  3. Reliability?
Reliability?
reliability
51 Posts 9 Posters 25.7k Views 5 Watching
  • DammeD Damme
    @ServiceXp One major stability change I did was using shorter wire bewteen radio and arduino.
    RJ_MakeR
    RJ_MakeR
    RJ_Make
    @Damme
    Unfortunately, I can't get any closer in my environment without going to a custom designed pcb. All my wires are soldered and are only 2" max in length. :-)
    RJ_Make
    • RJ_MakeR
      RJ_MakeR
      RJ_Make
      Well locked up again. I have confirmed that rebooting the gateway and or the Vera has NO effect. The only fix is to clear the eeprom and start over with the sensor.
      At this point I dont think its the gateway but I am not sure where to go at this point?
      RJ_Make
      • greglG
        greglG
        gregl
        This is very weird...but the wierdest bit to me is that you need to clear the eeprom to get it going again!
        Are you using the example sketches un-modified for these sensors?
        Few ideas:
        1. What about adding some code to void setup to print out all values in the eeprom - to test your idea in them being corrupt?
        2. What about swapping the mini pro's from your working DHT22 sensor and using it for the temp sensor...see if the problem follows....
        3. Change the resistor/add capacitor to the temp sensor in case the output is not ideal from the pro-mini http://www.picaxeforum.co.uk/archive/index.php/t-11268.html
          ( i have some ds18b20's on long cables using parasite power and i needed to drop the resistor value for stability)
        4. Change the powersupply AND cable !. Are you using a USB port on your computer??
          Hows it all connected up? ( post a photo )
        RJ_MakeR 2 Replies Last reply
        • greglG gregl
          Few ideas:
          RJ_MakeR
          RJ_MakeR
          RJ_Make
          @gregl said:> This is very weird...but the wierdest bit to me is that you need to clear the eeprom to get it going again!
          Few ideas:
          Yes, using the default sketch, with only a hard coded C to F conversion change.
          1. Not sure how to do that??
          2. I should be able to do that.
          3. How do I determine the appropriate size resistor and or cap? The wire length on one sensor is the standard DS18B20 length, The other sensor has been lengthened slightly to pass under a freezer door gasket. (Pic Below)
          4. These are battery powered sensors, and until the MySensors step up regulator is release I think it's my only option.
          The flat section is a SATA cable, very well spiced in.
          The only difference in this sensor build compared to the other is I started using screw in connector blocks for the sensor connection. (and of course the SATA cable splice.)
          RJ_Make
          • RJ_MakeR
            RJ_MakeR
            RJ_Make
            Thinking out loud.... In both area's I have z-wave extenders in close proximity of the sensors. Hmmmmm
            RJ_Make
            DammeD 1 Reply Last reply
            • RJ_MakeR RJ_Make
              DammeD
              DammeD
              Damme
              Code Contributor
              @ServiceXp Now when you sayit... I had a wireless mouse that lowerd my reception. A cheap brand, I did't like it and everytime a sensor transmitted the mouse got laggy.
              • greglG gregl
                Few ideas:
                RJ_MakeR
                RJ_MakeR
                RJ_Make
                wrote on last edited by RJ_Make
                Few ideas:
                Still dealing with this...
                1. Built up a completely new freezer sensor, connected it, and it locked up 8hrs later. My EH40 project with the DS18B20 is also locking up. This is driving me crazy..
                2. I added a cap (.22uF) to my EH40, but it still locked up.
                I've removed all near by z-wave devices, so I now know that is not causing it..
                RJ_Make
                • RJ_MakeR
                  RJ_MakeR
                  RJ_Make
                  Let me ask you guys this.. Is it 'OK' to power the mini pro via the VCC terminal on the side? This is how I've been powering all my sensors...
                  Should I be using the RAW pin?
                  I've been powering the DS18B20 directly from the stepped up 3.3v output of the module (not the mini pro)
                  RJ_Make
                  korttomaK 1 Reply Last reply
                  • RJ_MakeR RJ_Make
                    korttomaK
                    korttomaK
                    korttoma
                    #21
                    @ServiceXp
                    If you are feeding 3.3v to the VCC pin it should be ok but if you are in fact feeding 3.3v to the RAW pin it might not be enough (Input Voltage 3.35 -12 V (3.3V model))
                    http://arduino.cc/en/Main/ArduinoBoardProMini
                    • Tomas
                    • RJ_MakeR
                      RJ_MakeR
                      RJ_Make
                      #22
                      Locked up again this morning @ 7:37am with a temp of -0.1. So a .47uF cap isn't the answer.... I think my last option before giving up on this is to remove the stepup regulator.
