  3. Battery powered PIR and temp/humid sensor
22 Posts 7 Posters 10.3k Views 8 Watching
  • T tomkxy
    @hek This will definitely help but it still means that there is no real means to control the time between temp/humid measurements. In the worst case the PIR triggers over a longer time always the interrupt and thus temp is never send. Even if I introduce some counter which when reached will trigger a temp measurement I have no glue what the interval length in between is. Or do I miss something?
    @tomkxy
    I don't understand.. the timer option will wake your board at the specified time even if no motion was detected.
    • T
      tomkxy
      @hek
      Sorry, I didn't express it well enough.
      Let's say my sketch would sleep between two measurements 60 sec and send every 30 measurements its value, which means every 30 minutes (which are the defaults of the sensebender sketch). I can increase or reduce the frequency by adjusting the sleep times and send intervals easily.
      By introducing the interrupt - which I think there is no way around -, the sleep time can be interrupted somewhere between 1 second and 60 seconds. And I don't know how long my sketch has slept. If I cannot determine the time how long my sketch was sleeping I cannot determine when I should take the next temp/humid measurement. Although I can still use the loop counter, I have no control over the elapsed time between two temp/humid measurements.
        True, if you wake up from pin change you haven't the exact knowledge of elapsed time (< MAX-SLEEP-TIME though).
        But in most applications I doubt it would super exact temp-send-interval would matter much... It will only diff when pin change wake-up interfere.
        • T
          tomkxy
          @hek
          Thanks! That confirms my understanding.
          • HaakonH
            HaakonH
            Haakon
            @tomkxy: Have you gathered some experiences with this setup over time? And would you mind sharing the Arduino sketch you are using?
            I am hoping to do more or less the same with Sensebenders and PIRs, and I am new to electronics of this sort.
            • T
              tomkxy
              @Haakon I have one of these sensor in place since about half a year and it is working well. Last battery change is about 4 month ago.
              Please find the sketch below which requires some cleanup.
              Multisensor Sketch
              Author: Thomas Krebs, thkrebs@gmx.de
              This sketch reads temperature, humidity, light and presence.
              It is based on the various examples sketches from SparkFun and MySensors
              It uses the following sensors:
              Light           - TSL2561
              Temp&Humidity   - HTU21D
              Presence
              HTU21D and TLS2561 need to connect the I2C pins (SCL and SDA) to your Arduino.
              The pins are different on different Arduinos:
                                  SDA    SCL
              Any Arduino         "SDA"  "SCL"
              Uno, Redboard, Pro  A4     A5
              Mega2560, Due       20     21
              Leonardo            2      3
              #define MY_DEBUG_VERBOSE_SIGNING //!< Enable signing related debug prints to serial monitor
              #define MY_SIGNING_FEATURE
              #define MY_SIGNING_ATSHA204
              #define MY_NODE_ID              26
              #define BATT_SENSOR
              #include <TSL2561.h>
              #include <SparkFunHTU21D.h>
              #include <avr/power.h>
              #define VERSION           "1.4"
              #define SKETCH_NAME       "Multisensor A"
              #define TEMP_CHILD_ID   1
              #define HUM_CHILD_ID    2
              #define LIGHT_CHILD_ID  3
              #define MOTION_CHILD_ID 4
              // Uncomment the line below, to transmit battery voltage as a normal sensor value
              #define BATT_SENSOR    199
              #define MAX_VOLTAGE    1316
              #define MIN_VOLTAGE    890     // it seems that about 0.89 V the sensor stops working
              #define MEASURE_INTERVAL 120000
              #define FORCE_TRANSMIT_INTERVAL 30
              #define HUMI_TRANSMIT_THRESHOLD   0.5
              #define TEMP_TRANSMIT_THRESHOLD   0.5
              #define LIGHT_TRANSMIT_THRESHOLD  0.3    // relative change
              // Pin definitions
              #define LED_PIN            13            // TODO: need to check that
              #define BATTERY_SENSE_PIN  A0            // select the input pin for the battery sense point
              #define MOTION_SENSOR      3             // The digital input you attached your motion sensor.  (Only 2 and 3 generates interrupt!)
