  3. OTA flash types for MySensors
64 Posts 23 Posters 36.4k Views 20 Watching
  • tbowmoT
    tbowmoT
    tbowmo
    @Dirk_H
    Did you test the SST25 together with DualOptiboot? Or is it only the writing from library that is tested?
    • D
      Dirk_H
      @tbowmo
      I tested the complete chain with SST25. I.e. I prepared two sketches and uploaded them via OTA with MYSController and checked that the sketch changed via presentation Message.
      Dual Optiboot does not need modification because AFAIK it only reads from Flash, which works the same way for SST and other Flash Types.
      • KoreshK
        KoreshK
        Koresh
        wrote on last edited by Koresh
        I am new in this thread. But I think it may be worth using spi jedec flash in my latest hardware projects (insertable socket and insertable switch). So it will key to the future :)
        What about atmel AT26DF series(4/8mb)? It's compartible with AT25DF series pin to pin.
        • tbowmoT
          tbowmoT
          tbowmo
          @Dirk_H
          I think that DualOptiboot is writing to the external flash, after a successful upgrade of the internal flash, as it tries to delete the image stored there.
          But I haven't looked that much into the design of dualoptiboot.. Just forked it, and adjusted bits here and there, to be suitable for the sensebender :) So I don't know what commands it uses to erase the data.
          • D
            Dirk_H
            wrote on last edited by Dirk_H
            @tbowmo
            I looked at the defines inside the DualOptibootloader, I truly hope that there is no "hardcoded" opcode hidden somewhere... Assuming this, dualoptiboot does not write to the SPIFlash. It does erase, however thats not writing in this scope ;)
            #define SPIFLASH_STATUSWRITE      0x01        // write status register
            #define SPIFLASH_STATUSREAD       0x05        // read status register
            #define SPIFLASH_WRITEENABLE      0x06        // write enable
            #define SPIFLASH_ARRAYREADLOWFREQ 0x03        // read array (low frequency)
            #define SPIFLASH_BLOCKERASE_32K   0x52        // erase one 32K block of flash memory
            #define SPIFLASH_BLOCKERASE_64K   0xD8        // erase one 32K block of flash memory
            #define SPIFLASH_JEDECID          0x9F        // read JEDEC ID
            @Koresh please post a link to the datasheet. You can also check on your own: check if your spi-flash supports all commands listed in the SPIFlash.h defines. Of cause obvious things such as pinning and supply voltage range must also be checked.
            A caveeat I fell into, was that opcode 0x02 supports byte and pageprogramming for some SPI-Flash types but not for all (e.g. SST25 does not support pageprogramming but therefore has the AAI Wordprogramming feature).
              interesting..on my side I like the AT25DF512 for its voltage range 1.65v min and its low power mode 0.2uA in deepest mode. better for low power batt nodes I think..too bad there is not something like this in i2c format but I guess these flash types prefer faster spi transfer..
              • D
                Dirk_H
                Yes the AT25DF512 seems to outperform other memories and is truly a good chip. However unfortunately its hard to get in Germany (and maybe other parts of the world ;) ). The common distributors here do not have it in stock...
                AWIA 1 Reply Last reply
                • D Dirk_H
                  AWIA
                  AWIA
                  AWI
                  wrote on last edited by AWI
                  #23
                  @Dirk_H said:
                  AT25DF512
                  Hard for me to determine but is this different from AT25F512N?
                  D 1 Reply Last reply
                  • AWIA AWI
                    @Dirk_H said:
                    AT25DF512
                    Dirk_H
                    #24
                    @AWI
                    The AT25F512 (from Atmel?) is quiet different from the Adesto AT25DF512. As far as I can see the Atmel one seems not to have a Block erase command (32k/64k), which is used in MySensor AND in Bootloader code.
                    If I'm not wrong with that assumption (and I dont think I am), I would NOT recommend to use the Atmel AT25F512.
                    To all: please provide links to the Datasheet if you expect help... Its tedious to search them every time. Gulpman did great preparation work in his post above.
                    Edit: Never mind what I said in this Post. I got confused with sectors pages and blocks :eyes: ... I'll write some more later.
                    • tbowmoT
                      tbowmoT
                      tbowmo
                      @Dirk_H
                      It seems that atmel is calling it "Sector erase" instead of "Block erase".
                      • bjacobseB
                        bjacobseB
                        bjacobse
                        Hi I just wonder if this Spansion, S25FL208K0RMFI040 could be used?
