  3. Cobine working DHT22 and LDR with a RelayWithButtonActuator
dht22 ldr relay
36 Posts 4 Posters 8.4k Views 5 Watching
  • alexsh1A alexsh1
    Try to define BUTTON_PIN to a digital pin and see if it makes a difference.
    Change the following in the setup
    pinMode(BUTTON_PIN, INPUT);
    This is my sketch working on arduino+relay on my corner stand lamp and it is working fine on MySensors 1.5.4
    // This code is basically the same as the default RelayWithButtonActuator sketch. The only difference is the pin numbering.
    #define RELAY_PIN  3  // Arduino Digital I/O pin number for relay
    #define BUTTON_PIN  4  // Arduino Digital I/O pin number for button
    #define RELAY_ON 1
    #define RELAY_OFF 0
    #define NODE_ADDRESS 2
    Bounce debouncer = Bounce();
    int oldValue=0;
    bool state;
      gw.begin(incomingMessage, NODE_ADDRESS, true);
      gw.sendSketchInfo("Relay & Button", "1.0");
     // Setup the button
      pinMode(BUTTON_PIN,INPUT);
      // Activate internal pull-up
      debouncer.attach(BUTTON_PIN);
      debouncer.interval(5);
      gw.present(CHILD_ID, S_LIGHT);
      pinMode(RELAY_PIN, OUTPUT);
      state = gw.loadState(CHILD_ID);
    *  Example on how to asynchronously check for new messages from gw
      debouncer.update();
      // Get the update value
      int value = debouncer.read();
      if (value != oldValue && value==0) {
          gw.send(msg.set(state?false:true), true); // Send new state and request ack back
      oldValue = value;
      if (message.isAck()) {
         // Change relay state
         state = message.getBool();
         // Store state in eeprom
         gw.saveState(CHILD_ID, state);
    DickD
    DickD
    Dick
    thank you Alex, it did not work. It is strange, in my topic BartE posted a srcipt what workerd almost perfect. Relay change was good and saw it in the Serial minitor changing from 0 to 1. after adding the LDR stuff it went wrong. So it must be something in the LDR add-on. combining is still not easy for me but I am learning.
    alexsh1A 1 Reply Last reply
    • DickD Dick
      alexsh1A
      alexsh1A
      alexsh1
      @Dick With sketches it is like this sometimes - troubleshooting is time consuming.
      I would suggest the following. Try to comment out line by line on the LDR code, upload and see if it works. Try to insert as many Serial.print as you could to print the status of variables to the serial port.
      I do not have the LDR so cannot help you much on this one. I have multiple other sketches combined together working just fine.
      DickD 1 Reply Last reply
      • alexsh1A alexsh1
        DickD
        DickD
        Dick
        @alexsh1
        That could I do, thanks for the tip and will do that today. Any idea is welcome :smiley:
        BartEB 1 Reply Last reply
        • DickD Dick
          @alexsh1
          BartEB
          BartEB
          BartE
          wrote on last edited by BartE
          #22
          @Dick I think this issue sits here you use Digital port 0 (which is the serial debug port) i.s.o. Analog port 0 (A0).
          Change this line
          to
           #define LIGHT_SENSOR_ANALOG_PIN A0
          And you better also add this line to the setup function
          pinMode(LIGHT_SENSOR_ANALOG_PIN, INPUT);
          • BartEB BartE
            Change this line
            to
            DickD
            DickD
            Dick
            have not tried all the given options but started again with all the previous advises of Bart. Noe I still struggle with an error
            "gw.begin(incomingMessage, AUTO, true);" in mij script. I checkt the "{ }" over and over again but it must be something else.
            can anybody take a look?
