  3. Sketch for Lightning Sensor
58 Posts 14 Posters 41.7k Views 11 Watching
  • alexsh1A alexsh1
    I found a similar sensor in the UK and added this to the list of my to be sensors for the weatherstation. Can I use it inside or it has to be placed outside to have a direct vision?
    http://www.embeddedadventures.com/as3935_lightning_sensor_module_mod-1016.html
    Tore André RosanderT
    Tore André Rosander
    @alexsh1 What i read when researching this chip it can be placed inside.
    @Sparkman Nice, i see that it has a detection range about 40km so thats already a pretty good distance to get a notification when lightning is detected.
    • alexsh1A
      alexsh1A
      alexsh1
      #32
      @Sparkman I suppose your wiring diagram above is correct? I noted that the sensor is not working with 3.3V. Did you manage to find what the problem was? Looking at the datasheet http://www.embeddedadventures.com/datasheets/MOD-1016_hw_v8_doc_v4.pdf I can see what the module can operate down to 2.4V
      I am going to receive the sensor in a few days and test it.
      As I have a different module manufacturer, I may need to change the sketch as it uses a different library. This is unmodified example sketch:
      // AS3935 MOD-1016 Lightning Sensor Arduino test sketch
      // Written originally by Embedded Adventures
      #include <AS3935.h>
      #define IRQ_pin 2
      volatile bool detected = false;
        while (!Serial) {}
        Serial.println("Welcome to the MOD-1016 (AS3935) Lightning Sensor test sketch!");
        Serial.println("Embedded Adventures (www.embeddedadventures.com)\n");
        Wire.begin();
        mod1016.init(IRQ_pin);
        //Tune Caps, Set AFE, Set Noise Floor
        //autoTuneCaps(IRQ_pin);
        mod1016.setTuneCaps(7);
        mod1016.setOutdoors();
        mod1016.setNoiseFloor(5);
        Serial.println("TUNE\tIN/OUT\tNOISEFLOOR");
        Serial.print(mod1016.getTuneCaps(), HEX);
        Serial.print("\t");
        Serial.print(mod1016.getAFE(), BIN);
        Serial.print("\t");
        Serial.println(mod1016.getNoiseFloor(), HEX);
        Serial.print("\n");
        pinMode(IRQ_pin, INPUT);
        attachInterrupt(digitalPinToInterrupt(IRQ_pin), alert, RISING);
        Serial.println("after interrupt");
        if (detected) {
          translateIRQ(mod1016.getIRQ());
          detected = false;
      void alert() {
        detected = true;
      void translateIRQ(uns8 irq) {
        switch(irq) {
            case 1:
              Serial.println("NOISE DETECTED");
            case 4:
              Serial.println("DISTURBER DETECTED");
            case 8:
              Serial.println("LIGHTNING DETECTED");
              printDistance();
      void printDistance() {
        int distance = mod1016.calculateDistance();
        if (distance == -1)
          Serial.println("Lightning out of range");
        else if (distance == 1)
          Serial.println("Distance not in table");
        else if (distance == 0)
          Serial.println("Lightning overhead");
        else {
          Serial.print("Lightning ~");
          Serial.print(distance);
          Serial.println("km away\n");
      This is SPI sketch, I'd like to use I2C connection. Generally, the procedure is as follows:
      Wait a few milliseconds for the system to stabilise
       Set the tune capacitor to the value indicated on the packaging, by setting the
      TUNE_CAP bits of register 8
       Wait 2 milliseconds
       Callibrate RCO by:
      o Sending a calibrate RCO direct command (set memory location 0x3d to the
      value 0x96)
      o Set Register 0x08, bit 5 to 1
      o Wait 2 milliseconds
      o Set Register 0x08, bit 5 to 0
      The factory calibrating tuning cap value will be fine for general use. When you have a
      MOD-1016 in an enclosure or close to other electronics it is worth calibrating the tuning
      cap again.
        #33
        can't wait to test this one too ;) i have pcbs for a weather shield (with bme280, veml6070 etc. ) and i have this sensor on it too (https://forum.mysensors.org/uploads/files/1459631385870-stacked.jpg). But not assembled yet, was busy, i hope asap.. i plan to use it with 3v and i2c. @alexsh1 There are libs for i2c if you want :)
        Thx @Sparkman for your work on it ;)
        alexsh1A 1 Reply Last reply
        • scalzS scalz
          alexsh1A
          alexsh1A
          alexsh1
          @scalz yes, please (for i2c lib). What is this red board you have?
          • SparkmanS
            SparkmanS
            Sparkman
            @alexsh1 @scalz
            I'm running my sketch with I2C now, rather than SPI. I found the sensor would lock up occassionally, so recently converted it and am still testing it. I have mine running at 5v now as well instead of 3.3v, but it works fine with either.
            I'll post an updated sketch (and wiring diagram) soon. I based both the spi and i2c sketches on the examples found here: http://playingwithfusion.com/productview.php?pdid=22&catid=1001.
