  3. Sketch for Lightning Sensor
58 Posts 14 Posters 41.7k Views 11 Watching
  • H hleidecker
    Also, the AS3935 returns the distance in km, but I believe S_DISTANCE is in cm. Is there a way to specify different units or should I have the sketch convert it to cm and then have the controller convert back to km?
    The actual value returned can be as large as 16843008. I'll take a look at VAR_1, but don't believe the HomeSeer plugin supports that yet. As a test I used I used V_WATT/S_POWER for now.
    Two mechanisms have been implemented in the HomeSeer controller plugin (1.0.5574.17274) to support custom unit strings in the controller UI:
    • V_UNIT_PREFIX (only available in the development branch of the MySensors library). The prefix provided in the V_UNIT_PREFIX message will precede the default metric unit (defined by the plugin e.g. m (meter) for the distance sensor). The sensor configuration (metric/imperial) can be set by the user as a property on S_ARDUINO_NODE device via the HomeSeer UI. Please note, the prefix will not take effect when the sensor configuration is set to imperial.
    • A user defined unit string. A unit string can be defined by the user. The metric/imperial configuration unit string and unit prefix will be ignored if a user defined unit string exists. The user defined unit string can be set by the user as a property on the device e..g. S_DISTANCE via the HomeSeer UI.
    The HomeSeer MySensors plugin is available here.
    Best regards,
    Henrik
    SparkmanS
    SparkmanS
    Sparkman
    @hleidecker Thanks Henrik!
    • SparkmanS
      SparkmanS
      Sparkman
      Hi all,
      Well I was finally home when a thunderstorm rolled through and I was able to test the sensor and the sketch. Even though the sensor appeared to be working at 3.3V, I had to change it to 5V to get it to work properly with the USB powered Nano I have it connected to. I modified the sketch slightly (updated in my earlier post) to no longer send data when disturbers or unknown interrupt sources were detected. It's working great now and just need to put it into a case. I may use a different Arduino as well.
      Al
        Sweet. Would you want to create a pull request when you're ready with this example (including AS3935 library)?
        SparkmanS
        SparkmanS
        Sparkman
        wrote on last edited by Sparkman
        #25
        Hi Henrik,
        Pull request submitted. Hopefully I did it correctly.
        Al
          Nice that you finally got some lightings to test your sketch.
          Pull request looks all ok!
          • Tore André RosanderT
            Tore André Rosander
            Is it possible to detect the distance to the lightningstrike?
            I was thinking to get some sort of detector to notify me if there is ligning registered X km away from my home.
            B SparkmanS 2 Replies Last reply
            • Tore André RosanderT Tore André Rosander
              B
              B
              boozz
              @Tore-André-Rosander
              You would need a sound detector for the thunder. Time (in milliseconds) between lightning and thunder times 0.34[m].
              Same as you would do it with your own sensors (eyes and ears) :-)
              BR,
              Boozz
                SparkmanS
                SparkmanS
                Sparkman
                @Tore-André-Rosander Yes, the sensor can detect the distance. See the details of the sensor here: http://playingwithfusion.com/productview.php?pdid=22&catid=1001. Although I'm starting to believe that it's actually a lightning repeller rather than a lightning sensor as we've had very little lightning in our area after I installed it :laughing:
                Al
                • alexsh1A
                  alexsh1A
                  alexsh1
                  I found a similar sensor in the UK and added this to the list of my to be sensors for the weatherstation. Can I use it inside or it has to be placed outside to have a direct vision?
                  http://www.embeddedadventures.com/as3935_lightning_sensor_module_mod-1016.html
                  Tore André RosanderT 1 Reply Last reply
                  • alexsh1A alexsh1
                    Tore André Rosander
                    @alexsh1 What i read when researching this chip it can be placed inside.
                    @Sparkman Nice, i see that it has a detection range about 40km so thats already a pretty good distance to get a notification when lightning is detected.
                    • alexsh1A
                      alexsh1A
                      alexsh1
                      #32
                      @Sparkman I suppose your wiring diagram above is correct? I noted that the sensor is not working with 3.3V. Did you manage to find what the problem was? Looking at the datasheet http://www.embeddedadventures.com/datasheets/MOD-1016_hw_v8_doc_v4.pdf I can see what the module can operate down to 2.4V
                      I am going to receive the sensor in a few days and test it.
