  3. MYSBootloader 1.3 pre-release & MYSController 1.0.0beta
otamyscontrollermysbootloader
198 Posts 53 Posters 121.4k Views 58 Watching
  • tekkaT tekka
    @Anduril a factor 3 slower is a bit surprizing, in my hands the new bootloader performs even better than the old one. Do you have a repeater in between or are GW and the node close together? As @Dirk_H pointed out, the current .hex was compiled for 16Mhz (and is also compatible with 8Mhz) but I
    will prepare a separate 8Mhz version and 38.4kBaud for testing.
    AndurilA
    AndurilA
    Anduril
    @tekka did some testing again. I don't have a repeater inbetween, but maybe they were to close to each other (~30cm).
    I repeated the tests a few times:
    when on my desk the new bootloader is significantly slower than the old one.
    When 2m away I don't see many messages arriving. Maybe my power suply used when not at my pc was not stable enough to give the current for sending with pa-lna. I will repeat the tests with a improved setup the next days.
    Can I give you specific information where the problem is? Maybe a special log or anything else to help find the problem?
    tekkaT 1 Reply Last reply
    • AndurilA Anduril
      tekkaT
      tekkaT
      tekka
      @Anduril hmm...I'm not experiencing any speed issues with the new bootloader. Can you activate debug on your GW and post the log while running OTA updates?
      • AndurilA
        AndurilA
        Anduril
        @tekka here the serial monitor while OTA upload with #define MY_DEBUG
        0;255;3;0;9;send: 0-0-3-3 s=255,c=3,t=15,pt=0,l=2,sg=0,st=ok:
        0;255;3;0;9;read: 3-3-0 s=255,c=4,t=0,pt=6,l=10,sg=0:6E000100580648930102
        0;255;3;0;9;Client 0: 3;0;4;0;1;6E00010058068FD5
        0;255;3;0;9;send: 0-0-3-3 s=0,c=4,t=1,pt=6,l=8,sg=0,st=fail:6E00010058068FD5
        0;255;3;0;9;read and forward: 3-3-255 s=255,c=3,t=7,pt=1,l=0,sg=0
        0;255;3;0;9;send: 0-0-3-3 s=255,c=3,t=8,pt=1,l=1,sg=0,st=fail:0
        0;255;3;0;9;send: 0-0-3-3 s=255,c=3,t=8,pt=1,l=1,sg=0,st=ok:0
        0;255;3;0;9;read: 3-3-0 s=255,c=3,t=15,pt=6,l=2,sg=0:0100
        0;255;3;0;9;send: 0-0-3-3 s=255,c=3,t=15,pt=0,l=2,sg=0,st=fail:
        0;255;3;0;9;read: 3-3-0 s=255,c=4,t=2,pt=6,l=6,sg=0:6E0001005706
        0;255;3;0;9;Client 0: 3;255;4;0;3;6E0001005706FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
        0;255;3;0;9;send: 0-0-3-3 s=255,c=4,t=3,pt=6,l=22,sg=0,st=fail:6E0001005706FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
        • AndurilA Anduril
          tekkaT
          tekkaT
          tekka
          wrote on last edited by tekka
          #97
          @Anduril There are some communication issues here, i.e. the node radio doesn't not appear to receive msgs. If you put GW and node further away, different position, away from interference sources (wifi, speaker, monitor, etc.) do you see any improvements? Also you should try with different radios, larger caps, decoupling caps, stable PSU or batteries. What type of nRF24 are you using? Genuine, Clones (blob-version?).
          • AndurilA
            AndurilA
            Anduril
            @tekka I tried a few combinations: different positions (nearest ~20cm, farest ~5m with walls), radios (probably clones, but no blobs, nRF from mysensors store and others, also pa+lna for gateway) and different caps with no success. Still quite a lot of packages lost during transmision.
            I then reflashed the old bootloader again and it worked flawless for 5m and 20cm.
            • AndurilA Anduril
              tekkaT
              tekkaT
              tekka
              @Anduril Can you re-test this version of MYSBootloader (16Mhz, CH76, 250kbp) with the most recent dev 2.0.0 version (i.e. GW), clearing EEPROM before flashing is advisable. In my setup, I get pretty decent data rates for OTA updates...