            Al
            • SparkmanS Sparkman
              @alexsh1 @scalz
              Al
              alexsh1A
              alexsh1A
              alexsh1
              @Sparkman Thanks. Your sketch is very much appreciated. I'll have to adopt it anyway as I have a different manufacture and there is a certain process I have to follow to get it initiated (posted above).
              • alexsh1A
                alexsh1A
                alexsh1
                #37
                Absolutely delighted with the module I have received today by post. The weather is sh@t tonight (lightning, rain etc.) which means that I can test it:
                TUNE	IN/OUT	NOISEFLOOR
                6	10010	5
                after interrupt
                DISTURBER DETECTED
                DISTURBER DETECTED
                DISTURBER DETECTED
                DISTURBER DETECTED
                DISTURBER DETECTED
                LIGHTNING DETECTED
                Lightning ~27km away
                DISTURBER DETECTED
                DISTURBER DETECTED
                LIGHTNING DETECTED
                Lightning ~17km away
                DISTURBER DETECTED
                LIGHTNING DETECTED
                Lightning ~10km away
                I calibrated the sensor and put a reasonable "noise floor". Now I have to convert it into MySensors and hook up to the ceech board outside.
                @Sparkman I have my sensor running at 3.3V
                • alexsh1A alexsh1
                  6	10010	5
                  after interrupt
                  DISTURBER DETECTED
                  DISTURBER DETECTED
                  DISTURBER DETECTED
                  DISTURBER DETECTED
                  DISTURBER DETECTED
                  LIGHTNING DETECTED
                  DISTURBER DETECTED
                  DISTURBER DETECTED
                  LIGHTNING DETECTED
                  DISTURBER DETECTED
                  LIGHTNING DETECTED
                  alexsh1A
                  alexsh1A
                  alexsh1
                  BTW, I am not sure the sensor is similar to what you guys have.
                  SparkmanS K 2 Replies Last reply
                  • alexsh1A alexsh1
                    SparkmanS
                    SparkmanS
                    Sparkman
                    @alexsh1 It looks to be a different breakout board, but for the same chip. So I would expect them to work basically the same.
                    Al
                      Al
                      alexsh1A
                      alexsh1A
                      alexsh1
                      @Sparkman it is a different board made (or designed) by a UK company.
                      We are having a real British summer over here :-)))
                      LIGHTNING DETECTED
                      Lightning ~20km away
                      LIGHTNING DETECTED
                      LIGHTNING DETECTED
                      Lightning ~6km away
                      LIGHTNING DETECTED
                      Lightning ~6km away
                      LIGHTNING DETECTED
                      Lightning ~6km away
                      LIGHTNING DETECTED
                      Lightning ~6km away
                      LIGHTNING DETECTED
                      Lightning ~6km away
                      LIGHTNING DETECTED
                      Lightning ~5km away
                      • alexsh1A alexsh1
                        LIGHTNING DETECTED
                        LIGHTNING DETECTED
                        LIGHTNING DETECTED
                        Lightning ~6km away
                        LIGHTNING DETECTED
                        Lightning ~6km away
                        LIGHTNING DETECTED
                        Lightning ~6km away
                        LIGHTNING DETECTED
                        Lightning ~6km away
                        LIGHTNING DETECTED
                        Lightning ~6km away
                        LIGHTNING DETECTED
                        Lightning ~5km away
                        @alexsh1
                        There doesn't appear to be audio input to this board, nor a microphone on the board. So, how does it estimate the distance to the lightening?
                        SparkmanS 1 Reply Last reply
                          @alexsh1
                          SparkmanS
                          SparkmanS
                          Sparkman
                          @NeverDie All these breakout boards are based on this chip: http://ams.com/eng/Products/Wireless-Connectivity/Wireless-Sensor-Connectivity/AS3935. They use a proprietary method to figure out distance and is not based on sound.
                          Al
                            Al
                            Al
                            Any impression yet as to how accurate its distance estimates are?
                            SparkmanS alexsh1A 2 Replies Last reply
                              Al
                              SparkmanS
                              SparkmanS
                              Sparkman
                              @NeverDie No, as we've had very little lightning since I started using it.
                                Al
                                alexsh1A
                                alexsh1A
                                alexsh1
                                @NeverDie Al, was quicker replying to your question. :-)
                                yes, I think it is accurate for my needs - if a lightning detected at, say, 10km+/- 1km this is ok. How accurate do you want it to be?
                                This is a great technology
                                • alexsh1A alexsh1
                                  #46
                                  I'm not sure, but more accurate than lightningmaps.com or it's a no-go. I've played with lightningmaps.com during a few thunderstorms, and although it's great for getting a general idea of lightning strike rate and density, I was surprised that it seems to miss a lot of detections entirely that both my eyes and ears have confirmed. e.g. some strikes that were big enough to rattle the windows didn't show up at all on lightningmaps. Some of the others were detected, but the map plot of the strike was wrong by maybe 10 miles or so.
