  3. pimatic
  4. pimatic-mysensors controller plugin
Scheduled Pinned Locked Moved pimatic
controllernode idnrf24l01+mysensorsrasp
92 Posts 23 Posters 76.6k Views 11 Watching
  • karl261K karl261
    @fets Yes, indeed, I made some progress during the last weeks. Today I finally found a way to display these debug messages. Took me months. See this thread: http://forum.mysensors.org/topic/2392/how-to-properly-debug-serial-gateway-nrf24l01
    I think my serial gateway was somehow badly connected. During the past weeks I verified everything, re-soldered, tested various power supplies and radio modules, etc. Now it seems to work usually stable. But not always. Now I am playing around with increasing the sending power of the radio modules.
    I am using a pi 2.
    Interesting, your problem sounds very similar. Unfortunately I do not really have any advice. Maybe try to build a duplicate and see if this works better?
    fetsF
    fetsF
    fets
    @karl261 My issue seems solve using capacitors on my rfm69 radios.
    • fahrettineF
      fahrettineF
      fahrettine
      Hi everyone,
      I installed Pimatic and it looks work just fine.
      In the Config menu I added the codes below.
      Saved and restarted the Pimatic.
      I see "Light Unknown%" on the frontpage.
      How can I fix that? Thanks....
        "plugin": "mysensors",
        "driver": "serialport",
        "protocols": "1.5.1",
        "startingNodeId": 1,
        "driverOptions": {
          "//": "'/dev/ttyUSB0' if using serial Gateway",
          "serialDevice": "/dev/ttyMySensorsGateway",
          "baudrate": 115200
      "devices": [
      "id": "Light",
      "name": "Light",
      "class": "MySensorsLight",
      "nodeid": 15,
      "batterySensor": false,
      "sensorid": 2
      SweebeeS 1 Reply Last reply
      • fahrettineF fahrettine
        Hi everyone,
          "driverOptions": {
            "baudrate": 115200
        "devices": [
        "id": "Light",
        "name": "Light",
        "nodeid": 15,
        "sensorid": 2
        SweebeeS
        SweebeeS
        Sweebee
        @fahrettine How does your sketch look? Does pimatic receive anything in de log?
        • fahrettineF
          fahrettineF
          fahrettine
          Thanks for the answer.
          1-I installed Pimatic.
          2-I installed Serial Gateway on the Arduino Nano.
          3-I installed the Light sketch from MySensors on the Nano.
          Pimatic logs look like below. It seems it doesnt receive any signal.
          I think there is someting wrong with the USB port...
          Are my USB port settings coreect?
          You can see MySensors plugin settings above.
          2016-04-05 19:23:46info [pimatic]: Listening for HTTP-request on port 80...
          19:23:46info [pimatic-mobile-frontend]: rendering html finished
          19:23:20info [pimatic-mobile-frontend]: rendering html
          19:23:20info [pimatic-mobile-frontend]: packing static assets finished
          19:23:18info [pimatic-mobile-frontend]: packing static assets
          19:23:18info [pimatic]: New device "Light"...
          19:23:08info [pimatic-cron]: the time is: Tue Apr 05 2016 14:23:08 GMT-0200 (GMT+2)
          19:23:08info [pimatic]: Loading plugin: "pimatic-mysensors" (0.8.25)
          19:23:02info [pimatic]: Loading plugin: "pimatic-mobile-frontend" (0.8.82)
          19:22:59
          • OitzuO
            OitzuO
            Oitzu
               "driverOptions": {
                 "baudrate": 115200
            You may want to double check that config.
            It should be more like:
               "driverOptions": {
                 "serialDevice": "/dev/ttyUSB0",
                 "baudrate": 115200
            if, ttyUSB0 is your connected arduino nano.
            • fahrettineF
              fahrettineF
              fahrettine
              I plugged the controller and light sensor on my pc.
              The controller receives and the sensor transmits signals.
              So, the hardware is OK.
              I changed the USB setting as "serialDevice": "/dev/ttyUSB0"
              But still no signal.
              Because I am new on RPi I cant set the USB corectly.
              My USB settings (lsusb -t) are like below:
              What is my USB port? USB0 or USB1 or other else?
              pi@raspberrypi:~ $ lsusb -t
              /: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=dwc_otg/1p, 480M
              |__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/5p, 480M
              |__ Port 1: Dev 3, If 0, Class=Vendor Specific Class, Driver=smsc95xx, 480M
              |__ Port 2: Dev 4, If 0, Class=Wireless, Driver=btusb, 12M
              |__ Port 2: Dev 4, If 1, Class=Wireless, Driver=btusb, 12M
              |__ Port 3: Dev 5, If 0, Class=Vendor Specific Class, Driver=rtl8192cu, 480M
              |__ Port 5: Dev 7, If 0, Class=Vendor Specific Class, Driver=ch341, 12M
              • OitzuO
                OitzuO
                Oitzu
                dmesg | grep tty
                Will give you an output like:
                ch341-uart converter now attached to ttyUSBXX
                • fahrettineF
                  fahrettineF
                  fahrettine
                  Oitzu thank you very much.
                  I solved the problem.
                  It was the nodeID. I set the nodeID to on the sketch to 15 and the problem solved.
                  Thanks for your help...
                  • fahrettineF
                    fahrettineF
                    fahrettine
                    Hi everyone,
                    I installed Pimatic. It works fine...
                    I installed light sensor code from MySensor: http://www.mysensors.org/build/light
                    Light sensor works fine...
                    After that I intalled the Relay code: http://www.mysensors.org/build/relay
                    The relay doesnt work!!! Any idea for the problem???
                    When I turn the buton On/Off I can see the sending messages on debug.
                    Thanks!!!
                    Below are my Pimatic Config codes and debug messages:
                      "id": "Switch",
                      "name": "Switch",
                      "class": "MySensorsSwitch",
                      "nodeid": 10,
                      "sensorid": 1
                    debug [pimatic-mysensors]: -> Sending 10;1;1;1;2;1
                    21:21:09debug [pimatic-mysensors]: -> Sending 10;1;1;1;2;0
                    21:21:01debug [pimatic-mysensors]: -> Sending 10;1;1;1;2;1
                    21:20:56debug [pimatic-mysensors]: -> Sending 10;1;1;1;2;0
                    21:20:26info [pimatic]: Listening for HTTP-request on port 80...
                    21:20:26info [pimatic-mobile-frontend]: rendering html finished
                    D 1 Reply Last reply
                      Hi everyone,
                      Thanks!!!
                        "id": "Switch",
                        "name": "Switch",
                        "nodeid": 10,
                        "sensorid": 1
                      Dheeraj
                      @fahrettine said:
                      check whether you received any message ( serialport output ) on relay sensor node.
                      • rollercontainerR
                        rollercontainerR
                        rollercontainer
                        I've seen the "protocol" line. Is it suitable for 2.0.0beta sketches ?
                        • rollercontainerR rollercontainer
                          SweebeeS
                          SweebeeS
                          Sweebee
                          @rollercontainer the plug-in works fine with 2.0. You dont have to change the protocol value in the plug-in.
                          • RedferneR
                            RedferneR
                            Redferne
                            Is there any development of this plugin?
                            • R
                              R
                              ricardot
                              @Dheeraj,
                              Do you plan to continue to develop this plugin? I will very pleased to see a mysensors button. Thank you!
                              • R ricardot
                                @Dheeraj,
                                DavidZH
                                @ricardot said in pimatic-mysensors controller plugin:
                                @Dheeraj,
                                I second this. And also see if we can lose the dependency on serialport 2.0.6 so that we can use Node.js > 4.9.1