              AndurilA 1 Reply Last reply
              • tekkaT tekka
                AndurilA
                AndurilA
                Anduril
                @tekka I will test this asap (hopefully this weekend). One point for clearing EEPROM: do you know if the sketch also works on the ESP8266? Because I thought to have cleared the EEPROM and uploaded a sketch without wifi config, but it still connected to my wifi.
                • AndurilA
                  AndurilA
                  Anduril
                  wrote on last edited by Anduril
                  #101
                  @tekka I did test your new bootloader, with no success. I also tried to use the nano with 8Mhz internal clock, but same result.
                  Here again the serial debug of my ESP8266 gateway:
                  With the new bootloader:
                  0;255;3;0;9;read: 5-5-0 s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                  0;255;3;0;9;send: 0-0-5-5 s=255,c=3,t=15,pt=0,l=2,sg=0,st=ok:
                  0;255;3;0;9;read: 5-5-0 s=255,c=4,t=0,pt=6,l=10,sg=0:FFFFFFFFFFFFAA160102
                  0;255;3;0;9;Client 0: 5;0;4;0;1;6E000100000819CC
                  0;255;3;0;9;send: 0-0-5-5 s=0,c=4,t=1,pt=6,l=8,sg=0,st=ok:6E000100000819CC
                  0;255;3;0;9;read and forward: 5-5-255 s=255,c=3,t=7,pt=1,l=0,sg=0
                  0;255;3;0;9;send: 0-0-5-5 s=255,c=3,t=8,pt=1,l=1,sg=0,st=ok:0
                  0;255;3;0;9;send: 0-0-5-5 s=0,c=4,t=1,pt=6,l=8,sg=0,st=fail:6E000100000819CC
                  with the old bootloader:
                  0;255;3;0;9;read: 6-6-0 s=255,c=4,t=2,pt=6,l=6,sg=0:6E000100FD07
                  0;255;3;0;9;Client 0: 6;255;4;0;3;6E000100FD070895262FF999FECF92BD81BDF89A0197
                  0;255;3;0;9;send: 0-0-6-6 s=255,c=4,t=3,pt=6,l=22,sg=0,st=ok:6E000100FD070895262FF999FECF92BD81BDF89A0197
                  0;255;3;0;9;read: 6-6-0 s=255,c=4,t=2,pt=6,l=6,sg=0:6E000100FC07
                  0;255;3;0;9;Client 0: 6;255;4;0;3;6E000100FC07CB01840F951F2E9105D041505040D8F7
                  0;255;3;0;9;send: 0-0-6-6 s=255,c=4,t=3,pt=6,l=22,sg=0,st=ok:6E000100FC07CB01840F951F2E9105D041505040D8F7
                  0;255;3;0;9;read: 6-6-0 s=255,c=4,t=2,pt=6,l=6,sg=0:6E000100FB07
                  0;255;3;0;9;Client 0: 6;255;4;0;3;6E000100FB07B8F70895DC01A40FB51F4150504040F0
                  0;255;3;0;9;send: 0-0-6-6 s=255,c=4,t=3,pt=6,l=22,sg=0,st=ok:6E000100FB07B8F70895DC01A40FB51F4150504040F0
                  0;255;3;0;9;read: 6-6-0 s=255,c=4,t=2,pt=6,l=6,sg=0:6E000100FA07
                  0;255;3;0;9;Client 0: 6;255;4;0;3;6E000100FA07F2BDE1BDF89A319600B40D9241505040
                  0;255;3;0;9;send: 0-0-6-6 s=255,c=4,t=3,pt=6,l=22,sg=0,st=ok:6E000100FA07F2BDE1BDF89A319600B40D9241505040
                  0;255;3;0;9;read: 6-6-0 s=255,c=4,t=2,pt=6,l=6,sg=0:6E000100F907
                  0;255;3;0;9;Client 0: 6;255;4;0;3;6E000100F90711240895DC01CB01FC01F999FECF06C0
                  0;255;3;0;9;send: 0-0-6-6 s=255,c=4,t=3,pt=6,l=22,sg=0,st=ok:6E000100F90711240895DC01CB01FC01F999FECF06C0
                  0;255;3;0;9;read: 6-6-0 s=255,c=4,t=2,pt=6,l=6,sg=0:6E000100F807
                  0;255;3;0;9;Client 0: 6;255;4;0;3;6E000100F807990B08957AE0979F902D879F802D910D