                                    alexsh1A
                                    alexsh1A
                                    alexsh1
                                    @NeverDie I have not tested this sensor long enough, but recently we have had torrential rain, lightning, etc - you can see some data I published above. The sensor did not miss a single one. There are a few parameters you can alter (noise floor). One has to setup it correctly. I have not started looking into converting the sketch for MySensors yet
                                    • alexsh1A
                                      alexsh1A
                                      alexsh1
                                      #48
                                      I have adopted the MOD-1016 module (https://www.embeddedadventures.com/datasheets/MOD-1016_hw_v8_doc_v4.pdf) for MySensors if anyone is interested:
                                      Copyright (c) 2016, Embedded Adventures
                                      All rights reserved.
                                      Contact us at source [at] embeddedadventures.com
                                      Redistribution and use in source and binary forms, with or without
                                      modification, are permitted provided that the following conditions are met:
                                      - Redistributions of source code must retain the above copyright notice,
                                        this list of conditions and the following disclaimer.
                                      - Redistributions in binary form must reproduce the above copyright
                                        notice, this list of conditions and the following disclaimer in the
                                        documentation and/or other materials provided with the distribution.
                                      - Neither the name of Embedded Adventures nor the names of its contributors
                                        may be used to endorse or promote products derived from this software
                                        without specific prior written permission.
                                      THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
                                      AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
                                      IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
                                      ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE
                                      LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
                                      CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
                                      SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
                                      INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
                                      CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
                                      ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF
                                      THE POSSIBILITY OF SUCH DAMAGE.
                                      #define MY_NODE_ID 15
                                      #include <AS3935.h> // AS3935 MOD-1016 by Embedded Adventures
                                       //-----------------IMPORTANT--------------------
                                       //---------------CHANGE SETTINGS HERE-----------
                                      #define IRQ_pin 2
                                      #define AS3935_TUNE_CAPS     6 // <-- SET THIS VALUE TO THE NUMBER LISTED ON YOUR BOARD
                                      #define AS3935_INDOORS       1 // AS3935_INDOORS=1 indoors, AS3935_INDOORS=0 outdoors
                                      #define AS3935_NOISE_FLOOR   6
                                      #define AS3935_ENABLE_DISTURBERS 1 // 0 or 1
                                      #define CHILD_ID_DISTANCE 1
                                      #define CHILD_ID_INTENSITY 2
                                      MyMessage msgDist(CHILD_ID_DISTANCE, V_DISTANCE);
                                      MyMessage msgInt(CHILD_ID_INTENSITY, V_VAR1);
                                        while (!Serial) {}
                                        Serial.println("MOD-1016 (AS3935) Lightning Sensor");
                                        Serial.println("beginning boot procedure....");
                                        Wire.begin();
                                        mod1016.setTuneCaps(AS3935_TUNE_CAPS);
                                      delay(2);
                                      #if AS3935_INDOORS == 1
                                        mod1016.setIndoors();
                                      delay(2);
                                      mod1016.setNoiseFloor(AS3935_NOISE_FLOOR);
                                      delay(2);
                                      #if AS3935_ENABLE_DISTURBERS == 1
                                        mod1016.enableDisturbers();
                                        mod1016.disableDisturbers();
                                      //mod1016.calibrateRCO();
                                      delay(2);
                                        Serial.print("\t");
                                        Serial.print("\t");
                                        Serial.print("\n");
                                          // delay execution to allow chip to stabilize.
                                        delay(1000);
                                      void presentation()  {
                                        sendSketchInfo("Lightning Sensor MOD-1016", "1.0");
                                        present(CHILD_ID_DISTANCE, S_DISTANCE);
                                        present(CHILD_ID_INTENSITY, S_CUSTOM);
                                        if (detected) {
                                          detected = false;
                                      void alert() {
                                        detected = true;
                                        switch(irq) {
                                            case 1:
                                              Serial.println("Noise detected");
                                            case 4:
                                              Serial.println("Disturber detected");
                                            case 8:
                                              Serial.println("Lightning detected!");
                                              printandsendToGW();
                                      void printandsendToGW() {
                                        unsigned int lightning_intensity = mod1016.getIntensity();
                                        if (distance == -1)
                                        else {
                                          Serial.print("Lightning Intensity: ");
                                          Serial.println(lightning_intensity);
                                          send(msgDist.set(distance));
                                          send(msgInt.set(lightning_intensity));
                                      You have to change the sketch according to your module settings
                                      skywatchS 1 Reply Last reply
                                      • skywatchS
                                        skywatchS
                                        skywatch
                                        #49
                                        I ordered one form embedded adventures on 27/7 - Now it is 3/9 and still nothing.
                                        Waiting to hear from them....
                                        That's the whole truth.
                                        • skywatchS skywatch
                                          alexsh1A
                                          alexsh1A
                                          alexsh1
                                          @skywatch give them a call or send a e-mail. Maybe your order was lost in post. Happens.
                                          My order arrived in 2 days from Embedded Adventures
