  3. Is it possible to use ESP8266's OTA capabilities?
20 Posts 6 Posters 12.2k Views 10 Watching
  • AndurilA Anduril
    @tekka do you have and NodeMCU Devkit 0.9 or 1.0? I have a 1.0 and get the error. But I use it with fixed IP on the gateway sketch, maybe that's a problem. It uploads ok via serial. But when uploading via wifi (changed static ip for testing) it stuck. Maybe I will try it with dhcp enabled.
    tekkaT
    tekkaT
    tekka
    @Anduril I'm using a NodeMCU 1.0 (MySensors 2.0.0beta and ESP8266 lib 2.1.0) with fixed IP. Both, OTA and serial FW updates work flawlessly...
    • AndurilA
      AndurilA
      Anduril
      @tekka thanks for that info, I'm also using MySensors 2 beta but ESP lib 2.0 (as far as I know, corrently at work). I will check that later and test with updated ESP library.
      • AndurilA
        AndurilA
        Anduril
        @tekka did you changed any of the standard settings for ESP flashing? I simply updated ESP8266 library and reflashed, but I get an reboot loop. In the serial monitor I see:
        0‚~?–4“Ò¶£ÿOAaû0;255;3;0;9;Starting gateway (RNNGE-, 2.0.0-beta)
        scandone
        state: 0 -> 2 (b0)
        state: 2 -> 3 (0)
        state: 3 -> 5 (10)
        add 0
        aid 2
        cnt
        connected with mDjEKlujYacByG5JtxlY, channel 1
        ip:192.168.38.19,mask:255.255.255.0,gw:192.168.38.1
        .IP: 192.168.38.19
        ¥üÊæ” ×Åü1¤ñþ0;255;3;0;9;Starting gateway (RNNGE-, 2.0.0-beta)
        scandone
        state: 0 -> 2 (b0)
        When going back to 2.0.0 it works without problems. Here my settings for flashing:
        tekkaT 1 Reply Last reply
        • AndurilA Anduril
          scandone
          state: 0 -> 2 (b0)
          state: 2 -> 3 (0)
          state: 3 -> 5 (10)
          add 0
          aid 2
          cnt
          .IP: 192.168.38.19
          scandone
          state: 0 -> 2 (b0)
          tekkaT
          tekkaT
          tekka
          @Anduril I'm using the NodeMCU 1.0 (ESP-12E Module) settings / ESP 2.1.0 lib / and the latest MySensors dev (including PR#419 - there was indeed a rebooting issue before #419)...
          • AndurilA
            AndurilA
            Anduril
            thanks a lot, working with newest dev build and ESP8266 lib version 2.1.0 as you said.
            • AndurilA Anduril
              tekkaT
              tekkaT
              tekka
              @Anduril excellent! Have fun :)
              • R
                R
                Rasenheizung
                wrote on last edited by Rasenheizung
                I'm trying to use the serial monitor but I'm always ask entering a password? Although I didn't used one?
                Reflashing sketch via OTA worked without any issues.
                Edit: Tried to use a real OTA password and it's still not working although I'm using the correct. ESP8266 Tools 2.2.0
                • AndurilA
                  AndurilA
                  Anduril
                  to my last knowledge this feature is implemented but not working. If you want to see the serial monitor you have to connect physically.
                  • AndurilA Anduril
                    @Anduril
                    Regarding the bootloops: how you structure your code seems to have an effect. If you have busy-waits in your code, you're more likely to encounter the WDT timeout. I restructured my code to be more interrupt driven and to complete more frequent cycles through the main loop(). After doing that, the WDT timeouts stopped.
                    That said, I don't know whether your bootloop is caused by a WDT timeout or something else. At least in my case, the debug messages being printed in the serial window specifically mentioned WDT being involved.
                    • Mark SwiftM
                      Mark SwiftM
                      Mark Swift
                      I presume debugging via network is not supported, I read some posts on Github but couldn't be sure if it was implemented?
                      • Mark SwiftM Mark Swift
                        @Mark-Swift
                        By debugging, do you mean looking at the serial console output over the network, or something else?
                        Mark SwiftM 1 Reply Last reply
                          @Mark-Swift
                          Mark SwiftM
                          Mark SwiftM
                          Mark Swift
                          @NeverDie said:
                          @Mark-Swift
                          Yes, serial monitor via network within IDE...
                          • mfalkviddM
                            I haven't tried it yet but this plugin for serial monitor over network looks nice https://github.com/esp8266/Arduino/issues/1360
