  3. SCT-013-030 Energy Meter
35 Posts 15 Posters 40.0k Views 25 Watching
    A Former User
    Thanks for doing the groundwork in developing this. Before i copy your implementation, has there been any updates/improvements/observations now that you've had it running for almost a month? Cheers
    • P
      P
      patrick schaerer
      wrote on last edited by patrick schaerer
      I made some changes in the software. There was a mistake in the kwh and I added a DHT-Sensor (see comment in the code).
      It works well. The kwh is reset on each restart. I probably will change that in the future.
        A Former User
        wrote on last edited by [[global:former-user]]
        Hey Mate,
        Had a chance to sit down and build this node. Made a few tweaks which you may be interested in.
        Rewrote the code to sleep for 60 seconds between measurements. This saves approx 80% power ( 22mA down to 4.6mA on my 3.3v pro mini). This also corrects for the drift in the original code which resulted in gaining a second every few mins of measurements (its now only 2ms/min)
        Added battery level monitoring which is reported in volts every hour and require no additional hardware or wiring than the originally posted circuit but requires a new vcc library. The actual votlage is only reported if the battery level has changed since the last reading - to save power) .
        Let me know what you think:
        https://codebender.cc/sketch:276398
          maciejka
          Hi, great sketch! But i have a question: how to chanhe this sketch to send kwh often then once per hour? Maybe safer will be send kwh like sending wh - every minute?
          • P
            P
            patrick schaerer
            @maciejka : you can change the value on column 98: minuten == 60
            "Minuten" is german for minutes. if you want to report every minute change the value to 1.
            @Surge86 : thank you for your improvements! I will compare our codes and hopefully learn a lot.
            I startet arduino programming in november and keep on learning.
            greets patrick
              maciejka
              Thanks, i will test it :)
              Regards
              Maciej
              • bpairB
                bpairB
                bpair
                wrote on last edited by bpair
                Thanks for sharing this! I am hoping to create an all-in-one extension cord plus this meter. I hope this way I can detect when a pump fails or maybe just how much power is being used.
                I have read that you when using a CT you must be careful to avoid a voltage build up on the CT output. Is that a concern with this current setup? With a battery powered arduino you are not grounded? In my extension cord project I was thinking I could use the ground from the extension cord.
                I am not an electrical engineer so I may be way off here, just trying to be safe.
                I think this setup could be very useful. In the high school greenhouse where I have my sensor network there are so many pumps, heaters, air stones, that need to be monitored and an alert sent if they stop working.
                I may also try this with the sensebender micro.
                • P
                  P
                  patrick schaerer
                  As far as i understand there is a resistor built in the sct013 that prevents this voltage buildup. But i am not an electrician.
                  • P
                    P
                    patrick schaerer
                    I optimized my code with the help of Surge.
                    I added a KWH reading on a restart of the node.
                    Now it's Version 1.3
                      m1rk0
                      Hello Patrick, thank you for sharing your project. I tested it and it works fine but I want to test how acurate it is with low current measurements. Can you please tell me how to change your code to get results below 60W? I'm just beginning to learn arduino-programming so i don't understand everything..
                      P 1 Reply Last reply
                      • M m1rk0
                        P
                        P
                        patrick schaerer
                        @m1rk0
                        In Line 95 is the following expression:
                        if (Irms < 0.3) Irms = 0;
                        Irms is RMS current. The expression sets all current smaller than 0.3 as 0.
                        You can delete this line for smaller values.
                        I suggest to use a SCT-013-005 instead of a SCT-013-030.
                          m1rk0
                          Thank you patrik, i already ordered an sct-013-005, but i need sometimes higher measurements than 5a. With this second sensor i will be able to compare the results.
                          ? 1 Reply Last reply
                          • M m1rk0
                            A Former User
                            yeah 5A is within its range. I usually sit between 1A-20A
                            • john7845J
                              john7845J
                              john7845
                              hello, where is the MySensor.h file??
                              • tbowmoT
                                tbowmoT
                                tbowmo
                                This is made for an earlier version of the library, things has changed a lot since.
                                first off, the library header file is now called MySensors.h (note the added "s" to the name). But also how you use / initialize the mysensors project is very different in 2.x, than in 1.x,
                                have a look at this post to get an idea of what you have to change, to upgrade your arduino sketch to work with MySensors 2.x library
                                • P
                                  P
                                  patrick schaerer
                                  I alread updated to MySensors 2.0
                                  This is the update code:
                                  I also edited the first post.
                                   * EnergyMeterSCT by Patrick Schaerer
                                   * This Sketch is a WattMeter used with a SCT-013-030 non invasive PowerMeter
                                   * see documentation for schematic
                                   * Special thanks to Surge, who optimized my code.
                                   * updated to mySensors Library 2.0
                                  #define MY_REPEATER_FEATURE
                                  #include <EmonLib.h>
                                  #define ANALOG_INPUT_SENSOR 1  // The digital input you attached your SCT sensor.  (Only 2 and 3 generates interrupt!)
                                  //#define INTERRUPT DIGITAL_INPUT_SENSOR-2 // Usually the interrupt = pin -2 (on uno/nano anyway)
                                  EnergyMonitor emon1;
                                  MyMessage wattMsg(CHILD_ID,V_WATT);
                                  MyMessage kwhMsg(CHILD_ID,V_KWH);
                                  MyMessage msgKWH(CHILD_ID,V_VAR1);
                                  unsigned long SLEEP_TIME = 60000 - 3735; // sleep for 60 seconds (-4 seconds to calculate values)
                                  float wattsumme = 0;
                                  float kwh = 0;
                                  float wh = 0;
                                  int minuten = 0;  //vorher 61
                                  boolean KWH_received=false;
                                  //Humidity Sensor Code
                                  #define CHILD_ID_HUM 2
                                  #define CHILD_ID_TEMP 3
                                  #define HUMIDITY_SENSOR_DIGITAL_PIN 2
                                  DHT dht;
                                  float lastTemp;
                                  float lastHum;
                                  boolean metric = true;
                                  //End of Humidity Sensor Code
                                    //energy clamp code
                                    //gw.begin(incomingMessage, AUTO, true,0);
                                    emon1.current(ANALOG_INPUT_SENSOR, 30);             // Current: input pin, calibration.
