  3. Cobine working DHT22 and LDR with a RelayWithButtonActuator
dht22 ldr relay
36 Posts 4 Posters 8.4k Views 5 Watching
    Try commenting out
    state = gw.loadState(CHILD_ID);
    until you are ready to handle incoming messages.
    DickD
    DickD
    Dick
    I did what you suggested but no result. Perhaps I have to split-up the project into my initial plan (ldr, and 2x temp/Hum) and make another node for the relay because I do not know to solve the current issue.
    • alexsh1A
      alexsh1A
      alexsh1
      Try to define BUTTON_PIN to a digital pin and see if it makes a difference.
      Change the following in the setup
      pinMode(BUTTON_PIN, INPUT);
      This is my sketch working on arduino+relay on my corner stand lamp and it is working fine on MySensors 1.5.4
      // This code is basically the same as the default RelayWithButtonActuator sketch. The only difference is the pin numbering.
      #define RELAY_PIN  3  // Arduino Digital I/O pin number for relay
      #define BUTTON_PIN  4  // Arduino Digital I/O pin number for button
      #define RELAY_ON 1
      #define RELAY_OFF 0
      #define NODE_ADDRESS 2
      Bounce debouncer = Bounce();
      int oldValue=0;
      bool state;
        gw.begin(incomingMessage, NODE_ADDRESS, true);
        gw.sendSketchInfo("Relay & Button", "1.0");
       // Setup the button
        pinMode(BUTTON_PIN,INPUT);
        // Activate internal pull-up
        debouncer.attach(BUTTON_PIN);
        debouncer.interval(5);
        gw.present(CHILD_ID, S_LIGHT);
        pinMode(RELAY_PIN, OUTPUT);
      *  Example on how to asynchronously check for new messages from gw
        debouncer.update();
        // Get the update value
        int value = debouncer.read();
        if (value != oldValue && value==0) {
            gw.send(msg.set(state?false:true), true); // Send new state and request ack back
        oldValue = value;
        if (message.isAck()) {
           // Change relay state
           state = message.getBool();
           // Store state in eeprom
           gw.saveState(CHILD_ID, state);
      DickD 1 Reply Last reply
      • alexsh1A alexsh1
        #define RELAY_ON 1
        #define RELAY_OFF 0
        int oldValue=0;
        bool state;
         // Setup the button
          debouncer.update();
          oldValue = value;
        DickD
        DickD
        Dick
        thank you Alex, it did not work. It is strange, in my topic BartE posted a srcipt what workerd almost perfect. Relay change was good and saw it in the Serial minitor changing from 0 to 1. after adding the LDR stuff it went wrong. So it must be something in the LDR add-on. combining is still not easy for me but I am learning.
        alexsh1A 1 Reply Last reply
        • DickD Dick
          alexsh1A
          alexsh1A
          alexsh1
          @Dick With sketches it is like this sometimes - troubleshooting is time consuming.
          I would suggest the following. Try to comment out line by line on the LDR code, upload and see if it works. Try to insert as many Serial.print as you could to print the status of variables to the serial port.
          I do not have the LDR so cannot help you much on this one. I have multiple other sketches combined together working just fine.
          • alexsh1A alexsh1
            DickD
            DickD
            Dick
            @alexsh1
            That could I do, thanks for the tip and will do that today. Any idea is welcome :smiley:
            BartEB 1 Reply Last reply
            • DickD Dick
              @alexsh1
              BartEB
              BartEB
              BartE
              wrote on last edited by BartE
              #22
              @Dick I think this issue sits here you use Digital port 0 (which is the serial debug port) i.s.o. Analog port 0 (A0).
              Change this line
              to
               #define LIGHT_SENSOR_ANALOG_PIN A0
              And you better also add this line to the setup function
              pinMode(LIGHT_SENSOR_ANALOG_PIN, INPUT);
              • BartEB BartE
                Change this line
                to
                DickD
                DickD
                Dick
                have not tried all the given options but started again with all the previous advises of Bart. Noe I still struggle with an error
                "gw.begin(incomingMessage, AUTO, true);" in mij script. I checkt the "{ }" over and over again but it must be something else.
                can anybody take a look?
                #define CHILD_ID_HUM1 0
                 #define CHILD_ID_HUM2 1
                 #define CHILD_ID_TEMP1 3
                 #define CHILD_ID_TEMP2 4
                #define CHILD_ID_LIGHT 0
                // RelayWithActuator stuff
                 #define RELAY_PIN 5 // Arduino Digital I/O pin number for relay
                 #define BUTTON_PIN 6 // Arduino Digital I/O pin number for button
                 #define CHILD_ID 5 // Id of the sensor child
                 #define RELAY_ON 1
                 #define RELAY_OFF 0
                int oldValue=0;
                 bool state;
                MyMessage msgLight(CHILD_ID,V_LIGHT);
                MyMessage msgLightLevel(CHILD_ID_LIGHT, V_LIGHT_LEVEL);
                 int lastLightLevel;
                #define HEARTBEAT 10
                 unsigned int timer = 0;
                 // Sleep time between reads (in milliseconds)
                 #define SLEEP_TIME 3000
                DHT* dht[2];
                 byte sensorPin[2] = {3, 4};
                 float lastTemp[2] = {0.0, 0.0};
                 float lastHum[2] = {0.0, 0.0};
                boolean metric = true;
                //MyMessage msgHum(CHILD_ID_HUM1, V_HUM);
                //MyMessage msgTemp(CHILD_ID_TEMP1, V_TEMP);
                 gw.sendSketchInfo("HumidityAndRelay", "1.0");
                 for (int i = 0; i < 2; i++)
                 dht[i] = new DHT;
                 dht[i]->setup(sensorPin[i]);
                gw.present(CHILD_ID_HUM1, S_HUM);
                 gw.present(CHILD_ID_HUM2, S_HUM);
                 gw.present(CHILD_ID_TEMP1, S_TEMP);
                // Setup the button and Activate internal pull-up
                timer = 0;
                 timer++;
                if (timer > (SLEEP_TIME / HEARTBEAT))
                 // Reset timer again and for the next timed loop
                 timer = 0;
                 delay(dht[i]->getMinimumSamplingPeriod());
                 float temperature = dht[i]->getTemperature();
                 if (isnan(temperature))
                 Serial.print(F("Failed reading temperature from DHT"));
                 Serial.println(i);
                 else if (temperature != lastTemp[i])
                 lastTemp[i] = temperature;
                 if (!metric)
                 temperature = dht[i]->toFahrenheit(temperature);
                //gw.send(msgTemp.set(temperature, i));
                 Serial.print(F("T"));
                 Serial.print(i);
                 Serial.print(F("= "));
                 float humidity = dht[i]->getHumidity();
                 if (isnan(humidity))
                 Serial.print("Failed reading humidity from DHT");
                 Serial.println(i);
                 else if (humidity != lastHum[i])
                 lastHum[i] = humidity;
                //gw.send(msgHum.set(humidity, 1));
                 Serial.print(F("H"));
                 Serial.print(i);
                 Serial.println(humidity);
                int lightLevel = (1023-analogRead(LIGHT_SENSOR_ANALOG_PIN))/10.23;
                //Serial.println(lightLevel);
                 if (lightLevel != lastLightLevel)
                gw.send(msgLightLevel.set(lightLevel));
                  //lastLightLevel = lightLevel;
                  Serial.print("L=");
                debouncer.update();
                  oldValue = value;
                gw.wait(HEARTBEAT); //sleep a bit
                • mfalkviddM
                  #24
                  The auto-formatting feature in the Arduino IDE is very useful for makin the code easier to read (both for yourself and for us forum readers) and spot mistakes.
                  What is the error message you are getting?
                    DickD
                    DickD
                    Dick
                    three errors. hope you can give an advise!
                    In function 'void loop()':
                    laatste:163: error: 'msg' was not declared in this scope
                    At global scope:
                    laatste:172: error: expected declaration before '}' token
                    In function 'void setup()':
                    laatste:47: error: 'incomingMessage' was not declared in this scope
                    • DickD Dick
                      At global scope:
                      BartEB
                      BartEB
                      BartE
                      #26
                      @Dick
                      msg should become msgLight
                      gw.send(msgLight.set(state ? false : true), true); // Send new state and request ack back
                      and move one } just below this line
                      to the very end of you sketch
                      DickD 3 Replies Last reply
                      • BartEB BartE
                        @Dick
                        DickD
                        DickD
                        Dick
                        no errors anymore. I test the script now and will also put the changes you posted befor.
                        • BartEB BartE
                          @Dick
                          DickD
                          DickD
                          Dick
                          tested and also add the changes of your message (9hrs ago).
                          What I see on the serial monitor is, temp (2x), hum (2x) and light level but nothing of the relay. it is still clicking but no change in the logging from 1 to 0 etc. I already adjusted the script this morning with the 'RelayWithButtonActuator Example'. so only the relay part is not working and not visible in the serial log. Any idea?
                          • DickD Dick
                            BartEB
                            BartEB
                            BartE
                            @Dick are you sure it's not a hardware (wire) issue?