                  0;255;3;0;9;send: 0-0-6-6 s=255,c=4,t=3,pt=6,l=22,sg=0,st=ok:6E000100F807990B08957AE0979F902D879F802D910D
                  0;255;3;0;9;read: 6-6-0 s=255,c=4,t=2,pt=6,l=6,sg=0:6E000100F707
                  0;255;3;0;9;Client 0: 6;255;4;0;3;6E000100F7078D910190801921F441505040C8F7881B
                  0;255;3;0;9;send: 0-0-6-6 s=255,c=4,t=3,pt=6,l=22,sg=0,st=ok:6E000100F7078D910190801921F441505040C8F7881B
                  0;255;3;0;9;read: 6-6-0 s=255,c=4,t=2,pt=6,l=6,sg=0:6E000100F607
                  0;255;3;0;9;Client 0: 6;255;4;0;3;6E000100F6071EF4909581959F4F0895FB01DC0104C0
                  0;255;3;0;9;send: 0-0-6-6 s=255,c=4,t=3,pt=6,l=22,sg=0,st=ok:6E000100F6071EF4909581959F4F0895FB01DC0104C0
                  0;255;3;0;9;read: 6-6-0 s=255,c=4,t=2,pt=6,l=6,sg=0:6E000100F507
                  0;255;3;0;9;Client 0: 6;255;4;0;3;6E000100F50703C018D0820F911D219120532A30C8F3
                  0;255;3;0;9;send: 0-0-6-6 s=255,c=4,t=3,pt=6,l=22,sg=0,st=ok:6E000100F50703C018D0820F911D219120532A30C8F3
                  0;255;3;0;9;read: 6-6-0 s=255,c=4,t=2,pt=6,l=6,sg=0:6E000100F407
                  0;255;3;0;9;Client 0: 6;255;4;0;3;6E000100F40710F02E30C8F32B3239F02D3231F46894
                  0;255;3;0;9;send: 0-0-6-6 s=255,c=4,t=3,pt=6,l=22,sg=0,st=ok:6E000100F40710F02E30C8F32B3239F02D3231F46894
                  0;255;3;0;9;read: 6-6-0 s=255,c=4,t=2,pt=6,l=6,sg=0:6E000100F307
                  0;255;3;0;9;Client 0: 6;255;4;0;3;6E000100F307FC0188279927E89421912032E9F32930
                  0;255;3;0;9;send: 0-0-6-6 s=255,c=4,t=3,pt=6,l=22,sg=0,st=ok:6E000100F307FC0188279927E89421912032E9F32930
                  just for completeness my settings for burning the old bootloader:
                  nano.name=Arduino Nano
                  nano.upload.tool=avrdude
                  nano.upload.protocol=arduino
                  nano.bootloader.tool=avrdude
                  nano.build.f_cpu=16000000L
                  nano.build.board=AVR_NANO
                  nano.build.core=arduino
                  nano.menu.cpu.MYSBLoldatmega328=ATmega328 MYSBootloader old
                  nano.menu.cpu.MYSBLoldatmega328.upload.maximum_size=30720
                  nano.menu.cpu.MYSBLoldatmega328.upload.maximum_data_size=2048
                  nano.menu.cpu.MYSBLoldatmega328.upload.speed=115200
                  nano.menu.cpu.MYSBLoldatmega328.bootloader.low_fuses=0xFF
                  nano.menu.cpu.MYSBLoldatmega328.bootloader.high_fuses=0xDA
                  nano.menu.cpu.MYSBLoldatmega328.bootloader.extended_fuses=0x05
                  nano.menu.cpu.MYSBLoldatmega328.bootloader.file=MySensors/MYSBootloader.hex
                  And to note something I noticed (but don't know if it's related): sometimes the MYSController loses it's connection to the gateway. Serial monitor is still printing values but nothing in MYSController. When I reconnect the Controller it is working again.
                  edit: and is it normal that a sketch needs more than 20 min to upload? I mean the sketch is quite big (>70% of max), but it seems to be to long even with the old (for me faster) bootloader.
                  edit2: one hour and about 24k messages (MsgID in MYSController) later my node is still updating...
