  3. pimatic
  4. pimatic-mysensors controller plugin
Scheduled Pinned Locked Moved pimatic
controllernode idnrf24l01+mysensorsrasp
92 Posts 23 Posters 76.6k Views 11 Watching
  • fahrettineF
    fahrettineF
    fahrettine
    Hi everyone,
    I installed Pimatic and it looks work just fine.
    In the Config menu I added the codes below.
    Saved and restarted the Pimatic.
    I see "Light Unknown%" on the frontpage.
    How can I fix that? Thanks....
      "plugin": "mysensors",
      "driver": "serialport",
      "protocols": "1.5.1",
      "startingNodeId": 1,
      "driverOptions": {
        "//": "'/dev/ttyUSB0' if using serial Gateway",
        "serialDevice": "/dev/ttyMySensorsGateway",
        "baudrate": 115200
    "devices": [
    "id": "Light",
    "name": "Light",
    "class": "MySensorsLight",
    "nodeid": 15,
    "batterySensor": false,
    "sensorid": 2
    SweebeeS 1 Reply Last reply
    • fahrettineF fahrettine
      Hi everyone,
        "driverOptions": {
          "baudrate": 115200
      "devices": [
      "id": "Light",
      "name": "Light",
      "nodeid": 15,
      "sensorid": 2
      SweebeeS
      SweebeeS
      Sweebee
      @fahrettine How does your sketch look? Does pimatic receive anything in de log?
      • fahrettineF
        fahrettineF
        fahrettine
        Thanks for the answer.
        1-I installed Pimatic.
        2-I installed Serial Gateway on the Arduino Nano.
        3-I installed the Light sketch from MySensors on the Nano.
        Pimatic logs look like below. It seems it doesnt receive any signal.
        I think there is someting wrong with the USB port...
        Are my USB port settings coreect?
        You can see MySensors plugin settings above.
        2016-04-05 19:23:46info [pimatic]: Listening for HTTP-request on port 80...
        19:23:46info [pimatic-mobile-frontend]: rendering html finished
        19:23:20info [pimatic-mobile-frontend]: rendering html
        19:23:20info [pimatic-mobile-frontend]: packing static assets finished
        19:23:18info [pimatic-mobile-frontend]: packing static assets
        19:23:18info [pimatic]: New device "Light"...
        19:23:08info [pimatic-cron]: the time is: Tue Apr 05 2016 14:23:08 GMT-0200 (GMT+2)
        19:23:08info [pimatic]: Loading plugin: "pimatic-mysensors" (0.8.25)
        19:23:02info [pimatic]: Loading plugin: "pimatic-mobile-frontend" (0.8.82)
        19:22:59
        • OitzuO
          OitzuO
          Oitzu
             "driverOptions": {
               "baudrate": 115200
          You may want to double check that config.
          It should be more like:
             "driverOptions": {
               "serialDevice": "/dev/ttyUSB0",
               "baudrate": 115200
          if, ttyUSB0 is your connected arduino nano.
          • fahrettineF
            fahrettineF
            fahrettine
            I plugged the controller and light sensor on my pc.
            The controller receives and the sensor transmits signals.
            So, the hardware is OK.
            I changed the USB setting as "serialDevice": "/dev/ttyUSB0"
            But still no signal.
            Because I am new on RPi I cant set the USB corectly.
            My USB settings (lsusb -t) are like below:
            What is my USB port? USB0 or USB1 or other else?
            pi@raspberrypi:~ $ lsusb -t
            /: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=dwc_otg/1p, 480M
            |__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/5p, 480M
            |__ Port 1: Dev 3, If 0, Class=Vendor Specific Class, Driver=smsc95xx, 480M
            |__ Port 2: Dev 4, If 0, Class=Wireless, Driver=btusb, 12M
            |__ Port 2: Dev 4, If 1, Class=Wireless, Driver=btusb, 12M
            |__ Port 3: Dev 5, If 0, Class=Vendor Specific Class, Driver=rtl8192cu, 480M
            |__ Port 5: Dev 7, If 0, Class=Vendor Specific Class, Driver=ch341, 12M
            • OitzuO
              OitzuO
              Oitzu
              dmesg | grep tty
              Will give you an output like:
              ch341-uart converter now attached to ttyUSBXX
              • fahrettineF
                fahrettineF
                fahrettine
                Oitzu thank you very much.
                I solved the problem.
                It was the nodeID. I set the nodeID to on the sketch to 15 and the problem solved.
                Thanks for your help...
                • fahrettineF
                  fahrettineF
                  fahrettine
                  Hi everyone,
                  I installed Pimatic. It works fine...
                  I installed light sensor code from MySensor: http://www.mysensors.org/build/light
                  Light sensor works fine...
                  After that I intalled the Relay code: http://www.mysensors.org/build/relay
                  The relay doesnt work!!! Any idea for the problem???
                  When I turn the buton On/Off I can see the sending messages on debug.
                  Thanks!!!
                  Below are my Pimatic Config codes and debug messages:
                    "id": "Switch",
                    "name": "Switch",
                    "class": "MySensorsSwitch",
                    "nodeid": 10,
                    "sensorid": 1
                  debug [pimatic-mysensors]: -> Sending 10;1;1;1;2;1
                  21:21:09debug [pimatic-mysensors]: -> Sending 10;1;1;1;2;0
                  21:21:01debug [pimatic-mysensors]: -> Sending 10;1;1;1;2;1
                  21:20:56debug [pimatic-mysensors]: -> Sending 10;1;1;1;2;0
                  21:20:26info [pimatic]: Listening for HTTP-request on port 80...
                  21:20:26info [pimatic-mobile-frontend]: rendering html finished
                  D 1 Reply Last reply
                    Hi everyone,
                    Thanks!!!
                      "id": "Switch",
                      "name": "Switch",
                      "nodeid": 10,
                      "sensorid": 1
                    Dheeraj
                    @fahrettine said:
                    check whether you received any message ( serialport output ) on relay sensor node.
                    • rollercontainerR
                      rollercontainerR
                      rollercontainer
                      I've seen the "protocol" line. Is it suitable for 2.0.0beta sketches ?
                      • rollercontainerR rollercontainer
                        SweebeeS
                        SweebeeS
                        Sweebee
                        @rollercontainer the plug-in works fine with 2.0. You dont have to change the protocol value in the plug-in.
                        • RedferneR
                          RedferneR
                          Redferne
                          Is there any development of this plugin?
                          • R
                            R
                            ricardot
                            @Dheeraj,
                            Do you plan to continue to develop this plugin? I will very pleased to see a mysensors button. Thank you!
                            • R ricardot
                              @Dheeraj,
                              DavidZH
                              @ricardot said in pimatic-mysensors controller plugin:
                              @Dheeraj,
                              I second this. And also see if we can lose the dependency on serialport 2.0.6 so that we can use Node.js > 4.9.1
