  2. Bug Reports
  3. Possible Bug using Authentic Nordic nRF24L01+ Module
44 Posts 7 Posters 18.0k Views 6 Watching
  • tbowmoT
    tbowmoT
    tbowmo
    @tcontrada
    I only have China modules :). Right now I don't have the bandwidth for debugging nrf problems, and I have almost decided to go with rfm69 for my sensors instead of the nrf module (mostly due to theoretical better rf coverage)
    • tbowmoT tbowmo
      @tcontrada
      tcontrada
      @tbowmo Understand, any suggestions on another person to help. I think that in all honesty we should make this work and resolve the issue.
      • tbowmoT
        tbowmoT
        tbowmo
        @tcontrada
        This is not only related to the sensebender, it's the core library. So any one could look into it.. :)
        • T tcontrada
          @hek
          @hek said:
          The sketch works. We can rule out that. I suspect the power requirement might differ from the clone. You could play around width extra capacitors on the module.
          Well, not sure how you can say the sketch works when I have it here and it does not work with the Nordic module.
          Have you tested the SensBender sketch with the genuine Nordic module?
          Since these are battery powered adding a capacitor will not make a difference and it will further drain the battery over time.
          Again, there is something else going on...
          alexsh1A
          alexsh1A
          alexsh1
          #36
          @tcontrada said:
          @hek
          I would definitely back up @hek on this. It works for 99% people on this forum. We all are sourcing Nordic modules from Aliexpress / eBay (read China). Personally, I have not seen a single genuine module (not chip) built by Nordic so every test is based on chinese modules.
          I believe that the issue you have is related to a radio stack and not related to the sensebender sketch.
          • alexsh1A alexsh1
            @tcontrada said:
            @hek
            tcontrada
            @alexsh1 I believe the sketch works for the Chinese chips, as you say, but not for the genuine Nordic chips.
            That said, I contacted ITead yesterday and asked if the Nordic Module they sell uses the genuine Nordic chip or another chip from a 3rd party. The response I got back was that the supplier they get the Nordic chips says they are authentic. Although, they did not indicate which supplier. So I replied back to ask which supplier they use and I am still waiting for a response from ITead on this question.
            Let's say that ITead is using an authentic chip. I run the sketch with their module and it works. I replace the module with the Nordic sample I have and the sketch does not work. So now what?
            Is ITead actually using the authentic chip or not?
            alexsh1A 1 Reply Last reply
            • T tcontrada
              alexsh1A
              alexsh1A
              alexsh1
              #38
              @tcontrada The problem is to identify whether the a chip is genuine. Personally, I am not going to spend days on this. If modules are working - fine. If not I get my money back and move on to the next reseller. Unfortunately, that's the way it is with these modules.
              BTW, I do not think ITead will provide you its supplier. I wouldn't not. As you can appreciate they are resellers so putting their customer directly to suppliers is not in their best interest
              T JokgiJ 2 Replies Last reply
              • alexsh1A alexsh1
                tcontrada
                @alexsh1 I think that the folks that are getting unknown Nordic fakes are actually shortchanging themselves. First there is no way the Chinese can make an exact duplicate of the Nordic chip, all they can do is make a cheap facsimile (which is what they do best anyway). If you're like me an seriously want to utilize the work that the guys did on the SensBender module and get the longest battery life and best RF performance then you'd want to use the genuine Nordic chip.
                Second, Nordic does not manufacture those chips in China anyway (according to Nordic). So if a reseller says they get them from a Chinese manufacturer then they are fake, no doubt.
                I also received an email from Seeed Studio indicating they get their chips from a Chinese manufacturer...So probably fake as well.
                JokgiJ 1 Reply Last reply
                • alexsh1A alexsh1
                  JokgiJ
                  JokgiJ
                  Jokgi
                  @alexsh1 Of course there is no requirement that they say who they are using. However If the parts are Genuine Nordic nRF24L01P then releasing the source of the Nordic devices should not be a issue as the authorized worldwide Nordic Semiconductor distributors are listed on the Nordic Semiconductor Web Site. So if the Manufacture of the modules were not forthcoming with the distributor used this would raise questions in my mind as to the history of the parts.
                  • T tcontrada
                    JokgiJ
                    JokgiJ
                    Jokgi
                    @tcontrada The flow of Nordic materials are as following : Wafer fabrication, packaging (QFN or WLCSP) test, then packaging (Tape & Reel or Tray). None of this is done in China. The finished goods are then sent to the authorized distributors worldwide for sale to manufactures. There are authorized distribution channels in China.
                    • JokgiJ Jokgi
                      tcontrada
                      @Jokgi So then why would these companies not use the authentic Nordic chips if there are distributors in China? Seems like a lot of trouble to go and produce fake chips when the real chips are readily available there already?
                      • T tcontrada
                        JokgiJ
                        JokgiJ
                        Jokgi
                        @tcontrada I cannot say what their motivation is. I would imagine that the parts being made in China are still cheaper to manufacture. I am not hip to all the ways the Chinese government (State Capitalism) assists their companies but that may enter into the equations. (incentives, etc).
                        • JokgiJ Jokgi
                          tcontrada
                          @Jokgi Hi Jokgi, do you think you can have a rep from Nordic send out some sample authentic modules to the MySensors community to those that can help solve the deficiency between the fake and authentic modules? I think that might help.
                          If there are community members that might want to work with the authentic module maybe reply here if interested.
