  3. pimatic
  4. pimatic-mysensors controller plugin
Scheduled Pinned Locked Moved pimatic
controllernode idnrf24l01+mysensorsrasp
92 Posts 23 Posters 76.6k Views 11 Watching
  • karl261K karl261
    Good point. I had not, now I have. But still, there is absolutely 0 output from this. The only message I see is the "Gateway startup complete" stuff.
    fetsF
    fetsF
    fets
    @karl261 Do you have any news ?
    Which raspberry pi are you using ? PI 2 ?
    I experienced the same issue with domoticz on raspberry pi2 + serial gateway with RFM69 radio.
    I really don't think that the issue is the controller. It seems that the radio is stuck cause when I debug my node after reset, all outgoing messages are marked with st=fail meaning that radios can't reach each other.
    I don't know if it's my chinese arduino nano or raspberry pi 2 usb power or my radio module.
    Investigation in progress. Something a reboot is not enough, I have to disconnect usb cable in order to make it work again.
    • karl261K
      karl261K
      karl261
      @fets Yes, indeed, I made some progress during the last weeks. Today I finally found a way to display these debug messages. Took me months. See this thread: http://forum.mysensors.org/topic/2392/how-to-properly-debug-serial-gateway-nrf24l01
      I think my serial gateway was somehow badly connected. During the past weeks I verified everything, re-soldered, tested various power supplies and radio modules, etc. Now it seems to work usually stable. But not always. Now I am playing around with increasing the sending power of the radio modules.
      I am using a pi 2.
      Interesting, your problem sounds very similar. Unfortunately I do not really have any advice. Maybe try to build a duplicate and see if this works better?
      fetsF 1 Reply Last reply
      • karl261K karl261
        I am using a pi 2.
        fetsF
        fetsF
        fets
        @karl261 My issue seems solve using capacitors on my rfm69 radios.
        • fahrettineF
          fahrettineF
          fahrettine
          Hi everyone,
          I installed Pimatic and it looks work just fine.
          In the Config menu I added the codes below.
          Saved and restarted the Pimatic.
          I see "Light Unknown%" on the frontpage.
          How can I fix that? Thanks....
            "plugin": "mysensors",
            "driver": "serialport",
            "protocols": "1.5.1",
            "startingNodeId": 1,
            "driverOptions": {
              "//": "'/dev/ttyUSB0' if using serial Gateway",
              "serialDevice": "/dev/ttyMySensorsGateway",
              "baudrate": 115200
          "devices": [
          "id": "Light",
          "name": "Light",
          "class": "MySensorsLight",
          "nodeid": 15,
          "batterySensor": false,
          "sensorid": 2
          SweebeeS 1 Reply Last reply
          • fahrettineF fahrettine
            Hi everyone,
              "driverOptions": {
                "baudrate": 115200
            "devices": [
            "id": "Light",
            "name": "Light",
            "nodeid": 15,
            "sensorid": 2
            SweebeeS
            SweebeeS
            Sweebee
            @fahrettine How does your sketch look? Does pimatic receive anything in de log?
            • fahrettineF
              fahrettineF
              fahrettine
              Thanks for the answer.
              1-I installed Pimatic.
              2-I installed Serial Gateway on the Arduino Nano.
              3-I installed the Light sketch from MySensors on the Nano.
              Pimatic logs look like below. It seems it doesnt receive any signal.
              I think there is someting wrong with the USB port...
              Are my USB port settings coreect?
              You can see MySensors plugin settings above.
              2016-04-05 19:23:46info [pimatic]: Listening for HTTP-request on port 80...
              19:23:46info [pimatic-mobile-frontend]: rendering html finished
              19:23:20info [pimatic-mobile-frontend]: rendering html
              19:23:20info [pimatic-mobile-frontend]: packing static assets finished
              19:23:18info [pimatic-mobile-frontend]: packing static assets
              19:23:18info [pimatic]: New device "Light"...
              19:23:08info [pimatic-cron]: the time is: Tue Apr 05 2016 14:23:08 GMT-0200 (GMT+2)
              19:23:08info [pimatic]: Loading plugin: "pimatic-mysensors" (0.8.25)
              19:23:02info [pimatic]: Loading plugin: "pimatic-mobile-frontend" (0.8.82)
              19:22:59
              • OitzuO
                OitzuO
                Oitzu
                   "driverOptions": {
                     "baudrate": 115200
                You may want to double check that config.
