  3. Cobine working DHT22 and LDR with a RelayWithButtonActuator
dht22 ldr relay
36 Posts 4 Posters 8.4k Views 5 Watching
  • BartEB BartE
    @Dick I think this issue sits here you use Digital port 0 (which is the serial debug port) i.s.o. Analog port 0 (A0).
    Change this line
    to
     #define LIGHT_SENSOR_ANALOG_PIN A0
    And you better also add this line to the setup function
    pinMode(LIGHT_SENSOR_ANALOG_PIN, INPUT);
    DickD
    DickD
    Dick
    have not tried all the given options but started again with all the previous advises of Bart. Noe I still struggle with an error
    "gw.begin(incomingMessage, AUTO, true);" in mij script. I checkt the "{ }" over and over again but it must be something else.
    can anybody take a look?
    #define CHILD_ID_HUM1 0
     #define CHILD_ID_HUM2 1
     #define CHILD_ID_TEMP1 3
     #define CHILD_ID_TEMP2 4
    #define CHILD_ID_LIGHT 0
    // RelayWithActuator stuff
     #define RELAY_PIN 5 // Arduino Digital I/O pin number for relay
     #define BUTTON_PIN 6 // Arduino Digital I/O pin number for button
     #define CHILD_ID 5 // Id of the sensor child
     #define RELAY_ON 1
     #define RELAY_OFF 0
     Bounce debouncer = Bounce();
    int oldValue=0;
     bool state;
    MyMessage msgLight(CHILD_ID,V_LIGHT);
    MyMessage msgLightLevel(CHILD_ID_LIGHT, V_LIGHT_LEVEL);
     int lastLightLevel;
    #define HEARTBEAT 10
     unsigned int timer = 0;
     // Sleep time between reads (in milliseconds)
     #define SLEEP_TIME 3000
    DHT* dht[2];
     byte sensorPin[2] = {3, 4};
     float lastTemp[2] = {0.0, 0.0};
     float lastHum[2] = {0.0, 0.0};
    boolean metric = true;
    //MyMessage msgHum(CHILD_ID_HUM1, V_HUM);
    //MyMessage msgTemp(CHILD_ID_TEMP1, V_TEMP);
     gw.sendSketchInfo("HumidityAndRelay", "1.0");
     for (int i = 0; i < 2; i++)
     dht[i] = new DHT;
     dht[i]->setup(sensorPin[i]);
    gw.present(CHILD_ID_HUM1, S_HUM);
     gw.present(CHILD_ID_HUM2, S_HUM);
     gw.present(CHILD_ID_TEMP1, S_TEMP);
    // Setup the button and Activate internal pull-up
     pinMode(BUTTON_PIN,INPUT);
    // Activate internal pull-up
     debouncer.attach(BUTTON_PIN);
     debouncer.interval(5);
     gw.present(CHILD_ID, S_LIGHT);
     pinMode(RELAY_PIN, OUTPUT);
     state = gw.loadState(CHILD_ID);
    timer = 0;
     timer++;
    if (timer > (SLEEP_TIME / HEARTBEAT))
     // Reset timer again and for the next timed loop
     timer = 0;
     delay(dht[i]->getMinimumSamplingPeriod());
     float temperature = dht[i]->getTemperature();
     if (isnan(temperature))
     Serial.print(F("Failed reading temperature from DHT"));
     Serial.println(i);
     else if (temperature != lastTemp[i])
     lastTemp[i] = temperature;
     if (!metric)
     temperature = dht[i]->toFahrenheit(temperature);
    //gw.send(msgTemp.set(temperature, i));
     Serial.print(F("T"));
     Serial.print(i);
     Serial.print(F("= "));
     float humidity = dht[i]->getHumidity();
     if (isnan(humidity))
     Serial.print("Failed reading humidity from DHT");
     Serial.println(i);
     else if (humidity != lastHum[i])
     lastHum[i] = humidity;
    //gw.send(msgHum.set(humidity, 1));
     Serial.print(F("H"));
     Serial.print(i);
     Serial.println(humidity);
    int lightLevel = (1023-analogRead(LIGHT_SENSOR_ANALOG_PIN))/10.23;
    //Serial.println(lightLevel);
     if (lightLevel != lastLightLevel)
    gw.send(msgLightLevel.set(lightLevel));
      //lastLightLevel = lightLevel;
      Serial.print("L=");
    debouncer.update();
      // Get the update value
      int value = debouncer.read();
      if (value != oldValue && value==0)
          gw.send(msg.set(state?false:true), true); // Send new state and request ack back
      oldValue = value;
    gw.wait(HEARTBEAT); //sleep a bit
    void incomingMessage(const MyMessage &message)
     if (message.isAck())
    if (message.type == V_LIGHT)
     // Change relay state
     state = message.getBool();
     // Store state in eeprom
     gw.saveState(CHILD_ID, state);
    • mfalkviddM
      #24
      The auto-formatting feature in the Arduino IDE is very useful for makin the code easier to read (both for yourself and for us forum readers) and spot mistakes.
      What is the error message you are getting?
      DickD 1 Reply Last reply
        DickD
        DickD
        Dick
        three errors. hope you can give an advise!
