  3. Can't figure out what I'm doing wrong with test setup
32 Posts 4 Posters 6.2k Views 4 Watching
  • linus72982L Offline
    linus72982L Offline
    linus72982
    I wrote up a python serial reading script and figured out that I only ever can get one response for separating the magnets before it stops, so it can't be the arduino serial monitor as I just tested it on my own and still it stalls out. Not sure if there's a setting for this somewhere in the sketch or what.
    • martinhjelmareM Offline
      martinhjelmare
      The message read by the gateway was an internal message of subtype 3, which is a request for node id. The node will send this message if no manual node id is set in the sketch. If using automatic node id, a controller needs to be connected to the gateway, and the controller needs to be able to hand out node ids.
      Read about this on the api page on the mysensors web.
        linus72982L Offline
        linus72982
        So, the actual message is a subtype 9, trace-log a message and it's sending "read: 255-255-0 s=255,c=3,t=3,pt=0,l=0,sg=0: 255;255;3;0;3;" correct? So, it's trace-logging a node-id request? The thing is, these messages only happen when I separate or re-pair the magnet sensors.
        Two questions: Is this a normal message -- I mean, is everything working well? I don't care how node-ids get passed out. I assume the serial gateway example sketch has it handing out node-ids?
        If everything is working well -- how do I get my sensor open/closed messages? I don't seem to be getting those. I know the sensor is doing something as the trace-log messages only happen when I trigger the sensor.
        I'm not sure where to go from here.
        A 1 Reply Last reply
        • linus72982L linus72982
          A Offline
          A Offline
          AWI
          @linus72982 You need a "controller" to issue node id's. If you don't have one you can assign a fixed id. This will allow your sketch to move on and show it's real Tricks.
            linus72982L Offline
            linus72982
            I have the nano connected to the gateway radio -- isn't that the controller?
              linus72982L Offline
              linus72982
              If I do fixed ID's, where do I do that? I assume I do that in the BinarySwitchSleepSensor sketch, I'm just not sure where. It looks like there is already a PRIMARY_CHILD_ID and SECONDARY_CHILD_ID assigned (3 and 4 respectively). Is that what those are?
                linus72982L Offline
                linus72982
                Okay, I tooled around and figured it out. I assigned a manual id in the begin() on the pro mini. But, I still have a problem:
                I get the sensor open and closed messages just fine -- for about 30 seconds. After that, I get nothing through the serial port. I restart the serial monitor and I can get 30 seconds more. I opened my Python script and same thing. I get about 10 seconds of messages on that. I'm not sure what's going on here. Does anyone else know?
                  The nano is the gateway.
                  See https://www.mysensors.org/about/network for a description of the different parts. https://www.mysensors.org/controller/ has a list of supported controllers.
                    Great progress!
                    My guess would be a power problem or an error in the sketch. Could you post your sketch so we can take a look?
                      linus72982L Offline
                      linus72982
                      Ahh, I got a bit tripped up in the terminology. The controller is my computer. I'm going to be using a custom python script to control, I'm using the gateway as a sort of dongle from the radio network to the computer. Either way, I prefer the hard-coded node-ids so handing out IDs is moot now, anyway.
                      So, to my problem, it can't be power because everything works again when I restart the serial controller. It also works more when I stop and restart my python serial monitor. It's weird, there is no communication from the computer to the gateway when I restart the monitor so I don't think it can be anything in the gateway at all, it has to be from the USB, operating system of the computer (win 10), or the monitors (unlikely because I'm using two different ones). It's almost like there's a timeout on the port or something.
                      In any case, here's the sketch in case my reasoning above isn't sound and there is something there that is affecting operation (this sketch is, literally, just the example SerialGateway from MySensors but with the added arguments in the begin() line:
                       * Simple binary switch example
                       * Connect button or door/window reed switch between
                       * digitial I/O pin 3 (BUTTON_PIN below) and GND.
                       * http://www.mysensors.org/build/binary
                      #define CHILD_ID 3
                      #define BUTTON_PIN  3  // Arduino Digital I/O pin for button/reed switch
                      Bounce debouncer = Bounce();
                      int oldValue=-1;
                        gw.begin(NULL, CHILD_ID, false);
                       // Setup the button
                        pinMode(BUTTON_PIN,INPUT);
                        // Activate internal pull-up
                        debouncer.attach(BUTTON_PIN);
                        debouncer.interval(5);
                        gw.present(CHILD_ID, S_DOOR);
                        debouncer.update();
                        // Get the update value
                        int value = debouncer.read();
                        if (value != oldValue) {
                           // Send in the new value
                           oldValue = value;
                        linus72982L Offline
                        linus72982
                        I did a little reading and found out my earlier statement that there is no communication between the computer and the gateway when I start the serial monitor is incorrect. Starting a connection resets the board, auto-reset. I know this is happening because there is a green led blink when I click on the serial monitor.
