  3. gw.sleep on battery powered magnet door switch
42 Posts 13 Posters 15.7k Views 16 Watching
  • ChakkieC Offline
    ChakkieC Offline
    Chakkie
    wrote on last edited by Chakkie
    Hi all,
    I have made a magnet door contact using a Arduino mini Pro 3v3 powered with 2 coin cells battery. To save battery life, I want to use gw.sleep to let the Arduino mini to sleep and trigger when the door is open.
    Unfortunately, the arduino is not trigger when contact is open or closed due to gw.sleep. I was wonder how to use the sleep comment and still making the debounce action works. I have tried to use INTERRUPT but with no luck.
     * Simple binary switch example
     * Connect button or door/window reed switch between
     * digitial I/O pin 3 (BUTTON_PIN below) and GND.
     * http://www.mysensors.org/build/binary
    #define CHILD_ID 3
    #define BUTTON_PIN  3  // Arduino Digital I/O pin for button/reed switch
    #define INTERRUPT BUTTON_PIN -2 // Usually the interrupt = pin -2 (on uno/nano anyway)
    Bounce debouncer = Bounce();
    int oldValue=-1;
      gw.begin();
     // Setup the button
      pinMode(BUTTON_PIN,INPUT);
      // Activate internal pull-up
      debouncer.attach(BUTTON_PIN);
      debouncer.interval(5);
      gw.present(CHILD_ID, S_DOOR);
      debouncer.update();
      // Get the update value
      int value = debouncer.read();
      if (value != oldValue) {
         // Send in the new value
         oldValue = value;
      gw.sleep(INTERRUPT,CHANGE, SLEEP_TIME);
    Raspberry Pi 2
    Domoticz
    RFXCOM
    ZWAVE Aeon stick
    Coming soon Arduino mysensors GW
    • S Offline
      @Chakkie - Looks right, Do you see anything in the serial debug log when you try?
      ChakkieC 1 Reply Last reply
      • mfalkviddM Offline
        The code looks ok to me (except that you might as well set SLEEP_TIME to 0 since the loop only will report on change, regardless of the sleep time).
        Maybe add a few Serial.println statements in different parts of the loop so you can debug what happens?
        • S sundberg84
          ChakkieC Offline
          ChakkieC Offline
          Chakkie
          @sundberg84
          I have added some print to debugged. It seems like the code with sleep does not verify and send the high 1 or low 0 when I open and close the contact. See the serial debug log. The repeated sleep in the log is when i open and close the contact. Normally it will send 1 or 0 " send: 204-204-0-0 s=3,c=1,t=16,pt=2,l=2,sg=0,st=ok:0"
            debouncer.update();
               Serial.println("Trigger");
               oldValue = value;
            Serial.println("Sleep");
          send: 204-204-0-0 s=255,c=3,t=15,pt=2,l=2,sg=0,st=ok:0
          send: 204-204-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,st=ok:1.5.4
          send: 204-204-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
          read: 0-0-204 s=255,c=3,t=6,pt=0,l=1,sg=0:M
          sensor started, id=204, parent=0, distance=1
          send: 204-204-0-0 s=3,c=0,t=0,pt=0,l=0,sg=0,st=ok:
          Trigger
          Sleep
          Sleep
          Sleep
          Sleep
          Sleep
          Sleep
          Sleep
          Sleep
          Raspberry Pi 2
          Domoticz
          RFXCOM
          ZWAVE Aeon stick
          A 1 Reply Last reply
            ChakkieC Offline
            ChakkieC Offline
            Chakkie
            @mfalkvidd Hi thanks
            Changing the sleep time to 0 does not help. When I open and close the contact the status will not be sent. That's weird
            Raspberry Pi 2
            Domoticz
            RFXCOM
            ZWAVE Aeon stick
            • S Offline
              @Chakkie - add a debugline and see what value and oldvalue says.
              See if you can measure the input when you close the contact and when its open so its not a hardware failure.
              • ChakkieC Chakkie
                @sundberg84
                  debouncer.update();
                     oldValue = value;
                Trigger
                Sleep
                Sleep
                Sleep
                Sleep
                Sleep
                Sleep
                Sleep
                Sleep
                A Offline
                A Offline
                AWI
                @Chakkie debouncer does not function when you use the sleep function. Reason is that sleep puts the internal timer which is used by debouncer to rest. Remove the debouncer routine and debounce by including a gw.wait(40) before going to sleep. This avoids a retrigger by an eventual contact bounce.
                • S sundberg84
                  ChakkieC Offline
                  ChakkieC Offline
                  Chakkie
                  @sundberg84 I have debugged a several times. I am now sure it is not a hardware failure.
                  Raspberry Pi 2
                  Domoticz
                  RFXCOM
                  ZWAVE Aeon stick
                  • A AWI
                    ChakkieC Offline
                    ChakkieC Offline
                    Chakkie
                    @AWI Thank you so much. Yes I have came to the conclusion that the debouncer does not seems to work fine with sleep function. So I have used a method other than debouncer.
