  3. Cobine working DHT22 and LDR with a RelayWithButtonActuator
dht22 ldr relay
36 Posts 4 Posters 8.4k Views 5 Watching
  • mfalkviddM
    Try commenting out
    state = gw.loadState(CHILD_ID);
    until you are ready to handle incoming messages.
    DickD 1 Reply Last reply
      Try commenting out
      DickD
      DickD
      Dick
      I did what you suggested but no result. Perhaps I have to split-up the project into my initial plan (ldr, and 2x temp/Hum) and make another node for the relay because I do not know to solve the current issue.
      • alexsh1A
        alexsh1A
        alexsh1
        Try to define BUTTON_PIN to a digital pin and see if it makes a difference.
        Change the following in the setup
        pinMode(BUTTON_PIN, INPUT);
        This is my sketch working on arduino+relay on my corner stand lamp and it is working fine on MySensors 1.5.4
        // This code is basically the same as the default RelayWithButtonActuator sketch. The only difference is the pin numbering.
        #define RELAY_PIN  3  // Arduino Digital I/O pin number for relay
        #define BUTTON_PIN  4  // Arduino Digital I/O pin number for button
        #define RELAY_ON 1
        #define RELAY_OFF 0
        #define NODE_ADDRESS 2
        Bounce debouncer = Bounce();
        int oldValue=0;
        bool state;
          gw.begin(incomingMessage, NODE_ADDRESS, true);
          gw.sendSketchInfo("Relay & Button", "1.0");
         // Setup the button
          pinMode(BUTTON_PIN,INPUT);
          // Activate internal pull-up
          debouncer.attach(BUTTON_PIN);
          debouncer.interval(5);
          gw.present(CHILD_ID, S_LIGHT);
          pinMode(RELAY_PIN, OUTPUT);
        *  Example on how to asynchronously check for new messages from gw
          debouncer.update();
          // Get the update value
          int value = debouncer.read();
          if (value != oldValue && value==0) {
              gw.send(msg.set(state?false:true), true); // Send new state and request ack back
          oldValue = value;
          if (message.isAck()) {
             // Change relay state
             state = message.getBool();
             // Store state in eeprom
             gw.saveState(CHILD_ID, state);
        • alexsh1A alexsh1
          #define RELAY_ON 1
          #define RELAY_OFF 0
          int oldValue=0;
          bool state;
           // Setup the button
            debouncer.update();
            oldValue = value;
          DickD
          DickD
          Dick
          thank you Alex, it did not work. It is strange, in my topic BartE posted a srcipt what workerd almost perfect. Relay change was good and saw it in the Serial minitor changing from 0 to 1. after adding the LDR stuff it went wrong. So it must be something in the LDR add-on. combining is still not easy for me but I am learning.
          alexsh1A 1 Reply Last reply
          • DickD Dick
            alexsh1A
            alexsh1A
            alexsh1
            @Dick With sketches it is like this sometimes - troubleshooting is time consuming.
            I would suggest the following. Try to comment out line by line on the LDR code, upload and see if it works. Try to insert as many Serial.print as you could to print the status of variables to the serial port.
            I do not have the LDR so cannot help you much on this one. I have multiple other sketches combined together working just fine.
            • alexsh1A alexsh1
              DickD
              DickD
              Dick
              @alexsh1
              That could I do, thanks for the tip and will do that today. Any idea is welcome :smiley:
              BartEB 1 Reply Last reply
              • DickD Dick
                @alexsh1
                BartEB
                BartEB
                BartE
                wrote on last edited by BartE
                #22
                @Dick I think this issue sits here you use Digital port 0 (which is the serial debug port) i.s.o. Analog port 0 (A0).
                Change this line
                to
                 #define LIGHT_SENSOR_ANALOG_PIN A0
                And you better also add this line to the setup function
                pinMode(LIGHT_SENSOR_ANALOG_PIN, INPUT);
                • BartEB BartE
                  Change this line
                  to
                  DickD
                  DickD
                  Dick
                  have not tried all the given options but started again with all the previous advises of Bart. Noe I still struggle with an error
                  "gw.begin(incomingMessage, AUTO, true);" in mij script. I checkt the "{ }" over and over again but it must be something else.
                  can anybody take a look?
