  3. Controlling an inductive AC load
19 Posts 5 Posters 11.3k Views 4 Watching
  • dbemowskD
    dbemowskD
    Martin, Thanks for the response. I just wired up a serial gateway last night and now I need to build me a sensor to test it with. I may try some kind of multi-sensor node to test this
    AWIA 1 Reply Last reply
    • martinhjelmareM
      martinhjelmareM
      martinhjelmare
      For testing the radio coms and mysensors protocol, I recommend this sketch that will mock sensors:
      https://github.com/mysensors/Arduino/tree/master/libraries/MySensors/examples/MockMySensors
      This will let you test node to gateway coms without having to add any real sensors.
      • dbemowskD dbemowsk
        I am looking for a way to do speed control of a ceiling fan. The motor is obviously an inductive load and from my understanding is not too friendly to triacs. Is there a way that I can create a MySensors controller for ceiling fan speed control? What I might like to do on some is create a dual purpose ceiling fan and light dimmer as I have some combinations like this in some rooms. The light dimming I can do easily with a triac, it's the fan I am having trouble with.
        I am pretty new to MySensors, so a question I would have is when creating a node that has more than one sensor/controller on it, how do you define each so they are seen as separate devices on that node?
        m26872M
        m26872M
        m26872
        @dbemowsk Buy a speed controller then MySensorize it.
          AWIA
          AWIA
          AWI
          @dbemowsk I agree with @m26872 to have it save . There are many different types of ceiling fan types. Most available where I live are multiple (3) speed types which can easily be controlled with 3 "on/off" triac circuis (do include a snubber for the inductive load).
          I suppose you are familiar with building triac circuits, make sure you have galvanic isolation (optocoupler).
          0_1465070067072_upload-cc622a7e-6dfd-4723-b02f-a9813aebb16e
          • dbemowskD
            dbemowskD
            I have done a few triac circuits in past years. I wouldn't interface a triac circuit with anything but an optocoupler.
            • dbemowskD
              dbemowskD
              @m26872 I have never taken a dimmer apart myself. Is the circuit complex? I would prefer a schematic, but if the circuit is as simple as the one above I may be able to figure it out.
              alexsh1A 1 Reply Last reply
                alexsh1A
                alexsh1A
                alexsh1
                @dbemowsk You need to get the SSR relay connected to your arduino. I have it hooked up to my raspberry to remotely control 240V devices. You need to apply 3V to it in order to relay to switch on. Crydom is the top name though expensive. The same relay I have to control my hot water tank, which is heated at night (due to lower electricity cost).
                This is a link to a similar relay. I have 50A one as I need to control 3kW heater:
                http://uk.farnell.com/crydom/d2425/ssr-25a-24-280vac-3-32vdc-zero/dp/1200241
                • dbemowskD
                  dbemowskD
                  @alexsh1 An SSR will only turn the fan on and off. It will not allow any speed control which is what I am looking for. I currently have them connected to X10 inductive load dimmers and they work, but I am trying to see if I can move away from my X10 setup.
                    alexsh1A
                    alexsh1A
                    alexsh1
                    @dbemowsk Ok, how is it set-up now? More voltage - more speed?
                    • dbemowskD
                      dbemowskD
                      These are the dimmers I use: https://www.x10.com/xpdi3-dimmer-120-vac-500w-inductive.html . I never pulled the dimmer apart and scoped it or anything like that, so I am not sure. Could use PWM for all I know.
                      AWIA alexsh1A 2 Replies Last reply
                        AWIA
                        AWIA
                        AWI
                        wrote on last edited by AWI
                        @dbemowsk this article describes how to build triac dimmers for inductive loads. The x10 dimmer you use is most probably like the type 2. And thus a phase cutting dimmer.
                        The circuit above is for on/off (SSD) and would need to be switched synchronized with the net frequency. There are a few examples on the forum on how to let the Arduino take care of that.
                        All assuming that your fan can take phase cutting dimming.
                        • dbemowskD
                          dbemowskD
                          So, do you think it would be possible to use something like this:
                          http://www.ebay.com/itm/DIMMER-AC-MOTOR-for-Fan-Light-Bulb-electric-1000-WATT-electronic-circuit-board-k-/282042936124?hash=item41ab11ab3c:g:2VMAAOSwxehXPWC3
                          and control it with something like an AD5171 Digital Pot in place of the pot that comes with the kit?
                            AWIA
                            AWIA
                            AWI
                            @dbemowsk No... looking at the diagram there is no galvanic isolation.. .
                            0_1465105655511_upload-36f004aa-9aca-4d09-b0fc-60a54756c18f
                            This one requires to be isolated with plastic (including knob).
                            The AD5171 is a nice piece of circuit but is not isolated either, would need a seperate power supply from your arduino and is not suited for high voltage/current AC environment. (and would make an expensive solution)
                            If you want to meet you expected lifetime (I don't want to contribute to someone death) you better take a safer approach..
                            A few options:
                            1. the cheapest: build a circuit yourself like the one you cited and replace VR1 with and LDR and LED like this guy did. 0_1465106462915_upload-c804b20a-d546-43df-ad83-98881b6141cb
                            2. similar circuit (or take another working dimmer and attach a servo ;-) (that is what my son would do)
                            3. Go for the (complicated but fun) solution and like discussed in this topic.
                              0_1465106962029_upload-573c2269-184f-445f-ab1d-78569c0ddf8b
                            • dbemowskD
                              dbemowskD
                              Another option mentioned by @m26872 was modifying an existing switch. I was thinking a switch like this:
                              http://www.menards.com/main/electrical/light-switches-dimmers-outlets/dimmer-fan-control-combination/legrand-2-5-amp-300-watt-de-hummer-fan-single-pole-control-dimmer/p-1444451193535-c-6322.htm?tid=1329371385801776297
                              I could use the LED, LDR and shrink tube solution to get isolation as I would imagine that the switch just has 2 VR sliders. With that I would already have a combination switch that is designed to do what I want, I would just have to MySensorize it as @m26872 says.
                                alexsh1A
                                alexsh1A
                                alexsh1
                                @dbemowsk
                                FYG, I am controlling dimming via SSR on a few 240V lamps - ok not motors.
                                I think @AWI already said it all - time to dismantle your dimmer :)
                                You may want to read this:
                                http://alfadex.com/2014/02/dimming-230v-ac-with-arduino-2/
                                  AWIA
                                  AWIA
                                  AWI
                                  @dbemowsk what you will find is a circuit very comparable to the ones mentioned.
                                  To "MySensor"ize you you still need to control it from an arduino with (safe) stable power supply and isolation.
                                  Maybe easier to dismantle your x10 device.
                                  It's hard to determine your experience level from your questions but you need to be able to:
                                  1. Build a (semi) digital motor control.
                                  2. Have little experience with an arduino MySensors device.
                                    3.tie these together
                                  • dbemowskD
                                    dbemowskD
                                    @awi I have one of the X10 switches that I dismantled the other day and the issue with trying to use that is that there is so much circuitry for the X10 portion of the thing that without having a schematic, I wouldn't know exactly what to disconnect to only leave the triac motor control circuit. Also where and how to connect in my galvanic isolation circuit.
