  3. Multisensor PIR based on IKEA Molgan
112 Posts 21 Posters 71.9k Views 37 Watching
  • dynamiteD dynamite
    I have created a Multi sensor PIR including a dallas temp measurement and LDR light measurment. For the PIR I wanted to use the Original PIR but it got "destroyed" during my investigation. The Pir runs on two AAA as I have removed the voltage regulator on my arduino pro mini.
    2_1461762533494_image3.jpg0_1461765109880_image5.jpg 1_1461762533494_image2.jpg
    @dynamite Great hack!
    Especially when using the combination of original PIR, enclosure and battery holder for E 5,-.
    Can't be beaten! :+1:
    dynamiteD 1 Reply Last reply
    • YveauxY Yveaux
      dynamiteD
      dynamiteD
      dynamite
      @Yveaux And very easy to detach as it has a base plate as well...
      • scalzS scalz
        @dynamite
        nice clean hack :)
        Could you tell me what is the overall thickness please? I think I will try to buy one just to see how fit some of my multisensors boards inside..even if i will use 3d printing which cost less $ in plastic, it's still a very nice alternative to have at hand.
        Maybe you could use some i2c sensors to improve your power consumption.
        Thx for your share ;)
        dynamiteD
        dynamiteD
        dynamite
        @scalz What dimensions are you exactly looking for?
        Here you have some photos:
          @dynamite awesome, thx :)
          oh no, please no more pics :yum: lol it's very cool hack :heart_eyes:
          • tbowmoT
            tbowmoT
            tbowmo
            Think I have to visit ikea tomorrow, and bring home a couple of samples :)
            Only about 5$...
            • tbowmoT tbowmo
              Only about 5$...
              dynamiteD
              dynamiteD
              dynamite
              @tbowmo I think I am going to buy some IKEA shares....:grinning:
                7€ here...french conversion :angry:
                it's at one hour from my home..but I think I will visit too this weekend. well done, now I can't wait :)
                • scalzS scalz
                  dynamiteD
                  dynamiteD
                  dynamite
                  @scalz @tbowmo Looking forward to see you results! Now that my prototype is finished of course I am going to buy some more as well. Here "only" €4,99 for an item
                  • F
                    F
                    Floca
                    is it possible to describe, how to wire the original PIR, with the Arduino?
                    I have some Molgan's here and want to mod them, if i can use the original PIR, it would be perfect :)
                    Maybe an HowTo?
                    Many Thanks
                    • F Floca
                      Maybe an HowTo?
                      Many Thanks
                      dynamiteD
                      dynamiteD
                      dynamite
                      @Floca hi the Original Ikea Pir, I kind of destroyed during the "investigation". I my previous post I have posted a picture of the pir inside. I would feed the pir with either 2 or 3 batteries. (3/4,5v) after that you can either use the signal directly after the chip. Th is is 1,8v but I don't know if the arduino takes that as high..? If not you can take the signal at the resistors of the LEDs. The voltage level here is depending on your battery infeed. So either 3v or 4,5v. Don't think both will be a problem for the arduino. To eliminate the led you can take away one or more resistors.
                      Maybe somebody can say more
                      About the allowable Voltage levels. For battery live a 3v pro mini would be better. For ease of use a 5v version would be better
                        dynamiteD
                        dynamiteD
                        dynamite
                        After I have bought some new one I will try to make a how to....
                        • rhuehnR
                          rhuehnR
                          rhuehn
                          PLEASE! A How to would be amazing! Looking forward to it!
                          • dynamiteD
                            dynamiteD
                            dynamite
                            wrote on last edited by dynamite
                            I now have a fresh supply of Molgan to be modified. And I will post my modification of the existing board soon. Status I can now use the input of the existing PIR signal. And I have discovered that by sending out a high or low on one of the arduino pins I can switch the existing LED on / off. Of course I can use a relay function to control but as it is running on batteries the sensor has to sleep. I was thinking of sending out a parameter (true / false) which enables the sensor to activate the LED on a trigger of the PIR. How could I send over this parameter? Any (creative) idea's as the sensor is sleeping most of the time?
