  3. Is it possible to use ESP8266's OTA capabilities?
20 Posts 6 Posters 12.2k Views 10 Watching
  • AndurilA
    AndurilA
    Anduril
    @tekka did you used password protection for OTA update or any other security feature? Did you change anything in the sketch except SSID and password for wifi?
    tekkaT 1 Reply Last reply
    • AndurilA Anduril
      tekkaT
      tekkaT
      tekka
      wrote on last edited by tekka
      @Anduril No, I simply followed these instructions:
      https://github.com/esp8266/Arduino/blob/master/doc/ota_updates/readme.md and used this sketch for testing:
      https://github.com/mysensors/Arduino/tree/development/libraries/MySensors/examples/GatewayESP8266OTA
      • AndurilA
        AndurilA
        Anduril
        @tekka do you have and NodeMCU Devkit 0.9 or 1.0? I have a 1.0 and get the error. But I use it with fixed IP on the gateway sketch, maybe that's a problem. It uploads ok via serial. But when uploading via wifi (changed static ip for testing) it stuck. Maybe I will try it with dhcp enabled.
        • AndurilA Anduril
          tekkaT
          tekkaT
          tekka
          @Anduril I'm using a NodeMCU 1.0 (MySensors 2.0.0beta and ESP8266 lib 2.1.0) with fixed IP. Both, OTA and serial FW updates work flawlessly...
          • AndurilA
            AndurilA
            Anduril
            @tekka thanks for that info, I'm also using MySensors 2 beta but ESP lib 2.0 (as far as I know, corrently at work). I will check that later and test with updated ESP library.
            • AndurilA
              AndurilA
              Anduril
              @tekka did you changed any of the standard settings for ESP flashing? I simply updated ESP8266 library and reflashed, but I get an reboot loop. In the serial monitor I see:
              0‚~?–4“Ò¶£ÿOAaû0;255;3;0;9;Starting gateway (RNNGE-, 2.0.0-beta)
              scandone
              state: 0 -> 2 (b0)
              state: 2 -> 3 (0)
              state: 3 -> 5 (10)
              add 0
              aid 2
              cnt
              connected with mDjEKlujYacByG5JtxlY, channel 1
              ip:192.168.38.19,mask:255.255.255.0,gw:192.168.38.1
              .IP: 192.168.38.19
              ¥üÊæ” ×Åü1¤ñþ0;255;3;0;9;Starting gateway (RNNGE-, 2.0.0-beta)
              scandone
              state: 0 -> 2 (b0)
              When going back to 2.0.0 it works without problems. Here my settings for flashing:
              • AndurilA Anduril
                scandone
                state: 0 -> 2 (b0)
                state: 2 -> 3 (0)
                state: 3 -> 5 (10)
                add 0
                aid 2
                cnt
                .IP: 192.168.38.19
                scandone
                state: 0 -> 2 (b0)
                tekkaT
                tekkaT
                tekka
                @Anduril I'm using the NodeMCU 1.0 (ESP-12E Module) settings / ESP 2.1.0 lib / and the latest MySensors dev (including PR#419 - there was indeed a rebooting issue before #419)...
                • AndurilA
                  AndurilA
                  Anduril
                  thanks a lot, working with newest dev build and ESP8266 lib version 2.1.0 as you said.
                  • AndurilA Anduril
                    tekkaT
                    tekkaT
                    tekka
                    @Anduril excellent! Have fun :)
                    • R
                      R
                      Rasenheizung
                      wrote on last edited by Rasenheizung
                      I'm trying to use the serial monitor but I'm always ask entering a password? Although I didn't used one?
                      Reflashing sketch via OTA worked without any issues.
                      Edit: Tried to use a real OTA password and it's still not working although I'm using the correct. ESP8266 Tools 2.2.0
                      • AndurilA
                        AndurilA
                        Anduril
                        to my last knowledge this feature is implemented but not working. If you want to see the serial monitor you have to connect physically.
                        • AndurilA Anduril
                          @Anduril
                          Regarding the bootloops: how you structure your code seems to have an effect. If you have busy-waits in your code, you're more likely to encounter the WDT timeout. I restructured my code to be more interrupt driven and to complete more frequent cycles through the main loop(). After doing that, the WDT timeouts stopped.
                          That said, I don't know whether your bootloop is caused by a WDT timeout or something else. At least in my case, the debug messages being printed in the serial window specifically mentioned WDT being involved.
                          • Mark SwiftM
                            Mark SwiftM
                            Mark Swift
                            I presume debugging via network is not supported, I read some posts on Github but couldn't be sure if it was implemented?
                            • Mark SwiftM Mark Swift
                              @Mark-Swift
                              By debugging, do you mean looking at the serial console output over the network, or something else?
                              Mark SwiftM 1 Reply Last reply
                                @Mark-Swift
                                Mark SwiftM
                                Mark SwiftM
                                Mark Swift
                                @NeverDie said:
                                @Mark-Swift
                                Yes, serial monitor via network within IDE...
                                • mfalkviddM
                                  I haven't tried it yet but this plugin for serial monitor over network looks nice https://github.com/esp8266/Arduino/issues/1360
