  3. Cobine working DHT22 and LDR with a RelayWithButtonActuator
dht22 ldr relay
36 Posts 4 Posters 8.4k Views 5 Watching
  • DickD Dick
    thank you Alex, it did not work. It is strange, in my topic BartE posted a srcipt what workerd almost perfect. Relay change was good and saw it in the Serial minitor changing from 0 to 1. after adding the LDR stuff it went wrong. So it must be something in the LDR add-on. combining is still not easy for me but I am learning.
    alexsh1A
    alexsh1A
    alexsh1
    @Dick With sketches it is like this sometimes - troubleshooting is time consuming.
    I would suggest the following. Try to comment out line by line on the LDR code, upload and see if it works. Try to insert as many Serial.print as you could to print the status of variables to the serial port.
    I do not have the LDR so cannot help you much on this one. I have multiple other sketches combined together working just fine.
    DickD 1 Reply Last reply
    • alexsh1A alexsh1
      DickD
      DickD
      Dick
      @alexsh1
      That could I do, thanks for the tip and will do that today. Any idea is welcome :smiley:
      BartEB 1 Reply Last reply
      • DickD Dick
        @alexsh1
        BartEB
        BartEB
        BartE
        wrote on last edited by BartE
        #22
        @Dick I think this issue sits here you use Digital port 0 (which is the serial debug port) i.s.o. Analog port 0 (A0).
        Change this line
        to
         #define LIGHT_SENSOR_ANALOG_PIN A0
        And you better also add this line to the setup function
        pinMode(LIGHT_SENSOR_ANALOG_PIN, INPUT);
        • BartEB BartE
          Change this line
          to
          DickD
          DickD
          Dick
          have not tried all the given options but started again with all the previous advises of Bart. Noe I still struggle with an error
          "gw.begin(incomingMessage, AUTO, true);" in mij script. I checkt the "{ }" over and over again but it must be something else.
          can anybody take a look?
          #define CHILD_ID_HUM1 0
           #define CHILD_ID_HUM2 1
           #define CHILD_ID_TEMP1 3
           #define CHILD_ID_TEMP2 4
          #define CHILD_ID_LIGHT 0
          // RelayWithActuator stuff
           #define RELAY_PIN 5 // Arduino Digital I/O pin number for relay
           #define BUTTON_PIN 6 // Arduino Digital I/O pin number for button
           #define CHILD_ID 5 // Id of the sensor child
           #define RELAY_ON 1
           #define RELAY_OFF 0
           Bounce debouncer = Bounce();
          int oldValue=0;
           bool state;
          MyMessage msgLight(CHILD_ID,V_LIGHT);
          MyMessage msgLightLevel(CHILD_ID_LIGHT, V_LIGHT_LEVEL);
           int lastLightLevel;
          #define HEARTBEAT 10
           unsigned int timer = 0;
           // Sleep time between reads (in milliseconds)
           #define SLEEP_TIME 3000
          DHT* dht[2];
           byte sensorPin[2] = {3, 4};
           float lastTemp[2] = {0.0, 0.0};
           float lastHum[2] = {0.0, 0.0};
          boolean metric = true;
          //MyMessage msgHum(CHILD_ID_HUM1, V_HUM);
          //MyMessage msgTemp(CHILD_ID_TEMP1, V_TEMP);
           gw.sendSketchInfo("HumidityAndRelay", "1.0");
           for (int i = 0; i < 2; i++)
           dht[i] = new DHT;
           dht[i]->setup(sensorPin[i]);
          gw.present(CHILD_ID_HUM1, S_HUM);
           gw.present(CHILD_ID_HUM2, S_HUM);
           gw.present(CHILD_ID_TEMP1, S_TEMP);
          // Setup the button and Activate internal pull-up
           pinMode(BUTTON_PIN,INPUT);
          // Activate internal pull-up
           debouncer.attach(BUTTON_PIN);
           debouncer.interval(5);
           gw.present(CHILD_ID, S_LIGHT);
           pinMode(RELAY_PIN, OUTPUT);
           state = gw.loadState(CHILD_ID);
          timer = 0;
           timer++;
          if (timer > (SLEEP_TIME / HEARTBEAT))
           // Reset timer again and for the next timed loop
           timer = 0;
           delay(dht[i]->getMinimumSamplingPeriod());
