  3. problem with implementation of my sensors in rollershutter sketch
13 Posts 2 Posters 3.0k Views 2 Watching
  • AWIA AWI
    @ihtgtwtd The sketch works with a statemachine. i.e the rollladen[i].action!=,<ACTION> determines the what each of the rollershutters i is doing.. What you should do is fill that action in receive() similar to what is done after a buttonpress for that action. i.e. assign the action for the respective shutter and set the timeout.
    You can read look at the MySensors examples for rollershutter to find out how to get the values in the receive() routine.
    ihtgtwtdI
    ihtgtwtdI
    ihtgtwtd
    @AWI
    thank you, that helped a lot.
    I received my first arduino 3 weeks ago and since then I'm constantly learning. Getting things explained helps a lot.
    the code receives my commands now but when I press down, all the down relays switch on/off and the other way around. I thought the line for (int i=0;i<ANZAHLROLLLADEN;i++) declares the number of the rollershutter.
    #define MY_REPEATER_FEATURE
    // Rollladensteuerung by jurs for German Arduino-Forum
    #define BUTTONPRESSED LOW
    #define RELAYACTIVE LOW
    MyMessage sensorMsg0(0,V_DIMMER);
    MyMessage sensorMsg1(1,V_DIMMER);
    MyMessage sensorMsg2(2,V_DIMMER);
    enum {NOACTION, UPACTION, DOWNACTION};
    struct roll_t{byte downPin; byte upPin; boolean downPressed; boolean upPressed; byte action; unsigned long actionStarttime; unsigned long actionTimeout; byte relayOnePin; byte relayTwoPin;};
    roll_t rollladen[]={
      {2,3,false, false, NOACTION,0,60000L, A0, A1}, // Button-Pins 2, 3, Relay-Pins A0, A1, Timeout 60 secons
      {4,5,false, false, NOACTION,0,45000L, A2, A3}, // Button-Pins 4, 5, Relay-Pins A2, A3, Timeout 45 secons
      {6,7,false, false, NOACTION,0,45000L, A4, A5}, // Button-Pins 6, 7, Relay-Pins A4, A5, Timeout 45 secons
    #define ANZAHLROLLLADEN sizeof(rollladen)/sizeof(rollladen[0])
        if (BUTTONPRESSED==HIGH)
          pinMode(rollladen[i].downPin,INPUT);
          pinMode(rollladen[i].upPin,INPUT);
          pinMode(rollladen[i].downPin,INPUT_PULLUP);
          pinMode(rollladen[i].upPin,INPUT_PULLUP);
        if (RELAYACTIVE==LOW)
           digitalWrite(rollladen[i].relayOnePin,HIGH);
           digitalWrite(rollladen[i].relayTwoPin,HIGH);
        pinMode(rollladen[i].relayOnePin,OUTPUT);
        pinMode(rollladen[i].relayTwoPin,OUTPUT);
    void switchRelay(byte i)
      Serial.print("Schalte Rolladen-");
      Serial.print(i);
      switch (rollladen[i].action)
        case NOACTION: // STOP
          digitalWrite(rollladen[i].relayOnePin,!RELAYACTIVE);
          digitalWrite(rollladen[i].relayTwoPin,!RELAYACTIVE);
          Serial.println(" STOP");
        case UPACTION: // UP
          digitalWrite(rollladen[i].relayOnePin,RELAYACTIVE);
          Serial.println(" UP");
        case DOWNACTION: // DOWN
          digitalWrite(rollladen[i].relayTwoPin,RELAYACTIVE);
          Serial.println(" DOWN");
    void loop(void)
      byte state;
        // Prüfen, ob Down gedrückt wurde
        state=digitalRead(rollladen[i].downPin);
        if (BUTTONPRESSED==LOW) state=!state;
        if (state && !rollladen[i].downPressed)
            case NOACTION: rollladen[i].action=DOWNACTION;
                           rollladen[i].actionStarttime=millis();
                           switchRelay(i);
            default: if (rollladen[i].action!=NOACTION)
                       rollladen[i].action=NOACTION;
                       switchRelay(i);
        rollladen[i].downPressed=state;
        // Prüfen, ob Up gedrückt wurde
        state=digitalRead(rollladen[i].upPin);
        if (state && !rollladen[i].upPressed)
            case NOACTION: rollladen[i].action=UPACTION;
                           switchRelay(i);
                       switchRelay(i);
        rollladen[i].upPressed=state;
        // Prüfen auf Timeout
        if (rollladen[i].action!=NOACTION && millis()-rollladen[i].actionStarttime>=rollladen[i].actionTimeout)
          switchRelay(i);
      delay(5); // kleines Delay zum Entprellen der Buttons
      sendSketchInfo("Test", "1.0");
      // Fetch relay status
       for (int sensor = 1, pin = A0; sensor <= ANZAHLROLLLADEN; sensor++, pin++) {
          present(sensor, S_COVER);
        pinMode(pin, OUTPUT);
      byte state;
      if (message.type == V_UP) {
                           switchRelay(i);
                       switchRelay(i);
        Serial.println("going up:" + String(message.type));
      else if (message.type == V_DOWN) {
                           switchRelay(i);
                       switchRelay(i);
        Serial.println("going down:" + String(message.type));
      else if (message.type == V_STOP) {
            case DOWNACTION: rollladen[i].action=NOACTION;
                           switchRelay(i);
            case UPACTION: rollladen[i].action=NOACTION;
                           switchRelay(i);
        Serial.println("stopping:" + String(message.type));
    Do you have any idea whats wrong?
