  3. gw.sleep on battery powered magnet door switch
42 Posts 13 Posters 17.3k Views 16 Watching
  • sundberg84S sundberg84
    @Chakkie - Looks right, Do you see anything in the serial debug log when you try?
    ChakkieC
    ChakkieC
    Chakkie
    @sundberg84
    I have added some print to debugged. It seems like the code with sleep does not verify and send the high 1 or low 0 when I open and close the contact. See the serial debug log. The repeated sleep in the log is when i open and close the contact. Normally it will send 1 or 0 " send: 204-204-0-0 s=3,c=1,t=16,pt=2,l=2,sg=0,st=ok:0"
      debouncer.update();
      // Get the update value
      int value = debouncer.read();
      if (value != oldValue) {
         // Send in the new value
         Serial.println("Trigger");
         oldValue = value;
      gw.sleep(INTERRUPT,CHANGE, SLEEP_TIME);
      Serial.println("Sleep");
    send: 204-204-0-0 s=255,c=3,t=15,pt=2,l=2,sg=0,st=ok:0
    send: 204-204-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,st=ok:1.5.4
    send: 204-204-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
    read: 0-0-204 s=255,c=3,t=6,pt=0,l=1,sg=0:M
    sensor started, id=204, parent=0, distance=1
    send: 204-204-0-0 s=3,c=0,t=0,pt=0,l=0,sg=0,st=ok:
    Trigger
    Sleep
    Sleep
    Sleep
    Sleep
    Sleep
    Sleep
    Sleep
    Sleep
    Raspberry Pi 2
    Domoticz
    RFXCOM
    ZWAVE Aeon stick
    Coming soon Arduino mysensors GW
    AWIA 1 Reply Last reply
      The code looks ok to me (except that you might as well set SLEEP_TIME to 0 since the loop only will report on change, regardless of the sleep time).
      Maybe add a few Serial.println statements in different parts of the loop so you can debug what happens?
      ChakkieC
      ChakkieC
      Chakkie
      @mfalkvidd Hi thanks
      Changing the sleep time to 0 does not help. When I open and close the contact the status will not be sent. That's weird
      Raspberry Pi 2
      Domoticz
      RFXCOM
      ZWAVE Aeon stick
      • sundberg84S
        sundberg84S
        @Chakkie - add a debugline and see what value and oldvalue says.
        See if you can measure the input when you close the contact and when its open so its not a hardware failure.
        ChakkieC 1 Reply Last reply
        • ChakkieC Chakkie
          @sundberg84
            debouncer.update();
               oldValue = value;
          Trigger
          Sleep
          Sleep
          Sleep
          Sleep
          Sleep
          Sleep
          Sleep
          Sleep
          AWIA
          AWIA
          AWI
          @Chakkie debouncer does not function when you use the sleep function. Reason is that sleep puts the internal timer which is used by debouncer to rest. Remove the debouncer routine and debounce by including a gw.wait(40) before going to sleep. This avoids a retrigger by an eventual contact bounce.
            ChakkieC
            ChakkieC
            Chakkie
            @sundberg84 I have debugged a several times. I am now sure it is not a hardware failure.
            Raspberry Pi 2
            Domoticz
            RFXCOM
            ZWAVE Aeon stick
            • AWIA AWI
              ChakkieC
              ChakkieC
              Chakkie
              @AWI Thank you so much. Yes I have came to the conclusion that the debouncer does not seems to work fine with sleep function. So I have used a method other than debouncer.
              Here the working script below:
              #define CHILD_ID_Deur 11
              #define CHILD_ID_Post 12
              #define BUTTON_PIN_Deur  2  // Arduino Digital I/O pin for button/reed switch
              #define BUTTON_PIN_Post  3  // Arduino Digital I/O pin for button/reed switch
              MyMessage msgDeur(CHILD_ID_Deur,V_TRIPPED);
              MyMessage msgPost(CHILD_ID_Post,V_TRIPPED);
                gw.begin();
              gw.sendSketchInfo("Voordeur contacts", "1.0");
               // Setup the button
                pinMode(BUTTON_PIN_Deur,INPUT);
                pinMode(BUTTON_PIN_Post,INPUT);
                // Activate internal pull-up
                digitalWrite(BUTTON_PIN_Deur,HIGH);
                digitalWrite(BUTTON_PIN_Post,HIGH);
                gw.present(CHILD_ID_Deur, S_DOOR);
                gw.present(CHILD_ID_Post, S_DOOR);
                uint8_t value;
                static uint8_t sentValue = 2;
                static uint8_t sentValue2 = 2;
                gw.sleep(5);
                value = digitalRead(BUTTON_PIN_Deur);
                if (value != sentValue) {
                  gw.send(msgDeur.set(value == HIGH ? 1 : 0));
                  sentValue = value;
                value = digitalRead(BUTTON_PIN_Post);
                if (value != sentValue2) {
                  gw.send(msgPost.set(value == HIGH ? 1 : 0));
                  sentValue2 = value;
                gw.sleep(BUTTON_PIN_Deur - 2, CHANGE, BUTTON_PIN_Post - 2, CHANGE, 86400000);// changing Secondary button to correct pin (-3) does not work. So keep it on (-2)
              Notice that the script does not work properly when I set BUTTON_PIN_Post - 3. The button pin post will not trigger. But when I change it to -2, both switches will work
              Raspberry Pi 2
              Domoticz
              RFXCOM
              ZWAVE Aeon stick
              • ChakkieC Chakkie
                  gw.begin();
                 // Setup the button
                  uint8_t value;
                  gw.sleep(5);
                    sentValue = value;
                    sentValue2 = value;
                AWIA
                AWIA
                AWI
                @Chakkie Good to hear. Using "-3" makes the interrupt number the same for _Deur and _Post. Using -2 activates both interrupt 0 and 1.