                            Now I am thinking of it, could it be possible that such a value is read by the sensor when the sensor is getting out of the sleep function.
                            • DidiD
                              DidiD
                              Didi
                              Cool can´t wait for this,have bought 6 Molgans last week :+1:
                              • DidiD Didi
                                dynamiteD
                                dynamiteD
                                dynamite
                                @Didi Nice, I only bought four ....:smiley:
                                • rollercontainerR
                                  rollercontainerR
                                  rollercontainer
                                  In development branch there is a smartsleep function for receiving while sleeping (if I get it right)
                                  • rollercontainerR rollercontainer
                                    dynamiteD
                                    dynamiteD
                                    dynamite
                                    #23
                                    @rollercontainer I could use the wait function
                                    • Wait for a specified amount of time to pass or until specified message received. Keeps process()ing.
                                    • This does not power-down the radio nor the Arduino.
                                    • Because this calls process() in a loop, it is a good way to wait
                                    • in your loop() on a repeater node or sensor that listens to messages.
                                    • @param ms Number of milliseconds to sleep.
                                    • @param cmd Command of incoming message.
                                    • @param msgtype Message type.
                                      void wait(unsigned long ms, uint8_t cmd, uint8_t msgtype);
                                    And wait for a message, which is send out by the controller (by a rule) after receiving the PIR trigger. But it is a kind of waste of energy to wait for a signal which is not frequently used. As far as I can read in the code this is exactly what smart sleep does. But can how can prepare a reply by the gateway that will respond to such a heartbeat?
                                      dynamiteD
                                      dynamiteD
                                      dynamite
                                      #24
                                      It is unfortunately not a full How-To yet. But basically the IKEA PIR is ready for operation.
                                      • The PIR Runs on 3 Volt. There is a power regulator (U1). I am going to keep the 3 AAA batteries so I keep the regulator on the board.
                                      • I have removed the resistor (R17) and attached two wires to both the Original ends on the board. The one closest to the BISS0001 is your PIR signal. 3V when high and 0V for low. The other wire can be used to control the lights on the board. The wire is connected to the Q1 NPN transistor. Basically 3V high is on and 0V is off. But maybe you will also be able to dim the lights.
                                      • You also need to remove Resistor R11. The Original value is about 620 K and this will result in 30 seconds of ON after triggering. I have replaced it with 100 K and now it is about 5 seconds, a further reduction whill shorten this time lineair. So 10K = 0,5 sec. The PIR itself is retriggered.
                                      • With resistor R10 is controlling the time that the PIR cannot be triggered after a trigger. It is now approx 10K = 0,5 sec. So no need to change.
                                      • You need also to remove the photodiode on the front. Otherwise the PIR is only triggered when it is dark.
                                      • The powerconsumption of the PIR when not triggered is approx. 60 uA and when triggered 160 uA. So this is about the same as the standard PIR's. When the lights are activated the consumption is about 36 mA.
                                      • The PIR (without the hood) is quite sensitive. Even the slightest movement is already triggering the PIR.
                                        #25
                                        @dynamite Nice work!
                                        I'm currently working on the following Molgan hack:
                                        It is a small PCB (the red board) that overlays the original Molgan PCB.
                                        The original PIR & electronics stay in place.
                                        LEDs will remain functional (if you want) or can be partially removed to improve battery life, or completely to turn it into a motion-sensor only.
                                        It uses an SMD nRF24 module, has a mounting spot for SHA204A, FTDI and ISP connectors.
                                        The layout is currently at the board house.
                                        I'll report back when I get the PCBs and build one!
                                        • YveauxY Yveaux
                                          dynamiteD
                                          dynamiteD
                                          dynamite
                                          @Yveaux NICE! Can I get the files for the board as a sneak preview? Do you get the PIR signal / Light control from the same place as I was indicating?