    thx
    AWIA 1 Reply Last reply
    • ihtgtwtdI ihtgtwtd
      @AWI
        Serial.print(i);
      void loop(void)
        byte state;
                             switchRelay(i);
                         switchRelay(i);
                             switchRelay(i);
                         switchRelay(i);
            switchRelay(i);
        byte state;
                             switchRelay(i);
                         switchRelay(i);
                             switchRelay(i);
                         switchRelay(i);
                             switchRelay(i);
                             switchRelay(i);
      thx
      AWIA
      AWIA
      AWI
      wrote on last edited by AWI
      @ihtgtwtd in your receive() routine you are explicitly executing the action for all shutters in the for(.....) loop. What you should do is execute the action only for the shutter with the Id received . I.e. i = message.sensor
      ihtgtwtdI 1 Reply Last reply
      • AWIA AWI
        ihtgtwtdI
        ihtgtwtdI
        ihtgtwtd
        @AWI
        I don't get it. I inserted for (int i=0;i<message.sensor;i++) and the result is
        switch 1 up= relay 1; switch 1 down= relay 2
        switch 2 up= relay 1+3 ; switch 2 down=relay 2+4
        switch 3 up= relay 1+3+5; switch 3 down=relay 2+4+6
        shouldn't i++ give each following message.sensor it's own number?
        maybe I am just too tired to get it.
        thanks for your help, I'm going to sleep now
          @AWI
          AWIA
          AWIA
          AWI
          @ihtgtwtd something for when you wake up... :smile:
          Remove the whole for loop. When you want to switch only 1 shutter only 1 should be activated. So replace the whole for loop with only i = message.sensor.
          Btw.. I think the behavior of you last action is creative at least :bowtie:
          • AWIA AWI
            ihtgtwtdI
            ihtgtwtdI
            ihtgtwtd
            @AWI
            :smile: the result was indeed interesting and fun to watch.
              byte state;
              i = message.sensors
                                   switchRelay(i);
                               switchRelay(i);
                                   switchRelay(i);
                               switchRelay(i);
                                   switchRelay(i);
                                   switchRelay(i);
            I replaced the for loop with i = sensor.message , now i get "exit status 1
            'i' was not declared in this scope". Do I have to declare the variable?
              @AWI
                byte state;
                i = message.sensors
                                     switchRelay(i);
                                 switchRelay(i);
                                     switchRelay(i);
                                 switchRelay(i);
                                     switchRelay(i);
                                     switchRelay(i);
              AWIA
              AWIA
              AWI
              @ihtgtwtd int i = message.sensors ; would be the right syntax
              • AWIA AWI
                ihtgtwtdI
                ihtgtwtdI
                ihtgtwtd
                @AWI
                thx, I tried that. it exits with 'const class MyMessage' has no member named 'sensors'.
                  @AWI
                  AWIA
                  AWIA
                  AWI
                  @ihtgtwtd typo ... int i = message.sensor ; would be the right syntax, leave out the 's'
                  • AWIA AWI
                    ihtgtwtdI
                    ihtgtwtdI
                    ihtgtwtd
                    @AWI
                    thanks, still small problems to figure out though.
                    when I send a command to rollershutter 1 then rollershutter 2 receives the command. I can not control shutter 1, only 2 and 3 (with the buttons of 1 and 2)
                    output in serial monitor is right and physical buttons work the right way too
                    is there a problem in the registration or am I missing something (again)?
                    the physical buttons work the right way.
