  3. Reliability?
Reliability?
reliability
51 Posts 9 Posters 26.3k Views 5 Watching
  • greglG
    greglG
    gregl
    Try pulling power from Vera and see if the sensors come back to life....
    I think those fails will occur if the g/w doesnt respond also.
    i didnt have the best reliability with my Veralite and USB ( was using a hub + usb memory stick for datamine ) - much happier now with ethernet g/w.
    RJ_MakeR 1 Reply Last reply
      It could be the radio entering some weird state due to power issues (spikes etc). Have to tried some other power source on the sensor and adding a capacitor?
      • greglG gregl
        @ServiceXp said:
        I should add that I have another sensor built from the same batch of mini pro's, but uses the DHT22 for temp and humidity.
        So the problem may be related to the DS18B20's, but really don't know how to determine why they are locking up.
        And does this sensor NOT lockup??
        Is so hows it all wired up? do you have the resistor installed for the ds18b20's? - what happens if you disconnect the temp sensor?
        RJ_MakeR
        RJ_MakeR
        RJ_Make
        Ooops. That is correct the sensor using the DHT22 has not locked up after running for 48+ hours, and I can't remember it locking up in the past either.
        The 2 DS18B20's have a 4K7 resister installed. The sensor on one is soldered to the prototype pcb, and the other uses a screw type connector
        I have not tested to see what happens with the sensor disconnected.
        RJ_Make
        • greglG gregl
          RJ_MakeR
          RJ_MakeR
          RJ_Make
          @gregl said:> Try pulling power from Vera and see if the sensors come back to life....
          Will try, and report back
          RJ_Make
            RJ_MakeR
            RJ_MakeR
            RJ_Make
            @hek said:> It could be the radio entering some weird state due to power issues (spikes etc). Have to tried some other power source on the sensor and adding a capacitor?
            Wouldn't a power cycle or reset (button on the mini pro) correct that? It's almost like the eeprom is getting scrambled.
            RJ_Make
            • RJ_MakeR
              RJ_MakeR
              RJ_Make
              last night I upped the cap on the radio to 47uf on one of the sensors, and left the other one alone. This morning the one with the cap was still running, but the other was locked up.
              I power cycled the serial gateway, and it **appears **that the sensor came back up. So I decided to install the 47uf on the locked up sensor.
              Until next time.
              RJ_Make
              DammeD 1 Reply Last reply
              • RJ_MakeR RJ_Make
                Until next time.
                DammeD
                DammeD
                Damme
                Code Contributor
                @ServiceXp One major stability change I did was using shorter wire bewteen radio and arduino.
                • DammeD Damme
                  RJ_MakeR
                  RJ_MakeR
                  RJ_Make
                  @Damme
                  Unfortunately, I can't get any closer in my environment without going to a custom designed pcb. All my wires are soldered and are only 2" max in length. :-)
                  RJ_Make
                  • RJ_MakeR
                    RJ_MakeR
                    RJ_Make
                    Well locked up again. I have confirmed that rebooting the gateway and or the Vera has NO effect. The only fix is to clear the eeprom and start over with the sensor.
                    At this point I dont think its the gateway but I am not sure where to go at this point?
                    RJ_Make
                    • greglG
                      greglG
                      gregl
                      This is very weird...but the wierdest bit to me is that you need to clear the eeprom to get it going again!
                      Are you using the example sketches un-modified for these sensors?
                      Few ideas:
                      1. What about adding some code to void setup to print out all values in the eeprom - to test your idea in them being corrupt?
                      2. What about swapping the mini pro's from your working DHT22 sensor and using it for the temp sensor...see if the problem follows....
                      3. Change the resistor/add capacitor to the temp sensor in case the output is not ideal from the pro-mini http://www.picaxeforum.co.uk/archive/index.php/t-11268.html
                        ( i have some ds18b20's on long cables using parasite power and i needed to drop the resistor value for stability)
                      4. Change the powersupply AND cable !. Are you using a USB port on your computer??
                        Hows it all connected up? ( post a photo )
                      RJ_MakeR 2 Replies Last reply
                      • greglG gregl
                        Few ideas:
                        RJ_MakeR
                        RJ_MakeR
                        RJ_Make
                        @gregl said:> This is very weird...but the wierdest bit to me is that you need to clear the eeprom to get it going again!