                    Here the working script below:
                    #define CHILD_ID_Deur 11
                    #define CHILD_ID_Post 12
                    #define BUTTON_PIN_Deur  2  // Arduino Digital I/O pin for button/reed switch
                    #define BUTTON_PIN_Post  3  // Arduino Digital I/O pin for button/reed switch
                    MyMessage msgDeur(CHILD_ID_Deur,V_TRIPPED);
                    MyMessage msgPost(CHILD_ID_Post,V_TRIPPED);
                      gw.begin();
                    gw.sendSketchInfo("Voordeur contacts", "1.0");
                     // Setup the button
                      pinMode(BUTTON_PIN_Deur,INPUT);
                      pinMode(BUTTON_PIN_Post,INPUT);
                      digitalWrite(BUTTON_PIN_Deur,HIGH);
                      digitalWrite(BUTTON_PIN_Post,HIGH);
                      gw.present(CHILD_ID_Deur, S_DOOR);
                      gw.present(CHILD_ID_Post, S_DOOR);
                      uint8_t value;
                      static uint8_t sentValue = 2;
                      static uint8_t sentValue2 = 2;
                      gw.sleep(5);
                      value = digitalRead(BUTTON_PIN_Deur);
                      if (value != sentValue) {
                        gw.send(msgDeur.set(value == HIGH ? 1 : 0));
                        sentValue = value;
                      value = digitalRead(BUTTON_PIN_Post);
                      if (value != sentValue2) {
                        gw.send(msgPost.set(value == HIGH ? 1 : 0));
                        sentValue2 = value;
                      gw.sleep(BUTTON_PIN_Deur - 2, CHANGE, BUTTON_PIN_Post - 2, CHANGE, 86400000);// changing Secondary button to correct pin (-3) does not work. So keep it on (-2)
                    Notice that the script does not work properly when I set BUTTON_PIN_Post - 3. The button pin post will not trigger. But when I change it to -2, both switches will work
                    Raspberry Pi 2
                    Domoticz
                    RFXCOM
                    ZWAVE Aeon stick
                    • ChakkieC Chakkie
                        gw.begin();
                       // Setup the button
                        uint8_t value;
                        gw.sleep(5);
                          sentValue = value;
                          sentValue2 = value;
                      A Offline
                      A Offline
                      AWI
                      @Chakkie Good to hear. Using "-3" makes the interrupt number the same for _Deur and _Post. Using -2 activates both interrupt 0 and 1.
                      You'r ready for the next project..
                        We should really get rid of the confusing "- 2" stuff in the examples and start using DigtalPinToInterrupt instead.
                        I'm annoyed enough to see if I can create a pull request later this week.
                        • A AWI
                          ChakkieC Offline
                          ChakkieC Offline
                          Chakkie
                          @AWI Thanks. By the way would you care to explain the interrupt index number? or may be a link for explanation?
                          Raspberry Pi 2
                          Domoticz
                          RFXCOM
                          ZWAVE Aeon stick
                          • ChakkieC Chakkie
                            A Offline
                            A Offline
                            AWI
                            wrote on last edited by AWI
                            @Chakkie In a few words.. The ATMEGA has two external interrupts 0 and 1 which are connected to pins 2 and 3. ("-2" translates the pin number to the interrupt number, which is rather confusing as @mfalkvidd meant)
                              ChakkieC Offline
                              ChakkieC Offline
                              Chakkie
                              @mfalkvidd Thanks for the info. Does DigitalPinTolnterrupt works better?
                              Raspberry Pi 2
                              Domoticz
                              RFXCOM
                              ZWAVE Aeon stick
                              • A AWI
                                ChakkieC Offline
                                ChakkieC Offline
                                Chakkie
                                @AWI Thanks this clear thinks up but at the same time also confusing too.
                                So "-2" activates both 0 and 1 on pin 2 or pin 3 as you mentioned earlier. I always though it represents a pin number.
                                Raspberry Pi 2
                                Domoticz
                                RFXCOM
                                ZWAVE Aeon stick
                                • ChakkieC Chakkie
                                  A Offline
                                  A Offline
                                  AWI
                                  @Chakkie The function digitalPinToInterrupt(pin) translates the pin number to the attached interrupt like "-2" does but in a reliable and more understandable way.
                                  • A AWI
                                    ChakkieC Offline
                                    ChakkieC Offline
                                    Chakkie
                                    @AWI thanks. this looks like more promising.
                                    Raspberry Pi 2
                                    Domoticz
                                    RFXCOM
                                    ZWAVE Aeon stick
                                      Pull request done for the development version: https://github.com/mysensors/Arduino/pull/441
                                      • S Offline
                                        siod
                                        I would like to build the same but I am still very confused now. Could you upload some pictures so I can make myself an image of how you wirde things together?
                                        Also I don´t really understand what happens here: gw.sleep(BUTTON_PIN_Deur - 2, CHANGE, BUTTON_PIN_Post - 2, CHANGE, 86400000);
                                        still learning...
                                        • S siod
                                          A Offline
                                          A Offline
                                          AWI
                                          @siod If you are using a "standard" Atmega328 (pro-mini, etc.) don't make it hard for yourself. This processor has two external interrupts (0 & 1) connected to pins 2 & 3. Taking your line of code gw.sleep(BUTTON_PIN_Deur - 2, CHANGE, BUTTON_PIN_Post - 2, CHANGE, 86400000); the arguments are respectively:
                                          1. Use interrupt "0" (connected to pin 2 is BUTTON_PIN_Deur)
                                          2. Have is fired on change (i.e Rising and Falling)
                                          3. Use interrupt "1" (connected to pin 3 is BUTTON_PIN_Post)
                                          4. Have is fired on change (i.e Rising and Falling)
                                          5. Wake after every 86400000 ms (24 hrs) if no interrupt fired. To be safe you should use 86400000UL (the UL indicating that it is an Unsigned long type)
                                          S 1 Reply Last reply
                                          12.0k
