  3. Re-assign ID
Re-assign ID
myscontrollerreassign id
3 Posts 2 Posters 3.7k Views 1 Watching
  • D
    dzairo
    Hi.
    I try find in this formum solution why not possible manualy reassign new id to my node.
    I use Ethernet Gateway with MYSController 0.1.2.282 .
    I can Assign new firmware from list .. work perfect .. but if try change - reassign new ID then still use same ..
    In sketch is :
    this define auto .. then not problem to reassign .. I think ..
    If try it manualy also not working .. if try .. clear eeprom ...and must automatic reassign .. still use same ID ..
    regards.
    tekkaT 1 Reply Last reply
    • D dzairo
      Hi.
      In sketch is :
      regards.
      tekkaT
      tekkaT
      tekka
      @dzairo please provide logs with debug enabled.
      • D
        dzairo
         [2016-04-27 20:55:10.973 Info] INFO	*** Logging START ***
         [2016-04-27 20:55:10.974 Info] VERSION	MYSController 0.1.2.282
         [2016-04-27 20:55:33.569 Info] NODE	New node discovered, node id=2
         [2016-04-27 20:55:33.570 Info] CHILD	New child discovered, node id=2, child id=internal
         [2016-04-27 20:55:33.570 Info] DEBUG	Assigned firmware=Blink to node=2
         [2016-04-27 20:55:33.571 Info] INFO	BL version=257
         [2016-04-27 20:55:33.572 Info] INFO	Send FW info to node 2: type=A, version=1, blocks=0x02C8, CRC=0xB718
         [2016-04-27 20:55:33.573 Info] TX	2;0;4;0;1;0A000100C80218B7
         [2016-04-27 20:55:33.574 Info] RX	2;255;4;0;0;0A000100C80218B70101
         [2016-04-27 20:55:33.655 Info] SIGNING	Node 2 does not require signing
         [2016-04-27 20:55:33.656 Info] SIGNING	MYSController is not signing
         [2016-04-27 20:55:33.656 Info] TX	2;255;3;0;15;0
         [2016-04-27 20:55:33.658 Info] RX	2;255;3;0;15;0
         [2016-04-27 20:55:33.658 Info] DEBUG	Update child id=255, type=ARDUINO_NODE
         [2016-04-27 20:55:33.659 Info] RX	2;255;0;0;17;1.5.4
         [2016-04-27 20:55:33.662 Info] TX	2;255;3;0;6;M
         [2016-04-27 20:55:33.663 Info] RX	2;255;3;0;6;0
         [2016-04-27 20:55:35.671 Info] RX	2;255;3;0;11;Bin.Sensor Sleep
         [2016-04-27 20:55:35.674 Info] RX	2;255;3;0;12;1.0
         [2016-04-27 20:55:35.676 Info] CHILD	New child discovered, node id=2, child id=3
         [2016-04-27 20:55:35.677 Info] DEBUG	Update child id=3, type=DOOR
         [2016-04-27 20:55:35.678 Info] RX	2;3;0;0;0;
         [2016-04-27 20:55:35.679 Info] CHILD	New child discovered, node id=2, child id=4
         [2016-04-27 20:55:35.679 Info] DEBUG	Update child id=4, type=DOOR
         [2016-04-27 20:55:35.681 Info] RX	2;4;0;0;0;
         [2016-04-27 20:55:35.722 Info] RX	2;3;1;0;16;1
         [2016-04-27 20:55:35.745 Info] RX	2;255;3;0;0;79
         [2016-04-27 20:55:40.876 Info] RX	2;4;1;0;16;0
         [2016-04-27 20:55:41.375 Info] RX	2;4;1;0;16;1
         [2016-04-27 20:55:42.819 Info] RX	2;3;1;0;16;0
         [2016-04-27 20:55:43.461 Info] RX	2;3;1;0;16;1
         [2016-04-27 20:55:54.189 Info] TX	2;0;3;0;13;0
         [2016-04-27 20:56:13.510 Info] REPO	FW "Blink" loaded. t=10, v=1, blocks=712, crc=0xB718
         [2016-04-27 20:56:13.523 Info] REPO	FW "TimeReporter" loaded. t=20, v=1, blocks=840, crc=0x4AC5
         [2016-04-27 20:56:13.542 Info] REPO	FW "Sensebender Micro" loaded. t=100, v=1, blocks=1344, crc=0x3482
         [2016-04-27 20:56:13.552 Info] REPO	FW "Sensebender Blink" loaded. t=110, v=1, blocks=768, crc=0x1314
         [2016-04-27 20:56:13.552 Info] REPO	FW repository loaded. Items=4
         [2016-04-27 20:56:17.551 Info] TX	2;0;3;0;13;0
         [2016-04-27 20:57:00.075 Info] CHILD	New child discovered, node id=2, child id=3
         [2016-04-27 20:57:00.076 Info] RX	2;3;1;0;16;0
         [2016-04-27 20:57:00.439 Info] RX	2;3;1;0;16;1
         [2016-04-27 20:57:02.092 Info] CHILD	New child discovered, node id=2, child id=4
         [2016-04-27 20:57:02.094 Info] RX	2;4;1;0;16;0
         [2016-04-27 20:57:02.363 Info] RX	2;4;1;0;16;1
