  3. RFSensor
RFSensor
cryptopressurehumiditycr2450mysensorstemperaturecontest2016lightcr2032
17 Posts 7 Posters 8.1k Views 6 Watching
  • jbjallingJ
    jbjallingJ
    jbjalling
    Great idea. I'll upload it tomorrow.
    BR Jonas
    • jenbakerJ
      jenbakerJ
      jenbaker
      hi
      i am new in this field.
      hope to learn from each other here.
      could i embed it into these any rfid reader ?
      waiting for help.
      jbjallingJ 1 Reply Last reply
      • jenbakerJ jenbaker
        hi
        waiting for help.
        jbjallingJ
        jbjallingJ
        jbjalling
        @jenbaker Hi,
        well, it could be possible to embed it in a RFID reader, but it isn't really the purpose of the device.
        It is intended to be a stand-alone environment sensor.
        BR Jonas
        jenbakerJ 1 Reply Last reply
        • jbjallingJ jbjalling
          @jenbaker Hi,
          BR Jonas
          jenbakerJ
          jenbakerJ
          jenbaker
          @jbjalling
          hi great.
          thanks.
          • alexsh1A
            alexsh1A
            alexsh1
            hi
            any update on schematic please?
            Alex
            • jbjallingJ
              jbjallingJ
              jbjalling
              I have uploaded the Rev. 1.0 schematic. I'm currently making some small changes, to be able to use the RF69 module as well as the nRF24L01+.
              • GertSandersG
                GertSandersG
                GertSanders
                I see that you use ADC7 to power the BPM180. This will not work, ADC7 is an analog sensing pin only and can not be used as digital output (same for ADC6). Better to use PD4, which is still available in your v1 schematic.
                • GertSandersG
                  GertSandersG
                  GertSanders
                  @jbjalling I do not really understand why you need 2 FETs to switch the nrf power line. How do you see this work ?
                  • jbjallingJ
                    jbjallingJ
                    jbjalling
                    Yep, thanks. Found out the hard way :-/ I'm not sure if I really want to power the sensors from the micro. I have to turn on every sensor to be able to use the I2C bus, so I cant turn them on selectively, as I had hoped.
                    BR Jonas
                    • jbjallingJ
                      jbjallingJ
                      jbjalling
                      I use the N-fet to drive the P-fet, which powers the radio module - again, I'm not sure if its worth it, but when the power comes from a coincell, every nA counts.
                      /Jonas
                        nice work. for UV, I prefer VEML6070, a lot more precise ;) but not same price and not ambiant light
                        I agree with @GertSanders too, you just need one pfet for powering off radio..
                        • scalzS scalz
                          jbjallingJ
                          jbjallingJ
                          jbjalling
                          @scalz Yes, the Vishay one is more precies indeed, but my main reason for putting the Silabs one on the board, was to detect the ambient light level.
                          Reg. the mosfet, yes I could have used a single fet. I think the reason why I did it like this, was that in a previous project, I was controlling higher voltages, hence the need for the n-fet.
                          Anyway, I'm not sure if I will keep it or if I will just let the radio be powered on, all the time, in the next rev.
                          BR Jonas
                          • jbjallingJ
                            jbjallingJ
                            jbjalling
                            I have updated the schematic to rev. 1.1.
                            The following has been changed:
                            • Si1133 has been replaced by Si1145
                            • The mosfets are removed from the radio power path
                            • Radio pins shuffled around a bit
                            • FTDI connector removed from PCB and instead I made a programming jig
                            • All I2C sensors are powered from the same pin of the uC, as well as the I2C pull-ups (haven't decided which pin yet, still routing the PCB)
                            Comments are more than welcome.
                            BR Jonas
                            • MiKaM
                              MiKaM
                              MiKa
                              possible to share pcb files?
                              THX
                              MiKa
                              12.5k