        In function 'void loop()':
        laatste:163: error: 'msg' was not declared in this scope
        At global scope:
        laatste:172: error: expected declaration before '}' token
        In function 'void setup()':
        laatste:47: error: 'incomingMessage' was not declared in this scope
        BartEB 1 Reply Last reply
        • DickD Dick
          At global scope:
          BartEB
          BartEB
          BartE
          wrote on last edited by BartE
          #26
          @Dick
          msg should become msgLight
          gw.send(msgLight.set(state ? false : true), true); // Send new state and request ack back
          and move one } just below this line
          to the very end of you sketch
          DickD 3 Replies Last reply
          • BartEB BartE
            @Dick
            DickD
            DickD
            Dick
            no errors anymore. I test the script now and will also put the changes you posted befor.
            • BartEB BartE
              @Dick
              DickD
              DickD
              Dick
              tested and also add the changes of your message (9hrs ago).
              What I see on the serial monitor is, temp (2x), hum (2x) and light level but nothing of the relay. it is still clicking but no change in the logging from 1 to 0 etc. I already adjusted the script this morning with the 'RelayWithButtonActuator Example'. so only the relay part is not working and not visible in the serial log. Any idea?
              • DickD Dick
                BartEB
                BartEB
                BartE
                @Dick are you sure it's not a hardware (wire) issue?
                What happens if you load the RelayWithButtonActuator example code (with the correct pinning of course) ?
                • BartEB BartE
                  @Dick
                  DickD
                  DickD
                  Dick
                  here the latist version but not working
                   #define RELAY_ON 1
                   #define RELAY_OFF 0
                  int oldValue=0;
                   bool state;
                   int lastLightLevel;
                  DHT* dht[2];
                   dht[i] = new DHT;
                  timer = 0;
                   timer++;
                   timer = 0;
                   Serial.println(i);
                   if (!metric)
                   Serial.print(i);
                   Serial.println(i);
                   Serial.print(i);
                    Serial.print("L=");
                  debouncer.update();
                    oldValue = value;
                  • DickD Dick
                     #define RELAY_ON 1
                     #define RELAY_OFF 0
                    int oldValue=0;
                     bool state;
                     int lastLightLevel;
                    DHT* dht[2];
                     dht[i] = new DHT;
                    timer = 0;
                     timer++;
                     timer = 0;
                     Serial.println(i);
                     if (!metric)
                     Serial.print(i);
                     Serial.println(i);
                     Serial.print(i);
                      Serial.print("L=");
                    debouncer.update();
                      oldValue = value;
                    BartEB
                    BartEB
                    BartE
                    @Dick
                    Change these lines
                        oldValue = value;
                    to
                        oldValue = value;
                    DickD 2 Replies Last reply
                    • BartEB BartE
                      @Dick
                      Change these lines
                          oldValue = value;
                      to
                          oldValue = value;
                      DickD
                      DickD
                      Dick
                      and about the test of the RelayWithButtonActuator Example,
                      it works fine. I adjust the lines now and will test it
                      • BartEB BartE
                        @Dick
                        Change these lines
                            oldValue = value;
                        to
                            oldValue = value;
                        DickD
                        DickD
                        Dick
                        tested but still clicking relay. As you can see that there is nothing to see in the serial log
                        send: 4-4-0-0 s=255,c=3,t=15,pt=2,l=2,sg=0,st=ok:0
                        send: 4-4-0-0 s=255,c=0,t=18,pt=0,l=5,sg=0,st=ok:1.5.4
                        send: 4-4-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
                        read: 0-0-4 s=255,c=3,t=6,pt=0,l=1,sg=0:M
                        repeater started, id=4, parent=0, distance=1
                        send: 4-4-0-0 s=255,c=3,t=11,pt=0,l=16,sg=0,st=ok:HumidityAndRelay
                        send: 4-4-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:1.0
                        send: 4-4-0-0 s=0,c=0,t=7,pt=0,l=0,sg=0,st=ok:
                        send: 4-4-0-0 s=1,c=0,t=7,pt=0,l=0,sg=0,st=ok:
                        send: 4-4-0-0 s=3,c=0,t=6,pt=0,l=0,sg=0,st=ok:
                        send: 4-4-0-0 s=5,c=0,t=3,pt=0,l=0,sg=0,st=ok:
                        T0= 22.20
                        H0= 61.80
                        send: 4-4-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,st=ok:74
                        L=74
                        T1= 25.00
                        H1= 60.20
                        L=74
                        L=74
                        send: 4-4-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,st=ok:76
                        L=76
                        • DickD Dick
                          T0= 22.20
                          H0= 61.80
                          L=74
                          T1= 25.00
                          H1= 60.20
                          L=74
                          L=74
                          L=76
                          BartEB
                          BartEB
                          BartE
                          #34
                          @Dick If there is nothing visible in the log, then you can presume there is a hardware issue.
                          Some possible issues:
                          • loose relays wire (bad connection) --> try a different wire
                          • wrong pin is used (if set as input the pin will "float" resulting in unstable relay behaviour) --> double check your pin number in code and actual PCB
                          • pin double used ie the DHT drive poll this pin for some reason. --> use a different pin in both code and conection to relay
                          • BartEB BartE
                            DickD
                            DickD
                            Dick
                            thank you BartE, I received today an new Uno and some other stuff so I can rebuild it al to see if it is an HW failure. I hope I can start tomorrow. I keep you informed but thanks for your support. to be continued.
                            • DickD Dick
                              BartEB
                              BartEB
                              BartE
                              #36
                              @Dick Not sure what your approach is but normally i start with prototyping using these wires and when all works fine (software and hardware) i solder everything together on a PCB.