                        http://www.mouser.com/ds/2/100/S25FL208K_00-933907.pdf
                        • D
                          Dirk_H
                          About the AT25F512N wich was proposed by @AWI: tbowmo was right, I got confused by Sector, Page and Block erase. Like tbowmo said atmel does call blocks sectors... The AT25F512 does not support Block Erase 64k, which is defined but AFAIK not used in SPIFlash.cpp BUT it is used in the Bootloader if the "Imagesize" is > 32k. But I dont know how Image size is retrieved. Also I think for an ATMega 328p the image size should never be >32k. So this Flashtype could probably work as long as the image size is below 32k. I'd expect the Bootloader to crash or fail when program size is >32k.
                          About the S25FL... @bjacobse proposed I see the problem that it does not support the Bock Erase 32k opcode which is used in SPIFlash.cpp and Bootloader. Both must be changed when S25FL... should be used. (I would emulate the 32k Block erase by 8 times 4k Block erase.) However remember that Dualoptiboot must also be altered which requires "non-arduino" programming and some work / knowlegde about makefiles / compiler/linker settings in IDE.
                          bjacobseB 1 Reply Last reply
                          • D Dirk_H
                            bjacobseB
                            bjacobseB
                            bjacobse
                            @Dirk_H
                            Thank you Dirk for checking the flash I asked about. I have noticed that the company I'm working is using this device. And then I hoped I could buy it from the company to a hopefully reduced price compared to retail price for private.
                            • L
                              L
                              LastSamurai
                              Hey, guys I am currently looking for a (cheap) solution for OTA available in germany. I wanted to use the AT25DF512C-SSHN-B but the only source I could find was aliexpress which only sells 150 pcs at a time (a little too much, although future proof for me I guess ;) ).
                              I did not really understand this thread so far: is there another model that works with my sensors?
                              Or do you by chance know a place where I can get some of the AT25DF512C-SSHN-B ones here in europe? Thanks!
                              jbjallingJ 1 Reply Last reply
                              • L LastSamurai
                                jbjallingJ
                                jbjallingJ
                                jbjalling
                                wrote on last edited by jbjalling
                                #30
                                @LastSamurai said:
                                AT25DF512C
                                Well not in EU, but you can order from DigiKey or Mouser if everything else fails - thats where I order my parts.
                                EDIT: And I live in DK - maybe worth mentioning.
                                BR Jonas
                                L 1 Reply Last reply
                                • jbjallingJ jbjalling
                                  @LastSamurai said:
                                  AT25DF512C
                                  BR Jonas
                                  L
                                  L
                                  LastSamurai
                                  @LastSamurai said:
                                  AT25DF512C-SSHN-B
                                  Thanks, but both have shipping costs of abount 20€ (if you pay <50€ overall). Or is there a way around it?
                                  I also found SST25VF020B‑80‑4I‑SAE and 25VF512A33-4C-SA flash modules in german stores though. Would they work too?
                                  • L LastSamurai
                                    @LastSamurai said:
                                    AT25DF512C-SSHN-B
                                    jbjallingJ
                                    jbjallingJ
                                    jbjalling
                                    @LastSamurai Yes, thats true. My order is always above the "free shipping" limit :-)
                                    I'll give the datasheets a look, of the devices you mentioned.
                                    BR Jonas
                                    • D
                                      Dirk_H
                                      @LastSamurai The SST25VF020B... should work fine with the 2.0 developversion and #define MY_SPIFLASH_SST25TYPE set. It seems to be very close to the SST25PF020B I used. However keep an eye on the even more limited voltage range of the SST25VF Type which needs at least 2,7V which would be a problem if you want to power your circuit directly by 2xNiMH Batteries.
                                      The SST25VF512 needs also 2,7V but additionally does not support the 64k erase command (see my comments on that issue some posts above where I wrote something about the AT25F512).
                                      • X
                                        X
                                        XavTroniC
                                        wrote on last edited by XavTroniC
                                        #34
                                        Hi all,
                                        A question, why don't use an EPPROM SPI 25AA020A or 25AA512?
                                        They works between 1.8 and 5.5V.
                                        BR
                                        Xavier
                                        S 1 Reply Last reply
                                        • alexsh1A
                                          alexsh1A
                                          alexsh1
                                          #35
                                          I have AT25512N-SH-T SOIC-8 -> http://www.mouser.com/ds/2/36/Atmel-5165-SEEPROM-AT25512-Datasheet-476711.pdf
                                          Anyone knows if it is fully interchangeable with AT25DF512C? I cannot see any difference from the datasheet. The pinout is the same.
