  3. Irrigation Controller (up to 16 valves with Shift Registers)
371 Posts 56 Posters 331.3k Views 52 Watching
  • petewillP petewill
    @Lars65 Take a look at lines 663-667. I haven't tested this but it should be something similar to this:
              lcd.print(hour() < 10 ? F(" ") : F(""));
              lcd.print(hour());
              lcd.print(minute());
              //lcd.print(isAM() ? F("am") : F("pm"));
    L
    L
    Lars65
    @petewill I did try this, and it worked just fine. Thank you!
    • Sergio RiusS Sergio Rius
      Does anyone already made a pcb for this? My board keeps loosing it's "bridging" wires. They rot and fall near the solder.
      petewillP
      petewillP
      petewill
      @Sergio-Rius Where do you have your controller located? I have had mine running for over a year now and haven't had any issues. Maybe you need to put it into a waterproof case?
      To answer your question though, no, I don't believe anyone has created a PCB for this.
      • L
        L
        Lars65
        I will have mine in the greenhouse. Boxes is made of waxed oak,and it will be 3 modules, each one seald with a sillicone gasket.
        I have some trash wood in the garage, so I thought I could use it to something. :)
        • L
          L
          Lars65
          Have anyone compiled it with the 2.0.0?
            A Former User
            Hello Gentlemen, new to this board as well as new to micro electrics. Started this Irrigation Controller about a two weeks ago, after finding Pete B’s U tube video on this project. Got all the parts and have started building by following Pete B’s video. Have a few part questions and am not very literal with the nomenclature.
            1. This 4.7uF 50V 20% Axial-Lead Electrolytic Capacitor goes on which end or pins on the
            2. Have a FT232RL FTDI USB 3.3V 5.5V to TTL Serial Adapter Module for Mini Port that is different than Pete’s.
              Not sure how to post JPEG's so this is the problem I am having.
              0_1468546122072_7-14-16 Hello Gentlemen help.docx
              The Pins on the ftdi are different than on Pete’s board, in that I cannot find the info for the double GND on the Arduino Pro Mini.
            Any guidance of will be appreciated.
            Respectfully RJ Myers
            petewillP 1 Reply Last reply
            • ? A Former User
              petewillP
              petewillP
              petewill
              @Lars65 No, not yet. It's on the list but it will probably be a little while before I get to it.
              @Ngwpower To add pictures you just have to drag and drop into the edit window. They will automatically upload.
              1. Can you provide more info here? I'm not sure what you're asking.
              2. Both of my FTDI adapters connect into the Pro Mini straight across (the wires don't get crossed when connecting. The key thing is TX on one side should go to RX on the other (and vice versa) then the other 4 wires line up from there. So, you almost have it correct in your picture but the TX and RX are switched. Just start from the DTR and go straight across.
                A Former User
                Thank You, petewill I adjusted the wiring!
                0_1468603030032_upload-e9f66bab-6c30-42eb-80b2-da87857849e7
                This is the picture for the 4.7 UF that has me baffled of where to insert into the radio. Being color blind really hurts with wiring. And rather ask than fry another project....
                RJ
                • ? A Former User
                  RJ
                  Sergio RiusS
                  Sergio RiusS
                  Sergio Rius
                  #169
                  @Ngwpower
                  EDIT: My condenser is 10uF / 63v
                  ? 1 Reply Last reply
                  • Sergio RiusS
                    Sergio RiusS
                    Sergio Rius
                    Does this sketch still work with the current Mysensors libraries?
                    I lost my working environment so I had to build a new one. I downloaded the MySensors libraries and the sketch throws me an error not finding MySensor.h. The file is not at the libraries folder, but MySensorS.h
                    If adding this later (used at the samples) the compilation throws an error:
                    W:\....\MySensors_Arduino\arduino-1.6.9\portable\sketchbook\libraries\MySensors/MySensors.h:287:4: error: #error No forward link or gateway feature activated. This means nowhere to send messages! Pretty pointless.
                    exit status 1
                    Error compilación en tarjeta Arduino Nano.```
                    Does make sense for anyone?
                      @Ngwpower
                      A Former User
                      @Sergio-Rius
                      Than You for the clarfication & picture worth thousands of words.
                      RJ
                        exit status 1
                        petewillP
                        petewillP
                        petewill
                        @Sergio-Rius Hmm. Are you using the 2.0 release? If so then it's not compatible yet. It still needs to be upgraded.