                      As I have a different module manufacturer, I may need to change the sketch as it uses a different library. This is unmodified example sketch:
                      // AS3935 MOD-1016 Lightning Sensor Arduino test sketch
                      // Written originally by Embedded Adventures
                      #include <AS3935.h>
                      #define IRQ_pin 2
                      volatile bool detected = false;
                        while (!Serial) {}
                        Serial.println("Welcome to the MOD-1016 (AS3935) Lightning Sensor test sketch!");
                        Serial.println("Embedded Adventures (www.embeddedadventures.com)\n");
                        Wire.begin();
                        mod1016.init(IRQ_pin);
                        //Tune Caps, Set AFE, Set Noise Floor
                        //autoTuneCaps(IRQ_pin);
                        mod1016.setTuneCaps(7);
                        mod1016.setOutdoors();
                        mod1016.setNoiseFloor(5);
                        Serial.println("TUNE\tIN/OUT\tNOISEFLOOR");
                        Serial.print(mod1016.getTuneCaps(), HEX);
                        Serial.print("\t");
                        Serial.print(mod1016.getAFE(), BIN);
                        Serial.print("\t");
                        Serial.println(mod1016.getNoiseFloor(), HEX);
                        Serial.print("\n");
                        pinMode(IRQ_pin, INPUT);
                        attachInterrupt(digitalPinToInterrupt(IRQ_pin), alert, RISING);
                        Serial.println("after interrupt");
                        if (detected) {
                          translateIRQ(mod1016.getIRQ());
                          detected = false;
                      void alert() {
                        detected = true;
                      void translateIRQ(uns8 irq) {
                        switch(irq) {
                            case 1:
                              Serial.println("NOISE DETECTED");
                            case 4:
                              Serial.println("DISTURBER DETECTED");
                            case 8:
                              Serial.println("LIGHTNING DETECTED");
                              printDistance();
                      void printDistance() {
                        int distance = mod1016.calculateDistance();
                        if (distance == -1)
                          Serial.println("Lightning out of range");
                        else if (distance == 1)
                          Serial.println("Distance not in table");
                        else if (distance == 0)
                          Serial.println("Lightning overhead");
                        else {
                          Serial.print("Lightning ~");
                          Serial.print(distance);
                          Serial.println("km away\n");
                      This is SPI sketch, I'd like to use I2C connection. Generally, the procedure is as follows:
                      Wait a few milliseconds for the system to stabilise
                       Set the tune capacitor to the value indicated on the packaging, by setting the
                      TUNE_CAP bits of register 8
                       Wait 2 milliseconds
                       Callibrate RCO by:
                      o Sending a calibrate RCO direct command (set memory location 0x3d to the
                      value 0x96)
                      o Set Register 0x08, bit 5 to 1
                      o Wait 2 milliseconds
                      o Set Register 0x08, bit 5 to 0
                      The factory calibrating tuning cap value will be fine for general use. When you have a
                      MOD-1016 in an enclosure or close to other electronics it is worth calibrating the tuning
                      cap again.
                        #33
                        can't wait to test this one too ;) i have pcbs for a weather shield (with bme280, veml6070 etc. ) and i have this sensor on it too (https://forum.mysensors.org/uploads/files/1459631385870-stacked.jpg). But not assembled yet, was busy, i hope asap.. i plan to use it with 3v and i2c. @alexsh1 There are libs for i2c if you want :)
                        Thx @Sparkman for your work on it ;)
                        alexsh1A 1 Reply Last reply
                        • scalzS scalz
                          alexsh1A
                          alexsh1A
                          alexsh1
                          @scalz yes, please (for i2c lib). What is this red board you have?
                          • SparkmanS
                            SparkmanS
                            Sparkman
                            @alexsh1 @scalz
                            I'm running my sketch with I2C now, rather than SPI. I found the sensor would lock up occassionally, so recently converted it and am still testing it. I have mine running at 5v now as well instead of 3.3v, but it works fine with either.
                            I'll post an updated sketch (and wiring diagram) soon. I based both the spi and i2c sketches on the examples found here: http://playingwithfusion.com/productview.php?pdid=22&catid=1001.