                It should be more like:
                   "driverOptions": {
                     "serialDevice": "/dev/ttyUSB0",
                     "baudrate": 115200
                if, ttyUSB0 is your connected arduino nano.
                • fahrettineF
                  fahrettineF
                  fahrettine
                  I plugged the controller and light sensor on my pc.
                  The controller receives and the sensor transmits signals.
                  So, the hardware is OK.
                  I changed the USB setting as "serialDevice": "/dev/ttyUSB0"
                  But still no signal.
                  Because I am new on RPi I cant set the USB corectly.
                  My USB settings (lsusb -t) are like below:
                  What is my USB port? USB0 or USB1 or other else?
                  pi@raspberrypi:~ $ lsusb -t
                  /: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=dwc_otg/1p, 480M
                  |__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/5p, 480M
                  |__ Port 1: Dev 3, If 0, Class=Vendor Specific Class, Driver=smsc95xx, 480M
                  |__ Port 2: Dev 4, If 0, Class=Wireless, Driver=btusb, 12M
                  |__ Port 2: Dev 4, If 1, Class=Wireless, Driver=btusb, 12M
                  |__ Port 3: Dev 5, If 0, Class=Vendor Specific Class, Driver=rtl8192cu, 480M
                  |__ Port 5: Dev 7, If 0, Class=Vendor Specific Class, Driver=ch341, 12M
                  • OitzuO
                    OitzuO
                    Oitzu
                    dmesg | grep tty
                    Will give you an output like:
                    ch341-uart converter now attached to ttyUSBXX
                    • fahrettineF
                      fahrettineF
                      fahrettine
                      Oitzu thank you very much.
                      I solved the problem.
                      It was the nodeID. I set the nodeID to on the sketch to 15 and the problem solved.
                      Thanks for your help...
                      • fahrettineF
                        fahrettineF
                        fahrettine
                        Hi everyone,
                        I installed Pimatic. It works fine...
                        I installed light sensor code from MySensor: http://www.mysensors.org/build/light
                        Light sensor works fine...
                        After that I intalled the Relay code: http://www.mysensors.org/build/relay
                        The relay doesnt work!!! Any idea for the problem???
                        When I turn the buton On/Off I can see the sending messages on debug.
                        Thanks!!!
                        Below are my Pimatic Config codes and debug messages:
                          "id": "Switch",
                          "name": "Switch",
                          "class": "MySensorsSwitch",
                          "nodeid": 10,
                          "sensorid": 1
                        debug [pimatic-mysensors]: -> Sending 10;1;1;1;2;1
                        21:21:09debug [pimatic-mysensors]: -> Sending 10;1;1;1;2;0
                        21:21:01debug [pimatic-mysensors]: -> Sending 10;1;1;1;2;1
                        21:20:56debug [pimatic-mysensors]: -> Sending 10;1;1;1;2;0
                        21:20:26info [pimatic]: Listening for HTTP-request on port 80...
                        21:20:26info [pimatic-mobile-frontend]: rendering html finished
                        D 1 Reply Last reply
                          Hi everyone,
                          Thanks!!!
                            "id": "Switch",
                            "name": "Switch",
                            "nodeid": 10,
                            "sensorid": 1
                          Dheeraj
                          @fahrettine said:
                          check whether you received any message ( serialport output ) on relay sensor node.
                          • rollercontainerR
                            rollercontainerR
                            rollercontainer
                            I've seen the "protocol" line. Is it suitable for 2.0.0beta sketches ?
                            • rollercontainerR rollercontainer
                              SweebeeS
                              SweebeeS
                              Sweebee
                              @rollercontainer the plug-in works fine with 2.0. You dont have to change the protocol value in the plug-in.
                              • RedferneR
                                RedferneR
                                Redferne
                                Is there any development of this plugin?
                                • R
                                  R
                                  ricardot
                                  @Dheeraj,
                                  Do you plan to continue to develop this plugin? I will very pleased to see a mysensors button. Thank you!
                                  • R ricardot
                                    @Dheeraj,
                                    DavidZH
                                    @ricardot said in pimatic-mysensors controller plugin:
                                    @Dheeraj,
                                    I second this. And also see if we can lose the dependency on serialport 2.0.6 so that we can use Node.js > 4.9.1