                        Few ideas:
                        Yes, using the default sketch, with only a hard coded C to F conversion change.
                        1. Not sure how to do that??
                        2. I should be able to do that.
                        3. How do I determine the appropriate size resistor and or cap? The wire length on one sensor is the standard DS18B20 length, The other sensor has been lengthened slightly to pass under a freezer door gasket. (Pic Below)
                        4. These are battery powered sensors, and until the MySensors step up regulator is release I think it's my only option.
                        The flat section is a SATA cable, very well spiced in.
                        The only difference in this sensor build compared to the other is I started using screw in connector blocks for the sensor connection. (and of course the SATA cable splice.)
                        RJ_Make
                        • RJ_MakeR
                          RJ_MakeR
                          RJ_Make
                          Thinking out loud.... In both area's I have z-wave extenders in close proximity of the sensors. Hmmmmm
                          RJ_Make
                          • RJ_MakeR RJ_Make
                            DammeD
                            DammeD
                            Damme
                            Code Contributor
                            @ServiceXp Now when you sayit... I had a wireless mouse that lowerd my reception. A cheap brand, I did't like it and everytime a sensor transmitted the mouse got laggy.
                            • greglG gregl
                              Few ideas:
                              RJ_MakeR
                              RJ_MakeR
                              RJ_Make
                              wrote on last edited by RJ_Make
                              Few ideas:
                              Still dealing with this...
                              1. Built up a completely new freezer sensor, connected it, and it locked up 8hrs later. My EH40 project with the DS18B20 is also locking up. This is driving me crazy..
                              2. I added a cap (.22uF) to my EH40, but it still locked up.
                              I've removed all near by z-wave devices, so I now know that is not causing it..
                              RJ_Make
                              • RJ_MakeR
                                RJ_MakeR
                                RJ_Make
                                Let me ask you guys this.. Is it 'OK' to power the mini pro via the VCC terminal on the side? This is how I've been powering all my sensors...
                                Should I be using the RAW pin?
                                I've been powering the DS18B20 directly from the stepped up 3.3v output of the module (not the mini pro)
                                RJ_Make
                                korttomaK 1 Reply Last reply
                                • RJ_MakeR RJ_Make
                                  korttomaK
                                  korttomaK
                                  korttoma
                                  #21
                                  @ServiceXp
                                  If you are feeding 3.3v to the VCC pin it should be ok but if you are in fact feeding 3.3v to the RAW pin it might not be enough (Input Voltage 3.35 -12 V (3.3V model))
                                  http://arduino.cc/en/Main/ArduinoBoardProMini
                                  • Tomas
                                  • RJ_MakeR
                                    RJ_MakeR
                                    RJ_Make
                                    #22
                                    Locked up again this morning @ 7:37am with a temp of -0.1. So a .47uF cap isn't the answer.... I think my last option before giving up on this is to remove the stepup regulator.
                                    Any other idea's?
                                    RJ_Make
                                    • greglG
                                      greglG
                                      gregl
                                      @ServiceXp
                                      Could you try running a sketch which just uses the dallas temp lib eg: there is is an example called "Single" with the DallasTemperature lib. RUn it for 24hrs and see if it survives.
                                      Likewise... in your existing sketch...stop reading the temps ( but leave everything connected) and just send a value every say 30sec to Vera .... and leave for 24hrs or so...see if that survives.
                                      Also have you tried a different PIN for the onewire sensor?
                                      • greglG gregl
                                        @ServiceXp
                                        RJ_MakeR
                                        RJ_MakeR
                                        RJ_Make
                                        1. and 2) ---- will do and report back.
                                        Do you think the wire it self could be a/the problem. Since much of the sensor line is also subject to low temps, maybe it's breaking down some how... (Although I'm using 3 different DS18B20 sensors) just talking out loud..... ;-) ....
                                        1. I have not, but I can add that to the 'things to try' list..
                                        Thanks for you help @gregl
                                        RJ_Make
                                        • B
                                          B
                                          Bandra
                                          @ServiceXp
                                          My PCBs are winging their way to you (sorry, got forgot to send them for a week or two). They may solve your problem. Let me know when you get them.