                                    double Irms = emon1.calcIrms(1480);  // initial boot to charge up capacitor (no reading is taken) - testing
                                    request(CHILD_ID,V_VAR1);
                                    //end of energy clamp code
                                  sendSketchInfo("Energy Meter SCT013", "2.0");
                                  present(CHILD_ID, S_POWER);
                                  present(CHILD_ID_HUM, S_HUM);
                                    //process();
                                    //KWH reveived check
                                    if (!KWH_received) request(CHILD_ID,V_VAR1);
                                    // power used each minute
                                    if (minuten < 60) {
                                      double Irms = emon1.calcIrms(1480);  // Calculate Irms only
                                      long watt = Irms*240.0; // default was 230 but our local voltage is about 240
                                      wattsumme = wattsumme+watt;
                                      minuten++;
                                      Serial.print(watt);         // Apparent power
                                      Serial.print("W I= ");
                                      Serial.println(Irms);          // Irms
                                    // end power used each minute
                                    // hours KW reading
                                    if (minuten >= 60) {
                                      wh = wh + wattsumme/60;
                                      kwh = wh/1000;
                                      send(kwhMsg.set(kwh, 3)); // Send kwh value to gw
                                      send(msgKWH.set(kwh, 3)); // Send kwh value to gw
                                      wattsumme = 0;
                                      minuten = 0;
                                  // end of hourly KW reading
                                  // Humidity Sensor Code
                                   if (minuten == 15 || minuten == 30 || minuten == 45|| minuten == 60) {
                                      if (isnan(temperature)) {
                                        lastTemp = temperature;
                                      if (!metric) {
                                      Serial.print("T: ");
                                    if (isnan(humidity)) {
                                        lastHum = humidity;
                                        Serial.print("H: ");
                                        Serial.println(humidity);
                                   wait(SLEEP_TIME);
                                    if (message.type==V_VAR1) {
                                      kwh = message.getFloat();
                                      wh = kwh*1000;
                                      Serial.print("Received last KWH from gw:");
                                      Serial.println(kwh);
                                      //send(kwhMsg.set(kwh, 3)); // Send kwh value to gw
                                      KWH_received = true;
                                  Talat KeleşT Hassan AnsariH 2 Replies Last reply
                                  • P patrick schaerer
                                    float kwh = 0;
                                    float wh = 0;
                                    DHT dht;
                                    float lastTemp;
                                    float lastHum;
                                      //energy clamp code
                                      //process();
                                      if (minuten < 60) {
                                        minuten++;
                                      // hours KW reading
                                        kwh = wh/1000;
                                        wattsumme = 0;
                                        minuten = 0;
                                        if (!metric) {
                                          lastHum = humidity;
                                     wait(SLEEP_TIME);
                                        wh = kwh*1000;
                                    Talat KeleşT
                                    Talat KeleşT
                                    Talat Keleş
                                    wrote on last edited by Talat Keleş
                                    I just got my sct-013-000 non-burden version and will try it as soon as atmega+nrf packs arrive. Thanks for code update. :thumbsup:
                                    Meanwhile what is "msgKWH" for? What is different than "kwhMsg"? Which controller do you use?
                                    • john7845J
                                      john7845J
                                      john7845
                                      Hello, now with the new code I get this error:
                                      Arduino: 1.6.9 (Windows 10), Board: "Arduino/Genuino Uno"
                                      C:\Users\LENOVO\Desktop\arduino_code\Voltage_sensor_5\Voltage_sensor_5.ino:58:19: fatal error: DHT.h: No such file or directory
                                      compilation terminated.
                                      exit status 1
                                      Error compiling for board Arduino/Genuino Uno.
                                      Talat KeleşT 1 Reply Last reply
                                      • john7845J john7845
                                        exit status 1
                                        Talat KeleşT
                                        Talat KeleşT
                                        Talat Keleş
                                        @john7845
                                        Error is related to missing library of DHT. If you will use DHT temperature/humidity sensor in your circuit, you should add DHT library to your Sketchbook/libraries folder. If you don't use that sensor, clear or comment out dht related codes in sketch.
                                        • john7845J
                                          john7845J
                                          john7845
                                          I use this code just to see if the current sensor works, but I get 0.0 on the serial! What am I doing wrong?
                                          ReadAnalogVoltage
                                          Reads an analog input on pin 0, converts it to voltage, and prints the result to the serial monitor.
                                          Graphical representation is available using serial plotter (Tools > Serial Plotter menu)
                                          Attach the center pin of a potentiometer to pin A0, and the outside pins to +5V and ground.
                                          This example code is in the public domain.
                                          // the setup routine runs once when you press reset:
                                          // initialize serial communication at 9600 bits per second:
                                          Serial.begin(9600);
                                          // the loop routine runs over and over again forever:
                                          // read the input on analog pin 0:
                                          int sensorValue = analogRead(A0);
                                          // Convert the analog reading (which goes from 0 - 1023) to a voltage (0 - 5V):
                                          float voltage = sensorValue * (1.0 / 1023.0);
                                          // print out the value you read:
                                          Serial.println(voltage);