                You'r ready for the next project..
                • mfalkviddM
                  We should really get rid of the confusing "- 2" stuff in the examples and start using DigtalPinToInterrupt instead.
                  I'm annoyed enough to see if I can create a pull request later this week.
                  • AWIA AWI
                    ChakkieC
                    ChakkieC
                    Chakkie
                    @AWI Thanks. By the way would you care to explain the interrupt index number? or may be a link for explanation?
                    Raspberry Pi 2
                    Domoticz
                    RFXCOM
                    ZWAVE Aeon stick
                    • ChakkieC Chakkie
                      AWIA
                      AWIA
                      AWI
                      wrote on last edited by AWI
                      @Chakkie In a few words.. The ATMEGA has two external interrupts 0 and 1 which are connected to pins 2 and 3. ("-2" translates the pin number to the interrupt number, which is rather confusing as @mfalkvidd meant)
                        ChakkieC
                        ChakkieC
                        Chakkie
                        @mfalkvidd Thanks for the info. Does DigitalPinTolnterrupt works better?
                        Raspberry Pi 2
                        Domoticz
                        RFXCOM
                        ZWAVE Aeon stick
                        • AWIA AWI
                          ChakkieC
                          ChakkieC
                          Chakkie
                          @AWI Thanks this clear thinks up but at the same time also confusing too.
                          So "-2" activates both 0 and 1 on pin 2 or pin 3 as you mentioned earlier. I always though it represents a pin number.
                          Raspberry Pi 2
                          Domoticz
                          RFXCOM
                          ZWAVE Aeon stick
                          • ChakkieC Chakkie
                            AWIA
                            AWIA
                            AWI
                            @Chakkie The function digitalPinToInterrupt(pin) translates the pin number to the attached interrupt like "-2" does but in a reliable and more understandable way.
                            • AWIA AWI
                              ChakkieC
                              ChakkieC
                              Chakkie
                              @AWI thanks. this looks like more promising.
                              Raspberry Pi 2
                              Domoticz
                              RFXCOM
                              ZWAVE Aeon stick
                              • mfalkviddM
                                Pull request done for the development version: https://github.com/mysensors/Arduino/pull/441
                                • siodS
                                  siodS
                                  siod
                                  I would like to build the same but I am still very confused now. Could you upload some pictures so I can make myself an image of how you wirde things together?
                                  Also I don´t really understand what happens here: gw.sleep(BUTTON_PIN_Deur - 2, CHANGE, BUTTON_PIN_Post - 2, CHANGE, 86400000);
                                  still learning...
                                  • siodS siod
                                    AWIA
                                    AWIA
                                    AWI
                                    @siod If you are using a "standard" Atmega328 (pro-mini, etc.) don't make it hard for yourself. This processor has two external interrupts (0 & 1) connected to pins 2 & 3. Taking your line of code gw.sleep(BUTTON_PIN_Deur - 2, CHANGE, BUTTON_PIN_Post - 2, CHANGE, 86400000); the arguments are respectively:
                                    1. Use interrupt "0" (connected to pin 2 is BUTTON_PIN_Deur)
                                    2. Have is fired on change (i.e Rising and Falling)
                                    3. Use interrupt "1" (connected to pin 3 is BUTTON_PIN_Post)
                                    4. Have is fired on change (i.e Rising and Falling)
                                    5. Wake after every 86400000 ms (24 hrs) if no interrupt fired. To be safe you should use 86400000UL (the UL indicating that it is an Unsigned long type)
                                    siodS 1 Reply Last reply
                                    • AWIA AWI
                                      siodS
                                      siodS
                                      siod
                                      @AWI
                                      Ok thx for explanation, but that means he is using 2 reed switches, right (interrupt at pin2 and int pin3)?
                                      still learning...
                                      • siodS siod
                                        @AWI
                                        AWIA
                                        AWIA
                                        AWI
                                        @siod I guess so. But don't ask me why. One should be sufficient to detect if the door is open :smile:
                                        In addition (and for what it is worth). If you use a real low power circuit you can save around a factor 3 on battery lifetime when you get rid of the timed wakeup. The arduino sleeps a lot better when it doesn't have to look at the alarm clock every few ms :zzz:
                                        siodS ChakkieC 2 Replies Last reply
                                        • AWIA AWI
                                          siodS
                                          siodS
                                          siod
                                          @AWI
                                          yes, makes sense, but how should you do this wihout the wakeup ? I guess this is just the disadvantage one must accept...
                                          still learning...
                                          12.5k