                  • dpressleD
                    dpressleD
                    dpressle
                    wrote on last edited by dpressle
                    #102
                    Did any one able to make this work with atmega328p-PU 28 DIP 8MHz internal clock? or is it just me having problems with this boot loader?
                    I was able to load the boot loader successfully and able to upload a sketch but then nothing happen, i see nothing in the serial port (default 115200) and the gateway does not find any node.
                    I am using latest dev branch of 2.0 and the boot loader from this thread.
                    Just for compression i loaded another boot loader for 8MHz internal clock (Arduino on breadboard) and uploaded a sketch to it and it worked perfectly communicating with the gateway.
                    I want to be able to upload OTA.
                    AM i doing something wrong? does this boot loader even supports this MCU?
                    • abmantisA
                      abmantisA
                      abmantis
                      I have a node with the NRF already soldered. Since Arduino as ISP uses some of the pins used by the NRF, is there anything I can do to flash the bootloader without unsoldering the NRF? Thanks!
                      Thar0lT 1 Reply Last reply
                        mannkind
                        wrote on last edited by mannkind
                        #104
                        • abmantisA abmantis
                          Thar0lT
                          Thar0lT
                          Thar0l
                          @abmantis You can just solder ISP wires to arduino without disconneting NRF. It's programming well (I've already tested this solution with my network)
                          abmantisA 1 Reply Last reply
                          • Thar0lT Thar0l
                            abmantisA
                            abmantisA
                            abmantis
                            @Алексей-Гусаров Thank you! Will try that soon :)
                            Any updates regarding the bootloader?
                            dpressleD 1 Reply Last reply
                              dpressleD
                              dpressleD
                              dpressle
                              I managed to use the bootloader with version 2.0, thanks.
                              • abmantisA
                                abmantisA
                                abmantis
                                Yeah, the bootloader works well with the v2.0 release.
                                The major issue it has currently is that sometimes it takes quite a long time to flash a sketch. It seems that when the wireless connection is not perfect, it stops for 2 or 3 seconds multiple times. Like, send 10 packages, stop 3 seconds, send 5 packages, stop again.
                                yd kimY 1 Reply Last reply
                                • n1ck1355N
                                  n1ck1355N
                                  n1ck1355
                                  any news about 1.3 final release?
                                    Mickey
                                    @tekka
                                    I used the MYSBootloader 1.3pre with version 2.0.0
                                    I managed to upload FW to nodes with MYSController.
                                    As mention:
                                    "supports OTA FW AND serial FW updates"
                                    But I cannot get anything to serial port with the nodes.
                                    Is the serial option really works on this bootloader?
                                    the specs:
                                    1.board - my own developed board with atmega328p au without external clock.
                                    2.board.txt:
                                    ######## settings for 8Mhz internal clock, EESAVE, BOD1V8, no lock
                                    proMYSBL8.upload.tool=avrdude
                                    proMYSBL8.upload.speed=57600
                                    proMYSBL8.bootloader.high_fuses=0xD2
                                    proMYSBL8.bootloader.file=MySensors/MYSBootloaderV13pre.hex
                                    proMYSBL8.build.board=AVR_UNO
                                    proMYSBL8.build.core=arduino
                                    1. the bootloader hex file is : MYSBootloaderV13pre.hex from MYSController 1.0.0beta
                                    So is serial possible or/and should I change something?
                                    • n1ck1355N
                                      n1ck1355N
                                      n1ck1355
                                      @Mickey :
                                      It's the same problem i've posted about 4 months ago here.. i also cant run sketches i've uploaded via serial..
                                      i hope it is solved with a new release...maybe the final already @tekka?
                                      • M Mickey
                                        @tekka
                                        As mention:
                                        the specs:
                                        2.board.txt:
                                        tekkaT
                                        tekkaT
                                        tekka
                                        #112
                                        @Mickey There are some issues with Arduino IDE 1.6.10 and avrdude 6.3 - do you happen to have 1.6.10 installed?
                                        • tekkaT tekka
                                          Mickey
                                          @tekka
                                          My arduino IDE: 1.6.11
                                          The avrdude inside that arduino IDE is: 6.0.1