              #define INTERRUPT          1             // Usually the interrupt = pin -2 (on uno/nano anyway)
              // Global settings
              int tempMeasureCount = 0;
              int lightMeasureCount = 0;
              int sendBattery = 0;
              boolean isMetric = true;
              boolean highfreq = true;
              boolean motionDetected = false;
              int repeats = 2;
              float lastTemperature = -100;
              float lastHumidity = -100;
              long  lastBattery = -100;
              long  lastLight = -5000;
              int   lastTripped = -1;
              int   motionTrips = 0;  // count the number of cont. motion trips
              HTU21D myHumidity;
              TSL2561 myLight(TSL2561_ADDR_FLOAT);
              // Sensor messages
              MyMessage msgTemp(TEMP_CHILD_ID,V_TEMP);
              MyMessage msgHum(HUM_CHILD_ID,V_HUM);
              MyMessage msgLight(LIGHT_CHILD_ID,V_LEVEL);
              MyMessage msg(MOTION_CHILD_ID, V_TRIPPED);
              #ifdef BATT_SENSOR
              MyMessage msgBatt(BATT_SENSOR, V_VOLTAGE);
               * Setup code
                pinMode(LED_PIN, OUTPUT);
                Serial.print(F(SKETCH_NAME));
                Serial.println(VERSION);
                Serial.flush();
              #ifdef MY_SIGNING_ATSHA204_PIN
                // Make sure that ATSHA204 is not floating
                pinMode(MY_SIGNING_ATSHA204_PIN, INPUT);
                digitalWrite(MY_SIGNING_ATSHA204_PIN, HIGH);
                analogReference(INTERNAL);
                // setup sensors
                setup_htu21d();
                delay(100);
                setup_tls2561();
                delay(500);
                // setup motion sensor
                pinMode(MOTION_SENSOR, INPUT);
                Serial.println(F("Setup complete..."));
              void presentation()  {
                sendSketchInfo(SKETCH_NAME, VERSION);
                present(TEMP_CHILD_ID, S_TEMP);
                present(HUM_CHILD_ID, S_HUM);
              //  present(LIGHT_CHILD_ID,S_LIGHT_LEVEL);
                present(MOTION_CHILD_ID, S_MOTION);
              #ifdef BATT_SENSOR
                present(BATT_SENSOR, S_POWER);
                isMetric = getConfig().isMetric;
              #ifdef MY_DEBUG
                Serial.print(F("isMetric: ")); Serial.println(isMetric);
                Serial.flush();
              /* Setup HTU21d
              void setup_htu21d() {
                myHumidity.begin();
              #ifdef MY_DEBUG
                Serial.println("Setup temp/humid sensor completed");
              /* Setup TLS2561
              void setup_tls2561() {
                if (myLight.begin()) {
                  Serial.println(F("Found light sensor"));
                  Serial.println(F("Light Sensor not found - cont. anyway"));
                myLight.setGain(TSL2561_GAIN_0X);          // set 16x gain (for dim situations)
                // Changing the integration time gives you a longer time over which to sense light
                // longer timelines are slower, but are good in very low light situtations!
                //tsl.setTiming(TSL2561_INTEGRATIONTIME_13MS);  // shortest integration time (bright light)
                myLight.setTiming(TSL2561_INTEGRATIONTIME_101MS);  // medium integration time (medium light)
                //tsl.setTiming(TSL2561_INTEGRATIONTIME_402MS);  // longest integration time (dim light)
               *  Main loop function
                tempMeasureCount++;
                lightMeasureCount++;
                sendBattery++;
                bool forceTransmit = false;
                if (motionDetected) {
                  sendMotion(false);  // do not force transmission unless motion status has changed
                // do not enter into sensor data gathering on each motion tripped
                if ((!motionDetected) || (motionTrips > 3)) {
                  motionTrips = 0; // avoid starvation of temp measure in case we have a lot of motion
                  // I do the battery check at the beginning
                  if (sendBattery > 60) {
                     sendBattLevel(forceTransmit); // Not needed to send battery info that often
                     sendBattery = 0;
                  if ((lightMeasureCount > FORCE_TRANSMIT_INTERVAL) || (tempMeasureCount > FORCE_TRANSMIT_INTERVAL) ) { // force a transmission
                    forceTransmit = true;
                  // Get & send sensor data
                  wait(200);
                  sendTempHumidityMeasurement(forceTransmit);
                  wait(200);
                  sendLightLevelMeasurement(forceTransmit);
                  wait(200);
                  sendMotion(forceTransmit);
                wait(100);  // I don't know whether that is really required; however I have the impression that shutting down the radio leads to
                               // problems in the communication when using signatures
                Serial.println("going to sleep");
                if (sleep(INTERRUPT,RISING, MEASURE_INTERVAL)) {
                  motionDetected = true;
                  motionTrips++;
                Serial.print("Motion detected="); Serial.println(motionDetected);
               * Sends state of motion sensor
               * Parameters
              void sendMotion(bool force) {
                bool tx = force;
                // Read digital motion value
                bool tripped = digitalRead(MOTION_SENSOR) == HIGH;
                Serial.print(F("Tripped: ")); Serial.println(tripped);
                if (lastTripped != tripped) tx = true;