           float temperature = dht[i]->getTemperature();
           if (isnan(temperature))
           Serial.print(F("Failed reading temperature from DHT"));
           Serial.println(i);
           else if (temperature != lastTemp[i])
           lastTemp[i] = temperature;
           if (!metric)
           temperature = dht[i]->toFahrenheit(temperature);
          //gw.send(msgTemp.set(temperature, i));
           Serial.print(F("T"));
           Serial.print(i);
           Serial.print(F("= "));
           float humidity = dht[i]->getHumidity();
           if (isnan(humidity))
           Serial.print("Failed reading humidity from DHT");
           Serial.println(i);
           else if (humidity != lastHum[i])
           lastHum[i] = humidity;
          //gw.send(msgHum.set(humidity, 1));
           Serial.print(F("H"));
           Serial.print(i);
           Serial.println(humidity);
          int lightLevel = (1023-analogRead(LIGHT_SENSOR_ANALOG_PIN))/10.23;
          //Serial.println(lightLevel);
           if (lightLevel != lastLightLevel)
          gw.send(msgLightLevel.set(lightLevel));
            //lastLightLevel = lightLevel;
            Serial.print("L=");
          debouncer.update();
            // Get the update value
            int value = debouncer.read();
            if (value != oldValue && value==0)
                gw.send(msg.set(state?false:true), true); // Send new state and request ack back
            oldValue = value;
          gw.wait(HEARTBEAT); //sleep a bit
          void incomingMessage(const MyMessage &message)
           if (message.isAck())
          if (message.type == V_LIGHT)
           // Change relay state
           state = message.getBool();
           // Store state in eeprom
           gw.saveState(CHILD_ID, state);
          • mfalkviddM
            #24
            The auto-formatting feature in the Arduino IDE is very useful for makin the code easier to read (both for yourself and for us forum readers) and spot mistakes.
            What is the error message you are getting?
              DickD
              DickD
              Dick
              three errors. hope you can give an advise!
              In function 'void loop()':
              laatste:163: error: 'msg' was not declared in this scope
              At global scope:
              laatste:172: error: expected declaration before '}' token
              In function 'void setup()':
              laatste:47: error: 'incomingMessage' was not declared in this scope
              • DickD Dick
                At global scope:
                BartEB
                BartEB
                BartE
                #26
                @Dick
                msg should become msgLight
                gw.send(msgLight.set(state ? false : true), true); // Send new state and request ack back
                and move one } just below this line
                to the very end of you sketch
                DickD 3 Replies Last reply
                • BartEB BartE
                  @Dick
                  DickD
                  DickD
                  Dick
                  no errors anymore. I test the script now and will also put the changes you posted befor.
                  • BartEB BartE
                    @Dick
                    DickD
                    DickD
                    Dick
                    tested and also add the changes of your message (9hrs ago).
                    What I see on the serial monitor is, temp (2x), hum (2x) and light level but nothing of the relay. it is still clicking but no change in the logging from 1 to 0 etc. I already adjusted the script this morning with the 'RelayWithButtonActuator Example'. so only the relay part is not working and not visible in the serial log. Any idea?
                    • DickD Dick
                      BartEB
                      BartEB
                      BartE
                      @Dick are you sure it's not a hardware (wire) issue?
                      What happens if you load the RelayWithButtonActuator example code (with the correct pinning of course) ?
