor(5, 0, 127, 0);
                                            strip1.setPixelColor(6, 0, 127, 0);
                                            strip1.setPixelColor(7, 0, 127, 0);
                                            strip1.show();
                                            MowerHome = false;
                                        #ifdef MY_DEBUG
                                            strip1.show();
                                        Edit: I'm guessing the IF command should be "<" rather than ">" , fixed that. Check the code above for what I'm working on.
                                        The issue I see right now is that if either moisture or rain is detected the mower timer will be reset each loop (that's okay), how can I also reset the countdown timer you created that I've implemented so they're in sync?
                                          Code:
                                          #include <BH1750.h>
                                          #define NEO_PIN 2
                                          #define NUM_LEDS 8
                                          #define ECHO_PIN 3
                                          // Set BH1750 name
                                          BH1750 lightSensor;
                                          uint16_t lastlux;
                                          int lastDist;
                                            wait(RADIO_PAUSE);
                                            wait(RADIO_PAUSE);
                                            wait(RADIO_PAUSE);
                                            wait(RADIO_PAUSE);
                                            wait(RADIO_PAUSE);
                                            // Start NeoPixel
                                            strip1.begin();
                                            strip1.show();
                                          #ifdef MY_DEBUG
                                                wait(RADIO_PAUSE);
                                          #ifdef MY_DEBUG
                                                wait(RADIO_PAUSE);
                                              if (lux != lastlux)
                                          #ifdef MY_DEBUG
                                                wait(RADIO_PAUSE);
                                                lastlux = lux;
                                          #ifdef MY_DEBUG
                                                wait(RADIO_PAUSE);
                                                lastDist = dist;
                                          #ifdef MY_DEBUG
                                              timerActive = true;
                                              strip1.show();
                                          #ifdef MY_DEBUG
                                          #ifdef MY_DEBUG
                                                strip1.show();
                                          #ifdef MY_DEBUG
                                                Serial.println("");
                                                strip1.show();
                                          #ifdef MY_DEBUG
                                                Serial.println("");
                                                strip1.show();
                                          #ifdef MY_DEBUG
                                                Serial.println("");
                                                strip1.show();
                                          #ifdef MY_DEBUG
                                            if (lastDist < 60)
                                              MowerHome = true;
                                          #ifdef MY_DEBUG
                                              strip1.show();
                                              MowerHome = false;
                                          #ifdef MY_DEBUG
                                              strip1.show();
                                          TheoLT
                                          TheoLT
                                          TheoL
                                          @Mark-Swift It's hard to help, sence the sketch is getting large. But From what I'm seeing, you do not store the lastvalues. You allways assing 0 to them
                                          #ifdef MY_DEBUG
                                                wait(RADIO_PAUSE);
                                          //      lastRainValue = 0; // For testing can be 0 or 1 or back to rainValue
                                                  lastRainValue = rainValue; // remember the last value we've read
                                          That would be my first step. If you don't change it, then the sketch will only respond to the sensor's reporting 1.
                                          Also, when the timer is being started you set all led's with a max of 255 for the RED led. If I'm not mistaken, you wanted them to be off. So set the RED value also to 0.
                                          We'll get there step by step.
