  3. ESP8266 WiFi gateway port for MySensors
328 Posts 56 Posters 403.8k Views 39 Watching
  • Mark SwiftM
    Mark SwiftM
    Mark Swift
    @Yveaux Is there a way I can track dropped messages?
    • Mark SwiftM Mark Swift
      @Mark-Swift my queueing code counts how many messages could not be stored due to the queue being full, and therefore got lost. If the radio drops messages because it's FIFO is full we won't know...
      • Mark SwiftM
        Mark SwiftM
        Mark Swift
        @Yveaux I just tried to compile it and get the following error:
        In file included from /Users/markswift/Documents/Arduino/libraries/MySensors/core/MyTransportNRF24.cpp:23:0,
        from /Users/markswift/Documents/Arduino/libraries/MySensors/MySensor.h:260,
        from /Users/markswift/Documents/Personal/Hobbies/Arduino/GatewayESP8266MQTTClient/GatewayESP8266MQTTClient.ino:132:
        /Users/markswift/Documents/Arduino/libraries/MySensors/drivers/CircularBuffer/CircularBuffer.h:23:25: fatal error: util/atomic.h: No such file or directory
        #include <util/atomic.h>
          @Mark-Swift Sorry, my bad. This is AVR only code... Have to look for the ESP equivalent...
          • YveauxY
            This util/atomic.h is an easy fix, but then the next error occurs: current ESP8266 Arduino port (even tried upto 2.2.0) does not support SPI access from within interrupts (SPI.usingInterrupt is not supported.
            See https://github.com/esp8266/Arduino/issues/1943.
            This means I cannot reliably get the message data from the nRF from within an interrupt on ESP8266, using the regular Arduino SPI library.
            Have to think if there's another solution (or push this issue to be solved ;-) )
            To be continued...
            • Mark SwiftM
              Mark SwiftM
              Mark Swift
              nightmare!
              Let me know how you get on...
              • signal15S
                signal15S
                signal15
                Is anyone having luck running the ESP without problems at all? I'm on 1.5 and it's my first gateway, and I cannot get sensors to include. Should I try the development branch? Or, should I build a different gateway altogether? I just need something that works at this point.
                • alexsh1A
                  alexsh1A
                  alexsh1
                  Let me reiterate what @signal15 asked - did anyone successfully have esp8266 running as the GW on 2.0b? I have just acquired Wemos mini and would like to try it
                  • AndurilA
                    AndurilA
                    Anduril
                    @alexsh1 @signal15 I can confirm that the ESP gateway is working fine and stable. I even enabled the ESP OTA update function and that's working fine too.
                    signal15S 1 Reply Last reply
                    • AndurilA Anduril
                      signal15S
                      signal15S
                      signal15
                      @Anduril
                      Can you point me to documentation on how the OTA update stuff works and what the capabilities are?
                      • AndurilA
                        AndurilA
                        Anduril
                        wrote on last edited by Anduril
                        #312
                        @signal15 well there is a doc about OTA here. I discussed this topic with tekka, who is the author of the GatewayESP8266OTA example in the mysensors lib here.
                        It took me some time to get this working, but now I can upload new firmware to my ESP using wifi. Only drawback is that is seems to be not compatible with the mqtt version of the gateway. At least I was not able to get this working and stopped on that.
                        If you have further questions, don't hesitate to ask.
                          marceloaqno
                          Code Contributor
                          wrote on last edited by marceloaqno
                          #313
                          I recently built a mysensors node with esp8266 where I needed many I/O pins which made me realize the possibility of using the pin RX (http://www.forward.com.au/pfod/ESP8266/GPIOpins/ESP8266_01_pin_magic.html).
                          Initializing the serial with:
                          Serial.begin(MY_BAUD_RATE, SERIAL_8N1, SERIAL_TX_ONLY, 1);
                          allows to use RX pin for I/O.
                          So I was wondering if it would be useful to add a way in which the serial port can be initialized:
                          #define MY_SERIAL_MODE SERIAL_TX_ONLY
                          #define MY_SERIAL_MODE SERIAL_RX_ONLY
                          #define MY_SERIAL_MODE SERIAL_FULL   (default)
                          github.com/marceloaqno/MySensors/commit/687fecc6b4abb782eae8e1abb3b07016bfeac291
                          Also, to use the esp8266 analog pin, I had to comment the line:
                          ADC_MODE(ADC_VCC);
                          from MyHwESP8266.cpp.
                          Is there another way to use analog readings without messing the code?
                          Excellent port by the way, I have been using here and it works great!!
                          • Mark SwiftM
                            Mark SwiftM
                            Mark Swift
                            Was the blocking code issue ever resolved @Yveaux ?
                              @Mark-Swift no, still open at Esp side, and I couldn't think of a clean way working around it...
                              • G
                                G
                                gloob
                                I have an ESP using as a gateway and want to send some sensor information each 5 minutes to the controller.
                                Is it possible to use the wait command in the "loop"?
                                  wait(unsigned long ms);
                                  statusCounter += 1;
                                  send(msg.set(statusCounter));
                                • G gloob
                                    statusCounter += 1;
                                  @gloob yes
                                  • G
                                    G
                                    gloob
                                    wrote on last edited by gloob
                                    #318
                                    Thanks for the answer. So all incoming or outgoing messages of the gateway will be processed in the background, while the "wait" command is active?
                                      @gloob Yes
                                      • E
                                        E
                                        Eawo
                                        Hey
                                        Im not really getting it is this a gateway for mysensors nodes or for mtqq Nodes with esp stuff? I dont really getting it. Do you need a esp8266 wifi gateway to get a wireless gateway for mysensors stuff or is like. Mysensors gateway ---> Esp8266 gateway --- Esp8266 node.
                                        Sorry i dont really understand but im intressted in buying 8-10 sonoff for my window lamps, and i want them to work with domoticz :D
                                        alexsh1A 1 Reply Last reply
                                        • E Eawo
                                          Hey
                                          alexsh1A
                                          alexsh1A
                                          alexsh1
                                          @Eawo the sonoff does not require any GW to work with Domoticz.