                  #define CHILD_ID_HUM1 0
                   #define CHILD_ID_HUM2 1
                   #define CHILD_ID_TEMP1 3
                   #define CHILD_ID_TEMP2 4
                  #define CHILD_ID_LIGHT 0
                  // RelayWithActuator stuff
                   #define RELAY_PIN 5 // Arduino Digital I/O pin number for relay
                   #define BUTTON_PIN 6 // Arduino Digital I/O pin number for button
                   #define CHILD_ID 5 // Id of the sensor child
                   #define RELAY_ON 1
                   #define RELAY_OFF 0
                  int oldValue=0;
                   bool state;
                  MyMessage msgLight(CHILD_ID,V_LIGHT);
                  MyMessage msgLightLevel(CHILD_ID_LIGHT, V_LIGHT_LEVEL);
                   int lastLightLevel;
                  #define HEARTBEAT 10
                   unsigned int timer = 0;
                   // Sleep time between reads (in milliseconds)
                   #define SLEEP_TIME 3000
                  DHT* dht[2];
                   byte sensorPin[2] = {3, 4};
                   float lastTemp[2] = {0.0, 0.0};
                   float lastHum[2] = {0.0, 0.0};
                  boolean metric = true;
                  //MyMessage msgHum(CHILD_ID_HUM1, V_HUM);
                  //MyMessage msgTemp(CHILD_ID_TEMP1, V_TEMP);
                   gw.sendSketchInfo("HumidityAndRelay", "1.0");
                   for (int i = 0; i < 2; i++)
                   dht[i] = new DHT;
                   dht[i]->setup(sensorPin[i]);
                  gw.present(CHILD_ID_HUM1, S_HUM);
                   gw.present(CHILD_ID_HUM2, S_HUM);
                   gw.present(CHILD_ID_TEMP1, S_TEMP);
                  // Setup the button and Activate internal pull-up
                  timer = 0;
                   timer++;
                  if (timer > (SLEEP_TIME / HEARTBEAT))
                   // Reset timer again and for the next timed loop
                   timer = 0;
                   delay(dht[i]->getMinimumSamplingPeriod());
                   float temperature = dht[i]->getTemperature();
                   if (isnan(temperature))
                   Serial.print(F("Failed reading temperature from DHT"));
                   Serial.println(i);
                   else if (temperature != lastTemp[i])
                   lastTemp[i] = temperature;
                   if (!metric)
                   temperature = dht[i]->toFahrenheit(temperature);
                  //gw.send(msgTemp.set(temperature, i));
                   Serial.print(F("T"));
                   Serial.print(i);
                   Serial.print(F("= "));
                   float humidity = dht[i]->getHumidity();
                   if (isnan(humidity))
                   Serial.print("Failed reading humidity from DHT");
                   Serial.println(i);
                   else if (humidity != lastHum[i])
                   lastHum[i] = humidity;
                  //gw.send(msgHum.set(humidity, 1));
                   Serial.print(F("H"));
                   Serial.print(i);
                   Serial.println(humidity);
                  int lightLevel = (1023-analogRead(LIGHT_SENSOR_ANALOG_PIN))/10.23;
                  //Serial.println(lightLevel);
                   if (lightLevel != lastLightLevel)
                  gw.send(msgLightLevel.set(lightLevel));
                    //lastLightLevel = lightLevel;
                    Serial.print("L=");
                  debouncer.update();
                    oldValue = value;
                  gw.wait(HEARTBEAT); //sleep a bit
                  • mfalkviddM
                    #24
                    The auto-formatting feature in the Arduino IDE is very useful for makin the code easier to read (both for yourself and for us forum readers) and spot mistakes.
                    What is the error message you are getting?
                      DickD
                      DickD
                      Dick
                      three errors. hope you can give an advise!
                      In function 'void loop()':
                      laatste:163: error: 'msg' was not declared in this scope
                      At global scope:
                      laatste:172: error: expected declaration before '}' token
                      In function 'void setup()':
                      laatste:47: error: 'incomingMessage' was not declared in this scope
                      • DickD Dick
                        At global scope:
                        BartEB
                        BartEB
                        BartE
                        #26
                        @Dick
                        msg should become msgLight
                        gw.send(msgLight.set(state ? false : true), true); // Send new state and request ack back
                        and move one } just below this line
                        to the very end of you sketch
                        DickD 3 Replies Last reply
                        • BartEB BartE
                          @Dick
                          DickD
                          DickD
                          Dick
                          no errors anymore. I test the script now and will also put the changes you posted befor.
                          • BartEB BartE
                            @Dick
                            DickD
                            DickD
                            Dick
                            tested and also add the changes of your message (9hrs ago).
                            What I see on the serial monitor is, temp (2x), hum (2x) and light level but nothing of the relay. it is still clicking but no change in the logging from 1 to 0 etc. I already adjusted the script this morning with the 'RelayWithButtonActuator Example'. so only the relay part is not working and not visible in the serial log. Any idea?