            #define CHILD_ID_HUM1 0
             #define CHILD_ID_HUM2 1
             #define CHILD_ID_TEMP1 3
             #define CHILD_ID_TEMP2 4
            #define CHILD_ID_LIGHT 0
            // RelayWithActuator stuff
             #define RELAY_PIN 5 // Arduino Digital I/O pin number for relay
             #define BUTTON_PIN 6 // Arduino Digital I/O pin number for button
             #define CHILD_ID 5 // Id of the sensor child
             #define RELAY_ON 1
             #define RELAY_OFF 0
            int oldValue=0;
             bool state;
            MyMessage msgLight(CHILD_ID,V_LIGHT);
            MyMessage msgLightLevel(CHILD_ID_LIGHT, V_LIGHT_LEVEL);
             int lastLightLevel;
            #define HEARTBEAT 10
             unsigned int timer = 0;
             // Sleep time between reads (in milliseconds)
             #define SLEEP_TIME 3000
            DHT* dht[2];
             byte sensorPin[2] = {3, 4};
             float lastTemp[2] = {0.0, 0.0};
             float lastHum[2] = {0.0, 0.0};
            boolean metric = true;
            //MyMessage msgHum(CHILD_ID_HUM1, V_HUM);
            //MyMessage msgTemp(CHILD_ID_TEMP1, V_TEMP);
             gw.sendSketchInfo("HumidityAndRelay", "1.0");
             for (int i = 0; i < 2; i++)
             dht[i] = new DHT;
             dht[i]->setup(sensorPin[i]);
            gw.present(CHILD_ID_HUM1, S_HUM);
             gw.present(CHILD_ID_HUM2, S_HUM);
             gw.present(CHILD_ID_TEMP1, S_TEMP);
            // Setup the button and Activate internal pull-up
            timer = 0;
             timer++;
            if (timer > (SLEEP_TIME / HEARTBEAT))
             // Reset timer again and for the next timed loop
             timer = 0;
             delay(dht[i]->getMinimumSamplingPeriod());
             float temperature = dht[i]->getTemperature();
             if (isnan(temperature))
             Serial.print(F("Failed reading temperature from DHT"));
             Serial.println(i);
             else if (temperature != lastTemp[i])
             lastTemp[i] = temperature;
             if (!metric)
             temperature = dht[i]->toFahrenheit(temperature);
            //gw.send(msgTemp.set(temperature, i));
             Serial.print(F("T"));
             Serial.print(i);
             Serial.print(F("= "));
             float humidity = dht[i]->getHumidity();
             if (isnan(humidity))
             Serial.print("Failed reading humidity from DHT");
             Serial.println(i);
             else if (humidity != lastHum[i])
             lastHum[i] = humidity;
            //gw.send(msgHum.set(humidity, 1));
             Serial.print(F("H"));
             Serial.print(i);
             Serial.println(humidity);
            int lightLevel = (1023-analogRead(LIGHT_SENSOR_ANALOG_PIN))/10.23;
            //Serial.println(lightLevel);
             if (lightLevel != lastLightLevel)
            gw.send(msgLightLevel.set(lightLevel));
              //lastLightLevel = lightLevel;
              Serial.print("L=");
            debouncer.update();
              oldValue = value;
            gw.wait(HEARTBEAT); //sleep a bit
            • mfalkviddM
              #24
              The auto-formatting feature in the Arduino IDE is very useful for makin the code easier to read (both for yourself and for us forum readers) and spot mistakes.
              What is the error message you are getting?
                DickD
                DickD
                Dick
                three errors. hope you can give an advise!
                In function 'void loop()':
                laatste:163: error: 'msg' was not declared in this scope
                At global scope:
                laatste:172: error: expected declaration before '}' token
                In function 'void setup()':
                laatste:47: error: 'incomingMessage' was not declared in this scope
                • DickD Dick
                  At global scope:
                  BartEB
                  BartEB
                  BartE
                  #26
                  @Dick
                  msg should become msgLight
                  gw.send(msgLight.set(state ? false : true), true); // Send new state and request ack back
                  and move one } just below this line
                  to the very end of you sketch
                  DickD 3 Replies Last reply
                  • BartEB BartE
                    @Dick
                    DickD
                    DickD
                    Dick
                    no errors anymore. I test the script now and will also put the changes you posted befor.
                    • BartEB BartE
                      @Dick
                      DickD
                      DickD
                      Dick
                      tested and also add the changes of your message (9hrs ago).
                      What I see on the serial monitor is, temp (2x), hum (2x) and light level but nothing of the relay. it is still clicking but no change in the logging from 1 to 0 etc. I already adjusted the script this morning with the 'RelayWithButtonActuator Example'. so only the relay part is not working and not visible in the serial log. Any idea?
                      • DickD Dick
                        BartEB
                        BartEB
                        BartE
                        @Dick are you sure it's not a hardware (wire) issue?
                        What happens if you load the RelayWithButtonActuator example code (with the correct pinning of course) ?