                          A Former User
                          Got the controller all ready to test like petewill shows in his presentation. Get this error
                          MySensors-1.5.4 loaded it onto my board Arduino Pro Mini and get this error -*** F:\Arduino Programs\My sensors downloads\upload-9cc672c5-a5a3-4711-9e38-8f3f7da898a5\upload-9cc672c5-a5a3-4711-9e38-8f3f7da898a5.ino:33:19: fatal error: Relay.h: No such file or directory***
                          Can I see this operate on my screen, without all the advanced technology? Found the Domoticz site and no sure if this is for me anymore than the Vera that is being used by petewill. Way out of my knowledge base with this project, just to stubborn to quit or give up.
                          L 1 Reply Last reply
                          • ? A Former User
                            L
                            L
                            Lars65
                            @Ngwpower which sketch are you using?
                            • L Lars65
                              A Former User
                              @Lars65 Thanks
                              June 2, 2014 12:00 Version 1.0 Arduino Multi-Zone Sprinkler Control
                              • ? A Former User
                                @Lars65 Thanks
                                L
                                L
                                Lars65
                                @Ngwpower I use this one which is earlier in this thread, an it works with my domoticz.
                                MySprinkler for MySensors
                                May 31, 2015
                                *** Version 2.0
                                * LED status indicator
                                PARTS LIST:
                                * Relays (8 channel)
                                * NRF24L01 Radio
                                * Arduino (I used a Pro Mini)
                                * Capacitors (10uf and .1uf)
                                * 3.3v voltage regulator
                                * Resistors (270 & 10K)
                                * Female Dupont Cables
                                * LED
                                * Push button
                                * Shift Register (SN74HC595)
                                * 18 gauge wire (for relay)
                                INSTRUCTIONS:
                                  on the serial monitor.
                                #include <Time.h>
                                #include <LiquidCrystal.h>
                                #define NUMBER_OF_VALVES 4  // Change this to set your valve count up to 16.
                                #define RADIO_ID AUTO  // Change this to fix your Radio ID or use Auto
                                #define SKETCH_NAME "MySprinkler Domoticz"
                                #define SKETCH_VERSION "2.0"
                                #define CHILD_ID_SPRINKLER 0
                                //#define ACTIVE_LOW // comment out this line if your relays are active high
                                #ifdef ACTIVE_LOW
                                #define ALL_VALVES_OFF 0xFFFF
                                #define ALL_VALVES_OFF 0U
                                #ifdef DEBUG_ON
                                typedef enum {
                                SprinklerStates;
                                SprinklerStates lastState;
                                byte menuState = 0;
                                unsigned long menuTimer;
                                byte countDownTime = 10;
                                int allZoneTime [NUMBER_OF_VALVES + 1]= {0, 1, 1, 1, 1};     // Insert values in min, 0 = all zone (always 0) this is a 4 chan relay
                                int valveSoloTime [NUMBER_OF_VALVES + 1]= {0, 1, 1, 1, 1};   // Insert values in min, 0 = all zone (always 0) this is a 4 chan relay
                                int valveNumber;
                                int lastValve;
                                unsigned long startMillis;
                                const int ledPin = 5;
                                const int waterButtonPin = 3;
                                boolean buttonPushed = false;
                                boolean showTime = true;
                                boolean clockUpdating = false;
                                boolean recentUpdate = true;
                                const char *dayOfWeek[] = {
                                String valveNickName[17] = {
                                time_t lastTimeRun = 0;
                                //Setup Shift Register...
                                const int latchPin = 8;
                                const int clockPin = 4;
                                const int dataPin  = 7;
                                LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);  // Set the LCD I2C address to 0x27
                                  SERIAL_START(115200);
                                  pinMode(latchPin, OUTPUT);
                                  pinMode(clockPin, OUTPUT);
                                  pinMode(dataPin, OUTPUT);
                                  pinMode(ledPin, OUTPUT);
                                  attachInterrupt(1, PushButton, RISING); //May need to change for your Arduino model
                                  digitalWrite (ledPin, HIGH);
                                  updateRelays(ALL_VALVES_OFF);
                                  //delay(5000);
                                  lcd.clear();
                                  lcd.backlight();
                                  lcd.createChar(0, clock);
                                  lcd.createChar(1, raindrop);
                                  delay(500);
                                  if (gw.loadState(0) == 0xFF); // EEPROM flag
                                    for (int i = 0; i < 4 ; i++)
                                      lastTimeRun = lastTimeRun | gw.loadState(i + 1); // assemble 4 bytes into an ussigned long epoch timestamp
                                  gw.begin(getVariables, RADIO_ID, false); // Change 'false' to 'true' to create a Radio repeating node
                                    gw.present(i, S_LIGHT);
                                  digitalWrite (ledPin, LOW);
                                  DEBUG_PRINTLN(F("Ready..."));
                                  lcd.setCursor(0, 0);
                                  lcd.setCursor(15, 0);
                                  lcd.write(byte(0));
                                  lcd.setCursor(0, 1);
                                  int clockCounter = 0;
                                    gw.requestTime(receiveTime);
                                    delay(1000);
                                    lcd.print(".");
                                    clockCounter++;
                                    if (clockCounter > 16)
