  3. PiDome
  4. PiDome Domotica/Home Automation
Scheduled Pinned Locked Moved PiDome
controllerserialgatewayraspberrymqttpidome
199 Posts 17 Posters 144.4k Views 5 Watching
  • JohnJ
    JohnJ
    John
    @Fwessels
    Just send you a chat message because i got interested in the XML structure the device editor then would be creating.
    • JohnJ
      JohnJ
      John
      Thanks to @Fwessels the issue has been found :). More then many thanks to him.
      It was related to the build environment which supplied the alpha downloads. It "chose" the wrong source code to build which caused mixed results. This has been solved.
      • FrancoisF
        FrancoisF
        Francois
        Great news I now have PIdome running with Hum sensor and Dallas temp sensor.
        upload-2de9399e-840b-4589-9d3d-93eca635c53d
        • FrancoisF
          FrancoisF
          Francois
          @john this morning I have a funny issue as I add the new door sensor to PiDome all the Custom device disappear. Even it I add i new custom device it is not showing up in the list. I reboot the PI and it is still doing the same thing what can the issue be?
          upload-79baf84d-614a-40d3-8dfc-786d31154bef
          • JohnJ
            JohnJ
            John
            wrote on last edited by John
            @Fwessels
            Could you provide me the appLog file? This i have not seen before.
            • FrancoisF
              FrancoisF
              Francois
              @John I did not start it with the trace. I will rest start the server with trace on.
              appLog.txt
              • FrancoisF
                FrancoisF
                Francois
                @John here is the applog with trace enable. I also created the door sensor and still it is not showing up in the Custom device.
                appLog.txt
                upload-7edd95cb-dfaa-4f29-b8e3-f431022f83a7
                • JohnJ
                  JohnJ
                  John
                  First i'm seeing data coming in from the gateway before a gateway started message appears:
                  2014-09-07 10:11:13,452 [Thread-19] TRACE org.pidome.driver.driver.nativeMySensorsDriver14.NativeMySensorsDriver14 - Received from hardware driver:
                  2014-09-07 10:11:13,456 [Thread-19] ERROR org.pidome.driver.driver.nativeMySensorsDriver14.NativeMySensorsDriver14 - Faulty data or method handling: 2 (�
                  014-09-07 10:11:23,828 [Thread-19] TRACE org.pidome.driver.driver.nativeMySensorsDriver14.NativeMySensorsDriver14 - Received from hardware driver: 0;0;3;0;14;Gateway startup complete.
                  It does not interfere, but still, strange.
                  Do the devices show on the main start page e.q. dashboard? because i do see responses (still checking if server send valid ones)
                  • FrancoisF
                    FrancoisF
                    Francois
                    @john Yes all the sensor are still reporting
                    • JohnJ
                      JohnJ
                      John
                      #25
                      I think i've found it... i see a name with a "" in it: "Door\Window" all though it does not have a special meaning in json, it could mess with the tables code showing the devices, one moment. It is possible to edit a custom device with a direct link, i will send that one in a chat if you don't mind.
                      • FrancoisF
                        FrancoisF
                        Francois
                        @john not a problem
                        • JohnJ
                          JohnJ
                          John
                          The usage of "" characters in the custom device editors device naming have been tackled in the latest available snapshot.
                          • JohnJ
                            JohnJ
                            John
                            #28
                            I have added an MQTT bridge for MySensors based on the gateway/broker created by @Damme .
                            I was only not being able to test it on the real gateway but have tested it against a regular MQTT server. So if there is someone willing to test it i will be very thankful :). The tests i have done was with iot.eclipse.org, so i'm also not exactly sure if the data is implemented correctly
                            iot.eclipse.org test method
                            It has been implemented as a plugin which has the possibility to execute device mutations, so to add this plugin go to "Plugin management > Device Plugins". Click "Add new plugin". Choose the "MySensors MQTT bridge".
                            Fill in a name and description, use the MQTT gateway ip address. leave the port and prefix as the shown default if you have not changed it.
                            To create devices for the MQTT gateway refer to the first post and instead choosing the MySensors serial device, choose the MySensors MQTT device.
                            The plugin's view shows devices reported by the MQTT gateway, it shows the device address and sketch information. Adding devices shown on that page is exact the same as done with the serial version.
                            • FrancoisF
                              FrancoisF
                              Francois
                              wrote on last edited by Francois
                              #29
                              @John I did as you say with the MqTT drive now if I click on the driver and then on the "Pidome MySensor Mqtt" noting happen
                              upload-235f809e-bcb0-4de6-9104-ee41273114bd
                              applog:appLog.txt
                              Also if I click in view nothing happens
                              upload-40f6c457-0d63-4919-a618-7e37b7536bb7
                              • JohnJ
                                JohnJ
                                John
                                #30
                                Clear your browsers cache and try again. The devices appear at the plugin.
                                P.S.
                                I will in a later state modify the driver name, it is an emulator between the devices and the plugin so the plugin can create devices the same way a driver can. The reason why it is a plugin is that drivers are hardware based (GPIO, USB access). The plugin now behaves like it is hardware.
                                • FrancoisF
                                  FrancoisF
                                  Francois
                                  @John Hi I am back again. I now can see the MQTT node sensor. When I want to add the node sensor the custom devices don't show up in the "Select device to use" Why will that be?
                                  Custom device adde
                                  upload-c9a0b7b8-0e8a-4b1b-8d98-0bd9584820e9
                                  Custom device not show.
                                  upload-245527f8-f376-400c-96d2-b46432d82a93
                                  • JohnJ
                                    JohnJ
                                    John
                                    #32
                                    Device skeletons are limited to their driver/plugin and can not be interchanged (yet). When you are using the MQTT plugin you should create a MySensors MQTT custom device/skeleton. The first listing above shows these devices as a device for the serial version.
                                    • FrancoisF
                                      FrancoisF
                                      Francois
                                      @john Mysensor MQTT is now working. Thank for all you help :-) :+1:
                                      • JohnJ
                                        JohnJ
                                        John
                                        :+1: Next step would be integrating the Ethernet gateway, but that could take a week or so (working on other demanding tasks currently).
                                        • FrancoisF
                                          FrancoisF
                                          Francois
                                          @John I see that you don't have any time days in your automation triggers. Do you plan to do this at a later stage?
                                          I see that you are going to do twitter integration are you look as other message integration tools like pushbullet?
