  3. IR node
IR node
7 Posts 4 Posters 2.0k Views 4 Watching
  • S Offline
    skatun
    Hi
    I have connected my IR node to my serial gateway, however I have a wish that my controller(Opnehab on RPI) can send out NEC,xxxxxx to my gateway which then forwards it to the node. This way I do not need to recompile my node everytime I want to add a new IR command. Is it possible to achieve this? I had a glance at the IR code provided here:
      if (message.type==V_LIGHT) {
         int incomingRelayStatus = message.getInt();
         if (incomingRelayStatus == 1) {
          irsend.send(NEC, 0x2AA22DD, 32); // Vol up yamaha ysp-900
          irsend.send(NEC, 0x1EE1F807, 32); // Vol down yamaha ysp-900
         // Start receiving ir again...
        irrecv.enableIRIn();
    How has other people implemented IR commands?
    • mfalkviddM Offline
      There are several threads on IR in the forum. https://forum.mysensors.org/topic/2413/ir-record-and-playback-module Is probably a good starting point.
      S 1 Reply Last reply
        skatun
        @mfalkvidd , Thanks for the tip:) I saw some other IR codes in the forum, but @BartE code seems the most promissing. Do you think I can modify his code to achieve what I want?
        On OpenHab which I use as controller I will then send something similiar to this then when I want(single button in OH): to turn on my TV, select correct input source on my stereo, select correct hdmi channel:
        12;7;1;1;32;NEC,0xa8bca
        12;7;1;1;32;NEC,0xa54bca
        12;7;1;1;32;NEC,0xa62ca
        • CrankyCoderC Offline
          CrankyCoder
          Has anyone done any testing with having your IR codes stored at the controller?
          A while back I had played with having my IR codes stored on the controller in a mapping file so I wouldn't have to recode my IR blaster each time I wanted a new IR code added.
          However, this was all done with my blaster being over network not RF.
          Has anyone done anything with this type of setup over the mysensors RF?
          Home Automation Tinkerer
          www.CrankyCoder.net
          Gateway: MQTTClientGateway
          MySensors: 2.3
          martinhjelmareM mfalkviddM 2 Replies Last reply
          • CrankyCoderC CrankyCoder
            martinhjelmareM Offline
            martinhjelmare
            @Jason-Brunk
            It's now possible in home-assistant.
            https://forum.mysensors.org/topic/3917/an-hass-service-to-send-messages-to-nodes/7
              Yes. See the link I posted above your post.
                CrankyCoder
                Thanks! The looks alot like what I did with my non-mysensors stuff. So that is perfect!!
                www.CrankyCoder.net
                MySensors: 2.3
                12.1k
