  3. Vera
  4. Send heartbeat message from Vera
8 Posts 4 Posters 3.1k Views 3 Watching
  • Lior RubinL Offline
    Lior RubinL Offline
    Lior Rubin
    is there anyway to send this message ?
    I'm not so Luup script expert but i think it should be able, anyone ?
      Lior RubinL Offline
      Lior Rubin
      anyone ?
      • S Offline
        No clue... dont have vera but is this something?
        https://forum.mysensors.org/topic/80/getting-numbers-from-vera-to-a-sensor/6
          Lior RubinL Offline
          Lior Rubin
          I found that the following luup command send the variable V_VAR5 with payload (value=2):
          luup.call_action("urn:upnp-arduino-cc:serviceId:arduino1", "SendCommand", {radioId="1;255", variableId="VAR_5", value=2}, 98)
          is there any way to send the subtype message I_HEARTBEAT ?
          B 1 Reply Last reply
          • Lior RubinL Lior Rubin
            B Offline
            B Offline
            BartE
            wrote on last edited by BartE
            @Lior-Rubin What you can do is on your Vera (UI5 but should work on UI7):
            • Create a "Hearthbeat" scene
            • Add a scene "Schedule" on the heartbeat interval you like say: "Interval based: Every 1 hour"
            • On the Luup-tab fill in this command
            luup.call_action("urn:upnp-arduino-cc:serviceId:arduino1", "SendCommand", {radioId="2;255", variableId="VAR_5", value=2}, 98)
            • Confirm the new scene
            • Save changes to let restart your Luup engine
            There is no such thing as a I_HEARTBEAT (nor a V_HEARTBEAT) look on this page for the available sub-types (skip the V_ in your variableId-string)
            Your MySensors node (in the example with ID 2) should handle the incoming message with sub-type V_VAR5
            ID 1 (radioID 1) will not work this is reserved for the gateway
            • H Offline
              H Offline
              The vera plugin hasn't been updated with the most recent additions (like the I_HEARTBEAT) yet. But as @barte says, you can basically send anything to the node.
              Lior RubinL 1 Reply Last reply
              • H hek
                Lior RubinL Offline
                Lior RubinL Offline
                Lior Rubin
                @hek I'm aware of all you says.
                Is there any roadmap for the Vera Plugin ?
                I think that the plugin need to get attention...
                • H Offline
                  H Offline
                  No roadmap for the Vera plugin at the moment. I_HEARTBEAT will be documented on the main site when 2.0 is released.
                  @BartE has done a great job implementing new sensor types on Vera. Creating a new sensor type is a fun and pretty isolated development task. Additional maintainers is always welcome.
                  12.1k