                                      lcd.clear();
                                      delay(2000);
                                  lcd.clear();
                                    lcd.print(F(" Updating  "));
                                    lcd.print(i);
                                    boolean flashIcon = false;
                                    DEBUG_PRINT(i);
                                    DEBUG_PRINTLN(F(" Data..."));
                                    while (gw.process() == false)
                                      flashIcon = !flashIcon;
                                      gw.request(i, V_VAR1);
                                      delay(100);
                                      gw.request(i, V_VAR2);
                                      delay(100);
                                      gw.request(i, V_VAR3);
                                      delay(100);
                                  lcd.clear();
                                  updateClock();
                                  updateDisplay();
                                  //goGetValveTimes();
                                  if (buttonPushed)
                                    menuTimer = millis();
                                      state = ZONE_SELECT_MENU;
                                      menuState = 0;
                                      menuState++;
                                        menuState = 0;
                                    slowToggleLED ();
                                    if (state != lastState)
                                        delay(50);
                                        gw.send(msg1valve.setSensor(i).set(false), false);
                                      lcd.clear();
                                      lcd.setCursor(0,0);
                                      lcd.setCursor(0,1);
                                      delay(2000);
                                      lastValve = -1;
                                    if (lastValve != valveNumber)
                                          gw.send(msg1valve.setSensor(i).set(true), false);
                                    lastValve = valveNumber;
                                    fastToggleLed();
                                      valveNumber = 1;
                                      startMillis = millis();
                                      valveNumber++;
                                        state = CYCLE_COMPLETE;
                                        lastValve = -1;
                                        lastTimeRun = now();
                                        DEBUG_PRINT(F("State = "));
                                        DEBUG_PRINTLN(state);
                                    fastToggleLed();
                                      DEBUG_PRINT(F("Zone: "));
                                      DEBUG_PRINTLN(valveNumber);
                                      fastToggleLed();
                                  else if (state = ZONE_SELECT_MENU)
                                    displayMenu();
                                  lastState = state;
                                void displayMenu(void)
                                  static int lastSecond;
                                    lcd.clear();
                                    lcd.print(F("Starting"));
                                    lcd.print(F("."));
                                    Serial.print(".");
                                  lastSecond = thisSecond;
                                    if (menuState == 0)
                                      valveNumber = 1;
                                      state = RUN_ALL_ZONES;
                                      valveNumber = menuState;
                                      state = RUN_SINGLE_ZONE;
                                  lastMenuState = menuState;
                                void updateRelays(int value)
                                  digitalWrite(latchPin, LOW);
                                  digitalWrite(latchPin, HIGH);
                                    buttonPushed = true;
                                void fastToggleLed()
                                    fastLedTimer = millis ();
                                void slowToggleLED ()
                                    slowLedTimer = millis ();
                                  boolean zoneTimeUpdate = false;
                                  if (message.isAck())
                                    if (message.sensor == i)
                                      if (message.type == V_LIGHT)
                                        if (switchState == 0)
                                          if (i == 0)
                                            valveNumber = 1;
                                            valveNumber = i;
                                            DEBUG_PRINTLN(i);
                                        DEBUG_PRINT(i);
                                        DEBUG_PRINT(F(" = "));
                                        DEBUG_PRINTLN(variable1);
                                          allZoneTime[i] = variable1;
                                          zoneTimeUpdate = true;
                                        DEBUG_PRINT(i);
                                        DEBUG_PRINTLN(variable2);
                                          valveSoloTime[i] = variable2;
                                        if (newMessage.length() == 0)
                                          DEBUG_PRINTLN(i);
                                        if (newMessage.length() > 16)
                                          newMessage.substring(0, 16);
                                        valveNickName[i] = "";
                                        DEBUG_PRINT(F("Recieved new name for zone "));
                                        DEBUG_PRINT(i);
                                        DEBUG_PRINT(F(" and it is now called: "));
                                  if (zoneTimeUpdate)
                                      if (i != 0)
                                        DEBUG_PRINT(F("Zone "));
                                        DEBUG_PRINT(i);
                                        DEBUG_PRINTLN(allZoneTime[i]);
                                    recentUpdate = false;
                                void updateDisplay()
                                  static boolean displayToggle = false;
                                    switch (state) {
                                      case STAND_BY_ALL_OFF:
                                        fastClear();
                                        if (displayToggle)
                                          if (clockUpdating)
                                            lcd.write(byte(0));
                                          lcd.print(hourFormat12());
                                          lcd.print(month());
                                          lcd.print(day());
                                          lcd.print(F("/"));