                if (tx) {
                  resend(msg.set(tripped?"1":"0"),repeats);  // Send tripped value to gw
                  lastTripped = tripped;
               * Sends temperature and humidity from HTU21D sensor
               * Parameters
              void sendTempHumidityMeasurement(bool force)
                  bool tx = force;
                  float hum = myHumidity.readHumidity();
                  Serial.print(F("lastTemperature: ")); Serial.println(lastTemperature);
                  Serial.print(F("lastHumidity: ")); Serial.println(lastHumidity);
                  float diffTemp = abs(lastTemperature - temp);
                  float diffHum = abs(lastHumidity - hum);
              #ifdef MY_DEBUG
                  Serial.print(F("TempDiff :"));Serial.println(diffTemp);
                  Serial.print(F("HumDiff  :"));Serial.println(diffHum);
                  if (isnan(diffHum)) tx = true;
                  if (diffTemp > TEMP_TRANSMIT_THRESHOLD) tx = true;
                  if (diffHum >= HUMI_TRANSMIT_THRESHOLD) tx = true;
                  if (tx) {
                    resend(msgTemp.setSensor(TEMP_CHILD_ID).set(temp,1),repeats);
                    wait(20);
                    resend(msgHum.setSensor(HUM_CHILD_ID).set(hum,1),repeats);
                    lastTemperature = temp;
                    lastHumidity = hum;
               * Sends light level from TLS6512 sensor
               * Parameters
              void sendLightLevelMeasurement(bool force) {
                bool tx = force;
                uint32_t lum = myLight.getFullLuminosity();
                uint16_t ir, full;
                ir = lum >> 16;
                full = lum & 0xFFFF;
                Serial.print(F("IR: ")); Serial.print(ir);   Serial.print(F("\t\t"));
                Serial.print(F("Full: ")); Serial.print(full);   Serial.print(F("\t"));
                Serial.print(F("Visible: ")); Serial.print(full - ir);   Serial.print(F("\t"));
                double lux = myLight.calculateLux(full, ir);
                Serial.print(F("Lux: ")); Serial.println(lux);
                float diffLux = abs(lastLight - lux);
              #ifdef MY_DEBUG
                  Serial.print(F("Lux difference since last measurement: ")); Serial.println((float)diffLux/abs(lastLight));
                  if (isnan(diffLux)) tx = true;
                  if (diffLux/abs(lastLight)  >= LIGHT_TRANSMIT_THRESHOLD) tx = true;
                  if (tx) {
                    resend(msgLight.setSensor(LIGHT_CHILD_ID).set(lux,1),repeats);
                    lastLight = lux;
               * Prints error on I2C comm bus
              void printError(byte error)
                // If there's an I2C error, this function will
                // print out an explanation.
                Serial.print(F("I2C error: "));
                Serial.print(error,DEC);
                Serial.print(F(", "));
                switch(error)
                  case 0:
                    Serial.println(F("success"));
                  case 1:
                    Serial.println(F("data too long for transmit buffer"));
                  case 2:
                    Serial.println(F("received NACK on address (disconnected?)"));
                  case 3:
                    Serial.println(F("received NACK on data"));
                  case 4:
                    Serial.println(F("other error"));
                  default:
                    Serial.println(F("unknown error"));
               * Parameters
                if (force) lastBattery = -1;
                long batteryV =  analogRead(BATTERY_SENSE_PIN);
                for (int i = 1; i<5; i++) {
                  long newSample = analogRead(BATTERY_SENSE_PIN); //readVcc();
                  batteryV -= batteryV / (i+1);
                  batteryV += newSample / (i+1);
                 // 10M, 2,86M divider across battery and using internal ADC ref of 1.1V
                 // ((10+4,7)/4,7)*1.1 = 3.4404255
                 // 3.4404255/1023 = Volts per bit = 0.003630748
                long vcc  = batteryV * 3.3630748;
                if (vcc != lastBattery) {
                  lastBattery = vcc;
              #ifdef BATT_SENSOR
                  resend(msgBatt.set(vcc),repeats);
                  // Calculate on the fully charged cell. Since I have a step-up in place I go as low as possible no offset for minimum
                 sendBatteryLevel(  ((vcc-MIN_VOLTAGE)*10.0)/((MAX_VOLTAGE-MIN_VOLTAGE)*10.0) *100.0);
               * Send message, resend on error
               * Parameters
               * - msg : message to send
               * - repeats: number of repetitions
              void resend(MyMessage &msg, int repeats)
                int repeat = 0;
                int repeatdelay = 0;
                boolean sendOK = false;
                while ((sendOK == false) and (repeat < repeats)) {
                  if (send(msg)) {
                    sendOK = true;
                    sendOK = false;
                    Serial.print(F("Send ERROR "));
                    Serial.println(repeat);
                    repeatdelay += random(50,200);
                  repeat++;
                  delay(repeatdelay);
              long readVcc() {
              HaakonH 1 Reply Last reply
              • T tomkxy
                Multisensor Sketch
                Light           - TSL2561
                Presence
                                    SDA    SCL
                Mega2560, Due       20     21
                Leonardo            2      3
                #define BATT_SENSOR
                // Pin definitions
                // Global settings
