  3. Vera
  4. Vera3 UI5 MySensors Plugin not working after migration to 1.4
31 Posts 4 Posters 11.2k Views 3 Watching
    @samppa said:
    Has the radio power been lowered between 1.3 and 1.4?
    No.
    Please describe your setup. Radio model?, capacitors mounted?, cable length between radio/arduino?
    S 1 Reply Last reply
      No.
      samppa
      @hek
      Tough questions for newbie.. :-) The radio is from the buying guide, no capacitors and 10cm dupont cables.
      hekH 1 Reply Last reply
      • S samppa
        @hek
        @samppa
        Try adding capacitor as suggested. The latest discussions on the forum recommends a larger one than the one we link on buying guide (I will update the links soon).
        Here are some assorted electrolytic with different capacitance.
        S HomerH 2 Replies Last reply
          @samppa
          samppa
          @hek
          Why it is needed for 1.4 as earlier everything worked well in 1.3 without it?
          I do not have any readily available and I was hoping to get back up again without waiting for the delivery.
          • S samppa
            @hek
            @samppa
            This version transmits bursts of messages which probably requires more power for a short period.
            Try lowering transmit power in MyConfig.h while waiting for the capacitors.
              @samppa
              samppa
              @hek
              You mean
              #define RF24_PA_LEVEL RF24_PA_LOW
                @samppa
                HomerH
                HomerH
                Homer
                @hek said:
                @samppa
                Which capacitor is suggested now?
                  @samppa
                  Yes
                  @Homer
                  Read this thread: http://forum.mysensors.org/topic/171/efficiency-of-voltage-boosters
                  • S samppa
                    @hek
                    You mean
                    samppa
                    Did not help.. ;-(
                    Perhaps I have to wait for the capacitors..
                    Somehow the first message (with version) seems to go through more often than the rest..
                    • S samppa
                      Did not help.. ;-(
                      @samppa
                      Don't you have some old electronics you could butcher and desolder a couple of capacitors from? Or a nearby shop? Waiting 2 weeks for the Chinese/Finnish post isn't that fun.
                        @samppa
                        samppa
                        @hek
                        Yes I could do that. What size? Anything goes, right? Thee discussion in the post you liked was rather long without definitive conclusion.. :-)
                        • S samppa
                          @hek
                          samppa
                          @samppa
                          Just to confirm; the capacitor should be put to sensor node or serial gateway? Or both and all nodes?
                          And in parallel with the radio on the power lines?
                          • S samppa
                            @samppa
                            @samppa
                            I use it on all nodes. Mount it as close as possible to the radio between VCC/GND.
                            S 2 Replies Last reply
                              @samppa
                              samppa
                              @hek
                              Ok that made the radio to work.
                              But still the reported values are not shown in UI5.
                              Somehow the Humidity sensor has CurrentTemperature variable, so it seems something is mixed up..
                              I have one DHT22 and one Dallas temperature sensor in one node. The devices are found during inclusion and added, but no data is shown. The only thing shown is the last update time that seems to be correct..
                                @samppa
                                samppa
                                @hek
                                Here is how it looks on Sensor:
                                sensor started, id 1
                                send: 1-1-0-0 s=255,c=0,t=17,pt=0,l=3,st=ok:1.4
                                send: 1-1-0-0 s=255,c=3,t=6,pt=1,l=1,st=ok:0
                                read: 0-0-1 s=255,c=3,t=6,pt=0,l=2:M
                                send: 1-1-0-0 s=255,c=3,t=11,pt=0,l=0,st=ok:
                                send: 1-1-0-0 s=255,c=3,t=12,pt=0,l=3,st=ok:1.4
                                send: 1-1-0-0 s=0,c=0,t=7,pt=0,l=3,st=ok:1.4
                                send: 1-1-0-0 s=1,c=0,t=6,pt=0,l=3,st=ok:1.4
                                send: 1-1-0-0 s=2,c=0,t=6,pt=0,l=3,st=ok:1.4
                                send: 1-1-0-0 s=0,c=1,t=0,pt=7,l=5,st=ok:77.9
                                send: 1-1-0-0 s=1,c=1,t=1,pt=7,l=5,st=ok:43.1
                                send: 1-1-0-0 s=2,c=1,t=1,pt=7,l=5,st=ok:78.1
                                send: 1-1-0-0 s=1,c=1,t=1,pt=7,l=5,st=ok:43.0
                                send: 1-1-0-0 s=1,c=1,t=1,pt=7,l=5,st=ok:42.7
                                So the transmission seems to be ok..
                                • S samppa
                                  @hek
                                  samppa
                                  The mixup with temp and humidity was my typo in code. It would be great if the gateway or sensor would warn if a wrong type of value is sent compared to the presented sensor type.
                                  That temeprature is in Farenheit. Somehow the GW responds false when calling:
                                  Now everything else except the metric works with this node..
                                    It has no knowledge of this today. We're having discussions about the future elsewhere on this forum.
                                    Did you see this update?
                                    http://forum.mysensors.org/topic/326/mysensors-1-4-released/34
                                      samppa
                                      btw: thanks for the great help and outstanding forum!
                                      It had no reference to isMetric is it broken or am I misusing it somehow?
                                      In the migration guide it said:
                                      metric = gw.isMetricSystem();
                                      change to
                                      But I get false even though the seting is metric (and not Imperial) in Vera Plugin 1.4. Weird..
                                        There was another problem lurking in the code related to controller-configuration that was fixed a few hours ago. Did you get this change when you updated?
                                          samppa
                                          @hek
                                          I think the 1.4 version I downloaded and updated was a bit older. So perhaps I need to update again.. grr.
                                          What would be the easiest update mechanism? Is the OTA update working already?