                            Al
                            • SparkmanS Sparkman
                              @alexsh1 @scalz
                              Al
                              alexsh1A
                              alexsh1A
                              alexsh1
                              @Sparkman Thanks. Your sketch is very much appreciated. I'll have to adopt it anyway as I have a different manufacture and there is a certain process I have to follow to get it initiated (posted above).
                              • alexsh1A
                                alexsh1A
                                alexsh1
                                #37
                                Absolutely delighted with the module I have received today by post. The weather is sh@t tonight (lightning, rain etc.) which means that I can test it:
                                TUNE	IN/OUT	NOISEFLOOR
                                6	10010	5
                                after interrupt
                                DISTURBER DETECTED
                                DISTURBER DETECTED
                                DISTURBER DETECTED
                                DISTURBER DETECTED
                                DISTURBER DETECTED
                                LIGHTNING DETECTED
                                Lightning ~27km away
                                DISTURBER DETECTED
                                DISTURBER DETECTED
                                LIGHTNING DETECTED
                                Lightning ~17km away
                                DISTURBER DETECTED
                                LIGHTNING DETECTED
                                Lightning ~10km away
                                I calibrated the sensor and put a reasonable "noise floor". Now I have to convert it into MySensors and hook up to the ceech board outside.
                                @Sparkman I have my sensor running at 3.3V
                                • alexsh1A alexsh1
                                  6	10010	5
                                  after interrupt
                                  DISTURBER DETECTED
                                  DISTURBER DETECTED
                                  DISTURBER DETECTED
                                  DISTURBER DETECTED
                                  DISTURBER DETECTED
                                  LIGHTNING DETECTED
                                  DISTURBER DETECTED
                                  DISTURBER DETECTED
                                  LIGHTNING DETECTED
                                  DISTURBER DETECTED
                                  LIGHTNING DETECTED
                                  alexsh1A
                                  alexsh1A
                                  alexsh1
                                  BTW, I am not sure the sensor is similar to what you guys have.
                                  SparkmanS K 2 Replies Last reply
                                  • alexsh1A alexsh1
                                    SparkmanS
                                    SparkmanS
                                    Sparkman
                                    @alexsh1 It looks to be a different breakout board, but for the same chip. So I would expect them to work basically the same.
                                    Al
                                      Al
                                      alexsh1A
                                      alexsh1A
                                      alexsh1
                                      @Sparkman it is a different board made (or designed) by a UK company.
                                      We are having a real British summer over here :-)))
                                      LIGHTNING DETECTED
                                      Lightning ~20km away
                                      LIGHTNING DETECTED
                                      LIGHTNING DETECTED
                                      Lightning ~6km away
                                      LIGHTNING DETECTED
                                      Lightning ~6km away
                                      LIGHTNING DETECTED
                                      Lightning ~6km away
                                      LIGHTNING DETECTED
                                      Lightning ~6km away
                                      LIGHTNING DETECTED
                                      Lightning ~6km away
                                      LIGHTNING DETECTED
                                      Lightning ~5km away
                                      • alexsh1A alexsh1
                                        LIGHTNING DETECTED
                                        LIGHTNING DETECTED
                                        LIGHTNING DETECTED
                                        Lightning ~6km away
                                        LIGHTNING DETECTED
                                        Lightning ~6km away
                                        LIGHTNING DETECTED
                                        Lightning ~6km away
                                        LIGHTNING DETECTED
                                        Lightning ~6km away
                                        LIGHTNING DETECTED
                                        Lightning ~6km away
                                        LIGHTNING DETECTED
                                        Lightning ~5km away
                                        @alexsh1
                                        There doesn't appear to be audio input to this board, nor a microphone on the board. So, how does it estimate the distance to the lightening?
                                        SparkmanS 1 Reply Last reply
                                          @alexsh1
                                          SparkmanS
                                          SparkmanS
                                          Sparkman
                                          @NeverDie All these breakout boards are based on this chip: http://ams.com/eng/Products/Wireless-Connectivity/Wireless-Sensor-Connectivity/AS3935. They use a proprietary method to figure out distance and is not based on sound.
                                          Al