                    MyMessage sensorMsg0(0, V_DIMMER);
                    MyMessage sensorMsg1(1, V_DIMMER);
                    MyMessage sensorMsg2(2, V_DIMMER);
                    struct roll_t {
                      byte downPin;
                      byte upPin;
                      boolean upPressed;
                      byte action;
                      byte relayOnePin;
                      byte relayTwoPin;
                    roll_t rollladen[] = {
                      {2, 3, false, false, NOACTION, 0, 60000L, A0, A1}, // Button-Pins 2, 3, Relay-Pins A0, A1, Timeout 60 secons
                      {4, 5, false, false, NOACTION, 0, 45000L, A2, A3}, // Button-Pins 4, 5, Relay-Pins A2, A3, Timeout 45 secons
                      {6, 7, false, false, NOACTION, 0, 45000L, A4, A5}, // Button-Pins 6, 7, Relay-Pins A4, A5, Timeout 45 secons
                      for (int i = 0; i < ANZAHLROLLLADEN; i++)
                        if (BUTTONPRESSED == HIGH)
                          pinMode(rollladen[i].downPin, INPUT);
                          pinMode(rollladen[i].upPin, INPUT);
                          pinMode(rollladen[i].downPin, INPUT_PULLUP);
                          pinMode(rollladen[i].upPin, INPUT_PULLUP);
                        if (RELAYACTIVE == LOW)
                          digitalWrite(rollladen[i].relayOnePin, HIGH);
                          digitalWrite(rollladen[i].relayTwoPin, HIGH);
                        pinMode(rollladen[i].relayOnePin, OUTPUT);
                        pinMode(rollladen[i].relayTwoPin, OUTPUT);
                      Serial.print(i);
                          digitalWrite(rollladen[i].relayOnePin, !RELAYACTIVE);
                          digitalWrite(rollladen[i].relayTwoPin, !RELAYACTIVE);
                          digitalWrite(rollladen[i].relayOnePin, RELAYACTIVE);
                          digitalWrite(rollladen[i].relayTwoPin, RELAYACTIVE);
                    void loop(void)
                      byte state;
                        state = digitalRead(rollladen[i].downPin);
                        if (BUTTONPRESSED == LOW) state = !state;
                            case NOACTION: rollladen[i].action = DOWNACTION;
                              rollladen[i].actionStarttime = millis();
                              switchRelay(i);
                            default: if (rollladen[i].action != NOACTION)
                                rollladen[i].action = NOACTION;
                                switchRelay(i);
                        rollladen[i].downPressed = state;
                        state = digitalRead(rollladen[i].upPin);
                            case NOACTION: rollladen[i].action = UPACTION;
                              switchRelay(i);
                                switchRelay(i);
                        rollladen[i].upPressed = state;
                        if (rollladen[i].action != NOACTION && millis() - rollladen[i].actionStarttime >= rollladen[i].actionTimeout)
                          switchRelay(i);
                      byte state;
                              switchRelay(i);
                                switchRelay(i);
                              switchRelay(i);
                                switchRelay(i);
                            case DOWNACTION: rollladen[i].action = NOACTION;
                              switchRelay(i);
                            case UPACTION: rollladen[i].action = NOACTION;
                              switchRelay(i);
                    hope it's clear what I mean. It is a bit weird...
                      @AWI
                      struct roll_t {
                        byte downPin;
                        byte upPin;
                        boolean upPressed;
                        byte action;
                        byte relayOnePin;
                        byte relayTwoPin;
                        Serial.print(i);
                      void loop(void)
                        byte state;
                                switchRelay(i);
                                  switchRelay(i);
                                switchRelay(i);
                                  switchRelay(i);
                            switchRelay(i);
                        byte state;
                                switchRelay(i);
                                  switchRelay(i);
                                switchRelay(i);
                                  switchRelay(i);
                                switchRelay(i);
                                switchRelay(i);
                      AWIA
                      AWIA
                      AWI
                      @ihtgtwtd that is caused in the presentation part of your routine. You did not create a switch for shutter 0. (started with 1)
                      • ihtgtwtdI
                        ihtgtwtdI
                        ihtgtwtd
                        well thanks, I already tried that because it looked suspicious ;-)
                        but i was sending on switch 1 in domoticz and did not create a switch for 0.
                        So it seems this thing works, thanks again for your help and the patience to deal with my noob questions :-)
