  3. Multisensor PIR based on IKEA Molgan
112 Posts 21 Posters 71.9k Views 37 Watching
  • tbowmoT
    tbowmoT
    tbowmo
    Just looked up "Molgan" on ikea.com, it doesn't say anything about including PIR / Motion detection? Only that it's a LED lamp
    How well does it work with the large Fresnel lens?
    • tbowmoT tbowmo
      TimO
      @tbowmo I got hooked up too :D and found this: http://www.terenceang.com/archives/31
      dynamiteD 1 Reply Last reply
      • dynamiteD
        dynamiteD
        dynamite
        So far I do not see a big difference with the Original smaller lens. Although the detection from the side is limited. But that's about the same as the Original.
        Inside there is a PIR in combination with 5 leds and a photodiode. As soon as it gets dark the PIR is active and as soon as movement is detected the leds are switched on for about 30 sec.
        The IKEA PIR is based on BIS0001 chip, which is a very common chip. When High it has an output of about 1,8 volt. Via a transistor the leds are switch on. Although there are three batteries in the housing the PIR runs also very well on two. (3.3 volt)
        • T TimO
          dynamiteD
          dynamiteD
          dynamite
          wrote on last edited by dynamite
          @TimO Yes if have read this post too, but here he has used an optocoupler. Which is not necessary if you reduce the input to 3 volt... makes it more easy. Or even use the 1,8 volt as input. But don't short circuit it with the input pin next to it.... as the PIR will stay high forever.:smiling_imp:
            @dynamite
            nice clean hack :)
            Could you tell me what is the overall thickness please? I think I will try to buy one just to see how fit some of my multisensors boards inside..even if i will use 3d printing which cost less $ in plastic, it's still a very nice alternative to have at hand.
            Maybe you could use some i2c sensors to improve your power consumption.
            Thx for your share ;)
            • dynamiteD dynamite
              I have created a Multi sensor PIR including a dallas temp measurement and LDR light measurment. For the PIR I wanted to use the Original PIR but it got "destroyed" during my investigation. The Pir runs on two AAA as I have removed the voltage regulator on my arduino pro mini.
              2_1461762533494_image3.jpg0_1461765109880_image5.jpg 1_1461762533494_image2.jpg
              @dynamite Great hack!
              Especially when using the combination of original PIR, enclosure and battery holder for E 5,-.
              Can't be beaten! :+1:
              • YveauxY Yveaux
                dynamiteD
                dynamiteD
                dynamite
                @Yveaux And very easy to detach as it has a base plate as well...
                • scalzS scalz
                  @dynamite
                  nice clean hack :)
                  dynamiteD
                  dynamiteD
                  dynamite
                  @scalz What dimensions are you exactly looking for?
                  Here you have some photos:
                    @dynamite awesome, thx :)
                    oh no, please no more pics :yum: lol it's very cool hack :heart_eyes:
                    • tbowmoT
                      tbowmoT
                      tbowmo
                      Think I have to visit ikea tomorrow, and bring home a couple of samples :)
                      Only about 5$...
                      • tbowmoT tbowmo
                        Only about 5$...
                        dynamiteD
                        dynamiteD
                        dynamite
                        @tbowmo I think I am going to buy some IKEA shares....:grinning:
                          7€ here...french conversion :angry:
                          it's at one hour from my home..but I think I will visit too this weekend. well done, now I can't wait :)
                          • scalzS scalz
                            dynamiteD
                            dynamiteD
                            dynamite
                            @scalz @tbowmo Looking forward to see you results! Now that my prototype is finished of course I am going to buy some more as well. Here "only" €4,99 for an item
                            • F
                              F
                              Floca
                              is it possible to describe, how to wire the original PIR, with the Arduino?
                              I have some Molgan's here and want to mod them, if i can use the original PIR, it would be perfect :)
                              Maybe an HowTo?
                              Many Thanks
                              • F Floca
                                Maybe an HowTo?
                                Many Thanks
                                dynamiteD
                                dynamiteD
                                dynamite
                                @Floca hi the Original Ikea Pir, I kind of destroyed during the "investigation". I my previous post I have posted a picture of the pir inside. I would feed the pir with either 2 or 3 batteries. (3/4,5v) after that you can either use the signal directly after the chip. Th is is 1,8v but I don't know if the arduino takes that as high..? If not you can take the signal at the resistors of the LEDs. The voltage level here is depending on your battery infeed. So either 3v or 4,5v. Don't think both will be a problem for the arduino. To eliminate the led you can take away one or more resistors.
                                Maybe somebody can say more
                                About the allowable Voltage levels. For battery live a 3v pro mini would be better. For ease of use a 5v version would be better
                                  dynamiteD
                                  dynamiteD
                                  dynamite
                                  After I have bought some new one I will try to make a how to....
                                  • rhuehnR
                                    rhuehnR
                                    rhuehn
                                    PLEASE! A How to would be amazing! Looking forward to it!
                                    • dynamiteD
                                      dynamiteD
                                      dynamite
                                      I now have a fresh supply of Molgan to be modified. And I will post my modification of the existing board soon. Status I can now use the input of the existing PIR signal. And I have discovered that by sending out a high or low on one of the arduino pins I can switch the existing LED on / off. Of course I can use a relay function to control but as it is running on batteries the sensor has to sleep. I was thinking of sending out a parameter (true / false) which enables the sensor to activate the LED on a trigger of the PIR. How could I send over this parameter? Any (creative) idea's as the sensor is sleeping most of the time?
                                      Now I am thinking of it, could it be possible that such a value is read by the sensor when the sensor is getting out of the sleep function.
                                      • DidiD
                                        DidiD
                                        Didi
                                        Cool can´t wait for this,have bought 6 Molgans last week :+1:
                                        • DidiD Didi
                                          dynamiteD
                                          dynamiteD
                                          dynamite
                                          @Didi Nice, I only bought four ....:smiley:
