  3. Arduino Mini Pro 5v - how to power
powerarduinopromini
31 Posts 8 Posters 31.6k Views 3 Watching
  • DammeD Damme
    @ddluk I run my 5v 16mhz at 3.3v.. Direcly off 2 AA batteries too (I think the reported voltage last I checked was 2.88v, Still works just fine. :) (But I have flashed bootloader to disable brownout voltage)
    marceltrapmanM
    marceltrapmanM
    marceltrapman
    Interesting, are you saying that you removed the boot loader and use an external programmer or do you use another bootloader (I must admit that I did not pay attention too much when the bootloader was discussed elsewhere on the forum)?
    Fulltime Servoy Developer
    • Z
      Z
      Zeph
      I think he's talking about setting fuses, rather than the bootloader per se - but it's often done with the same tool (eg: AVRDUDE).
      The bootloader is code that runs in a protected portion of Flash memory. The fuses are a few extra bytes of low level processor configuration. Both are set using the same tools.
      You can google for programming ATMega328 fuses (and look in the datasheet for the bit values).
      • korttomaK
        korttomaK
        korttoma
        Anybody have any thoughts about running the Pro Mini 5v or 3.3v on one of these:
        • Tomas
        • Z Zeph
          marceltrapmanM
          marceltrapmanM
          marceltrapman
          @Zeph interesting stuff. Will look that up as soon as I am home again...
            I've added an ISP programmer (used to program Arduino bootloader) in the "shop" now.
            epierreE 1 Reply Last reply
              epierreE
              epierreE
              epierre
              @hek looks like you've ha enough of arduino slowdown you now propose a cubie ;-) A lipo would be a very good addition to the store too !
              I'm searching for a leaf wetness sensor... not a rain sensor, hard to find as it seems...
              z-wave - Vera -> Domoticz
              hekH 1 Reply Last reply
              • epierreE epierre
                Cubie has a bit more processing power than RPi. For the demading controllers :)
                @epierre said:
                leaf wetness sensor
                The only leaf wetness sensors I can find is super expensive. Like this:
                http://www.ebay.com/itm/Brand-New-DAVIS-LEAF-WETNESS-SENSOR-/331222331582?pt=LH_DefaultDomain_0&hash=item4d1e63b0be
                Can you (or someone else) recommend any lipo battery seller on ebay? I haven't got any buying experience just yet.
                epierreE YveauxY 3 Replies Last reply
                  @epierre said:
                  leaf wetness sensor
                  epierreE
                  epierreE
                  epierre
                  @hek yes it looks like I've added one sensor to much on the raspi... (infact 10...)
                  For the Lipo, no idea yet (not supercaps...), I was hoping this thread would propose something interresting...
                  For the leaf wetness I'll try with the rain sensor but... I need some autonomous energy system for it will sleep outside...
                    @epierre said:
                    leaf wetness sensor
                    @hek @epierre What exactly is a 'leaf wetness sensor' and in what does your link differ from e.g. http://www.dx.com/p/cg05sz-063-rain-sensor-for-arduino-black-silver-works-with-official-arduino-boards-266534#.VAv7_FV_v7s ?
                    • YveauxY Yveaux
                      @Yveaux
                      http://en.wikipedia.org/wiki/Leaf_wetness
                      Probably just a calibration/quality thing. The technique/principle is probably the same.
                        @Yveaux
                        @hek OK thanks.
                        Reading this I think there also is a very close relation to humidity sensor readings. Would be nice to see the readings of both next to each other!
                        • YveauxY Yveaux
                          @hek OK thanks.
                          epierreE
                          epierreE
                          epierre
                          @Yveaux @hek I've forked to its own post: http://forum.mysensors.org/topic/352/leaf-wetness
                          I'll try to add things following mysearches and experiments
                            @epierre said:
                            leaf wetness sensor
                            epierreE
                            epierreE
                            epierre
                            @hek
                            http://www.cooking-hacks.com/lipo-rider-pro
                            http://www.cooking-hacks.com/shop/arduino/converters/5v-regulator-module-for-arduino
                            http://www.cooking-hacks.com/7-4v-lipo-2200mah-battery-arduino-power-jack
                            they have the same at spark.io (hardware cum software like mysensors, same radio different core) :
                            http://docs.spark.io/shields/#battery-shield
                            The battery shield is a LiPo battery charger and voltage regulator combined into one. You can use it to power your Core with any 3.7V LiPo battery and charge it at the same time via the USB port. The shield is built around Microchip's MCP73871 battery charge management controller and TI's TPS61200 boost converter for up converting 3.7V to 5.0V.
                            There are plenty of 3.7V lipo batteries on ebay.com ...
                              Moustache shaped LiPo charger. Hmm.. ;)
                              The lipo-rider looks good, but there's mostly the older version on ebay. They seem to have switched JST-connector-version between their rider-revisions.
                              It is still hard to recommend LiPo batteries from ebay without doing some tests on them. I wouldn't use any without protection as they might explode if you use/charge them wrong.
                              epierreE 2 Replies Last reply
                                epierreE
                                epierreE
                                epierre
                                @hek sadly I'm not expert at all on this to test them...
                                • D
                                  ddluk
                                  Because discussion is going to different direction than topic could any of you clarify what exactly I will need to power those 5.0v mini pro. I'd like to order parts to get them this month :)
                                  • Z
                                    Z
                                    Zeph
                                    A tested and trustworthy Li-Ion battery supplier could be a good thing. I'm glad @hek is waiting to know something about a vendor before suggesting them, they do need to be vetted.
                                    From what I've read, there are a lot of cheap rebuilt ones out there. Some may just substantially exaggerate the capacity but do work OK, some won't last long. And of course, they are more dangerous than most of our components. You can't tell what you are getting from the outside and many vendors take advantage of that so there are a lot of fakes out there.
                                    A good source for info is the flashlight lover sites like http://candlepowerforums.com
                                    • D ddluk
                                      By mistake I bought some time ago 10pcs of Arduino Mini Pro 5v (instead of 3.3v) and now I've got a problem how to give them power? It's better to use:
                                      • 2x1.5V AA batteries and use step up converter to get from 3.0v -> 5.0v
                                      • 4x1.5V AA batteries and use step down converter to get from 6.0v -> 5v
                                      Or maybe there is different possibility? I will be really happy if someone will be able to help me with this issue.
                                      Z
                                      Z
                                      Zeph
                                      wrote on last edited by Zeph
                                      #23
                                      Let me try again on this one. The answer depends on what else you need to power (assuming that you feed Vcc without using the onboard regulator).. Like do you have any other 5V devices (eg: sensors, actuators), and/or any 3.3v devices (eg: sensors, radios).
                                      If you need regulated 3.3v,and you want to sleep to save battery, I'm becoming attracted to the idea of 3c 1.5v alkaline and MCP1700 linear regulator. When your duty cycle is low, the efficiency of the regulator under load for short periods becomes less important to battery life than the quiescent current of the regulator (and the sleep mode of the processor and other devices).
                                      As others have said, if all of your devices can handle the voltage range, using 2 or 3 batteries without a regulator becomes another option. The ATMega328P and other AVRs are remarkably tolerant of voltages (with appropriate brownout fuses if necessary), so it's more about the other devices.
                                      If you power the 5V APMs via the VCC pins, I would at least test the sleep mode power drain and be sure the unused backward-fed onboard regulator isn't drawing too much current and remove it if so.
                                      • Z Zeph
                                        epierreE
                                        epierreE
                                        epierre
                                        @Zeph said:
                                        MCP1700
                                        Is there a componant including it ? I would have gone for an AMS1117 asproposed in the store ?
                                        Z 1 Reply Last reply
                                          epierreE
                                          epierreE
                                          epierre
                                          #25
                                          @hek I'm sure the oustache will fit you perfectly ;-)
                                          From Adafruit website I've extracted two LiPo batteries reference, maybe we could start this way ? would there be fakes of some reference ?
                                          PKCELL LP803860
                                          18650 3.7v 2200mAh samsung version