                        • BartEB BartE
                          @Dick
                          DickD
                          DickD
                          Dick
                          here the latist version but not working
                           #define RELAY_ON 1
                           #define RELAY_OFF 0
                          int oldValue=0;
                           bool state;
                           int lastLightLevel;
                          DHT* dht[2];
                           dht[i] = new DHT;
                          timer = 0;
                           timer++;
                           timer = 0;
                           Serial.println(i);
                           if (!metric)
                           Serial.print(i);
                           Serial.println(i);
                           Serial.print(i);
                            Serial.print("L=");
                          debouncer.update();
                            oldValue = value;
                          • DickD Dick
                             #define RELAY_ON 1
                             #define RELAY_OFF 0
                            int oldValue=0;
                             bool state;
                             int lastLightLevel;
                            DHT* dht[2];
                             dht[i] = new DHT;
                            timer = 0;
                             timer++;
                             timer = 0;
                             Serial.println(i);
                             if (!metric)
                             Serial.print(i);
                             Serial.println(i);
                             Serial.print(i);
                              Serial.print("L=");
                            debouncer.update();
                              oldValue = value;
                            BartEB
                            BartEB
                            BartE
                            @Dick
                            Change these lines
                                oldValue = value;
                            to
                                oldValue = value;
                            DickD 2 Replies Last reply
                            • BartEB BartE
                              @Dick
                              Change these lines
                                  oldValue = value;
                              to
                                  oldValue = value;
                              DickD
                              DickD
                              Dick
                              and about the test of the RelayWithButtonActuator Example,
                              it works fine. I adjust the lines now and will test it
                              • BartEB BartE
                                @Dick
                                Change these lines
                                    oldValue = value;
                                to
                                    oldValue = value;
                                DickD
                                DickD
                                Dick
                                tested but still clicking relay. As you can see that there is nothing to see in the serial log
                                send: 4-4-0-0 s=255,c=3,t=15,pt=2,l=2,sg=0,st=ok:0
                                send: 4-4-0-0 s=255,c=0,t=18,pt=0,l=5,sg=0,st=ok:1.5.4
                                send: 4-4-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
                                read: 0-0-4 s=255,c=3,t=6,pt=0,l=1,sg=0:M
                                repeater started, id=4, parent=0, distance=1
                                send: 4-4-0-0 s=255,c=3,t=11,pt=0,l=16,sg=0,st=ok:HumidityAndRelay
                                send: 4-4-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:1.0
                                send: 4-4-0-0 s=0,c=0,t=7,pt=0,l=0,sg=0,st=ok:
                                send: 4-4-0-0 s=1,c=0,t=7,pt=0,l=0,sg=0,st=ok:
                                send: 4-4-0-0 s=3,c=0,t=6,pt=0,l=0,sg=0,st=ok:
                                send: 4-4-0-0 s=5,c=0,t=3,pt=0,l=0,sg=0,st=ok:
                                T0= 22.20
                                H0= 61.80
                                send: 4-4-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,st=ok:74
                                L=74
                                T1= 25.00
                                H1= 60.20
                                L=74
                                L=74
                                send: 4-4-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,st=ok:76
                                L=76
                                • DickD Dick
                                  T0= 22.20
                                  H0= 61.80
                                  L=74
                                  T1= 25.00
                                  H1= 60.20
                                  L=74
                                  L=74
                                  L=76
                                  BartEB
                                  BartEB
                                  BartE
                                  #34
                                  @Dick If there is nothing visible in the log, then you can presume there is a hardware issue.
                                  Some possible issues:
                                  • loose relays wire (bad connection) --> try a different wire
                                  • wrong pin is used (if set as input the pin will "float" resulting in unstable relay behaviour) --> double check your pin number in code and actual PCB
                                  • pin double used ie the DHT drive poll this pin for some reason. --> use a different pin in both code and conection to relay
                                  • BartEB BartE
                                    DickD
                                    DickD
                                    Dick
                                    thank you BartE, I received today an new Uno and some other stuff so I can rebuild it al to see if it is an HW failure. I hope I can start tomorrow. I keep you informed but thanks for your support. to be continued.
                                    • DickD Dick
                                      BartEB
                                      BartEB
                                      BartE
                                      #36
                                      @Dick Not sure what your approach is but normally i start with prototyping using these wires and when all works fine (software and hardware) i solder everything together on a PCB.
