  3. Indigo Domotics
  4. Plugin for Indigo for Mac
Scheduled Pinned Locked Moved Indigo Domotics
28 Posts 3 Posters 16.3k Views 2 Watching
    Oh, question: After sending the ID to a sensor will the sensor store it 'permanently'?
    @marceltrapman
    Yes (it saves it to the EEPROM).
      @wannabee Thanks, will play with this tomorrow. Looks good :)
      W
      W
      wannabee
      @marceltrapman Glad it was helpful, Tricky part is to develop something that sends information into the network from outside. ie when you want to turn a switch on or off.
        W
        W
        wannabee
        @marceltrapman and you clear the eeprom by uploading https://github.com/mysensors/Arduino/blob/master/libraries/MySensors/examples/ClearEepromConfig/ClearEepromConfig.ino.
        • marceltrapmanM
          marceltrapmanM
          marceltrapman
          Nice @wannabee
          Three other questions:
          1. Am I correct that an Arduino board/node always presents itself and its children upon inclusion (after startup) ?
          2. I do not see a way to set the child id so assume this is set by the Arduino board/node itself?
          3. Is there a way to 'manually' ask for all available Arduino boards/nodes and/or sensors available through the gateway?
          In other words: "I like this" :)
          Fulltime Servoy Developer
          W 1 Reply Last reply
            Nice @wannabee
            W
            W
            wannabee
            wrote on last edited by wannabee
            1 For every sensor on a board you send:
            gw.sendSensorPresentation(<sensor_child_id>,<sensor_type_id>);
            2 the sensor_child_id is set by the board.
            Ie.
            #define CHILD_ID_HUM 0
            #define CHILD_ID_TEMP 1
            And then later:
            gw.sendSensorPresentation(CHILD_ID_HUM, S_HUM);
            gw.sendSensorPresentation(CHILD_ID_TEMP, S_TEMP);
            In the HumiditySensor.ino
            3 Here @hek have to correct me. The answer is maybe, if you dig deep in the routing table in the gateway. But the gateway will lose that info when rebooted. It would also be possible to send a broadcast to all nodes asking them for info, but in that case you have to implement a function in the nodes that answers on broadcast. It will also make them not sleep. I keep track of available sensors in the python code. It’s the same way the vera is doing it. You basicly stores all sensors that have sent a presentation.
              Currently, no, The routing table exists in gateway (and is not lost when rebooting). But it only contains information about were to send messages for a certain radioId (realy or direct route). Not what type of sensor(s) that each node has attached. Unfortunately the Arduino is a bit limited on how much data we can store in the EEPROM.
              • marceltrapmanM
                marceltrapmanM
                marceltrapman
                wrote on last edited by marceltrapman
                @wannabee @hek
                Both your answers have helped me a lot! Thanks a million!!!
                My 'issue' was that I was trying to do all the fancy stuff from the Controller (Indigo, or better my plugin, in this case) but obviously the sensor can be set to be active as well :)
                I have made great progress today thanks to you guys...
                • marceltrapmanM
                  marceltrapmanM
                  marceltrapman
                  For the fun of it!
                  Screen Shot 2014-04-29 at 21.42.13.png Screen Shot 2014-04-29 at 21.42.40.png Screen Shot 2014-04-29 at 21.42.58.png
                    Cool! Great work!
                    • marceltrapmanM
                      marceltrapmanM
                      marceltrapman
                      Thanks, while looking at my screenshots again I also found a little mistake :)
                      • marceltrapmanM
                        marceltrapmanM
                        marceltrapman
                        Here you see the full power of Indigo.
                        I added 2 relays to the existing temperature sensor.
                        In fact a created a custom multi sensor.
                        This is what it looks like in Indigo.
                        I will make it so that when a device will be updated or added all sensors are included :)
                        • marceltrapmanM
                          marceltrapmanM
                          marceltrapman
                          I am happy, the plugin is not ready but I moved it to my Indigo Server and it is now in production :)
                          What am I using it for right now?
                          The temperature sensor shows the temperature in a computer cabinet.
                          Based on the temperature a fan is enabled/disabled to lower the temperature.
                          For that I added the board with attached sensors and I created triggers.
                          Here it is:...
                          Screen Shot 2014-05-06 at 22.11.48.png Screen Shot 2014-05-06 at 22.12.13.png Screen Shot 2014-05-06 at 22.12.17.png
                          • marceltrapmanM
                            marceltrapmanM
                            marceltrapman
                            Added the source to github: https://github.com/IT2BE/indigo-mysensors
                            Please beware: the plugin is not ready. I have a few sensors working but I am awaiting my mini pro's to be delivered before I can move ahead.
                            In the meantime I will polish things as I am also getting ready to go on vacation in about 10 days :)
                              Nice.
                              I cloned it to mysensors so people will find it easier.
                              • marceltrapmanM
                                marceltrapmanM
                                marceltrapman
                                @hek thanks!
                                When, in the future, you want to move it to your repo that is fine with me as well.
                                • marceltrapmanM
                                  marceltrapmanM
                                  marceltrapman
                                  Yesterday evening I added a bit to the read me and improved support for the motion sensor.
                                  • marceltrapmanM
                                    marceltrapmanM
                                    marceltrapman
                                    And I updated the readme file so that it should be possible for those that feel like it to start testing it.
                                    This was my favourite piece of work :)
                                      Ok, great work!
                                      Pulled your changes.
                                      • marceltrapmanM
                                        marceltrapmanM
                                        marceltrapman
                                        It is a long time ago (too long) since I found the time to work on the plugin.
                                        Once I restarted the project I noticed that 1.4 beta was out so I first wanted to work on adopting these libs before moving on.
                                        There are still a few things I don't like so I am not going to commit yet but the work is going well.
                                        One of the things I wanted to add was support for the battery level.
                                        Indigo supports it very well (see screenshot) and it is dynamic.
                                        What does that mean: when you implement 'gw.sendBatteryLevel(value);' indigo will create support for it and from that moment on Indigo will update the battery level.
                                        BTW don't pay attention to the 200%, I definitely need to do some additional work on my battery check libs...
                                        I will keep you posted again :)
                                        • marceltrapmanM
                                          marceltrapmanM
                                          marceltrapman
                                          Following the release of MySensors 1.4 I made the latest build of the MySensors plugin for Indigo available on GitHub.
                                          I have been using it for a while now with 1.4beta and changed things around to support the 1.4 release (among other things).
                                          When you start using this version of the plugin please be aware of yet limited support of sensors simply because I have not (yet in some cases) built them...
                                          Please use GitHub to let me know about bugs and/or feature requests...
                                          • Added support for 1.4 (1.3 is not supported anymore).
                                          • Added support for batteryLevel
                                          • Added more variable types with 'native' states instead of generic states:
                                          • TEMP
                                          • HUM
                                          • PRESSURE
                                          • RAIN
                                          • RAINRATE
                                          • WIND
                                          • GUST
                                          • UV
                                          • DISTANCE
                                          • TRIPPED
                                          • HEATER_SW
                                          • LIGHT_LEVEL
                                          • Added menu item to remove failed devices
                                          • Added menu item to remove unused device
                                          • Cleaned up and optimized code