                int repeats = 2;
                HTU21D myHumidity;
                // Sensor messages
                #ifdef BATT_SENSOR
                 * Setup code
                  Serial.flush();
                  // setup sensors
                  setup_htu21d();
                  delay(100);
                  setup_tls2561();
                  delay(500);
                #ifdef BATT_SENSOR
                #ifdef MY_DEBUG
                  Serial.flush();
                /* Setup HTU21d
                  myHumidity.begin();
                #ifdef MY_DEBUG
                /* Setup TLS2561
                  tempMeasureCount++;
                  sendBattery++;
                       sendBattery = 0;
                    wait(200);
                    wait(200);
                    wait(200);
                    motionTrips++;
                 * Parameters
                  bool tx = force;
                  if (tx) {
                 * Parameters
                    bool tx = force;
                #ifdef MY_DEBUG
                    if (tx) {
                      wait(20);
                      lastHumidity = hum;
                 * Parameters
                  bool tx = force;
                  uint16_t ir, full;
                  ir = lum >> 16;
                #ifdef MY_DEBUG
                    if (tx) {
                      lastLight = lux;
                  switch(error)
                    case 0:
                    case 1:
                    case 2:
                    case 3:
                    case 4:
                    default:
                 * Parameters
                    lastBattery = vcc;
                #ifdef BATT_SENSOR
                 * Parameters
                  int repeat = 0;
                    if (send(msg)) {
                      sendOK = true;
                      sendOK = false;
                    repeat++;
                    delay(repeatdelay);
                long readVcc() {
                HaakonH
                HaakonH
                Haakon
                Thanks, @tomkxy, fantastic! I will be trying it our shortly, as soon as I got those PIRs working on 3V.
                • T
                  tomkxy
                  @Haakon Regarding the PIRs: There are a couple of postings in the Internet or I think even in this forum. For example, have a look here: http://randomnerdtutorials.com/modifying-cheap-pir-motion-sensor-to-work-at-3-3v/
                  L 1 Reply Last reply
                  • T tomkxy
                    L
                    L
                    LastSamurai
                    @tomkxy How did you power it though? I wanted to use a battery (or several ones) that might fall under 3.3V when used. So I decided to use a step-up converter but that seems to introduce too much noise, so I get false positives from the pir. From a stable 3.3V source it worked just fine.
                    • T
                      tomkxy
                      @LastSamurai I powered it through 3.3v step up with one AA battery. I cannot confirm that I get false positives.
                      martinhjelmareM L 2 Replies Last reply
                      • T tomkxy
                        martinhjelmareM
                        martinhjelmareM
                        martinhjelmare
                        @tomkxy
                        What range on the PIR do you get on 3.3 V?
                        • T
                          tomkxy
                          Around 4 meters. However, this puppy is sitting in my entrance which is rather narrow.
                          • T tomkxy
                            L
                            L
                            LastSamurai
                            Nice, what PIR and what step up did you use? Hopefully I can get the same ones too ;)
                            • T
                              tomkxy
                              I used this one one which is rather expensive. I do not remember, however whether I bought really at Sparkfun or some other place. That were one of my first purchases when I started with all that crazy stuff :-)
                              • Mark SwiftM
                                Mark SwiftM
                                Mark Swift
                                wrote on last edited by Mark Swift
                                Hi @tomkxy
                                I'm going to add one of these sensors myself, looks like you've done the hard work...
                                Could I ask what board you are using, perhaps a simple schematic too if you find a moment? I have a bunch of Nano's, some light sensors (BH1750) and temperature sensors (DS18B20's) - I presume I can swap over the code as required. Thankfully I also have a number of those exact step ups!
                                • T
                                  tomkxy
                                  @Mark-Swift I used a ProMini 3.3v. Unfortunately, I have no schematic. Since I used breakout boards anyway this is not a big deal. You connect those boards to your power, ground and a digital pin or on SCA, SCL pins. I don't know what the power consumption of the Nano's is. So that is something you have to try out.
                                  alexsh1A 1 Reply Last reply
                                  • T tomkxy
                                    alexsh1A
                                    alexsh1A
                                    alexsh1
                                    @tomkxy it is a few mA while sleeping. This means that it has to be modified (no VDO and no LED) - consumption drops to a reasonable 160uA or even below.