                        So, now there are more options for what it could be -- I'll check power and some other things and come back. Let me know if there's anything in the sketch that looks like it could be doing it. I don't know C well at all.
                          A Offline
                          A Offline
                          AWI
                          @linus72982 what does the serial monitor on your node show when you strart the node now. Any radio failures?
                          Your sketch looks fine.
                            linus72982L Offline
                            linus72982
                            The monitor only shows Gateway Startup Complete or whatever the initial message is. I don't have two of the cables needed so I can't check the pro mini at the same time. If I check the pro mini, then I can't get power to gateway.
                            I checked power to the pro mini, the pro mini's radio, and the nano's radio -- all good, even after I "time it out".
                            I noticed one thing, though -- after a reset, I can go for many minutes without triggering the sensor but once I do, I only get one sensor trigger before it stops reporting. If I start triggering the sensor immediately after a reset, I can get about 5 seconds of triggering before it stops reporting. If I do REALLY fast triggering of the sensor on and off I can go indefinitely. Weird?
                              linus72982L Offline
                              linus72982
                              Also, keep in mind, I can only start getting data again after a timeout by resetting the nano. Even if I reset it manually with the same serial monitor left open, I can get data back by triggering the sensors -- but again, only for a few seconds. If I reset the pro-mini, I don't get data back, just the nano.
                                linus72982L Offline
                                linus72982
                                Just a thought -- does the nano require I respond that I'm receiving the messages? As I'm only monitoring and not sending anything, could it just time out sending it if I don't tell it I'm still listening? Being that I'm not yet using a controller, if it does require some sort of response, could that be the problem?
                                  A Offline
                                  A Offline
                                  AWI
                                  @linus72982 it sounds a little confusing..
                                  Let's start again.
                                  The nano is your serial gateway node. The pro mini is your sensor node.
                                  The MySensors protocol needs a communication between two nodes to work. So both the nodes must be switched on.
                                  As far as I can see your gateway seems to function. So connect that to a powered usb port (or charger). Then connect the pro mini to a serial monitor (with ftdi) and tell us what it is doing.
                                    linus72982L Offline
                                    linus72982
                                    Yes, both nodes were switched on -- what I was saying was that I don't have two of the mini-USB cables, just one that came with the FTDI. So, if I have it plugged into the nano to power everything, I can't see the pro mini's output. If I have it plugged into the pro mini, I can't power the nano unless I move around some cables. I will head to the store in a bit and grab another usb cable in a bit and let you know the output of both.
                                      linus72982L Offline
                                      linus72982
                                      Okay, I got another cable and now have the pro-mini's output:
                                      It starts up and does this automatically:
                                      send: 3-3-0-0 s=255,c=3,t=15,pt=2,l=2,sg=0,st=fail:0
                                      send: 3-3-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,st=fail:1.5.4
                                      send: 3-3-0-0 s=3,c=0,t=0,pt=0,l=0,sg=0,st=fail:
                                      send: 3-3-0-0 s=3,c=1,t=16,pt=2,l=2,sg=0,st=fail:0
                                      Then, when I trigger the sensor open:
                                      send: 3-3-0-0 s=3,c=1,t=16,pt=2,l=2,sg=0,st=fail:1
                                      find parent
                                      Then closed:
                                      And opened again:
                                      After a few opens/closes, I get the find parent again:
                                      find parent
                                        find parent
                                        Then closed:
                                        And opened again:
                                        find parent
                                        A Offline
                                        A Offline
                                        AWI
                                        @linus72982 as expected, there is no radio contact between the node and gateway. If the node can't find a parent node (gateway) it will keep on searching. Make sure the radio is working by following the flowchart mentioned by @mfalkvidd.
                                        linus72982L 1 Reply Last reply
                                          linus72982L Offline
                                          linus72982
                                          Will do and I'll get back to you.
                                          Curious though, there does seem to be some comm between the two because I get triggers for about 5 seconds. If it doesn't find a parent, it stops sending? Maybe hardcoding a parent id would work? I'll try a few things.