                                          lcd.print(year() % 100);
                                          if (clockUpdating)
                                            lcd.write(byte(0));
                                          lcd.setCursor(11, 1);
                                          lcd.print(day(lastTimeRun));
                                      case RUN_SINGLE_ZONE:
                                        fastClear();
                                        if (displayToggle)
                                          lcd.print(F(" Zone:"));
                                          lcd.print(valveNumber);
                                          lcd.print(F(" Active"));
                                            lcd.print("min");
                                            lcd.print("sec  ");
                                      case RUN_ALL_ZONES:
                                        fastClear();
                                        if (displayToggle)
                                          lcd.print(F(" Active "));
                                          lcd.print("min");
                                          lcd.print("sec  ");
                                      case CYCLE_COMPLETE:
                                        if (displayToggle)
                                          int totalTimeRan = 0;
                                          lcd.print(totalTimeRan);
                                          lcd.print(" Minutes   ");
                                    lastUpdateTime = millis();
                                  lastDisplayState = state;
                                  int lastSecond = second();
                                  int lastMinute = minute();
                                  int lastHour = hour();
                                  setTime(newTime);
                                    DEBUG_PRINT(hourFormat12());
                                    DEBUG_PRINT(minute());
                                    DEBUG_PRINT(month());
                                    DEBUG_PRINT(F("/"));
                                    DEBUG_PRINT(day());
                                    DEBUG_PRINTLN(year());
                                    showTime = false;
                                void fastClear()
                                void updateClock()
                                    lcd.write(byte(0));
                                    clockUpdating = true;
                                    lastVeraGetTime = millis();
                                  if (gw.loadState(0) != 0xFF)
                                    gw.saveState(0, 0xFF); // EEPROM flag for last date saved stored in EEPROM (location zero)
                                  for (int i = 1; i < 5; i++)
                                    gw.saveState(5 - i, byte(theDate >> 8 * (i - 1))); // store epoch datestamp in 4 bytes of EEPROM starting in location one
                                void goGetValveTimes()
                                  static byte valveIndex = 1;
                                  if (millis() - valveUpdateTime >= 300000UL / NUMBER_OF_VALVES)// update each valve once every 5 mins (distributes the traffic)
                                    DEBUG_PRINTLN(F("Calling for Valve Data..."));
                                    lcd.write(byte(1)); //lcd.write(1);
                                    gw.request(valveIndex, V_VAR1);
                                    gw.request(valveIndex, V_VAR2);
                                    gw.request(valveIndex, V_VAR3);
                                    valveUpdateTime = millis();
                                    valveIndex++;
                                    if (valveIndex > NUMBER_OF_VALVES + 1)
                                      valveIndex = 1;
                                 Take away the three dots in the bottom.
                                Sergio RiusS ? 2 Replies Last reply
                                • Sergio RiusS
                                  Sergio RiusS
                                  Sergio Rius
                                  Does anyone have a working portable Arduino IDE for that sketch that would want to share with me? I lost my installation and so many things changed in the built in scripts when you do a new installation. I can compile the project even using 1.4.5 mysensors libraries.
                                  Thanks a lot.
                                  • petewillP
                                    petewillP
                                    petewill
                                    @Ngwpower Don't give up! It is a learning curve for sure but totally worth it when you finally get it. Try the irrigation controller sketch from the MySensors 1.5 library example. All the required stuff should be there.
                                    @Sergio-Rius I'm not sure what you're looking for. Do you need the 1.5 version?
                                      A Former User
                                      Thanks, I envy you young people at 67 just opening the wide world of tech - do't have to do this sitting on a motor grader or Bull Dozer in the high desert. I have tried from 1.3 to 2.0 and thought I saw a flicker of LED in the string of switches, as in your example. Had my 5V on the wrong pin, so back to square one.
                                      I am having fun attempting to learn the terminology as well as the application!
                                      L petewillP 2 Replies Last reply
                                      • ? A Former User
                                        L
                                        L
                                        Lars65
                                        @Ngwpower I am 55 and still learning. I don't know anything about programming. But I spend a lot of time on forums, and reading.
                                        I would love to learn programming, but I have a slow learning curve now.
                                        I work as a processengineer,so I guess I can understand some logic.
                                        But this is really fun stuff.
                                        Started up a couple of years ago, reading about a home made CNC mill.
                                        Now I have my own, and it got pretty big can mill surfaces about 1100x800mm.
                                        And I use it most to mill PCB boards. Hahaha.
                                          Sergio RiusS
                                          Sergio RiusS
                                          Sergio Rius
                                          @petewill
                                          The problem are the new libraries that come with newer arduino ide. My attempts fail about the wire.h library location or a wrong "positive" variable at liquiddisplay.
                                          I think it's not compatible with newer libraries.