                            What happens if you load the RelayWithButtonActuator example code (with the correct pinning of course) ?
                            • BartEB BartE
                              @Dick
                              DickD
                              DickD
                              Dick
                              here the latist version but not working
                               #define RELAY_ON 1
                               #define RELAY_OFF 0
                              int oldValue=0;
                               bool state;
                               int lastLightLevel;
                              DHT* dht[2];
                               dht[i] = new DHT;
                              timer = 0;
                               timer++;
                               timer = 0;
                               Serial.println(i);
                               if (!metric)
                               Serial.print(i);
                               Serial.println(i);
                               Serial.print(i);
                                Serial.print("L=");
                              debouncer.update();
                                oldValue = value;
                              • DickD Dick
                                 #define RELAY_ON 1
                                 #define RELAY_OFF 0
                                int oldValue=0;
                                 bool state;
                                 int lastLightLevel;
                                DHT* dht[2];
                                 dht[i] = new DHT;
                                timer = 0;
                                 timer++;
                                 timer = 0;
                                 Serial.println(i);
                                 if (!metric)
                                 Serial.print(i);
                                 Serial.println(i);
                                 Serial.print(i);
                                  Serial.print("L=");
                                debouncer.update();
                                  oldValue = value;
                                BartEB
                                BartEB
                                BartE
                                @Dick
                                Change these lines
                                    oldValue = value;
                                to
                                    oldValue = value;
                                DickD 2 Replies Last reply
                                • BartEB BartE
                                  @Dick
                                  Change these lines
                                      oldValue = value;
                                  to
                                      oldValue = value;
                                  DickD
                                  DickD
                                  Dick
                                  and about the test of the RelayWithButtonActuator Example,
                                  it works fine. I adjust the lines now and will test it
                                  • BartEB BartE
                                    @Dick
                                    Change these lines
                                        oldValue = value;
                                    to
                                        oldValue = value;
                                    DickD
                                    DickD
                                    Dick
                                    tested but still clicking relay. As you can see that there is nothing to see in the serial log
                                    send: 4-4-0-0 s=255,c=3,t=15,pt=2,l=2,sg=0,st=ok:0
                                    send: 4-4-0-0 s=255,c=0,t=18,pt=0,l=5,sg=0,st=ok:1.5.4
                                    send: 4-4-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
                                    read: 0-0-4 s=255,c=3,t=6,pt=0,l=1,sg=0:M
                                    repeater started, id=4, parent=0, distance=1
                                    send: 4-4-0-0 s=255,c=3,t=11,pt=0,l=16,sg=0,st=ok:HumidityAndRelay
                                    send: 4-4-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:1.0
                                    send: 4-4-0-0 s=0,c=0,t=7,pt=0,l=0,sg=0,st=ok:
                                    send: 4-4-0-0 s=1,c=0,t=7,pt=0,l=0,sg=0,st=ok:
                                    send: 4-4-0-0 s=3,c=0,t=6,pt=0,l=0,sg=0,st=ok:
                                    send: 4-4-0-0 s=5,c=0,t=3,pt=0,l=0,sg=0,st=ok:
                                    T0= 22.20
                                    H0= 61.80
                                    send: 4-4-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,st=ok:74
                                    L=74
                                    T1= 25.00
                                    H1= 60.20
                                    L=74
                                    L=74
                                    send: 4-4-0-0 s=0,c=1,t=23,pt=2,l=2,sg=0,st=ok:76
                                    L=76
                                    • DickD Dick
                                      T0= 22.20
                                      H0= 61.80
                                      L=74
                                      T1= 25.00
                                      H1= 60.20
                                      L=74
                                      L=74
                                      L=76
                                      BartEB
                                      BartEB
                                      BartE
                                      #34
                                      @Dick If there is nothing visible in the log, then you can presume there is a hardware issue.
                                      Some possible issues:
                                      • loose relays wire (bad connection) --> try a different wire
                                      • wrong pin is used (if set as input the pin will "float" resulting in unstable relay behaviour) --> double check your pin number in code and actual PCB
                                      • pin double used ie the DHT drive poll this pin for some reason. --> use a different pin in both code and conection to relay
                                      • BartEB BartE
                                        DickD
                                        DickD
                                        Dick
                                        thank you BartE, I received today an new Uno and some other stuff so I can rebuild it al to see if it is an HW failure. I hope I can start tomorrow. I keep you informed but thanks for your support. to be continued.
                                        • DickD Dick
                                          BartEB
                                          BartEB
                                          BartE
                                          #36
                                          @Dick Not sure what your approach is but normally i start with prototyping using these wires and when all works fine (software and hardware) i solder everything together on a PCB.