                      • BartEB BartE
                        @Dick
                        DickD
                        DickD
                        Dick
                        here the latist version but not working
                         #define RELAY_ON 1
                         #define RELAY_OFF 0
                        int oldValue=0;
                         bool state;
                         int lastLightLevel;
                        DHT* dht[2];
                         dht[i] = new DHT;
                        timer = 0;
                         timer++;
                         timer = 0;
                         Serial.println(i);
                         if (!metric)
                         Serial.print(i);
                         Serial.println(i);
                         Serial.print(i);
                          Serial.print("L=");
                        debouncer.update();
                          oldValue = value;
                        • DickD Dick
                           #define RELAY_ON 1
                           #define RELAY_OFF 0
                          int oldValue=0;
                           bool state;
                           int lastLightLevel;
                          DHT* dht[2];
                           dht[i] = new DHT;
                          timer = 0;
                           timer++;
                           timer = 0;
                           Serial.println(i);
                           if (!metric)
                           Serial.print(i);
                           Serial.println(i);
                           Serial.print(i);
                            Serial.print("L=");
                          debouncer.update();
                            oldValue = value;
                          BartEB
                          BartEB
                          BartE
                          @Dick
                          Change these lines
                              oldValue = value;
                          to
                              oldValue = value;
                          DickD 2 Replies Last reply
                          • BartEB BartE
                            @Dick
                            Change these lines
                                oldValue = value;
                            to
                                oldValue = value;
                            DickD
                            DickD
                            Dick
                            and about the test of the RelayWithButtonActuator Example,
                            it works fine. I adjust the lines now and will test it
                            • BartEB BartE
                              @Dick
                              Change these lines
                                  oldValue = value;
                              to
                                  oldValue = value;
                              DickD
                              DickD
                              Dick
                              tested but still clicking relay. As you can see that there is nothing to see in the serial log
                              send: 4-4-0-0 s=255,c=3,t=15,pt=2,l=2,sg=0,st=ok:0
                              send: 4-4-0-0 s=255,c=0,t=18,pt=0,l=5,sg=0,st=ok:1.5.4
                              send: 4-4-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
                              read: 0-0-4 s=255,c=3,t=6,pt=0,l=1,sg=0:M
                              repeater started, id=4, parent=0, distance=1
                              send: 4-4-0-0 s=255,c=3,t=11,pt=0,l=16,sg=0,st=ok:HumidityAndRelay
                              send: 4-4-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:1.0
                              send: 4-4-0-0 s=0,c=0,t=7,pt=0,l=0,sg=0,st=ok:
                              send: 4-4-0-0 s=1,c=0,t=7,pt=0,l=0,sg=0,st=ok:
                              send: 4-4-0-0 s=3,c=0,t=6,pt=0,l=0,sg=0,st=ok:
                              send: 4-4-0-0 s=5,c=0,t=3,pt=0,l=0,sg=0,st=ok:
                              T0= 22.20
                              H0= 61.80
                              send: 4-4-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,st=ok:74
                              L=74
                              T1= 25.00
                              H1= 60.20
                              L=74
                              L=74
                              send: 4-4-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,st=ok:76
                              L=76
                              • DickD Dick
                                T0= 22.20
                                H0= 61.80
                                L=74
                                T1= 25.00
                                H1= 60.20
                                L=74
                                L=74
                                L=76
                                BartEB
                                BartEB
                                BartE
                                #34
                                @Dick If there is nothing visible in the log, then you can presume there is a hardware issue.
                                Some possible issues:
                                • loose relays wire (bad connection) --> try a different wire
                                • wrong pin is used (if set as input the pin will "float" resulting in unstable relay behaviour) --> double check your pin number in code and actual PCB
                                • pin double used ie the DHT drive poll this pin for some reason. --> use a different pin in both code and conection to relay
                                • BartEB BartE
                                  DickD
                                  DickD
                                  Dick
                                  thank you BartE, I received today an new Uno and some other stuff so I can rebuild it al to see if it is an HW failure. I hope I can start tomorrow. I keep you informed but thanks for your support. to be continued.
                                  • DickD Dick
                                    BartEB
                                    BartEB
                                    BartE
                                    #36
                                    @Dick Not sure what your approach is but normally i start with prototyping using these wires and when all works fine (software and hardware) i solder everything together on a PCB.