                      Any other idea's?
                      RJ_Make
                      • greglG
                        greglG
                        gregl
                        @ServiceXp
                        Could you try running a sketch which just uses the dallas temp lib eg: there is is an example called "Single" with the DallasTemperature lib. RUn it for 24hrs and see if it survives.
                        Likewise... in your existing sketch...stop reading the temps ( but leave everything connected) and just send a value every say 30sec to Vera .... and leave for 24hrs or so...see if that survives.
                        Also have you tried a different PIN for the onewire sensor?
                        • greglG gregl
                          @ServiceXp
                          RJ_MakeR
                          RJ_MakeR
                          RJ_Make
                          @gregl said:> @ServiceXp
                          1. and 2) ---- will do and report back.
                          Do you think the wire it self could be a/the problem. Since much of the sensor line is also subject to low temps, maybe it's breaking down some how... (Although I'm using 3 different DS18B20 sensors) just talking out loud..... ;-) ....
                          1. I have not, but I can add that to the 'things to try' list..
                          Thanks for you help @gregl
                          RJ_Make
                          • B
                            B
                            Bandra
                            @ServiceXp
                            My PCBs are winging their way to you (sorry, got forgot to send them for a week or two). They may solve your problem. Let me know when you get them.
                            RJ_MakeR 1 Reply Last reply
                            • B Bandra
                              @ServiceXp
                              RJ_MakeR
                              RJ_MakeR
                              RJ_Make
                              @Bandra Thank you Sir. I'll report back.
                              RJ_Make
                              • greglG gregl
                                @ServiceXp
                                RJ_MakeR
                                RJ_MakeR
                                RJ_Make
                                @gregl
                                Only sending this, every 30 sec
                                gw.send(msgTEMP.setSensor(i).set(777, 1));
                                and this is what I'm getting in return.. Not sure what the fails are about?
                                RJ_Make
                                • RJ_MakeR
                                  RJ_MakeR
                                  RJ_Make
                                  The section of code
                                  	void sendTemperatureToController(){
                                  		//Start time for Temperature readings
                                  		TemperatureTimeing = millis ();
                                  		//sensors.requestTemperatures();
                                  			//float temperature = static_cast<float>(static_cast<int>((sensors.getTempFByIndex(i)) * 10.)) / 10.;
                                  			//float temperature = static_cast<float>(static_cast<int>((gw.getConfig().isMetric?sensors.getTempCByIndex(i):sensors.getTempFByIndex(i)) * 10.)) / 10.;
                                  			//if (lastTemperature[i] != temperature && temperature != -127.00) {
                                  				//// Send in the new temperature
                                  				//gw.send(msgTEMP.setSensor(i).set(temperature,1));
                                  				//lastTemperature[i]=temperature;
                                  RJ_Make
                                  • RJ_MakeR
                                    RJ_MakeR
                                    RJ_Make
                                    Ok,
                                    The sensor has has been running for ~24 hrs and has not locked up. So the problem is either in the code (which I doubt because I think others would be seeing this problem) or the actual DS18B20's. Maybe a bad run of them?
                                    I think I'm going to let it run a while longer like this, just to make sure.
                                    RJ_Make
                                    • RJ_MakeR
                                      RJ_MakeR
                                      RJ_Make
                                      Oh and the strangest thing.. those fails stopped.. So I still don't know what those where about..
                                      send: 1-1-0-0 s=0,c=1,t=0,pt=7,l=5,st=ok:777.0
                                      RJ_Make
                                      • RJ_MakeR RJ_Make
                                        @ServiceXp Your previous logging showed the failing messages being routed from node 2 via 1 to 0 (gateway).
                                        This log shows messages from node 1 directly to 0 (gateway).
                                        This is a different situation, so message routing seems to fail.
                                        Any idea what could cause this?
                                        Furthermore, which DS18B20 library do you use?
                                        • YveauxY Yveaux
                                          RJ_MakeR
                                          RJ_MakeR
                                          RJ_Make
                                          #32
                                          @Yveaux
                                          1. I'm thinking maybe that's because this node is a relaying node?? Other than that I have no ideal.
                                          2. Whatever comes with MySensors.
                                          I did try using another Dallas library (the latest version) but there was a gazillion compile errors so I quickly replace it with existing... :-)
                                          I just don't know enough yet, to work out all those compile errors.
                                          RJ_Make
                                          YveauxY 2 Replies Last reply