                            • DickD Dick
                              BartEB
                              BartEB
                              BartE
                              @Dick are you sure it's not a hardware (wire) issue?
                              What happens if you load the RelayWithButtonActuator example code (with the correct pinning of course) ?
                              • BartEB BartE
                                @Dick
                                DickD
                                DickD
                                Dick
                                here the latist version but not working
                                 #define RELAY_ON 1
                                 #define RELAY_OFF 0
                                int oldValue=0;
                                 bool state;
                                 int lastLightLevel;
                                DHT* dht[2];
                                 dht[i] = new DHT;
                                timer = 0;
                                 timer++;
                                 timer = 0;
                                 Serial.println(i);
                                 if (!metric)
                                 Serial.print(i);
                                 Serial.println(i);
                                 Serial.print(i);
                                  Serial.print("L=");
                                debouncer.update();
                                  oldValue = value;
                                • DickD Dick
                                   #define RELAY_ON 1
                                   #define RELAY_OFF 0
                                  int oldValue=0;
                                   bool state;
                                   int lastLightLevel;
                                  DHT* dht[2];
                                   dht[i] = new DHT;
                                  timer = 0;
                                   timer++;
                                   timer = 0;
                                   Serial.println(i);
                                   if (!metric)
                                   Serial.print(i);
                                   Serial.println(i);
                                   Serial.print(i);
                                    Serial.print("L=");
                                  debouncer.update();
                                    oldValue = value;
                                  BartEB
                                  BartEB
                                  BartE
                                  @Dick
                                  Change these lines
                                      oldValue = value;
                                  to
                                      oldValue = value;
                                  DickD 2 Replies Last reply
                                  • BartEB BartE
                                    @Dick
                                    Change these lines
                                        oldValue = value;
                                    to
                                        oldValue = value;
                                    DickD
                                    DickD
                                    Dick
                                    and about the test of the RelayWithButtonActuator Example,
                                    it works fine. I adjust the lines now and will test it
                                    • BartEB BartE
                                      @Dick
                                      Change these lines
                                          oldValue = value;
                                      to
                                          oldValue = value;
                                      DickD
                                      DickD
                                      Dick
                                      tested but still clicking relay. As you can see that there is nothing to see in the serial log
                                      send: 4-4-0-0 s=255,c=3,t=15,pt=2,l=2,sg=0,st=ok:0
                                      send: 4-4-0-0 s=255,c=0,t=18,pt=0,l=5,sg=0,st=ok:1.5.4
                                      send: 4-4-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
                                      read: 0-0-4 s=255,c=3,t=6,pt=0,l=1,sg=0:M
                                      repeater started, id=4, parent=0, distance=1
                                      send: 4-4-0-0 s=255,c=3,t=11,pt=0,l=16,sg=0,st=ok:HumidityAndRelay
                                      send: 4-4-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:1.0
                                      send: 4-4-0-0 s=0,c=0,t=7,pt=0,l=0,sg=0,st=ok:
                                      send: 4-4-0-0 s=1,c=0,t=7,pt=0,l=0,sg=0,st=ok:
                                      send: 4-4-0-0 s=3,c=0,t=6,pt=0,l=0,sg=0,st=ok:
                                      send: 4-4-0-0 s=5,c=0,t=3,pt=0,l=0,sg=0,st=ok:
                                      T0= 22.20
                                      H0= 61.80
                                      send: 4-4-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,st=ok:74
                                      L=74
                                      T1= 25.00
                                      H1= 60.20
                                      L=74
                                      L=74
                                      send: 4-4-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,st=ok:76
                                      L=76
                                      • DickD Dick
                                        T0= 22.20
                                        H0= 61.80
                                        L=74
                                        T1= 25.00
                                        H1= 60.20
                                        L=74
                                        L=74
                                        L=76
                                        BartEB
                                        BartEB
                                        BartE
                                        #34
                                        @Dick If there is nothing visible in the log, then you can presume there is a hardware issue.
                                        Some possible issues:
                                        • loose relays wire (bad connection) --> try a different wire
                                        • wrong pin is used (if set as input the pin will "float" resulting in unstable relay behaviour) --> double check your pin number in code and actual PCB
                                        • pin double used ie the DHT drive poll this pin for some reason. --> use a different pin in both code and conection to relay
                                        • BartEB BartE
                                          DickD
                                          DickD
                                          Dick
                                          thank you BartE, I received today an new Uno and some other stuff so I can rebuild it al to see if it is an HW failure. I hope I can start tomorrow. I keep you informed but thanks for your support. to be continued.
